固件文件名称:AIO-3588Q
固件下载地址:rk3588-android12.0-bundle.7z
Log日志:111.zip
AIO-3588Q的主板,固件用的官方的;
问题是:用HDMI接口输出视频到一个480*1920的长条形屏上没法正常显示,需要修改代码里面哪些参数?才能支持这种屏的显示
111.zip (151 Bytes)
固件文件名称:AIO-3588Q
Log日志:111.zip
111.zip (151 Bytes)
可以在这里面添加分辨率 kernel/drivers/gpu/drm/drm_edid.c,
同时android上层添加分辨率白名单device/rockchip/common/resolution_white.xml 或是把白名单删除
你好,我们尝试了上面的修改方案,但仍未点亮屏幕,过程和修改内容如附件,请再帮忙看下,谢谢
接上显示器,adb 查看一下这个值
cat /d/dri/0/summary
cj15 发表于 2023-7-20 11:53
Video Port0: DISABLED
Video Port1: DISABLED
Video Port2: DISABLED
以下是介入显示器的值
Video Port0: ACTIVE
Connector: HDMI-A-1
bus_format[100a]: RGB888_1X24
overlay_mode[0] output_mode[f] color_space[0], eotf:0
Display mode: 480x1920p60
clk[66280] real_clk[66280] type[48] flag[5]
H: 480 510 540 570
V: 1920 1926 1932 1938
Cluster0-win0: ACTIVE
win_id: 0
format: AB24 little-endian (0x34324241)[AFBC] SDR[0] color_space[0] glb_alpha[0xff]
rotate: xmirror: 0 ymirror: 0 rotate_90: 0 rotate_270: 0
csc: y2r[0] r2y[0] csc mode[0]
zpos: 0
src: pos[0, 0] rect[480 x 1920]
dst: pos[9, 0] rect[462 x 1920]
buf[0]: addr: 0x00000000ef72c000 pitch: 1920 offset: 0
Video Port3: ACTIVE
Connector: DSI-1
overlay_mode[0] output_mode[0] color_space[0], eotf:0
Display mode: 800x1280p60
clk[72600] real_clk[72600] type[48] flag[a]
H: 800 832 846 872
V: 1280 1360 1368 1388
Cluster3-win0: ACTIVE
win_id: 6
zpos: 0
src: pos[0, 0] rect[800 x 1280]
dst: pos[0, 0] rect[800 x 1280]
buf[0]: addr: 0x00000000ee41e000 pitch: 3200 offset: 0
