在模拟器上转换rknn模型build失败
SDK包名称:rv1126_rv1109_linux_release_20220224_v2.2.5a
SDK修改内容:rv1126_rv1109_linux_release_20220224_v2.2.5a
Log日志:log.txt
pytorch框架,基于yolov7的模型。在pc端可正常推理,在模拟器转换为rknn模型的过程中,提示
I squeeze_to_4d_transpose: remove node = , add node = [‘2569_Transpose_squeeze0’, ‘2569_Transpose_squeeze1’]
I squeeze_to_4d_transpose: remove node = , add node = [‘2544_Transpose_squeeze0’, ‘2544_Transpose_squeeze1’]
I squeeze_to_4d_transpose: remove node = , add node = [‘2519_Transpose_squeeze0’, ‘2519_Transpose_squeeze1’]
E build: Catch exception when building RKNN model!
E build: Traceback (most recent call last):
E build: File “rknn/api/rknn_base.py”, line 1546, in rknn.api.rknn_base.RKNNBase.build
E build: File “rknn/api/graph_optimizer.py”, line 1276, in rknn.api.graph_optimizer.GraphOptimizer.fuse_ops
E build: File “rknn/api/fuse_rules.py”, line 5449, in rknn.api.fuse_rules._p_tiling_conv_channelin
E build: File “rknn/api/fuse_rules.py”, line 5387, in rknn.api.fuse_rules._judge_filter_limit
E build: ZeroDivisionError: division by zero
Build model failed!
其他模型均可正常转换,猜测可能是有些op不支持,请教如何进一步分析?
log.txt (12.2 KB)
请问你的问题解决了么?
icy 发表于 2023-7-24 15:20
请问你的问题解决了么?
并没有,推测是某些op不支持,不过没有得到证实
