IPQ6018 IPQ6010 High-Powerful WiFi6 Chips Breaking 23KM Transmission| Wallys
Are you ready to experience the next level of wireless connectivity? Say hello to the revolutionary IPQ6010, a high-powerful wireless chip that is set to redefine the way we communicate and connect. With its cutting-edge capabilities and seamless integration with OpenWiFi QSDK, get ready to unlock the true potential of wireless communication like never before.
Powering the Impossible
The IPQ6010 is a game-changer in the world of wireless technology. Developed with state-of-the-art engineering and innovation, this chip boasts unparalleled power and efficiency. Designed to operate on the latest Wi-Fi standards, it supports blazing-fast speeds and long-range transmission like you’ve never seen before.
OpenWiFi QSDK - Empowering Developers
OpenWiFi QSDK is a powerful open-source software development kit that complements the IPQ6010’s capabilities. Designed to be flexible, robust, and easy to use, this SDK empowers developers to build, customize, and optimize wireless applications and networking solutions. Whether you’re a seasoned developer or just starting, OpenWiFi QSDK makes the process seamless and efficient.
23KM Transmission - Redefining Range
The IPQ6010 takes long-range communication to new heights with its impressive 23KM transmission capacity. Now, imagine the possibilities - connecting distant devices, expanding network coverage in remote areas, or enabling high-speed data transfer over extended distances. The potential applications are limitless!
Endless Applications
The combination of the IPQ6010 and OpenWiFi QSDK opens up a world of possibilities across various industries and use cases:
1.Smart Cities: Enable smart city infrastructure with seamless connectivity across large urban areas.
2.Rural Connectivity: Bridge the digital divide by extending high-speed internet to remote and underserved regions.
3.Agriculture & IoT: Facilitate precision farming and IoT applications in vast agricultural landscapes.
4.Drones & Robotics: Enhance control and data transmission for drones and autonomous robotic systems.
5.Industrial Automation: Power wireless communication in factories and manufacturing facilities.
6.Enterprise Solutions: Enable reliable and fast Wi-Fi coverage for offices and corporate environments.
7.Hospitality & Public Spaces: Offer high-quality Wi-Fi access to guests and visitors in hotels, malls, and public areas.
Embrace the Future Today
With the IPQ6010 chip and OpenWiFi QSDK, the future of wireless communication is here. Embrace the limitless possibilities of long-range transmission and explore new horizons of connectivity. Whether you’re a developer, an entrepreneur, or an enthusiast, the IPQ6010 is your ticket to ride the wave of the wireless revolution.
Join us and be a part of this extraordinary journey towards a connected world without boundaries.
1.DR6018
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
More detail and opportunities attach Emile :sales4@wallystech.com. This is Jane for you
Connect. Innovate. Thrive. Together with Wallys.
