The world of the Internet of Things (IoT) is continuously evolving, and with the increasing demand for seamless connectivity, the race to develop faster and more efficient WiFi solutions is on! In this post, we’ll explore two cutting-edge WiFi 6 solutions: the IPQ8072 with QCN9074 and the IPQ8074 with QCN9074, both of which promise to revolutionize the way we connect and interact with IoT devices.
IPQ8072 with QCN9074:
The IPQ8072 chipset is a powerhouse when it comes to handling high-performance networking tasks. It is specifically designed to cater to the growing demands of IoT applications, which require not only speed but also robustness and reliability. The QCN9074 is a WiFi 6 (802.11ax) radio chip that works in conjunction with the IPQ8072 to deliver ultra-fast and stable wireless connectivity.
Key Features:
Blazing Fast Speeds: WiFi 6 technology brings faster speeds, reduced latency, and improved capacity, enabling smooth data transmission even in crowded networks.
Multi-Gigabit Ethernet: IPQ8072 supports multi-gigabit Ethernet, offering lightning-fast wired connections for data-intensive applications.
Enhanced Security: The chipset implements the latest security standards to protect sensitive data and ensure a secure connection between devices.
Low Power Consumption: Despite its high performance, the IPQ8072 with QCN9074 is designed to be energy-efficient, making it ideal for power-constrained IoT devices.
IPQ8074 with QCN9074:
The IPQ8074 is a close sibling of the IPQ8072, boasting similar capabilities but with a focus on even more demanding networking scenarios. Just like the IPQ8072, it is optimized for IoT applications and seamlessly integrates with the QCN9074 WiFi 6 radio chip.
Key Features:
Superior Performance: With a more powerful processor, the IPQ8074 delivers exceptional performance, making it suitable for IoT deployments that require extensive data processing and fast response times.
Advanced QoS (Quality of Service): The IPQ8074 is equipped with advanced QoS features, ensuring optimal bandwidth allocation to different devices and services for a smooth user experience.
Intelligent Mesh Networking: The chipset supports mesh networking, allowing multiple devices to work together to create a unified network with extended coverage and improved reliability.
Edge Computing Capabilities: The IPQ8074 is designed to handle edge computing tasks efficiently, reducing the need for sending all data to the cloud and enabling faster data processing at the device level.
In conclusion, both the IPQ8072 with QCN9074 and the IPQ8074 with QCN9074 are top-of-the-line WiFi 6 solutions tailored for the ever-expanding IoT ecosystem. When choosing between them, consider the specific requirements of your IoT application, such as the scale of the deployment, processing needs, and desired network features. Whether it’s smart homes, industrial automation, healthcare, or any other IoT use case, these WiFi 6 solutions will undoubtedly play a pivotal role in shaping the future of connected devices.
1.DR8072V01
Website:
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualco…
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
NOR Flash: 8 MB
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR9074-6E(PN02.7)
Link here get more information
https://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qual…
Features
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Operating Temperature Range -20 to 70 ºC
Storage Temperature Range -40 to 90 ºC
Symbol Parameter
Chipset Qualcomm Atheros QCN9074
WLAN Host Interface PCI Express 3.0 Interface
ystem Memory 2Mbit serial I²C bus EEPROM
Standard Operating Voltage 5V
Operating Systems QSDK
Host Interface M.2 E Key
Antenna Cable / Port 4 x MMCX Connectors,4T4R
Frequency Range 5.925GHz-7.125GHz
Data Rates for WALN 6GHz, max 23dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz at 6GHz
Modulation Techniques OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification TBD
Reference Design PN02.7
Dimensions (WxHxD) 57mm x 63mm x 6mm
More detail and opportunities attach Emial :sales4@wallystech.com. This is Jane for you
