Explore Relations between IPQ4019 IPQ4029 WiFi 5 Wireless Socs|Wallys DR40X9
In the world of wireless networking, Two such solutions are the IPQ4019 and IPQ4029, both designed to provide reliable and efficient WiFi 5 connectivity. Let’s delve into their features and explore their relations.
1 PQ4019 WiFi 5 Solution:
The IPQ4019 is a highly integrated system-on-chip (SoC) that combines a quad-core ARM Cortex A7 CPU with a powerful WiFi 5 radio. This solution offers impressive performance, advanced features, and excellent power efficiency. It supports 2x2 MU-MIMO (Multi-User, Multiple-Input, Multiple-Output) and provides data rates of up to 1.73 Gbps. The IPQ4019 is often found in mid-range routers, gateways, and access points.
2 IPQ4029 WiFi 5 Solution:
The IPQ4029 is an upgraded version of the IPQ4019, offering enhanced capabilities and improved performance. It features a quad-core ARM Cortex A7 CPU as well but includes an upgraded WiFi 5 radio subsystem. This solution supports 4x4 MU-MIMO and offers data rates of up to 2.6 Gbps, making it ideal for high-bandwidth applications and demanding network environments. The IPQ4029 is commonly utilized in high-end routers, gateways, and enterprise-grade access points.
Relations between IPQ4019 and IPQ4029:
Both the IPQ4019 and IPQ4029 are part of Qualcomm Technologies’ lineup of WiFi 5 solutions. They share several similarities while also exhibiting notable differences:
  1. CPU Architecture: Both SoCs utilize the ARM Cortex A7 CPU architecture, providing a reliable processing foundation for networking tasks.
  2. WiFi 5 Standard: Both solutions are designed to comply with the WiFi 5 (802.11ac) standard, enabling fast and stable wireless connectivity.
  3. Multi-User Support: While the IPQ4019 supports 2x2 MU-MIMO, the IPQ4029 takes it a step further by supporting 4x4 MU-MIMO. This allows the IPQ4029 to handle more simultaneous connections and deliver improved performance in multi-device scenarios.
  4. Data Rates: The IPQ4019 offers maximum data rates of up to 1.73 Gbps, whereas the IPQ4029 provides higher data rates of up to 2.6 Gbps. The increased data rates of the IPQ4029 make it better suited for bandwidth-intensive applications.
  5. Application Targeting: The IPQ4019 is typically used in mid-range networking devices, catering to residential and small office environments. In contrast, the IPQ4029 is commonly found in high-end and enterprise-grade networking solutions that require top-notch performance and reliability.
In summary, the IPQ4019 and IPQ4029 WiFi 5 wireless solutions from Qualcomm Technologies share a foundation of reliable CPU architecture and compliance with the WiFi 5 standard. However, the IPQ4029 stands out with its improved multi-user support, higher data rates, and target market, making it an excellent choice for demanding networking applications.
1.DR40X9:
One of the key features of the DR4019S is its powerful processor, which is a quad-core ARM Cortex-A15 CPU with a clock speed of 1.4 GHz. This processor can handle heavy network traffic and complex routing tasks with ease, ensuring smooth and fast data transfers and low latency.
The DR4019S also comes with 2 GB of DDR4 RAM and 8 GB of eMMC storage, which can be expanded with a microSD card slot. This ample amount of memory and storage allows you to store and run multiple applications and services, such as VPNs, firewalls, QoS, and more.
In terms of connectivity, the DR4019S has a rich set of ports and interfaces, including:
10 Gigabit Ethernet ports (1x SFP+ and 9x RJ45)
1 Gigabit Ethernet port (RJ45)
1 USB 3.0 port
1 serial console port
1 microUSB port (for power)
2.DR7915
Product Description
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Cards are individually calibrated for Quality Assurance
Our company:
Wallys Communications (Suzhou) Co., LTD Wallys 802.11ax, wifi 6, IPQ4029,IPQ4019,IPQ6018,IPQ6000.Router board, wireless card.Access Point-Wallys Communications (Suzhou ) Co., LTD
Our products link:PRODUCTS_Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales4@wallystech.com
