固件文件名称:rv1126_rv1109_linux_release_20221222_v2.2.5d.xml
Log日志:log.rar
RV1126 采用DM-M10R800 V2屏幕模组无触摸,烧录的为官方提供的固件,hexdump eventX后触摸屏幕无数据,不太清楚用的什么触摸芯片,看原理图是gsl3680,内核配置将gsl|X680编译进去,设备树gsl3680 status改为okay,依然无触摸,移植tilib测试也不行。请求大神协助,日志为开机信息。
DDR Version V1.08 20210825
LPDDR4, 328MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=2048MB
change to: 328MHz
change to: 528MHz
change to: 784MHz
change to: 924MHz(final freq)
out
U-Boot SPL board init
U-Boot SPL 2017.09(u-boot commit id: 617c0aeae793895dfbcfad2e0d67ce0620736a93)(sdk version: rv1126_rv1109_linux_release_20221222_v2.2.5d.xml)-g617c0aeae7 #lvsx (Dec 22 2022 - 10:32:10)
unknown raw ID phN
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 2
spl: mmc init failed with error: -123
Trying to boot from MMC1
## Verified-boot: 0
## Checking optee 0x08400000 (gzip @0x08600000) … sha256(501681e1e7…) + sha256(447872e443…) + OK
## Checking uboot 0x00400000 (gzip @0x00600000) … sha256(525d1d9d7f…) + sha256(7d3b5f9915…) + OK
## Checking fdt 0x004b6b14 … sha256(80f00e7967…) + OK
Jumping to U-Boot(0x00400000) via OP-TEE(0x08400000)
Total: 119.99 ms
I/TC:
I/TC: cpu feature:0x0
I/TC: RV1126 SoC
I/TC: cpu_st=0xe0
I/TC: Next entry point address: 0x00400000
I/TC: OP-TEE version: 3.13.0-549-gef7f159d #derrick.huang (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 Thu Oct 28 10:52:10 CST 2021 arm
U-Boot 2017.09(u-boot commit id: 617c0aeae793895dfbcfad2e0d67ce0620736a93)(sdk version: rv1126_rv1109_linux_release_20221222_v2.2.5d.xml)-g617c0aeae7 #lvsx (Dec 22 2022 - 10:32:10 +0800)
Model: Rockchip RV1126 Evaluation Board
PreSerial: 2, raw, 0xff570000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bbf98f0 - 7bbfeddc
CR: M/C/I
dwmmc@ffc50000: 0, dwmmc@ffc60000: 1
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
DTB: rk-kernel.dtb
HASH(c): OK
I2c0 speed: 400000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_npu_vepu 800000 uV
vdd_arm 800000 uV
io-domain: OK
Can’t get crtc id, default set to id = 0
Model: Firefly Core-RV1126-JD4 BE-45 Board
Using display timing dts
dsi@ffb30000: detailed mode clock 72600 kHz, flags[a]
H: 0800 0832 0846 0872
V: 1280 1360 1368 1388
bus_format: 1009
final DSI-Link bandwidth: 500 Mbps x 4
apll 816000 KHz
dpll 462000 KHz
gpll 1188000 KHz
cpll 500000 KHz
hpll 1400000 KHz
aclk_pdbus 500000 KHz
hclk_pdbus 198000 KHz
pclk_pdbus 99000 KHz
aclk_pdphp 297000 KHz
hclk_pdphp 198000 KHz
hclk_pdaudio 148500 KHz
hclk_pdcore 198000 KHz
pclk_pdpmu 99000 KHz
Net: eth0: ethernet@ffc40000
## Booting FIT Image at 0x7aa338c0 with size 0x00fc3000
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at 7aa338c0 …
Using ‘conf’ configuration
optee api revision: 2.0
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0x7aa4d0c0
Data Size: 7261976 Bytes = 6.9 MiB
Architecture: ARM
OS: Linux
Load Address: 0x02008000
Entry Point: 0x02008000
Hash algo: sha256
Hash value: 21446cf18c001e544f3977a835ee3f31d00da5e6db5f32a864c60b863f3dcb3f
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at 7aa338c0 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0x7b13a0c0
Data Size: 9160505 Bytes = 8.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 34c8dbec64a0c800281419dccd445b0b6ff60dcb9c431584b823cc4088347bde
Loading ramdisk from 0x7b13a0c0 to 0x0a200000
## Loading fdt from FIT Image at 7aa338c0 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0x7aa340c0
Data Size: 101918 Bytes = 99.5 KiB
Architecture: ARM
Load Address: 0x08300000
Hash algo: sha256
Hash value: 3e97b0b9044556892dafe4697a4cc4b23460af8a5eb2cacd7c0edbc2c376537b
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0x7aa4d0c0 to 0x02008000 … OK
‘reserved-memory’ ramoops@8000000: addr=8000000 size=100000
Using Device Tree in place at 08300000, end 0831be1d
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x08648000 - 0x80000000 (size: 0x779b8000)
Total: 851.417 ms
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (book@100ask) (rv1126_rv1109_linux_release_20230711_v2.2.5e.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #10 SMP PREEMPT Mon Jul 17 21:40:50 EDT 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Firefly Core-RV1126-JD4 BE-45 Board
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options ‘’)
[ 0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x6dc00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521656
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal ro rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 cgroup_enable=memory swapaccount=1 snd_aloop.index=7
[ 0.000000] Memory: 1781392K/2094816K available (9216K kernel code, 379K rwdata, 2400K rodata, 1024K init, 939K bss, 43088K reserved, 270336K cma-reserved, 777528K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
[ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
[ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (10208 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 380 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 940 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000753] Switching to timer-based delay loop, resolution 41ns
[ 0.002655] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003610] pid_max: default: 4096 minimum: 301
[ 0.004219] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004841] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006292] CPU: Testing write buffer coherency: ok
[ 0.007144] /cpus/cpu@f00 missing clock-frequency property
[ 0.007668] /cpus/cpu@f01 missing clock-frequency property
[ 0.008188] /cpus/cpu@f02 missing clock-frequency property
[ 0.008709] /cpus/cpu@f03 missing clock-frequency property
[ 0.009225] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.010535] Setting up static identity map for 0x100000 - 0x100060
[ 0.011290] rcu: Hierarchical SRCU implementation.
[ 0.012385] smp: Bringing up secondary CPUs …
[ 0.014466] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.016209] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.017968] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.018106] smp: Brought up 1 node, 4 CPUs
[ 0.020100] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.020679] CPU: All CPU(s) started in SVC mode.
[ 0.022154] devtmpfs: initialized
[ 0.051181] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.051235] Unpacking initramfs…
[ 0.052648] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.053563] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.054455] pinctrl core: initialized pinctrl subsystem
[ 0.056304] NET: Registered protocol family 16
[ 0.057674] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.060402] cpuidle: using governor menu
[ 0.060810] Registered FIQ tty driver
[ 0.061987] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.062733] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.065654] console [pstore-1] enabled
[ 0.066284] pstore: Registered ramoops as persistent store backend
[ 0.066864] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.116897] cryptd: max_cpu_qlen set to 1000
[ 0.118321] fiq debugger fiq mode enabled
[[ 0.119230] console [ttyFIQ0] enabled
[ 0.119912] bootconsole [uart8250] disabled
[ 0.120691] Registered fiq debugger ttyFIQ0
[ 0.121382] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.126493] rk_iommu ffb00f00.iommu: version = 1
[ 0.127224] rk_iommu ffb20800.iommu: version = 1
[ 0.127697] rk_iommu ffb60e00.iommu: version = 1
[ 0.128384] rk_iommu ffb80480.iommu: version = 1
[ 0.128979] rk_iommu ffb90800.iommu: version = 1
[ 0.129483] rk_iommu ffbb0f00.iommu: version = 1
[ 0.130651] SCSI subsystem initialized
[ 0.131008] usbcore: registered new interface driver usbfs
[ 0.131106] usbcore: registered new interface driver hub
[ 0.131282] usbcore: registered new device driver usb
[ 0.131415] media: Linux media interface: v0.10
[ 0.131493] videodev: Linux video capture interface: v2.00
[ 0.131567] pps_core: LinuxPPS API ver. 1 registered
[ 0.131590] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.131639] PTP clock support registered
[ 0.133159] Advanced Linux Sound Architecture Driver Initialized.
[ 0.133951] Bluetooth: Core ver 2.22
[ 0.134047] NET: Registered protocol family 31
[ 0.134072] Bluetooth: HCI device and connection manager initialized
[ 0.134102] Bluetooth: HCI socket layer initialized
[ 0.134130] Bluetooth: L2CAP socket layer initialized
[ 0.134190] Bluetooth: SCO socket layer initialized
[ 0.134743] rockchip-cpuinfo cpuinfo: SoC : 11260000
[ 0.134784] rockchip-cpuinfo cpuinfo: Serial : 49dff9dbeb588032
[ 0.136020] clocksource: Switched to clocksource arch_sys_counter
[ 0.138730] NET: Registered protocol family 2
[ 0.139706] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.139772] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.139931] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.140129] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.140303] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.140387] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.140668] NET: Registered protocol family 1
[ 0.142887] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.145739] Initialise system trusted keyrings
[ 0.146134] workingset: timestamp_bits=29 max_order=19 bucket_order=0
[ 0.153729] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.156601] Key type asymmetric registered
[ 0.156643] Asymmetric key parser ‘x509’ registered
[ 0.156727] bounce: pool size: 64 pages
[ 0.156820] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.156850] io scheduler noop registered
[ 0.156872] io scheduler deadline registered
[ 0.157064] io scheduler cfq registered (default)
[ 0.157096] io scheduler mq-deadline registered
[ 0.157118] io scheduler kyber registered
[ 0.157280] io scheduler bfq registered
[ 0.161622] phy phy-ff4c0000.usb2-phy.1: Linked as a consumer to regulator.4
[ 0.163879] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.3
[ 0.167954] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.168126] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.168551] mpp_service mpp-srv: 4cdfd254f099 author: Yandong Lin 2021-02-21 video: rockchip: mpp: Fix irq state err.
[ 0.168587] mpp_service mpp-srv: probe start
[ 0.169595] iommu: Adding device ffb80000.rkvdec to group 3
[ 0.169663] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.169869] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.170599] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.170639] rkvdec_init:1182: No niu aclk reset resource define
[ 0.170669] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.170692] rkvdec_init:1185: No niu hclk reset resource define
[ 0.171064] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.171805] iommu: Adding device ffbb0000.rkvenc to group 5
[ 0.171866] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.172208] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.172928] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
[ 0.172967] rkvenc_init:1194: failed to add venc devfreq
[ 0.174087] iommu: Adding device ffb90400.vdpu to group 4
[ 0.174145] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[ 0.174265] mpp_vdpu2 ffb90400.vdpu: probe device
[ 0.174824] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.174864] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.175179] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.175864] iommu: Adding device ffb90000.vepu to group 4
[ 0.175928] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[ 0.176110] mpp_vepu2 ffb90000.vepu: probe device
[ 0.176656] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.176698] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.176967] mpp_vepu2 ffb90000.vepu: probing finish
[ 0.177555] iommu: Adding device ffb20000.iep to group 1
[ 0.177618] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[ 0.177738] mpp-iep2 ffb20000.iep: probe device
[ 0.178446] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[ 0.178665] mpp-iep2 ffb20000.iep: probing finish
[ 0.178980] mpp_service mpp-srv: probe success
[ 0.184333] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.184387] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.186924] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.187885] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.188871] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 32, base_baud = 1500000) is a 16550A
[ 0.191723] random: fast init done
[ 0.192279] random: crng init done
[ 0.192348] iommu: Adding device ffb00000.vop to group 0
[ 0.192401] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.196687] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
[ 0.197751] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
[ 0.199099] rockchip-drm display-subsystem: devfreq is not set
[ 0.199663] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3fe00)
[ 0.199755] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] ERROR Failed to find panel or bridge: -517
[ 0.199797] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb0a46534): -517
[ 0.200084] rockchip-drm display-subsystem: master bind failed: -517
[ 0.205194] panel probe ok!!!
[ 0.205371] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply power not found, using dummy regulator
[ 0.205528] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
[ 0.205584] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
[ 0.205689] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
[ 0.214328] loop: module loaded
[ 0.215014] zram: Added device: zram0
[ 0.217615] libphy: Fixed MDIO Bus: probed
[ 0.219725] rk_gmac-dwmac ffc40000.ethernet: no regulator found
[ 0.219780] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (output).
[ 0.219804] rk_gmac-dwmac ffc40000.ethernet: TX delay(0x2a).
[ 0.219827] rk_gmac-dwmac ffc40000.ethernet: RX delay(0x1a).
[ 0.219870] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
[ 0.224981] rk_gmac-dwmac ffc40000.ethernet: init for RGMII
[ 0.225316] rk_gmac-dwmac ffc40000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.225355] rk_gmac-dwmac ffc40000.ethernet: DWMAC4/5
[ 0.225382] rk_gmac-dwmac ffc40000.ethernet: DMA HW capability register supported
[ 0.225407] rk_gmac-dwmac ffc40000.ethernet: RX Checksum Offload Engine supported
[ 0.225430] rk_gmac-dwmac ffc40000.ethernet: TX Checksum insertion supported
[ 0.225453] rk_gmac-dwmac ffc40000.ethernet: Wake-Up On Lan supported
[ 0.225528] rk_gmac-dwmac ffc40000.ethernet: TSO supported
[ 0.225549] rk_gmac-dwmac ffc40000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.225579] rk_gmac-dwmac ffc40000.ethernet: TSO feature enabled
[ 0.356109] libphy: stmmac: probed
[ 0.358235] PPP generic driver version 2.4.2
[ 0.358557] PPP BSD Compression module registered
[ 0.358588] PPP Deflate Compression module registered
[ 0.358631] PPP MPPE Compression module registered
[ 0.358655] NET: Registered protocol family 24
[ 0.358788] usbcore: registered new interface driver r8152
[ 0.358868] usbcore: registered new interface driver asix
[ 0.358959] usbcore: registered new interface driver ax88179_178a
[ 0.359035] usbcore: registered new interface driver cdc_ether
[ 0.359099] usbcore: registered new interface driver net1080
[ 0.359182] usbcore: registered new interface driver cdc_subset
[ 0.359254] usbcore: registered new interface driver zaurus
[ 0.359419] usbcore: registered new interface driver cdc_ncm
[ 0.359506] usbcore: registered new interface driver qmi_wwan
[ 0.361384] dwc3 ffd00000.dwc3: Failed to get clk ‘ref’: -2
[ 0.368116] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.368171] ehci-platform: EHCI generic platform driver
[ 0.371839] ehci-platform ffe00000.usb: EHCI Host Controller
[ 0.371918] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[ 0.372161] ehci-platform ffe00000.usb: irq 67, io mem 0xffe00000
[ 0.382776] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.383123] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.383160] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.383188] usb usb1: Product: EHCI Host Controller
[ 0.383213] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.383237] usb usb1: SerialNumber: ffe00000.usb
[ 0.384103] hub 1-0:1.0: USB hub found
[ 0.384185] hub 1-0:1.0: 1 port detected
[ 0.385006] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.385065] ohci-platform: OHCI generic platform driver
[ 0.385737] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.385805] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.386085] ohci-platform ffe10000.usb: irq 68, io mem 0xffe10000
[ 0.447087] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.447142] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.447166] usb usb2: Product: Generic Platform OHCI controller
[ 0.447208] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.447238] usb usb2: SerialNumber: ffe10000.usb
[ 0.448095] hub 2-0:1.0: USB hub found
[ 0.448179] hub 2-0:1.0: 1 port detected
[ 0.450020] usbcore: registered new interface driver cdc_wdm
[ 0.450184] usbcore: registered new interface driver usb-storage
[ 0.450359] usbcore: registered new interface driver ch341
[ 0.450414] usbserial: USB Serial support registered for ch341-uart
[ 0.450496] usbcore: registered new interface driver option
[ 0.450564] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.451416] ============ himax_hx83102_init 1742 jjlook ==========
[ 0.451453] ============ himax_hx83102_probe 1725 jjlook ==========
[ 0.451476] ============ himax_common_init 1050 jjlook ==========
[ 0.451498] ============ himax_common_init 1059 jjlook ==========
[ 0.451864] i2c /dev entries driver
[ 0.453979] rk808 0-0020: chip id: 0x8090
[ 0.454093] rk808 0-0020: No cache defaults, reading back from HW
[ 0.460536] rk808 0-0020: source: on=0x40, off=0x00
[ 0.460591] rk808 0-0020: support dcdc3 fb mode:-22, -1330052488
[ 0.460618] rk808 0-0020: support pmic reset mode:0,0
[ 0.465292] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.465427] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.465537] DCDC_REG1: supplied by vcc5v0_sys
[ 0.466371] DCDC_REG2: supplied by vcc5v0_sys
[ 0.467047] DCDC_REG3: supplied by vcc5v0_sys
[ 0.467567] DCDC_REG4: supplied by vcc5v0_sys
[ 0.468096] DCDC_REG5: supplied by vcc5v0_sys
[ 0.468757] LDO_REG1: supplied by vcc_buck5
[ 0.469470] LDO_REG2: supplied by vcc_buck5
[ 0.469968] LDO_REG3: supplied by vcc_buck5
[ 0.470494] LDO_REG4: supplied by vcc_buck5
[ 0.471023] LDO_REG5: supplied by vcc_buck5
[ 0.471513] LDO_REG6: supplied by vcc_buck5
[ 0.471588] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.472240] LDO_REG7: supplied by vcc5v0_sys
[ 0.472832] LDO_REG8: supplied by vcc5v0_sys
[ 0.473507] LDO_REG9: supplied by vcc5v0_sys
[ 0.474165] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.474654] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.477073] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.480278] rk808-rtc rk808-rtc: registered as rtc0
[ 0.480909] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:02 UTC (1501837202)
[ 0.483190] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[ 0.483325] pca953x 1-0020: Linked as a consumer to regulator.0
[ 0.483533] pca953x 1-0020: failed reading register
[ 0.483643] pca953x 1-0020: Dropping the link to regulator.0
[ 0.484226] ============ himax_chip_common_probe 963 jjlook ==========
[ 0.484251] ============ himax_chip_common_probe 973 jjlook ==========
[ 0.484286] ============ himax_chip_common_probe 982 jjlook addr = 0x48==========
[ 0.484309] ============ himax_chip_common_probe 989 jjlook ==========
[ 0.484330] ============ himax_chip_common_init 2793 jjlook ==========
[ 0.492922] ============ himax_parse_dt 168 jjlook 800 1280==========
[ 0.493050] ============ himax_parse_dt 181 jjlook ==========
[ 0.493100] ============ himax_parse_dt 210 jjlook ========== DT:gpio_irq=32, gpio_rst=28, gpio_3v3_en=-2
[ 0.493129] ============ himax_chip_common_init 2845 jjlook ==========
[ 0.493151] ============ himax_gpio_power_config 523 jjlook ==========
[ 0.493172] ============ himax_gpio_power_config 527 jjlook ==========
[ 0.493231] ============ himax_gpio_power_config 537 jjlook ==========
[ 0.493248] ============ himax_gpio_power_config 548 jjlook ==========
[ 0.493262] ============ himax_gpio_power_config 572 jjlook ==========
[ 0.493284] ============ himax_gpio_power_config 589 jjlook ==========
[ 0.493305] ============ himax_gpio_power_config 591 jjlook ==========
[ 0.493341] ============ himax_gpio_power_config 603 jjlook ==========
[ 0.493366] ============ himax_gpio_power_config 612 jjlook irq = 106==========
[ 0.493387] ============ himax_gpio_power_config 622 jjlook ==========
[ 0.495437] ============ himax_gpio_power_config 628 jjlook ==========
[ 0.495458] ============ himax_gpio_power_config 630 jjlook ==========
[ 0.495493] ============ himax_gpio_power_config 640 jjlook ==========
[ 0.495515] ============ himax_chip_common_init 2864 jjlook ==========
[ 0.619100] ============ himax_chip_common_init 2903 jjlook ==========
[ 0.712786] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 0.802128] Freeing initrd memory: 8948K
[ 0.861248] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 0.861289] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.861310] usb 1-1: Product: USB2.0 Hub
[ 0.862459] hub 1-1:1.0: USB hub found
[ 0.862873] hub 1-1:1.0: 4 ports detected
[ 1.142730] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.240873] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
[ 1.240910] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.240929] usb 1-1.3: Product: USB 10/100 LAN
[ 1.240955] usb 1-1.3: Manufacturer: Realtek
[ 1.240980] usb 1-1.3: SerialNumber: 00E04C9212A6
[ 1.322772] usb 1-1.3: reset high-speed USB device number 3 using ehci-platform
[ 1.359684] input: himax-touchscreen as /devices/virtual/input/input1
[ 1.360186] ============ himax_int_register_trigger 747 jjlook ==========
[ 1.362433] ircut cam_ircut: driver version: 00.01.00
[ 1.362719] ircut cam_ircut: failed get pulse-width,use dafult value 100
[ 1.362802] ircut cam_ircut: Failed to get ircut-open-gpios
[ 1.362874] ircut cam_ircut: Failed to get ircut-close-gpios
[ 1.363001] ircut cam_ircut: probe successful!
[ 1.363839] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
[ 1.365191] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[ 1.365244] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[ 1.365390] rkcif rkcif_dvp: rkcif driver version: v00.01.09
[ 1.365505] rkcif rkcif_dvp: attach to cif hw node
[ 1.366659] rkcif_dvp: cif_subdev_notifier: no subdev be found!
[ 1.366682] rkcif_dvp: Failed to register subdev notifier(-19)
[ 1.367627] rkcif rkcif_dvp: detach to cif hw node
[ 1.367750] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.09
[ 1.367861] rkcif rkcif_mipi_lvds: attach to cif hw node
[ 1.368844] rkcif rkcif_mipi_lvds: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 1.368869] rockchip-mipi-csi2: Async registered subdev
[ 1.371277] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[ 1.371308] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[ 1.371639] rkisp_hw ffb50000.rkisp: iommu is disabled, using non-iommu buffers
[ 1.371693] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[ 1.372012] rkisp rkisp-vir0: rkisp driver version: v01.04.01
[ 1.372251] rkisp rkisp-vir0: No memory-region-thunderboot specified
[ 1.372503] rkisp rkisp-vir0: Entity type for entity rkisp-isp-subdev was not initialized!
[ 1.372541] rkisp rkisp-vir0: Entity type for entity rkisp-csi-subdev was not initialized!
[ 1.372576] rkisp rkisp-vir0: Entity type for entity rkisp-bridge-ispp was not initialized!
[ 1.376179] iommu: Adding device ffb60000.rkispp to group 2
[ 1.376248] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[ 1.376881] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[ 1.376935] rkispp_hw ffb60000.rkispp: can’t request region for resource [mem 0xffb60000-0xffb7ffff]
[ 1.377458] rkispp rkispp-vir0: rkispp driver version: v01.04.01
[ 1.380209] usbcore: registered new interface driver uvcvideo
[ 1.380245] USB Video Class driver (1.1.1)
[ 1.380759] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.19
[ 1.380913] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.15
[ 1.381111] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.22
[ 1.381414] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.13
[ 1.381541] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.10
[ 1.384762] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -8
[ 1.385169] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[ 1.385652] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -3
[ 1.385914] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[ 1.386938] Bluetooth: HCI UART driver ver 2.3
[ 1.386973] Bluetooth: HCI UART protocol H4 registered
[ 1.387322] cpu cpu0: bin=0
[ 1.387382] cpu cpu0: leakage=1.375
[ 1.387547] cpu cpu0: Linked as a consumer to regulator.8
[ 1.399235] cpu cpu0: temp=45500, pvtm=103092 (102988 + 104)
[ 1.399428] cpu cpu0: pvtm-volt-sel=2
[ 1.399539] cpu cpu0: Dropping the link to regulator.8
[ 1.399608] cpu cpu0: bin-scale=5
[ 1.400030] cpu cpu0: Linked as a consumer to regulator.8
[ 1.400109] cpu cpu0: Dropping the link to regulator.8
[ 1.400370] cpu cpu0: Linked as a consumer to regulator.8
[ 1.401553] cpu cpu0: avs=0
[ 1.402049] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.402095] cpu cpu0: failed to read out thermal zone (-22)
[ 1.402994] cpu cpu0: failed to find power_model node
[ 1.403079] cpuidle: enable-method property ‘psci’ found operations
[ 1.403180] cpuidle: enable-method property ‘psci’ found operations
[ 1.403249] cpuidle: enable-method property ‘psci’ found operations
[ 1.403319] cpuidle: enable-method property ‘psci’ found operations
[ 1.403962] Synopsys Designware Multimedia Card Interface Driver
[ 1.404444] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.404496] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[ 1.404516] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[ 1.404577] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[ 1.404704] mmc_host mmc0: card is non-removable.
[ 1.416447] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.430940] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.431115] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 1.431194] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 1.431370] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 1.431693] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.19
[ 1.442915] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.457289] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.457438] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 1.457508] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 1.457745] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[ 1.458176] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[ 1.458232] mmc_host mmc1: card is non-removable.
[ 1.467317] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 1.467375] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 1.467969] mmc0: new HS200 MMC card at address 0001
[ 1.469895] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.469970] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 1.470962] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 1.471920] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 1.472935] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB, chardev (241:0)
[ 1.480966] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 1.484536] usbcore: registered new interface driver usbhid
[ 1.484590] usbhid: USB HID core driver
[ 1.487261] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.15
[ 1.488179] rksfc_base v1.1 2016-01-08
[ 1.488704] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 1.488785] rkflash_dev_init enter
[ 1.488807] sfc nor id: 0 0 0
[ 1.488820] rkflash[1] is invalid
[ 1.488822] rkflash_dev_init enter
[ 1.488848] sfc_nand id: 0 0 0
[ 1.488858] rkflash[2] is invalid
[ 1.494960] rk817-codec rk817-codec: DMA mask not set
[ 1.495085] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 1.499065] NET: Registered protocol family 17
[ 1.499117] NET: Registered protocol family 15
[ 1.499582] Bluetooth: RFCOMM TTY layer initialized
[ 1.499635] Bluetooth: RFCOMM socket layer initialized
[ 1.499671] Bluetooth: RFCOMM ver 1.11
[ 1.499698] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.499715] Bluetooth: HIDP socket layer initialized
[ 1.499727] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.499738] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.500063] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.500116] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 1.500130] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.500141] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.500207] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 1.500245] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.500260] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.500630] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 48.
[ 1.500664] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 7.
[ 1.500711] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[ 1.500725] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.500775] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.500889] [BT_RFKILL]: ** disable irq
[ 1.501000] [BT_RFKILL]: bt shut off power
[ 1.501049] [BT_RFKILL]: bt_default device registered.
[ 1.501904] flash vendor_init_thread!
[ 1.501936] flash vendor storage:20170308 ret = -1
[ 1.502450] Registering SWP/SWPB emulation handler
[ 1.504150] Loading compiled-in X.509 certificates
[ 1.504409] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.505085] rga2: Driver loaded successfully ver:3.02
[ 1.505403] rga2: Module initialized.
[ 1.507772] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.507993] r8152 1-1.3:1.0 eth1: v2.12.0 (2019/04/29)
[ 1.508024] r8152 1-1.3:1.0 eth1: This product is covered by one or more of the following patents:
[ 1.508024] US6,570,884, US6,115,776, and US6,327,625.
[ 1.508024]
[ 1.510463] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.513374] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.516789] vendor storage:20190527 ret = 0
[ 1.516881] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.531910] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 1.532419] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.7
[ 1.532465] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 1.532486] mpp_rkvenc ffbb0000.rkvenc: leakage=1.375
[ 1.532532] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 1.532558] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 1.533043] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 1.533337] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 1.533351] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 1.533474] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 1.533499] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 1.533800] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 1.535627] rockchip-drm display-subsystem: devfreq is not set
[ 1.536057] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb0a3fe00)
[ 1.536177] rockchip-drm display-subsystem: bound ffb30000.dsi (ops 0xb0a46534)
[ 1.536233] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.536247] [drm] No driver support for vblank timestamp query.
[ 1.552456] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.554298] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 1.554940] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 1.558844] asoc-simple-card rk809-sound: rk817-hifi ↔ ff800000.i2s mapping ok
[ 1.558915] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.558933] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.558949] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 1.558963] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.558978] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.558998] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.559018] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.559037] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.560064] input: rockchip,rk809-codec Headphone Jack as /devices/platform/rk809-sound/sound/card0/input3
[ 1.562015] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 1.562047] ======== dhd_wlan_init_plat_data ========
[ 1.562059] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.562131] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=108, oob_irq_flags=0x414
[ 1.562143] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.562154] dhd_wifi_platform_load: Enter
[ 1.562166] Power-up adapter ‘DHD generic adapter’
[ 1.562205] wifi_platform_set_power = 1
[ 1.562216] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.562227] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.562239] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 1.562344] rkcif rkcif_mipi_lvds: clear unready subdev num: 1
[ 1.562362] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.562929] rkcif_mipi_lvds: Async subdev notifier completed
[ 1.563716] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.573030] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 1.573167] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.573186] cfg80211: failed to load regulatory.db
[ 1.573637] rkisp rkisp-vir0: clear unready subdev num: 1
[ 1.574079] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.574110] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.574124] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 1.574138] rkisp0: Invalid mipi data type
[ 1.574149] rkisp0: update sensor failed
[ 1.574641] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 270
[ 1.574874] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 1.575143] ret 1024 0
[ 1.575379] ALSA device list:
[ 1.575395] #0: rockchip,rk809-codec
[ 1.575406] #7: Loopback 1
[ 1.576471] Freeing unused kernel memory: 1024K
[ 1.576661] Run /init as init process
Loading, please wait…
[ 1.610832] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.612549] mmc1: new high speed SDIO card at address 0001
Couldn’t get a file descriptor referring to the console
starting version 237
log.rar (4.15 KB)
