High-Speed IoT Soc Showdown: IPQ8072& QCN9074 VS IPQ8072& QCN9072|Wallys
The world of Internet of Things (IoT) is evolving at an incredible pace, and with it, the demand for high-speed and reliable solutions is increasing exponentially. Today, we are comparing two cutting-edge IoT solutions that have been making waves in the tech industry: IPQ8072 with QCN9074 and IPQ8072 with QCN9072.
IPQ8072 with QCN9074:
The IPQ8072 is a powerful system-on-chip (SoC) designed by Qualcomm Technologies Inc., a global leader in wireless technologies. It is equipped with a quad-core ARM Cortex A53 processor, making it ideal for handling complex tasks and enabling seamless multitasking. The real star of the show, however, is the QCN9074 wireless connectivity chip integrated into the IPQ8072.
The QCN9074 is a cutting-edge Wi-Fi 6E (802.11ax) chip that takes wireless connectivity to a whole new level. It supports ultra-fast data transfer rates, wider channels, and operates in the 6 GHz band, providing ample spectrum for congestion-free communication. With multi-user MIMO technology and OFDMA (Orthogonal Frequency-Division Multiple Access) support, the QCN9074 can efficiently handle multiple devices concurrently, ensuring smooth and lag-free performance in densely populated IoT environments.
Security is a paramount concern in the IoT ecosystem, and the IPQ8072 with QCN9074 doesn’t disappoint. It boasts robust security features like WPA3 encryption, secure boot, and hardware-based cryptographic acceleration, providing a solid shield against potential threats.
IPQ8072 with QCN9072:
The IPQ8072 with QCN9072 follows a similar architecture to its counterpart but uses a different wireless connectivity chip, the QCN9072. While not as advanced as the QCN9074, the QCN9072 is still a top-tier Wi-Fi 6E chip with excellent performance characteristics.
The QCN9072 also supports Wi-Fi 6E technology, offering impressive data rates and low-latency communication. However, compared to the QCN9074, it might have slightly lower throughput and capacity due to differences in channel width and other features. Nevertheless, for most IoT applications, the QCN9072 should still deliver remarkable performance.
In terms of security, the IPQ8072 with QCN9072 matches its sibling, leveraging WPA3 and other robust measures to keep data safe and secure.
The Verdict:
Both the IPQ8072 with QCN9074 and IPQ8072 with QCN9072 are formidable IoT solutions, catering to a wide range of applications with their powerful SoCs and advanced Wi-Fi 6E connectivity. If you’re looking for the absolute best performance and cutting-edge features, the IPQ8072 with QCN9074 would be the preferred choice. However, if budget constraints are a concern and the application’s requirements don’t necessitate the highest performance levels, the IPQ8072 with QCN9072 would still be an excellent option.
Ultimately, when choosing between the two, it’s essential to evaluate the specific needs of your IoT project, considering factors like device density, data throughput requirements, and budget constraints. Both solutions are part of Qualcomm Technologies’ commitment to pushing the boundaries of IoT connectivity, empowering developers and businesses to create innovative and seamless IoT experiences for consumers worldwide.
1.DR8072V01
Website:
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
NOR Flash: 8 MB
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR9074-6E(PN02.7)
Link here get more information
Features
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Operating Temperature Range -20 to 70 ºC
Storage Temperature Range -40 to 90 ºC
Symbol Parameter
Chipset Qualcomm Atheros QCN9074
WLAN Host Interface PCI Express 3.0 Interface
ystem Memory 2Mbit serial I²C bus EEPROM
Standard Operating Voltage 5V
Operating Systems QSDK
Host Interface M.2 E Key
Antenna Cable / Port 4 x MMCX Connectors,4T4R
Frequency Range 5.925GHz-7.125GHz
Data Rates for WALN 6GHz, max 23dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz at 6GHz
Modulation Techniques OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification TBD
Reference Design PN02.7
Dimensions (WxHxD) 57mm x 63mm x 6mm
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
