IPQ6018 IPQ5018: Exploring the Cutting-Edge WiFi 6 IoT Solution|Wallys
In today’s rapidly evolving world of technology, the Internet of Things (IoT) has become an integral part of our lives. As we witness a surge in connected devices, the demand for faster, more reliable, and secure wireless connectivity is on the rise. Enter WiFi 6, the latest standard in wireless communication that promises to revolutionize IoT solutions.
WiFi 6, also known as 802.11ax, brings significant advancements over its predecessors, providing enhanced data rates, lower latency, improved energy efficiency, and increased capacity for handling numerous connected devices simultaneously. As we delve into the realm of WiFi 6 IoT solutions, two key players have emerged as front-runners: the IPQ6018 and IPQ5018.
IPQ6018 - Powering Seamless Connectivity:
The IPQ6018 is a cutting-edge system-on-chip (SoC) designed by Qualcomm Technologies Inc., a leader in wireless communication solutions. This robust and versatile chipset is purpose-built to address the challenges posed by the growing number of IoT devices.
Key Features:
  • Quad-core ARM CPU: The IPQ6018 houses a quad-core ARM Cortex-A53 CPU, providing substantial processing power to handle data-intensive tasks and manage multiple IoT devices with ease.
  • Tri-band WiFi: This chipset supports tri-band WiFi, enabling it to operate in three frequency bands simultaneously (2.4 GHz, 5 GHz, and 6 GHz), thereby reducing congestion and ensuring seamless connectivity.
  • Multi-Gigabit Ethernet: With integrated multi-gigabit Ethernet ports, the IPQ6018 can handle high-speed data transfers, making it an ideal choice for bandwidth-intensive IoT applications.
  • Advanced Security: The SoC boasts state-of-the-art security features, including WPA3 encryption and hardware-based encryption accelerators, ensuring data privacy and safeguarding against potential threats.
IPQ5018 - Empowering Compact IoT Devices:
The IPQ5018, also developed by Qualcomm, complements the IPQ6018 with its focus on catering to the growing demand for compact and power-efficient IoT devices.
Key Features:
  • Dual-core Kryo CPU: The IPQ5018 houses a dual-core Qualcomm Kryo CPU, providing excellent performance in a small form factor while minimizing power consumption.
  • Dual-band WiFi: This chipset supports dual-band WiFi (2.4 GHz and 5 GHz), delivering high-speed data transmission and reliable connectivity for a wide range of IoT applications.
  • Ethernet Connectivity: The IPQ5018 comes with integrated Ethernet support, making it a suitable choice for devices that require wired connectivity in addition to wireless capabilities.
  • Low Power Consumption: With a focus on energy efficiency, the IPQ5018 enables longer battery life and reduced power consumption for battery-operated IoT devices.
Relation between IPQ6018 and IPQ5018:
While both the IPQ6018 and IPQ5018 are designed to cater to IoT applications, they target different segments of the market. The IPQ6018 serves as a high-performance solution for more demanding and complex IoT deployments, while the IPQ5018 is ideal for compact and power-sensitive IoT devices.
It’s worth noting that both chipsets share Qualcomm’s expertise in wireless connectivity, security, and reliability. Whether it’s in smart homes, industrial automation, healthcare, or smart cities, these WiFi 6 IoT solutions are set to drive the next wave of innovation and revolutionize the way we interact with connected devices.
In conclusion, as the world embraces the Internet of Things, WiFi 6 and its powerful chipsets, such as the IPQ6018 and IPQ5018, pave the way for a more connected, efficient, and secure future. These solutions are poised to shape the IoT landscape and create new opportunities for technological advancements in various industries. So, get ready to embrace the limitless possibilities that WiFi 6 IoT solutions have to offer!
1 DR5018
https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.html
Feature:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Absolute Maximum Rating:
Supply Voltage 12 V
Storage Temperature Range -45 to +105ºC
Hardware Specifications:
CPU: Qualcomm-Atheros IPQ5018
CPU Frequency: Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory:512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port:4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot:M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
EMMC:4G/8G(optional)
USB /header:1x USB 3.0 Port
POE:NA
DC Jack:12V power supply
LED header LED for power ,Wifi strength
Serial Port support
Wireless:On-board 2x22.4GHz MU-MIMO OFDMA: 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
Bluetooth: BT5.1
Nor Flash: 8MB
Nand Flash: 128 MB
DDR: 512MB
Dimension:170mm x 120mm x 15mm
2 DR6018(CP01)
Website below:
https://www.wallystech.com/Routerboard/DR6018-CP01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-CP01-802-11AX-MU-MIMO-OFDMA.html
Qualcomm-Atheros IPQ6018
1GB DDRL3L System Memory
Parameter Rating Unit
Supply Voltage 24V~48 V
Symbol Parameter
CPU Qualcomm-Atheros IPQ6018
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port, 1x USB 3.0 Type-C Port
POE 24V~48V passive POE
DC Jack 12V power supply
LED header FFC/FPC Connector
Serial Port 1x Serial Port 12 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
4x U.FL Connectors
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension (W x H x D)219mm x 150mm x 16.5mm (Without Heatsink)
Website:https://www.wallystech.com/
EMAIL:sales4@wallystech.com
