ffmedia报错Segmentation fault (core dumped)
固件文件名称:ffmedia
固件下载地址:Firefly-Linux / ffmedia_release · GitLab
Log日志:error.txt
运行官方的ffmedia的demo_opencv.py,当长时间运行时,会报错Segmentation fault (core dumped),无其他任何报错信息就单独一条Segmentation fault (core dumped),然后程序停止;ffmedia最近2星期前才升级到v2.0.1,请问后续还有升级计划吗,后续升级会尝试解决上述问题吗
error.txt (32 Bytes)
ffmedia会持续更新支持;请具体描述一下复现方法,比如使用demo的命令是什么?
有基于demo进行过一点改动,在外面包了一层,可以开启多个demo获取不同的rtsp流,今天测试的时候出现新的报错信息:
Thread 0x0000007f3d4f7160 (most recent call first):
File “/usr/lib/python3.8/threading.py”, line 306 in wait
File “/usr/lib/python3.8/threading.py”, line 558 in wait
File “/usr/local/lib/python3.8/dist-packages/apscheduler/schedulers/blocking.py”, line 30 in _main_loop
File “/usr/lib/python3.8/threading.py”, line 870 in run
File “/usr/lib/python3.8/threading.py”, line 932 in _bootstrap_inner
File “/usr/lib/python3.8/threading.py”, line 890 in _bootstrap
Thread 0x0000007f78eb0160 (most recent call first):
File “/usr/local/Ai_platform/rtsp_fun/load_stream_fun.py”, line 45 in run
Thread 0x0000007f717fa160 (most recent call first):
File “/usr/local/Ai_platform/rtsp_fun/load_stream_vpu.py”, line 106 in RtspLoadVPU
Thread 0x0000007f71ffb160 (most recent call first):
File “/usr/local/Ai_platform/pred_fun/predict_fun/yolo_detect.py”, line 110 in detect
Thread 0x0000007fb2730160 (most recent call first):
File “/usr/local/lib/python3.8/dist-packages/paho/mqtt/client.py”, line 1150 in _loop
File “/usr/local/lib/python3.8/dist-packages/paho/mqtt/client.py”, line 1756 in loop_forever
File “/usr/local/lib/python3.8/dist-packages/paho/mqtt/client.py”, line 3591 in _thread_main
Thread 0x0000007fb1f2f160 (most recent call first):
File “/usr/local/Ai_platform/utils/sys_info.py”, line 113 in network_speed
File “/usr/local/Ai_platform/utils/sys_info.py”, line 28 in run
Thread 0x0000007fb172e160 (most recent call first):
Thread 0x0000007faef2d160 (most recent call first):
File “/usr/local/Ai_platform/utils/warn_file_deal.py”, line 52 in run
Thread 0x0000007fb9f48010 (most recent call first):
File “/usr/lib/python3.8/selectors.py”, line 415 in select
File “/usr/lib/python3.8/socketserver.py”, line 232 in serve_forever
File “/usr/local/lib/python3.8/dist-packages/werkzeug/serving.py”, line 741 in serve_forever
File “/usr/local/lib/python3.8/dist-packages/werkzeug/serving.py”, line 1098 in run_simple
File “/usr/local/lib/python3.8/dist-packages/flask/app.py”, line 1188 in run
File “/usr/local/Ai_platform/runserver.py”, line 62 in
啊这?能否给个复现环境或者复现方法,我这边能复现出来就容易解决
我这边上传了一个我改动过的demo,整体改动应该也不大,请大佬帮忙看看一下长时间运行会不会报上面的错,运行环境应该只需要OpenCV和ffmedia,给一个runserver.py里面的source_rtsp的可用rtsp地址,运行runserver应该就可以了。提取码:pjof
Fatal Python error: Segmentation fault
Thread 0x0000007f62ae8160 (most recent call first):
File "/usr/local/fSegmentation fault (core dumped)
sky-brid 发表于 2023-7-13 11:45
我这边上传了一个我改动过的demo,整体改动应该也不大,请大佬帮忙看看一下长时间运行会不会报上面的错, …
你那边大概运行多久会出问题?你们的rtsp是有多流吗(比如有音频流及字幕流)?
如果你们这样同步处理的话,可以不用导出rga模块buf,在回调中直接锁住等待和通知处理线程,等处理线程处理完成后,再通知回调函数退出回调,只要不退出回调,那么回调的那块buff就归你使用,当回调退出,模块会回收并使用该buf;
导出buf是从模块的内存池抽离,模块不再管理该buf,是为了支持异步处理buf,
如果你们这样同步处理的 …
时间说不准,有时候能运行好十几小时,有时候2.3小时就没了,我用的rtsp流是直接从摄像头获取的,带音频的;我研究一下安装你给的建议试试看
sky-brid 发表于 2023-7-14 12:02
时间说不准,有时候能运行好十几小时,有时候2.3小时就没了,我用的rtsp流是直接从摄像头获取的,带音频 …
我这边海康摄像机一个流测试一晚上没出现问题,可能是多流导致的;前阵子修复了多流导致的问题,可能修复了他,下个星期更新一版。
dengkx 发表于 2023-7-14 16:24
我这边海康摄像机一个流测试一晚上没出现问题,可能是多流导致的;前阵子修复了多流导致的问题,可能修复 …
我这边现在测试下来也没问题了,还有一个问题想请教一下,在前面还没改之前,我使用gunicron异步workers工作模式启动时,不知道是回调函数还是哪里总是出问题,无法获取到图像,换成同步worker就没有问题。
大佬,我这边又发现一个新问题,不知道是不是我操作的不对,我用官方的demo_opencv.py读取MP4文件(无音频),然后报错成MP4文件,发现保存下来的MP4文件无法打开,提升文件损坏的,然后我看了一下保存使用的bufferedwriter,这个怎么在生成MP4文件的时候指定h264编码?
sky-brid 发表于 2023-7-18 17:36
大佬,我这边又发现一个新问题,不知道是不是我操作的不对,我用官方的demo_opencv.py读取MP4文件(无音频 …
给一下使用命令和出问题的log
参考demo.py, -e 0 是 h264 , -e 1 是 h265, -m 后面加保存文件名字,根据后缀来封装成裸流mp4,mkv等文件
如果你们这样同步处理的 …
请问一下demo_opencv.py中的cv2_call_back函数中的VideoBuffer是不是ff_pymedia.MediaBuffer,然后怎么获取到ff_pymedia.MediaBuffer,感谢回复
sky-brid 发表于 2023-7-26 10:09
请问一下demo_opencv.py中的cv2_call_back函数中的VideoBuffer是不是ff_pymedia.MediaBuffer,然后怎么获 …
默认都是以Mediabuffer传输的,cv2_call_back函数中的VideoBuffer是ff_pymedia.MediaBuffer,如果想将ff_pymedia.MediaBuffer转成ff_pymedia.VideoBuffer 参考demo.py:
vb = VideoBuffer.from_base(mb)
dengkx 发表于 2023-7-26 17:19
默认都是以Mediabuffer传输的,cv2_call_back函数中的VideoBuffer是ff_pymedia.MediaBuffer,如果想将ff_ …
INFO: 10MppDecoder: getTimeoutSample: 0x7f3dee39c0 frame info changed 0 error 1 discard 0
在运行过程中,常常会看到大量的这种info,有时还有error信息输出,但是现在Python代码中没有找到接口可以获取到这些信息,请问一下现在Python有方法能获取到这些输出信息吗
INFO: 1 …
这些信息一般不用理会,你传递进去的图像数据有问题,解码不出来就会打印
好的,确实一般这种信息可以不理会,但是我现在碰到一个问题,比如当demo成功获取rtsp流,运行一段时间后,rtsp因为网络原因等导致断了,但Python的demo还是在运行的,后台一直在抛出rtsp流异常的信息,这些信息现在Python有办法获取吗,这样就能在rtsp流出问题时主动结束demo了,请教大佬了,感谢
sky-brid 发表于 2023-7-27 16:37
好的,确实一般这种信息可以不理会,但是我现在碰到一个问题,比如当demo成功获取rtsp流,运行一段时间后 …
因为模块是模块自己开线程运行的,抛出异常也没人去捕获,所以不会抛出异常。可以所以getModuleStatus接口获取模块状态。rtsp断开和超时不会改变模块状态,最新的代码rtsp支持了断线和超时重连。
python库要先卸载旧的,新的才能安装进去。
