In the world of wireless networking, Two of notable offerings in the Wifi 6 domain are the IPQ8072 and IPQ8074 wireless solutions. Let’s delve into their relations and explore their capabilities.
Relationship and Similarities:
Both the IPQ8072 and IPQ8074 are part of Qualcomm’s IPQ807x family of chipsets, specifically designed for Wifi 6 (802.11ax) technology. They share several similarities due to their common architectural foundation:
1 Wifi 6 Capabilities: Both solutions support the Wifi 6 standard, enabling faster speeds, improved network efficiency, and increased capacity compared to previous generations. This technology enhances the overall wireless performance, making it ideal for demanding applications like video streaming, online gaming, and large-scale deployments.
2 Multi-Gigabit Speeds: The IPQ8072 and IPQ8074 chipsets are equipped with multiple high-speed Ethernet ports, allowing for multi-gigabit wired connections. This feature enables faster data transfers within the network and helps eliminate bottlenecks.
3 Qualcomm Technologies Integration: As part of Qualcomm’s portfolio, both solutions leverage the company’s expertise in wireless technologies, ensuring robust connectivity, advanced security features, and efficient power management.
Key Differences:
While sharing common traits, the IPQ8072 and IPQ8074 do have notable differences that cater to different use cases and deployment scenarios:
1 Processor Cores: The IPQ8072 is a quad-core processor, while the IPQ8074 is equipped with a more powerful quad-core processor, delivering increased processing capabilities. This distinction allows the IPQ8074 to handle more complex tasks and larger network loads effectively.
2 Antenna Support: The IPQ8074 offers higher antenna support compared to the IPQ8072, which translates to enhanced signal coverage and improved network range. This feature is particularly advantageous in larger homes, offices, or public areas with a higher density of connected devices.
3 Throughput Capacity: Due to its more robust processing power and higher antenna support, the IPQ8074 generally offers higher throughput capacity compared to the IPQ8072. This makes the IPQ8074 better suited for high-demand scenarios with a large number of concurrent users and data-intensive applications.
If you’re seeking a wireless solution that offers powerful client connections, lightning-fast speeds, extended coverage, enhanced security, and seamless connectivity, then look no further than Wallys IPQ 8072A. Upgrade your network infrastructure and unlock the full potential of your internet experience.
1.DR8072V01
Website:
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
NOR Flash: 8 MB
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
Our company:
Wallys Communications (Suzhou) Co., LTD www.wallystech.com/index.html
EMAIL:sales4@wallystech.com
