Exploring the Relations between IPQ6000 IPQ6010 IPQ6018: WiFi 6 Solutions|Wallys
In the world of wireless technology, continuous advancements have paved the way for faster and more efficient networks. One such advancement is the emergence of WiFi 6 (also known as 802.11ax), which introduces several enhancements over its predecessors. Within the WiFi 6 ecosystem, Qualcomm Technologies, Inc. has developed a series of system-on-chip (SoC) solutions, including the IPQ6000, IPQ6010, and IPQ6018. Let’s dive into the relations between these three WiFi 6 solutions.
:one: IPQ6000:
The IPQ6000 is a powerful and versatile SoC designed specifically for WiFi 6 access points and routers. It features a quad-core ARM Cortex-A53 processor running at high clock speeds, providing substantial processing capabilities for managing WiFi network traffic. The IPQ6000 also integrates a dedicated WiFi subsystem, offering support for multiple simultaneous streams, MU-MIMO (Multi-User Multiple-Input Multiple-Output), and advanced beamforming techniques.
:two: IPQ6010:
Building upon the foundation of the IPQ6000, the IPQ6010 takes WiFi 6 performance to the next level. It retains the quad-core ARM Cortex-A53 processor while introducing a more powerful and efficient fifth-generation WiFi (5G WiFi 6) subsystem. This subsystem incorporates advanced features like Orthogonal Frequency Division Multiple Access (OFDMA), which enables more efficient spectrum utilization and improves network capacity. The IPQ6010 is an ideal choice for high-performance routers and access points that require increased throughput and advanced networking capabilities.
:three: IPQ6018:
The IPQ6018 represents a further evolution in WiFi 6 technology, offering enhanced performance and capabilities compared to its predecessors. It features a higher-performance quad-core ARM Cortex-A53 processor, enabling even greater processing power for managing complex network tasks. The WiFi subsystem in the IPQ6018 delivers superior performance with support for the latest WiFi 6E standard, which extends WiFi into the 6 GHz frequency band. This expansion provides additional bandwidth and less interference, resulting in improved speed and reliability for WiFi connections.
While all three solutions—IPQ6000, IPQ6010, and IPQ6018—are designed to support WiFi 6 networks, they cater to different deployment scenarios and requirements. The IPQ6000 offers a solid foundation for WiFi 6 deployment, while the IPQ6010 and IPQ6018 provide increased performance and capabilities for more demanding applications.
It’s worth noting that the IPQ6000 series of WiFi 6 SoCs from Qualcomm Technologies, Inc. serve as building blocks for various manufacturers and OEMs (Original Equipment Manufacturers) to develop their own WiFi 6-enabled devices, such as routers, access points, and other networking equipment.
In summary, the IPQ6000, IPQ6010, and IPQ6018 are WiFi 6 SoC solutions from Qualcomm Technologies, Inc., each offering different levels of performance and capabilities for WiFi 6 networks. These solutions cater to a wide range of deployment scenarios, ensuring that users can enjoy faster, more efficient, and reliable wireless connectivity in various settings.
The WAllys WiFi6E wireless solution:
1.DR6018
Website:
Yuotube:
https://www.youtube.com/watch?v=RPk_6fZbHZU
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
2.DR6000
Website:
Qualcomm-Atheros IPQ6000
Quad-core ARM 64 bit A53s 1.2GHz processor
2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
2 on board radios (Dual Band Concurrent Radio)
Supply Voltage 12 V
Operating Temperature Range -20 to +70ºC
Storage Temperature Range -45 to +90 ºC
Operating Humidity Range 5 to +95 (non-condensing)%
Symbol Parameter
CPU Qualcomm-Atheros IPQ6000
CPU Frequency Quad-core ARM 64 bit A53 @1.2GHz processor
System Memory DDR3L 512MB 16-bit interface
Nand Flash 128MB
NOR Flash 16MB
Ethernet Port 2x 1Gbps Ethernet Ports
DC Jack Input 1x DC Jack Connector: 12V
Power Consumption(Board Only) 1TD
On Board Radio 2 radios (Dual band concurrent radio)
Wireless On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz 2.4GHz Data Rate 2x2 MU-MIMO OFDMA Technology, up to 573Mbps 5GHz Data Rate 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
LED 4x LED Indicators
USB /Header 1x MicroUSB 2.0 Port
Serial Port 1x Serial Interface 12 Pin Connectors
Certification TBD
Humidity Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
Temperature Range
Operating: TBD Storage: -40ºC to 90ºC
Dimension (Diameter x Height) 100mm x 23.5mm (Without Heatsink)
BY:https://www.wallystech.com/
More detail and opportunities attach Emile :sales4@wallystech.com.
