Are you tired of slow and unreliable connections in your Internet of Things (IoT) devices? Say goodbye to lagging smart home devices and sluggish industrial IoT applications! We are thrilled to unveil the revolutionary IOT Solution powered by the IPQ6018, IPQ6010, IPQ5018, and IPQ8072 chipsets, providing unmatched Fast Roaming capabilities.
What is Fast Roaming?
Fast Roaming is a critical feature in any IoT network, enabling seamless and uninterrupted connectivity as devices move within the coverage area. Traditional Wi-Fi setups can cause frustrating disruptions, resulting in delayed commands, buffering streaming services, or even data loss during roaming. However, with our state-of-the-art IOT Solution, Fast Roaming becomes a breeze!
The Power of IPQ Chipsets
Our IOT Solution harnesses the powerful capabilities of four Qualcomm chipsets: IPQ6018, IPQ6010, IPQ5018, and IPQ8072. Let’s take a closer look at what each brings to the table:
IPQ6018: This robust chipset is designed to handle high data loads, making it perfect for smart homes and busy IoT environments. It offers impressive processing power and enhanced security features to safeguard your connected devices.
IPQ6010: Tailored for industrial IoT applications, the IPQ6010 chipset offers rugged performance and exceptional reliability, ensuring your critical infrastructure stays connected and operational at all times.
IPQ5018: Ideal for smaller-scale IoT deployments, the IPQ5018 provides a cost-effective yet powerful solution, making it a top choice for smart offices, retail spaces, and smart city initiatives.
IPQ8072: Designed for enterprise-level IoT setups, the IPQ8072 brings enterprise-grade security, multi-gigabit speeds, and extensive network optimization capabilities, ensuring a smooth experience even in the most demanding environments.
Seamless Smart Home Experience
With our IOT Solution’s Fast Roaming capabilities, your smart home devices will always stay connected, providing a seamless experience for home automation, smart entertainment systems, and voice-controlled assistants. Enjoy uninterrupted streaming, lightning-fast response times, and full control at your fingertips.
Uninterrupted Industrial IoT Applications
In industrial settings, uptime is crucial. Our IOT Solution with Fast Roaming ensures continuous connectivity for mission-critical applications, such as industrial automation, remote monitoring, and asset tracking. Minimize downtime, optimize productivity, and keep your operations running smoothly.
Building Smarter Cities
Cities are becoming smarter every day, and our IOT Solution is ready to power this transformation. Whether it’s smart traffic management, intelligent street lighting, or public safety applications, our Fast Roaming capabilities guarantee a connected and responsive urban landscape.
Secure Connectivity
Security is paramount in the IoT world, and our IOT Solution prioritizes it. The IPQ chipsets come equipped with robust security protocols, safeguarding your data and devices against potential threats, ensuring your peace of mind.
Experience the Future of IoT Connectivity
Step into the future of IoT connectivity with our IOT Solution, backed by the exceptional IPQ6018, IPQ6010, IPQ5018, and IPQ8072 chipsets. Embrace the power of Fast Roaming and unlock the true potential of your IoT devices. Whether at home, in the industry, or across smart cities, our solution promises to deliver an unparalleled experience.
1 DR5018
Feature:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Absolute Maximum Rating:
Supply Voltage 12 V
Storage Temperature Range -45 to +105ºC
Hardware Specifications:
CPU: Qualcomm-Atheros IPQ5018
CPU Frequency: Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory:512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port:4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot:M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
EMMC:4G/8G(optional)
USB /header:1x USB 3.0 Port
POE:NA
DC Jack:12V power supply
LED header LED for power ,Wifi strength
Serial Port support
Wireless:On-board 2x22.4GHz MU-MIMO OFDMA: 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
Bluetooth: BT5.1
Nor Flash: 8MB
Nand Flash: 128 MB
DDR: 512MB
Dimension:170mm x 120mm x 15mm
2 DR6018(CP01)
Website below:
Qualcomm-Atheros IPQ6018
1GB DDRL3L System Memory
Parameter Rating Unit
Supply Voltage 24V~48 V
Symbol Parameter
CPU Qualcomm-Atheros IPQ6018
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port, 1x USB 3.0 Type-C Port
POE 24V~48V passive POE
DC Jack 12V power supply
LED header FFC/FPC Connector
Serial Port 1x Serial Port 12 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
4x U.FL Connectors
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension (W x H x D)219mm x 150mm x 16.5mm (Without Heatsink)
Website:https://www.wallystech.com/
