In the ever-evolving world of wireless technology, WiFi 6 has emerged as a groundbreaking standard, promising faster speeds, increased capacity, and enhanced performance. As we compare two notable WiFi 6 solutions, the IPQ5018 with QCN6122 and the IPQ5018 with QCN9074, let’s delve into the features and advantages they bring to the table.
The IPQ5018 with QCN6122 is a robust WiFi 6 solution developed to meet the growing demands of modern networks. Let’s explore some of its key features:
Performance: The IPQ5018 chipset offers powerful processing capabilities, ensuring efficient data handling and low latency. Coupled with the QCN6122 radio chip, this solution can deliver impressive throughput and reliable connections.
MU-MIMO: Multi-User Multiple Input Multiple Output (MU-MIMO) is a cutting-edge technology that allows the router to communicate with multiple devices simultaneously, thereby optimizing network efficiency in crowded environments.
Dual-Band Operation: The QCN6122 supports both 2.4 GHz and 5 GHz bands, enabling the router to cater to a wide range of devices, regardless of their WiFi compatibility.
Smart Antenna Technology: The QCN6122 incorporates advanced beamforming technology that focuses the WiFi signals directly to connected devices, enhancing signal strength and overall coverage.
Advanced Security: With WPA3 encryption and other security features, the IPQ5018 with QCN6122 provides robust protection against unauthorized access and potential threats.
The IPQ5018 with QCN9074 is another powerful WiFi 6 solution designed to deliver exceptional network performance. Let’s explore its distinctive features:
Quad-Core Processing: The IPQ5018 chipset’s quad-core CPU enhances the overall processing speed and efficiency, ensuring a smooth and lag-free user experience, even in data-intensive scenarios.
WiFi 6E Support: While the IPQ5018 with QCN6122 operates in the 2.4 GHz and 5 GHz bands, the QCN9074 takes it a step further by supporting the 6 GHz band, unlocking additional spectrum for even faster and less congested connections.
Extended Capacity: With support for a broader range of channels and higher data rates in the 6 GHz band, the IPQ5018 with QCN9074 can accommodate more devices simultaneously without sacrificing performance.
Tri-Band Operation: This solution leverages three separate bands (2.4 GHz, 5 GHz, and 6 GHz) to segregate traffic efficiently, reducing interference and ensuring each device gets the best possible connection.
Backward Compatibility: Despite its advanced features, the QCN9074 is designed to work seamlessly with older WiFi standards, ensuring compatibility with a wide array of devices.
Conclusion
Both the IPQ5018 with QCN6122 and the IPQ5018 with QCN9074 are impressive WiFi 6 solutions that cater to different networking needs. The IPQ5018 with QCN6122 excels in environments with mixed device compatibility, offering reliable and fast dual-band connections with smart antenna technology. On the other hand, the IPQ5018 with QCN9074 pushes the boundaries with its tri-band support, WiFi 6E capabilities, and robust processing power, making it ideal for high-density environments and future-proofing the network.
When selecting the right solution, consider the specific requirements of your network, the number of connected devices, and the expected growth in the coming years. Whether it’s the IPQ5018 with QCN6122 or the IPQ5018 with QCN9074, embracing WiFi 6 technology will undoubtedly elevate your network performance to new heights.
Wallys IPQ 5018 Soc:
Feature:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Absolute Maximum Rating:
Supply Voltage 12 V
Storage Temperature Range -45 to +105ºC
Hardware Specifications:
CPU: Qualcomm-Atheros IPQ5018
CPU Frequency: Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory:512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port:4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot:M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
EMMC:4G/8G(optional)
USB /header:1x USB 3.0 Port
POE:NA
DC Jack:12V power supply
LED header LED for power ,Wifi strength
Serial Port support
Wireless:On-board 2x22.4GHz MU-MIMO OFDMA: 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
Bluetooth: BT5.1
Nor Flash: 8MB
Nand Flash: 128 MB
DDR: 512MB
Dimension:170mm x 120mm x 15m
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile:sales4@wallystech.com. This is Jane for you
