Are you tired of slow internet speeds and constant buffering? It’s time to dive into the world of WiFi solutions and explore two powerful contenders: IPQ4019 with QCA9880 and IPQ4019 with MT7915. These chipsets have been making waves in the networking industry, promising high-performance and reliable wireless connections. Let’s see how they stack up against each other!
IPQ4019 with QCA9880:
The IPQ4019 is a robust quad-core networking processor developed by Qualcomm Technologies, Inc. Its integration with the QCA9880 WiFi chip creates an impressive combination for wireless networking. Here are some key features:
1 Performance: The quad-core processor ensures fast data processing and efficient performance, making it suitable for handling multiple connected devices simultaneously.
2 Dual-band WiFi: The QCA9880 chip supports both 2.4 GHz and 5 GHz bands, providing better compatibility with a wide range of devices and reducing interference.
3 MU-MIMO: Multi-User Multiple Input Multiple Output (MU-MIMO) technology allows the router to communicate simultaneously with multiple devices, enhancing overall network efficiency.
4 Beamforming: With beamforming capabilities, the router can focus the WiFi signal directly towards connected devices, improving signal strength and coverage.
IPQ4019 with MT7915
The IPQ4019, paired with the MT7915 WiFi chip from MediaTek, is another formidable combination. Let’s explore its highlights:
1 Performance: Like the QCA9880, the MT7915 also offers powerful processing capabilities with a quad-core design, ensuring smooth data handling and network performance.
2 Tri-band WiFi: Unlike its counterpart, the MT7915 is capable of operating on three bands: one 2.4 GHz band and two 5 GHz bands. This allows for even greater device compatibility and reduced congestion.
3 Advanced OFDMA: Orthogonal Frequency Division Multiple Access (OFDMA) technology allows for better channel allocation, enabling higher efficiency and reduced latency in high-density environments.
4 Ultra-Fast Speeds: The MT7915 boasts impressive WiFi speeds, which can cater to bandwidth-intensive applications like 4K streaming and online gaming.
Conclusion:
Both WiFi solutions offer cutting-edge technology and powerful performance. The IPQ4019 with QCA9880 excels in its dual-band approach, MU-MIMO support, and beamforming capabilities, making it a solid choice for most homes and small businesses.
On the other hand, the IPQ4019 with MT7915 goes a step further with its tri-band capability and advanced OFDMA technology, making it ideal for crowded environments and homes with a multitude of devices.
Ultimately, the choice between these two solutions depends on your specific needs and the environment where you plan to deploy them. Whether you prioritize dual-band versatility or tri-band performance, these chipsets are sure to elevate your wireless networking experience to new heights!
DR4019
Product Parameter
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Storage Humidity Range 0 to +90 (non-condensing)%
Hardware Specifications
Symbol Parameter
CPU IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional)
3G/4G 1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR 256MB~512MB
EMAIL:sales4@wallystech.com
