固件文件名称:null
固件下载地址:百度网盘
Log日志:rk3588_728_.zip
1.自己做的底板,用的AIO-3588JQ核心板,使用了核心板的一下接口:
①4.0v 核心板供电,正常;
②rk806 5v供电 正常;
③1路MIPI ;
④TF卡接口;
⑤部分IO口,reset \power_l \recover
⑥USB2.0;
⑦DEBUG串口;
⑧其它IO
2.上电后Linux kernel启动了一部分,就卡住了,然后就跑崩了;
3.参考的是AIO-3588JQ套件,核心板,是直接购买的,出厂镜像;
log;
DDR V1.10 75d050770f typ 23/02/28-20:47:10
LPDDR4, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
Manufacturer ID:0xff
CH0 RX Vref:36.1%, TX Vref:13.2%,0.0%
CH1 RX Vref:34.8%, TX Vref:13.2%,0.0%
CH2 RX Vref:36.1%, TX Vref:13.2%,0.0%
CH3 RX Vref:40.8%, TX Vref:13.2%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09 (Apr 15 2023 - 14:36:42)
unknown raw ID 0 0 0
Trying to boot from MMC2
mmc_init: -95, time 12
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(f2d0b9de19…) + OK
## Checking uboot 0x00200000 … sha256(77d001788b…) + OK
## Checking fdt 0x0033fcf0 … sha256(c07f4a4d71…) + OK
## Checking atf-2 0xff100000 … sha256(c0f2f7769f…) + OK
## Checking atf-3 0x000f0000 … sha256(338cd7cb83…) + OK
## Checking optee 0x08400000 … sha256(fde0860845…) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 127.673 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-555-g49f658cae:derrick.huang
NOTICE: BL31: Built : 09:45:47, Mar 3 2023
INFO: spec: 0xa
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022年 09月 20日 星期二 09:41:09 CST aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Apr 15 2023 - 14:36:42 +0800)
Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: eda37000
Relocation fdt: eb9fa9b8 - eb9fecc8
CR: M/C/I
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI,dev_type: 6
DM: v2
boot mode: recovery (misc)
boot mode: None
Android 12.0, Build 2022.7, v2
Found DTB in boot part
DTB: rk-kernel.dtb
HASH(c): OK
ANDROID: Loading dt entry to 0xebc43860 size 0x17b idx 0 from “dtbo” part
ANDROID: fdt overlay OK
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 800000 uV
vdd_cpu_big1_s0 800000 uV
I2c1 speed: 100000Hz
vdd_npu_s0 800000 uV
spi2: RK806: 2
ON=0x00, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
I2c6 speed: 400000Hz
Error reading output register
get vp0 plane mask:0x5, primary id:2, cursor_plane:-1, from dts
get vp1 plane mask:0xa, primary id:3, cursor_plane:-1, from dts
get vp2 plane mask:0x140, primary id:8, cursor_plane:-1, from dts
get vp3 plane mask:0x280, primary id:9, cursor_plane:-1, from dts
Model: Firefly AIO-3588Q HDMI(Android)
vp0 have layer nr:2[0 2 ], primary plane: 2
vp1 have layer nr:2[1 3 ], primary plane: 3
vp2 have layer nr:2[6 8 ], primary plane: 8
vp3 have layer nr:2[7 9 ], primary plane: 9
disp info 0, type:11, id:0
edid base block is 0, get edid failed
can’t get edid block:0
failed to get edid
base_parameter.mode:7680x4320
color_format:0
hdmi_select_link_config use tmds mode
mode:1920x1080 bus_format:0x100a
hdmi@fde80000: detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
VOP update mode to: 1920x1080p60, type: HDMI0 for VP0
dclk:148500,if_pixclk_div;2,if_dclk_div:4
hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
hdptx phy pll locked!
VP0 set crtc_clock to 1485KHz
VOP VP0 enable Esmart0[500x501->500x501@710x289] fmt[2] addr[0xedf20000]
CEA mode used vic=16
mtmdsclock:148500000
dw_hdmi_setup HDMI mode
don’t use dsc mode
dw hdmi qp use tmds mode
bus_width:0x16a8c8,bit_rate:1485000
hdptx phy lane locked!
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
dw-dp: Too many retries, giving up. First error: -110
failed to probe DP link: -110
aux timeout
dw-dp: transaction timed out
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
aux timeout
failed to get edid
dp@fde60000 l2 disconnected
CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 24000 KHz
lpll 24000 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 594000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth1: ethernet@fe1c0000, eth0: ethernet@fe1b0000
optee api revision: 2.0
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:762: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
get image from preloaded partition…
ANDROID: Hash OK
Could not find “system” partition
Booting IMAGE kernel at 0x00400000 with fdt at 0x08300000…
Fdt Ramdisk skip relocation
## Booting Android Image at 0x003ff800 …
Kernel: 0x00400000 - 0x02a29808 (39079 KiB)
ramdisk: 0x0a200000 - 0x0a349a20 (1319 KiB)
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
XIP Kernel Image from 0x00400000 to 0x00400000 … OK
kernel loaded at 0x00400000, end = 0x02a29808
‘reserved-memory’ cma: addr=10000000 size=8000000
‘reserved-memory’ ramoops@110000: addr=110000 size=e0000
Using Device Tree in place at 0000000008300000, end 0000000008342882
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 3428.169 ms
[ 3.944477][ T0] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 3.944498][ T0] Linux version 5.10.110 (liangyj@tchipserver19) (Android (7284624, based on r416183b) clang version 12.0.5 (https://android.googlesource.com/toolchain/llvm-project c935d99d7cf2016289302412d708641d52d2f7ee), LLD 12.0.5 (/buildbot/src/android/llvm-toolchain/out/llvm-project/lld c935d99d7cf2016289302412d708641d52d2f7ee)) #639 SMP PREEMPT Sat Apr 15 14:44:36 CST 2023
[ 3.958508][ T0] Machine model: Firefly AIO-3588Q HDMI(Android)
[ 4.000980][ T0] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 4.005959][ T0] printk: bootconsole [uart8250] enabled
[ 4.013980][ T0] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 4.015213][ T0] Reserved memory: created CMA memory pool at 0x0000000010000000, size 128 MiB
[ 4.016021][ T0] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 4.085274][ T0] Zone ranges:
[ 4.085584][ T0] DMA32 [mem 0x0000000000200000-0x00000000ffffffff]
[ 4.086223][ T0] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 4.086858][ T0] Movable zone start for each node
[ 4.087315][ T0] Early memory node ranges
[ 4.087710][ T0] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 4.088351][ T0] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 4.088991][ T0] node 0: [mem 0x00000001f0000000-0x00000001ffffffff]
[ 4.089633][ T0] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[ 4.113178][ T0] psci: probing for conduit method from DT.
[ 4.113714][ T0] psci: PSCIv1.1 detected in firmware.
[ 4.114204][ T0] psci: Using standard PSCI v0.2 function IDs
[ 4.114751][ T0] psci: Trusted OS migration not required
[ 4.115267][ T0] psci: SMC Calling Convention v1.2
[ 4.116089][ T0] percpu: Embedded 31 pages/cpu s88792 r8192 d29992 u126976
[ 4.116917][ T0] Detected VIPT I-cache on CPU0
[ 4.117381][ T0] CPU features: detected: GIC system register CPU interface
[ 4.118039][ T0] CPU features: detected: Virtualization Host Extensions
[ 4.118676][ T0] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 4.119396][ T0] alternatives: patching kernel code
[ 4.122037][ T0] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 4.122742][ T0] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.storagenode=/mmc@fe2e0000 androidboot.dtb_idx=0 androidboot.dtbo_idx=0 androidboot.verifiedbootstate=orange androidboot.serialno=d478912e38605e50 console=ttyFIQ0 firmware_class.path=/vendor/etc/firmware init=/init rootwait ro loop.max_part=7 androidboot.console=ttyFIQ0 androidboot.wificountrycode=CN androidboot.hardware=rk30board androidboot.boot_devices=fe2e0000.mmc,fe2c0000.mmc androidboot.selinux=permissive buildvariant=userdebug earlycon=uart8250,mmio32,0xfeb50000 irqchip.gicv3_pseudo_nmi=0
[ 4.128516][ T0] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 4.129500][ T0] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 4.130332][ T0] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 4.136935][ T0] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
[ 4.170086][ T0] Memory: 3853400K/4175872K available (21246K kernel code, 4262K rwdata, 12096K rodata, 1408K init, 988K bss, 191400K reserved, 131072K cma-reserved)
[ 4.171554][ T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 4.172438][ T0] rcu: Preemptible hierarchical RCU implementation.
[ 4.173037][ T0] rcu: RCU event tracing is enabled.
[ 4.173519][ T0] Trampoline variant of Tasks RCU enabled.
[ 4.174048][ T0] Tracing variant of Tasks RCU enabled.
[ 4.174554][ T0] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 4.179908][ T0] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 4.183130][ T0] GICv3: GIC: Using split EOI/Deactivate mode
[ 4.183679][ T0] GICv3: 480 SPIs implemented
[ 4.184096][ T0] GICv3: 0 Extended SPIs implemented
[ 4.184593][ T0] GICv3: Distributor has no Range Selector support
[ 4.185183][ T0] GICv3: 16 PPIs implemented
[ 4.185633][ T0] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 4.186415][ T0] ITS [mem 0xfe640000-0xfe65ffff]
[ 4.186906][ T0] ITS@0x00000000fe640000: allocated 8192 Devices @1f0110000 (indirect, esz 8, psz 64K, shr 0)
[ 4.187851][ T0] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @1f0120000 (flat, esz 2, psz 64K, shr 0)
[ 4.188868][ T0] ITS: using cache flushing for cmd queue
[ 4.189406][ T0] ITS [mem 0xfe660000-0xfe67ffff]
[ 4.189892][ T0] ITS@0x00000000fe660000: allocated 8192 Devices @1f0140000 (indirect, esz 8, psz 64K, shr 0)
[ 4.190836][ T0] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @1f0150000 (flat, esz 2, psz 64K, shr 0)
[ 4.191852][ T0] ITS: using cache flushing for cmd queue
[ 4.192583][ T0] GICv3: using LPI property table @0x00000001f0160000
[ 4.193297][ T0] GIC: using cache flushing for LPI property table
[ 4.193886][ T0] GICv3: CPU0: using allocated LPI pending table @0x00000001f0170000
[ 4.194699][ T0] kfence: initialized - using 524288 bytes for 63 objects at 0x(ptrval)-0x(ptrval)
[ 4.195755][ T0] random: get_random_bytes called from start_kernel+0x268/0x500 with crng_init=0
[ 4.324895][ T0] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 4.326336][ T0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 4.327387][ T0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 4.329404][ T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 4.330412][ T0] pid_max: default: 32768 minimum: 301
[ 4.330963][ T0] LSM: Security Framework initializing
[ 4.331476][ T0] SELinux: Initializing.
[ 4.331927][ T0] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 4.332677][ T0] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 4.335147][ T1] rcu: Hierarchical SRCU implementation.
[ 4.335963][ T1] Platform MSI: msi-controller@fe640000 domain created
[ 4.336589][ T1] Platform MSI: msi-controller@fe660000 domain created
[ 4.337558][ T1] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 4.338395][ T1] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 4.339821][ T1] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 4.341497][ T0] Detected VIPT I-cache on CPU1
[ 4.341521][ T0] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 4.341535][ T0] GICv3: CPU1: using allocated LPI pending table @0x00000001f0180000
[ 4.341573][ T0] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 4.342814][ T0] Detected VIPT I-cache on CPU2
[ 4.342834][ T0] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 4.342847][ T0] GICv3: CPU2: using allocated LPI pending table @0x00000001f0190000
[ 4.342881][ T0] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 4.344088][ T0] Detected VIPT I-cache on CPU3
[ 4.344105][ T0] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 4.344118][ T0] GICv3: CPU3: using allocated LPI pending table @0x00000001f01a0000
[ 4.344151][ T0] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 4.345348][ T0] CPU features: detected: Spectre-v4
[ 4.345351][ T0] CPU features: detected: Spectre-BHB
[ 4.345353][ T0] Detected PIPT I-cache on CPU4
[ 4.345364][ T0] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 4.345372][ T0] GICv3: CPU4: using allocated LPI pending table @0x00000001f01b0000
[ 4.345393][ T0] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 4.346548][ T0] Detected PIPT I-cache on CPU5
[ 4.346559][ T0] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 4.346567][ T0] GICv3: CPU5: using allocated LPI pending table @0x00000001f01c0000
[ 4.346588][ T0] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 4.347751][ T0] Detected PIPT I-cache on CPU6
[ 4.347762][ T0] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 4.347770][ T0] GICv3: CPU6: using allocated LPI pending table @0x00000001f01d0000
[ 4.347791][ T0] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 4.348948][ T0] Detected PIPT I-cache on CPU7
[ 4.348959][ T0] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 4.348967][ T0] GICv3: CPU7: using allocated LPI pending table @0x00000001f01e0000
[ 4.348988][ T0] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 4.349044][ T1] smp: Brought up 1 node, 8 CPUs
[ 4.368047][ T1] SMP: Total of 8 processors activated.
[ 4.368543][ T1] CPU features: detected: Privileged Access Never
[ 4.369128][ T1] CPU features: detected: LSE atomic instructions
[ 4.369702][ T1] CPU features: detected: User Access Override
[ 4.370252][ T1] CPU features: detected: 32-bit EL0 Support
[ 4.370786][ T1] CPU features: detected: Common not Private translations
[ 4.371421][ T1] CPU features: detected: RAS Extension Support
[ 4.371979][ T1] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 4.372851][ T1] CPU features: detected: CRC32 instructions
[ 4.373385][ T1] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 4.374086][ T1] CPU features: detected: RCpc load-acquire (LDAPR)
[ 4.410835][ T1] CPU: All CPU(s) started at EL2
[ 4.412935][ T1] devtmpfs: initialized
[ 4.423707][ T1] dto_overide: not find dto node
[ 4.424518][ T1] Registered cp15_barrier emulation handler
[ 4.424525][ T7] Trying to unpack rootfs image as initramfs…
[ 4.425601][ T1] Registered setend emulation handler
[ 4.426083][ T1] KASLR disabled due to lack of seed
[ 4.426613][ T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 4.427562][ T1] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 4.428312][ T1] pinctrl core: initialized pinctrl subsystem
[ 4.429188][ T1] NET: Registered protocol family 16
[ 4.430102][ T1] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 4.430855][ T1] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 4.431647][ T1] audit: initializing netlink subsys (disabled)
[ 4.432250][ T61] audit: type=2000 audit(0.099:1): state=initialized audit_enabled=0 res=1
[ 4.432665][ T1] thermal_sys: Registered thermal governor ‘fair_share’
[ 4.433027][ T1] thermal_sys: Registered thermal governor ‘step_wise’
[ 4.433643][ T1] thermal_sys: Registered thermal governor ‘user_space’
[ 4.434250][ T1] thermal_sys: Registered thermal governor ‘power_allocator’
[ 4.434973][ T1] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 4.436440][ T1] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 4.437248][ T1] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 4.438180][ T1] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 4.438987][ T1] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 4.439805][ T1] cpuidle: using governor menu
[ 4.440233][ T1] Registered FIQ tty driver
[ 4.440738][ T1] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 4.441531][ T1] ASID allocator initialised with 65536 entries
[ 4.443292][ T1] ramoops: boot-log-0 0x8000@0x0000000000110000
[ 4.443857][ T1] ramoops: dmesg-0 0x14000@0x0000000000118000
[ 4.444392][ T1] ramoops: dmesg-1 0x14000@0x000000000012c000
[ 4.444938][ T1] ramoops: console 0x80000@0x0000000000140000
[ 4.445479][ T1] ramoops: pmsg 0x30000@0x00000000001c0000
[ 4.446265][ T1] printk: console [ramoops-1] enabled
[ 4.446805][ T1] pstore: Registered ramoops as persistent store backend
[ 4.447429][ T1] ramoops: using 0xe0000@0x110000, ecc: 0
[ 4.464985][ T7] Freeing initrd memory: 1316K
[ 4.488803][ T1] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 4.489613][ T1] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 4.490402][ T1] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 4.491196][ T1] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 4.491993][ T1] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 4.492678][ T1] rockchip-pinctrl pinctrl: probed pinctrl
[ 4.504361][ T1] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 4.504922][ T1] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 4.505504][ T1] fiq_debugger_probe: could not install nmi irq handler
[[ 4.506154][ T1] printk: console [ttyFIQ0] enabled
[ 4.507047][ T1] printk: bootconsole [uart8250] disabled
[ 4.507594][ T1] Registered fiq debugger ttyFIQ0
[ 4.507875][ T1] vcc5v0_sys: supplied by vcc12v_dcin
[ 4.507961][ T1] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 4.508039][ T1] vcc5v0_usb: supplied by vcc12v_dcin
[ 4.508116][ T1] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 4.508280][ T1] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 4.508408][ T1] iommu: Default domain type: Translated
[ 4.508461][ T1] rk_iommu fdab9000.iommu: version = 2
[ 4.508741][ T1] rk_iommu fdb50800.iommu: version = 2
[ 4.508927][ T1] rk_iommu fdb60f00.iommu: version = 2
[ 4.509060][ T1] rk_iommu fdb70f00.iommu: version = 2
[ 4.509184][ T1] rk_iommu fdb90480.iommu: version = 2
[ 4.509327][ T1] rk_iommu fdba0800.iommu: version = 2
[ 4.509477][ T1] rk_iommu fdba4800.iommu: version = 2
[ 4.509621][ T1] rk_iommu fdba8800.iommu: version = 2
[ 4.509766][ T1] rk_iommu fdbac800.iommu: version = 2
[ 4.509909][ T1] rk_iommu fdbb0800.iommu: version = 2
[ 4.510052][ T1] rk_iommu fdbdf000.iommu: version = 2
[ 4.510251][ T1] rk_iommu fdbef000.iommu: version = 2
[ 4.510471][ T1] rk_iommu fdc38700.iommu: version = 2
[ 4.510700][ T1] rk_iommu fdc48700.iommu: version = 2
[ 4.510859][ T1] rk_iommu fdce0800.iommu: version = 2
[ 4.510943][ T1] rk_iommu fdd97e00.iommu: version = 2
[ 4.511169][ T1] SCSI subsystem initialized
[ 4.511231][ T1] usbcore: registered new interface driver usbfs
[ 4.511243][ T1] usbcore: registered new interface driver hub
[ 4.511257][ T1] usbcore: registered new device driver usb
[ 4.511360][ T1] mc: Linux media interface: v0.10
[ 4.511369][ T1] videodev: Linux video capture interface: v2.00
[ 4.511387][ T1] pps_core: LinuxPPS API ver. 1 registered
[ 4.511390][ T1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.511396][ T1] PTP clock support registered
[ 4.511575][ T1] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 4.511603][ T1] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 4.512384][ T1] Advanced Linux Sound Architecture Driver Initialized.
[ 4.512537][ T1] Bluetooth: Core ver 2.22
[ 4.512548][ T1] NET: Registered protocol family 31
[ 4.512551][ T1] Bluetooth: HCI device and connection manager initialized
[ 4.512556][ T1] Bluetooth: HCI socket layer initialized
[ 4.512560][ T1] Bluetooth: L2CAP socket layer initialized
[ 4.512567][ T1] Bluetooth: SCO socket layer initialized
[ 4.513800][ T1] rockchip-cpuinfo cpuinfo: SoC : 35881000
[ 4.513805][ T1] rockchip-cpuinfo cpuinfo: Serial : d478912e38605e50
[ 4.514040][ T1] clocksource: Switched to clocksource arch_sys_counter
[ 4.817381][ T1] VFS: Disk quotas dquot_6.6.0
[ 4.817412][ T1] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 4.818148][ T1] NET: Registered protocol family 2
[ 4.818265][ T1] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 4.819228][ T1] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 4.819289][ T1] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 4.819450][ T1] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 4.819770][ T1] TCP: Hash tables configured (established 32768 bind 32768)
[ 4.819811][ T1] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 4.819875][ T1] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 4.819969][ T1] NET: Registered protocol family 1
[ 4.820160][ T1] RPC: Registered named UNIX socket transport module.
[ 4.820167][ T1] RPC: Registered udp transport module.
[ 4.820169][ T1] RPC: Registered tcp transport module.
[ 4.820172][ T1] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 4.820406][ T1] PCI: CLS 0 bytes, default 64
[ 4.821145][ T1] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 4.822704][ T1] Initialise system trusted keyrings
[ 4.822755][ T1] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 4.824193][ T1] NFS: Registering the id_resolver key type
[ 4.824205][ T1] Key type id_resolver registered
[ 4.824208][ T1] Key type id_legacy registered
[ 4.824230][ T1] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 4.824236][ T1] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 4.824314][ T1] utf8_selftest: All 154 tests passed
[ 4.824544][ T1] Key type cifs.idmap registered
[ 4.824550][ T1] ntfs: driver 2.1.32 [Flags: R/W].
[ 4.824586][ T1] fuse: init (API version 7.32)
[ 4.844452][ T1] Key type asymmetric registered
[ 4.844458][ T1] Asymmetric key parser ‘x509’ registered
[ 4.844471][ T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 4.844475][ T1] io scheduler mq-deadline registered
[ 4.844481][ T1] io scheduler kyber registered
[ 4.844510][ T1] io scheduler bfq registered
[ 4.844865][ T1] rockchip-csi2-dphy-hw fedc0000.csi2-dphy0-hw: csi2 dphy hw probe successfully!
[ 4.845043][ T1] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 4.845754][ T1] input: fd5d0000.syscon:usb2-phy@0 as /devices/platform/fd5d0000.syscon/fd5d0000.syscon:usb2-phy@0/input/input0
[ 4.846767][ T1] input: fd5d8000.syscon:usb2-phy@8000 as /devices/platform/fd5d8000.syscon/fd5d8000.syscon:usb2-phy@8000/input/input1
[ 4.847037][ T1] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 4.847179][ T1] input: fd5dc000.syscon:usb2-phy@c000 as /devices/platform/fd5dc000.syscon/fd5dc000.syscon:usb2-phy@c000/input/input2
[ 4.847436][ T1] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 4.847695][ T1] input: fd5d4000.syscon:usb2-phy@4000 as /devices/platform/fd5d4000.syscon/fd5d4000.syscon:usb2-phy@4000/input/input3
[ 4.848058][ T1] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 4.850131][ T1] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
[ 4.851056][ T1] Firefly gpio driver init!
[ 4.851125][ T1] Firefly gpio driver register return : 0
[ 4.852081][ T148] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node
[ 4.852168][ T149] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 4.852190][ T149] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
[ 4.852358][ T1] iep: Module initialized.
[ 4.852412][ T1] mpp_service mpp-srv: 8d40432f8b5 author: Firefly 2022-10-21 [kernel-5.10] video: rockchip: mpp: Fix mmu sharing on multi device
[ 4.852416][ T1] mpp_service mpp-srv: probe start
[ 4.852512][ T149] rk-pcie fe170000.pcie: missing legacy IRQ resource
[ 4.852532][ T149] rk-pcie fe170000.pcie: IRQ msi not found
[ 4.852540][ T149] rk-pcie fe170000.pcie: use outband MSI support
[ 4.852549][ T149] rk-pcie fe170000.pcie: Missing config reg space
[ 4.852563][ T149] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 4.852583][ T149] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 4.852599][ T149] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 4.852615][ T149] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 4.852629][ T149] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 4.852656][ T149] rk-pcie fe170000.pcie: Missing config reg space
[ 4.852684][ T149] rk-pcie fe170000.pcie: invalid resource
[ 4.853587][ T1] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 4.853788][ T1] mpp_vdpu2 fdb50400.vdpu: probe device
[ 4.853873][ T1] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 4.853879][ T1] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 4.853976][ T1] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 4.854145][ T1] mpp_vepu2 jpege-ccu: probing start
[ 4.854150][ T1] mpp_vepu2 jpege-ccu: probing finish
[ 4.854219][ T1] mpp_vepu2 fdb50000.vepu: Adding to iommu group 1
[ 4.854294][ T1] mpp_vepu2 fdb50000.vepu: probing start
[ 4.854357][ T1] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0
[ 4.854361][ T1] mpp_vepu2 fdb50000.vepu: reset_group->rw_sem_on=0
[ 4.854455][ T1] mpp_vepu2 fdb50000.vepu: probing finish
[ 4.854544][ T1] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 4.854668][ T1] mpp_vepu2 fdba0000.jpege-core: probing start
[ 4.854746][ T1] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 4.854836][ T1] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 4.854917][ T1] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 4.855041][ T1] mpp_vepu2 fdba4000.jpege-core: probing start
[ 4.855110][ T1] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 4.855199][ T1] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 4.855280][ T1] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 4.855406][ T1] mpp_vepu2 fdba8000.jpege-core: probing start
[ 4.855482][ T1] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 4.855559][ T1] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 4.855638][ T1] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 4.855766][ T1] mpp_vepu2 fdbac000.jpege-core: probing start
[ 4.855836][ T1] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 4.855918][ T1] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 4.856130][ T1] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 4.856254][ T1] mpp-iep2 fdbb0000.iep: probe device
[ 4.856343][ T1] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 4.856427][ T1] mpp-iep2 fdbb0000.iep: probing finish
[ 4.856591][ T1] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 4.856782][ T1] mpp_jpgdec fdb90000.jpegd: probe device
[ 4.856948][ T1] mpp_jpgdec fdb90000.jpegd: probing finish
[ 4.857227][ T1] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 4.857269][ T1] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 4.857337][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 4.857608][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
[ 4.857693][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 4.857697][ T1] rkvdec2_init:1008: No niu aclk reset resource define
[ 4.857701][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 4.857704][ T1] rkvdec2_init:1011: No niu hclk reset resource define
[ 4.857717][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled
[ 4.857761][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
[ 4.857764][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
[ 4.857968][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
[ 4.857973][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
[ 4.857976][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
[ 4.857980][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
[ 4.857984][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
[ 4.858007][ T1] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
[ 4.858064][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
[ 4.858269][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
[ 4.858351][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 4.858354][ T1] rkvdec2_init:1008: No niu aclk reset resource define
[ 4.858359][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 4.858361][ T1] rkvdec2_init:1011: No niu hclk reset resource define
[ 4.858374][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled
[ 4.858405][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
[ 4.858421][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
[ 4.858651][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
[ 4.858655][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
[ 4.858659][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
[ 4.858663][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
[ 4.858667][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
[ 4.858691][ T1] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
[ 4.858846][ T1] mpp_rkvenc2 rkvenc-ccu: probing start
[ 4.858850][ T1] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 4.858930][ T1] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
[ 4.859094][ T1] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 4.859107][ T1] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
[ 4.859211][ T1] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 4.859314][ T1] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 4.859357][ T1] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
[ 4.859569][ T1] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 4.859582][ T1] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
[ 4.859704][ T1] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 4.859790][ T1] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 4.860192][ T1] mpp_av1dec: Adding child /av1d@fdc70000
[ 4.860243][ T1] mpp_av1dec: register device av1d-master
[ 4.860266][ T1] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
[ 4.860281][ T1] av1_iommu_probe_device,737, consumer : av1d-master, supplier : fdca0000.iommu
[ 4.860305][ T1] mpp_av1dec av1d-master: Adding to iommu group 16
[ 4.860537][ T1] mpp_av1dec av1d-master: probing start
[ 4.860711][ T1] mpp_av1dec av1d-master: probing finish
[ 4.860736][ T1] mpp_service mpp-srv: probe success
[ 4.867963][ T1] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.867970][ T1] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.868613][ T1] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.868620][ T1] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.869266][ T1] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.869272][ T1] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.869529][ T1] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 4.869572][ T1] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 4.869609][ T1] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 4.869649][ T1] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 4.869684][ T1] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 4.870043][ T1] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 4.870820][ T1] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 4.871166][ T1] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 28, base_baud = 1500000) is a 16550A
[ 4.871440][ T1] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 92, base_baud = 1500000) is a 16550A
[ 4.871618][ T1] feb80000.serial: ttyS5 at MMIO 0xfeb80000 (irq = 93, base_baud = 1500000) is a 16550A
[ 4.871858][ T1] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 94, base_baud = 1500000) is a 16550A
[ 4.872321][ T173] random: fast init done
[ 4.872372][ T173] random: crng init done
[ 4.873191][ T1] rockchip-vop2 fdd90000.vop: Adding to iommu group 15
[ 5.058512][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.084055][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.110713][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.137378][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.164043][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.190711][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.217377][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.244044][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.270710][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 5.297376][ T149] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 7.724042][ T149] rk-pcie fe170000.pcie: PCIe Link Fail
[ 7.724050][ T149] rk-pcie fe170000.pcie: failed to initialize host
[ 20.347372][ C3] ------------[ cut here ]------------
[ 20.347389][ C3] Watchdog detected hard LOCKUP on cpu 4
[ 20.347418][ C3] WARNING: CPU: 3 PID: 0 at kernel/watchdog.c:418 watchdog_timer_fn+0x168/0x3c8
[ 20.347433][ C3] Modules linked in:
[ 20.347450][ C3] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.10.110 #639
[ 20.347458][ C3] Hardware name: Firefly AIO-3588Q HDMI(Android) (DT)
[ 20.347470][ C3] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=–)
[ 20.347481][ C3] pc : watchdog_timer_fn+0x168/0x3c8
[ 20.347492][ C3] lr : watchdog_timer_fn+0x158/0x3c8
[ 20.347500][ C3] sp : ffffffc012753e20
[ 20.347509][ C3] x29: ffffffc012753e30 x28: ffffffc0121d38d8
[ 20.347523][ C3] x27: 0000000000000004 x26: ffffffc0121d3840
[ 20.347537][ C3] x25: ffffffc01220a000 x24: 000000000000000b
[ 20.347551][ C3] x23: ffffffc0121d3830 x22: 0000000000000000
[ 20.347564][ C3] x21: ffffffc01220a5a8 x20: ffffff81fb56d850
[ 20.347578][ C3] x19: ffffffc012953da0 x18: ffffffc01273d038
[ 20.347591][ C3] x17: 0000000000000000 x16: 0000000000000118
[ 20.347605][ C3] x15: 0000000000000004 x14: 0000000000003fff
[ 20.347618][ C3] x13: ffffffc01228ccf0 x12: 0000000000000003
[ 20.347631][ C3] x11: 00000000ffffbfff x10: 00000000ffffffff
[ 20.347645][ C3] x9 : 4d4eac75e9b0c300 x8 : 4d4eac75e9b0c300
[ 20.347658][ C3] x7 : 554b434f4c206472 x6 : ffffffc012638eb6
[ 20.347671][ C3] x5 : ffffffffffffffff x4 : 0000000000000000
[ 20.347684][ C3] x3 : ffffffc011eec419 x2 : 0000000000000000
[ 20.347697][ C3] x1 : 0000000000000000 x0 : ffffffc0126b8780
[ 20.347710][ C3] Call trace:
[ 20.347723][ C3] watchdog_timer_fn+0x168/0x3c8
[ 20.347735][ C3] __run_hrtimer+0xa8/0x2a8
[ 20.347745][ C3] hrtimer_interrupt+0x174/0x3fc
[ 20.347757][ C3] arch_timer_handler_phys+0x40/0x54
[ 20.347768][ C3] handle_percpu_devid_irq+0x88/0x280
[ 20.347780][ C3] __handle_domain_irq+0x80/0xd0
[ 20.347793][ C3] gic_handle_irq+0x78/0x154
[ 20.347804][ C3] el1_irq+0xe4/0x1c0
[ 20.347817][ C3] arch_cpu_idle+0x1c/0x40
[ 20.347827][ C3] default_idle_call+0x3c/0x194
[ 20.347839][ C3] cpuidle_idle_call+0x64/0x238
[ 20.347850][ C3] do_idle+0xac/0xfc
[ 20.347861][ C3] cpu_startup_entry+0x28/0x2c
[ 20.347873][ C3] secondary_start_kernel+0x1b4/0x274
[ 20.347882][ C3]
[ 20.347882][ C3] PC: 0xffffffc0101523dc:
[ 20.347890][ C3] 21dc a9034ff4 910003fd aa0003f7 f0011520 91172000 aa0403f3 aa0303f4 aa0203f5
[ 20.347923][ C3] 21fc 2a0103f6 944d4906 aa1703e0 2a1603e1 aa1503e2 aa1403e3 aa1303e4 97fc18ff
[ 20.347954][ C3] 221c 2a0003f3 34000156 35000133 f00105a8 f00105a9 b94fe10a b94dd129 0a090149
[ 20.347985][ C3] 223c 92401d29 f907f109 94000112 f0011520 91172000 944d4915 2a1303e0 a9434ff4
[ 20.348015][ C3] 225c a94257f6 f9400bf7 a8c47bfd f85f8e5e d50323bf d65f03c0 d503233f d101c3ff
[ 20.348045][ C3] 227c f800865e a9017bfd a9026ffc a90367fa a9045ff8 a90557f6 a9064ff4 910043fd
[ 20.348076][ C3] 229c b000eee8 f9427908 900105d9 f90007e8 d53cd048 f9400729 b4000669 b001041a
[ 20.348106][ C3] 22bc 9121035a b0010417 f0010449 f87a690c 9120c2f7 9136e129 900105ca b201f3eb
[ 20.348136][ C3] 22dc f8776918 f8696913 b9401956 f295556b 9b0b7d89 b200f3ea aa0003f4 eb0a013f
[ 20.348166][ C3] 22fc 54000868 b00103c9 91002129 f00105aa b8696915 f947f94a 910003e1 2a1503e0
[ 20.348196][ C3] 231c f90003ea 94169465 f00105bb b94f8b68 6b08001f 540000c3 910003e0 52800101
[ 20.348226][ C3] 233c aa1f03e2 94159a85 b94f8b68 6b15001f 1a800101 6b08003f 540005a2 900105d5
[ 20.348256][ C3] 235c d50339bf 9116a2b5 f8615aa8 b0010409 9120a129 3869690a 340000aa 3828693f
[ 20.348287][ C3] 237c 14000023 2a1f03e0 1400008a b001040a 9121214a f87a6909 f86a690b 2a0103fb
[ 20.348317][ C3] 239c eb09017f 540002a1 b001041c 9123639c 387c6908 350002c8 f00105a8 b94fe908
[ 20.348347][ C3] 23bc 35001228 b000ec60 91255400 97fbdf47 d0012b20 911e0000 aa1f03e1 aa1f03e2
[ 20.348377][ C3] 23dc* d4210000 97fcb563 f87b7aa8 52800029 383c6909 14000006 f87b7aab f8286949
[ 20.348407][ C3] 23fc b0010408 91236108 3828697f d53cd048 f87a6909 b0010415 912242b5 91000529
[ 20.348437][ C3] 241c f83a6909 d53cd048 8b150100 97fd6846 360001c0 b00103c9 d53cd048 b835691f
[ 20.348467][ C3] 243c 91002129 d53cd048 b8696900 b0010409 9122c129 90000001 8b090103 9118f021
[ 20.348497][ C3] 245c aa1f03e2 97ffbd7b f9401a88 900105c9 f9401135 f9401908 d63f0100 aa0003e1
[ 20.348527][ C3] 247c aa1403e0 aa1503e2 97feabce b100071f 540007c0 97fd0e05 39402329 aa0003e8
[ 20.348557][ C3] 249c 52800020 36080869 f00105a9 b94fdd29 34000809 d35efd08 531f7929 cb08030a
[ 20.348588][ C3] 24bc ab29c15f 54000745 6b180114 54000700 34000176 d0012b28 f943cd08 37000688
[ 20.348618][ C3] 24dc d503201f d503201f d0012b29 52800028 911e6129 f8a83128 370005a8 97fd0deb
[ 20.348648][ C3] 24fc d35efc09 d53cd048 f8376909 b00103c9 91002129 d53cd048 d538410a b8696901
[ 20.348678][ C3] 251c b9455144 f000e420 911c6143 910a8c00 2a1403e2 944d2ef9 97ff3879 b40005f3
[ 20.348708][ C3] 253c aa1303e0 97fae056 340000f6 d503201f d503201f d0012b28 52800029 911e6108
[ 20.348738][ C3] 255c f8691109 528001c0 2a1f03e1 97fbddbb f00105a8 b94ff908 340001a8 d000e8a0
[ 20.348768][ C3] 257c 9112dc00 944d2dfc b0010409 9120e129 d53cd048 3869690a 350002aa 97fd0dc3
[ 20.348798][ C3] 259c d35efc09 d53cd048 f8376909 52800020 b000eee9 f94007e8 f9427929 eb08013f
[ 20.348828][ C3] 25bc 540001a1 a9417bfd a9464ff4 a94557f6 a9445ff8 a94367fa a9426ffc f85f8e5e
[ 20.348859][ C3]
[ 20.348859][ C3] LR: 0xffffffc0101523cc:
[ 20.348866][ C3] 21cc f800865e a9bc7bfd f9000bf7 a90257f6 a9034ff4 910003fd aa0003f7 f0011520
[ 20.348897][ C3] 21ec 91172000 aa0403f3 aa0303f4 aa0203f5 2a0103f6 944d4906 aa1703e0 2a1603e1
[ 20.348926][ C3] 220c aa1503e2 aa1403e3 aa1303e4 97fc18ff 2a0003f3 34000156 35000133 f00105a8
[ 20.348956][ C3] 222c f00105a9 b94fe10a b94dd129 0a090149 92401d29 f907f109 94000112 f0011520
[ 20.348987][ C3] 224c 91172000 944d4915 2a1303e0 a9434ff4 a94257f6 f9400bf7 a8c47bfd f85f8e5e
[ 20.349017][ C3] 226c d50323bf d65f03c0 d503233f d101c3ff f800865e a9017bfd a9026ffc a90367fa
[ 20.349046][ C3] 228c a9045ff8 a90557f6 a9064ff4 910043fd b000eee8 f9427908 900105d9 f90007e8
[ 20.349076][ C3] 22ac d53cd048 f9400729 b4000669 b001041a 9121035a b0010417 f0010449 f87a690c
[ 20.349106][ C3] 22cc 9120c2f7 9136e129 900105ca b201f3eb f8776918 f8696913 b9401956 f295556b
[ 20.349136][ C3] 22ec 9b0b7d89 b200f3ea aa0003f4 eb0a013f 54000868 b00103c9 91002129 f00105aa
[ 20.349166][ C3] 230c b8696915 f947f94a 910003e1 2a1503e0 f90003ea 94169465 f00105bb b94f8b68
[ 20.349197][ C3] 232c 6b08001f 540000c3 910003e0 52800101 aa1f03e2 94159a85 b94f8b68 6b15001f
[ 20.349227][ C3] 234c 1a800101 6b08003f 540005a2 900105d5 d50339bf 9116a2b5 f8615aa8 b0010409
[ 20.349257][ C3] 236c 9120a129 3869690a 340000aa 3828693f 14000023 2a1f03e0 1400008a b001040a
[ 20.349287][ C3] 238c 9121214a f87a6909 f86a690b 2a0103fb eb09017f 540002a1 b001041c 9123639c
[ 20.349317][ C3] 23ac 387c6908 350002c8 f00105a8 b94fe908 35001228 b000ec60 91255400 97fbdf47
[ 20.349347][ C3] 23cc* d0012b20 911e0000 aa1f03e1 aa1f03e2 d4210000 97fcb563 f87b7aa8 52800029
[ 20.349377][ C3] 23ec 383c6909 14000006 f87b7aab f8286949 b0010408 91236108 3828697f d53cd048
[ 20.349407][ C3] 240c f87a6909 b0010415 912242b5 91000529 f83a6909 d53cd048 8b150100 97fd6846
[ 20.349437][ C3] 242c 360001c0 b00103c9 d53cd048 b835691f 91002129 d53cd048 b8696900 b0010409
[ 20.349467][ C3] 244c 9122c129 90000001 8b090103 9118f021 aa1f03e2 97ffbd7b f9401a88 900105c9
[ 20.349496][ C3] 246c f9401135 f9401908 d63f0100 aa0003e1 aa1403e0 aa1503e2 97feabce b100071f
[ 20.349526][ C3] 248c 540007c0 97fd0e05 39402329 aa0003e8 52800020 36080869 f00105a9 b94fdd29
[ 20.349556][ C3] 24ac 34000809 d35efd08 531f7929 cb08030a ab29c15f 54000745 6b180114 54000700
[ 20.349586][ C3] 24cc 34000176 d0012b28 f943cd08 37000688 d503201f d503201f d0012b29 52800028
[ 20.349616][ C3] 24ec 911e6129 f8a83128 370005a8 97fd0deb d35efc09 d53cd048 f8376909 b00103c9
[ 20.349646][ C3] 250c 91002129 d53cd048 d538410a b8696901 b9455144 f000e420 911c6143 910a8c00
[ 20.349676][ C3] 252c 2a1403e2 944d2ef9 97ff3879 b40005f3 aa1303e0 97fae056 340000f6 d503201f
[ 20.349706][ C3] 254c d503201f d0012b28 52800029 911e6108 f8691109 528001c0 2a1f03e1 97fbddbb
[ 20.349736][ C3] 256c f00105a8 b94ff908 340001a8 d000e8a0 9112dc00 944d2dfc b0010409 9120e129
[ 20.349766][ C3] 258c d53cd048 3869690a 350002aa 97fd0dc3 d35efc09 d53cd048 f8376909 52800020
[ 20.349796][ C3] 25ac b000eee9 f94007e8 f9427929 eb08013f 540001a1 a9417bfd a9464ff4 a94557f6
[ 20.349827][ C3]
[ 20.349827][ C3] SP: 0xffffffc012753e20:
[ 20.349835][ C3] 3c20 12753cd0 ffffffc0 100c6f3c ffffffc0 12753c50 ffffffc0 100336c0 ffffffc0
[ 20.349865][ C3] 3c40 f2000800 00000000 00000000 00000000 12753c90 ffffffc0 114a0018 ffffffc0
[ 20.349895][ C3] 3c60 0000000b 00000000 60400089 00000000 101523dc ffffffc0 00010400 faefd9cf
[ 20.349925][ C3] 3c80 12753cd0 ffffffc0 f2000800 00000000 12753cc0 ffffffc0 1149fd18 ffffffc0
[ 20.349955][ C3] 3ca0 12753e20 ffffffc0 100c9c80 ffffffc0 ffffffff 0000007f 12953da0 ffffffc0
[ 20.349985][ C3] 3cc0 12753e00 ffffffc0 1000244c ffffffc0 126b8780 ffffffc0 00000000 00000000
[ 20.350015][ C3] 3ce0 00000000 00000000 11eec419 ffffffc0 00000000 00000000 ffffffff ffffffff
[ 20.350046][ C3] 3d00 12638eb6 ffffffc0 4c206472 554b434f e9b0c300 4d4eac75 e9b0c300 4d4eac75
[ 20.350076][ C3] 3d20 ffffffff 00000000 ffffbfff 00000000 00000003 00000000 1228ccf0 ffffffc0
[ 20.350105][ C3] 3d40 00003fff 00000000 00000004 00000000 00000118 00000000 00000000 00000000
[ 20.350135][ C3] 3d60 1273d038 ffffffc0 12953da0 ffffffc0 fb56d850 ffffff81 1220a5a8 ffffffc0
[ 20.350165][ C3] 3d80 00000000 00000000 121d3830 ffffffc0 0000000b 00000000 1220a000 ffffffc0
[ 20.350196][ C3] 3da0 121d3840 ffffffc0 00000004 00000000 121d38d8 ffffffc0 12753e30 ffffffc0
[ 20.350226][ C3] 3dc0 101523cc ffffffc0 12753e20 ffffffc0 101523dc ffffffc0 60400089 00000000
[ 20.350256][ C3] 3de0 12753db8 ffffffc0 fb5796c0 ffffff81 ffffffff 0000007f e9b0c300 4d4eac75
[ 20.350286][ C3] 3e00 12753e30 ffffffc0 101523dc ffffffc0 00000000 00000000 10152324 ffffffc0
[ 20.350316][ C3] 3e20* 000000ff 00000000 e9b0c300 4d4eac75 12753e90 ffffffc0 100ff6ec ffffffc0
[ 20.350345][ C3] 3e40 00000001 00000000 fb56d1c0 ffffff81 baaaf1fb 00000003 fb56d18c ffffff81
[ 20.350375][ C3] 3e60 10152274 ffffffc0 00000080 00000000 12753ef0 ffffffc0 fb56d180 ffffff81
[ 20.350405][ C3] 3e80 fb56d850 ffffff81 fb56d1c0 ffffff81 12753f00 ffffffc0 100fe358 ffffffc0
[ 20.350436][ C3] 3ea0 00000080 00000000 fb56d1e8 ffffff81 00000000 00000000 00000000 00000000
[ 20.350465][ C3] 3ec0 00000001 00000000 fb56d180 ffffff81 baaaf1fb 00000003 fb56d2b8 ffffff81
[ 20.350495][ C3] 3ee0 fb56d278 ffffff81 fb56d238 ffffff81 baaaf1fb 00000003 e9b0c300 4d4eac75
[ 20.350525][ C3] 3f00 12753f60 ffffffc0 10f15f70 ffffffc0 f0368ec0 ffffff81 00000000 00000000
[ 20.350555][ C3] 3f20 e939a000 ffffffc1 12750000 ffffffc0 127fd030 ffffffc0 60800009 00000000
[ 20.350585][ C3] 3f40 124938f0 ffffffc0 f02a0480 ffffff81 0000000d 00000000 f0292400 ffffff81
[ 20.350615][ C3] 3f60 12753f70 ffffffc0 100d30fc ffffffc0 12753fb0 ffffffc0 100cbc70 ffffffc0
[ 20.350646][ C3] 3f80 127fd030 ffffffc0 60800009 00000000 114a0bf0 ffffffc0 00000000 00000000
[ 20.350675][ C3] 3fa0 121dddb8 ffffffc0 f0292400 ffffff81 12753fe0 ffffffc0 107150a0 ffffffc0
[ 20.350703][ C7] ------------[ cut here ]------------
[ 20.350708][ C7] Watchdog detected hard LOCKUP on cpu 0
[ 20.350712][ C3] 3fc0
[ 20.350724][ C7] WARNING: CPU: 7 PID: 0 at kernel/watchdog.c:418 watchdog_timer_fn+0x168/0x3c8
[ 20.350728][ C7] Modules linked in:
[ 20.350734][ C3] 12953ef0 ffffffc0
[ 20.350739][ C7]
[ 20.350741][ C3] 00000000 00000000 12953da0 ffffffc0
[ 20.350753][ C7] CPU: 7 PID: 0 Comm: swapper/7 Not tainted 5.10.110 #639
[ 20.350757][ C7] Hardware name: Firefly AIO-3588Q HDMI(Android) (DT)
[ 20.350762][ C3] 0000001a 00000000
[ 20.350768][ C7] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=–)
[ 20.350771][ C3]
[ 20.350774][ C3] 3fe0 12953ed0 ffffffc0
[ 20.350783][ C7] pc : watchdog_timer_fn+0x168/0x3c8
[ 20.350785][ C3] 100025e4 ffffffc0 ffffffff
[ 20.350794][ C7] lr : watchdog_timer_fn+0x158/0x3c8
[ 20.350797][ C3] 0000007f 12953da0 ffffffc0
[ 20.350804][ C7] sp : ffffffc012773e20
[ 20.350806][ C3]
[ 20.350809][ C3] 4000
[ 20.350816][ C7] x29: ffffffc012773e30
[ 20.350818][ C3] ******** ******** ********
[ 20.350826][ C7] x28: ffffffc0121d38d8
[ 20.350828][ C3] ******** ******** ********
[ 20.350835][ C7]
[ 20.350838][ C3] ******** ********
[ 20.350843][ C7] x27: 0000000000000000
[ 20.350845][ C3]
[ 20.350849][ C3]
[ 20.350849][ C3] X0: 0xffffffc0126b8780:
[ 20.350852][ C3] 8580 126b8578 ffffffc0
[ 20.350859][ C7] x26: ffffffc0121d3840
[ 20.350861][ C3] 126b8588 ffffffc0 126b8588
[ 20.350868][ C7]
[ 20.350870][ C3] ffffffc0 126b8598 ffffffc0
[ 20.350878][ C7] x25: ffffffc01220a000
[ 20.350879][ C3]
[ 20.350882][ C3] 85a0 126b8598 ffffffc0
[ 20.350889][ C7] x24: 000000000000000b
[ 20.350891][ C3] 126b85a8 ffffffc0 126b85a8
[ 20.350898][ C7]
[ 20.350900][ C3] ffffffc0 126b85b8 ffffffc0
[ 20.350907][ C7] x23: ffffffc0121d3830
[ 20.350908][ C3]
[ 20.350911][ C3] 85c0 126b85b8 ffffffc0
[ 20.350918][ C7] x22: 0000000000000000
[ 20.350920][ C3] 126b85c8 ffffffc0 126b85c8
[ 20.350927][ C7]
[ 20.350929][ C3] ffffffc0 126b85d8 ffffffc0
[ 20.350936][ C7] x21: ffffffc01220a5a8
[ 20.350937][ C3]
[ 20.350940][ C3] 85e0 126b85d8 ffffffc0
[ 20.350948][ C7] x20: ffffff81fb5e9850
[ 20.350950][ C3] 126b85e8 ffffffc0 126b85e8
[ 20.350956][ C7]
[ 20.350958][ C3] ffffffc0 126b85f8 ffffffc0
[ 20.350965][ C7] x19: ffffffc012973da0
[ 20.350967][ C3]
[ 20.350970][ C3] 8600 126b85f8 ffffffc0
[ 20.350977][ C7] x18: ffffffc01275d038
[ 20.350979][ C3] 126b8608 ffffffc0 126b8608
[ 20.350986][ C7]
[ 20.350988][ C3] ffffffc0 126b8618 ffffffc0
[ 20.350995][ C7] x17: 0000000000000000
[ 20.350997][ C3]
[ 20.351000][ C3] 8620 126b8618 ffffffc0
[ 20.351007][ C7] x16: 0000000000000118
[ 20.351009][ C3] 126b8628 ffffffc0 126b8628
[ 20.351016][ C7]
[ 20.351018][ C3] ffffffc0 126b8638 ffffffc0
[ 20.351025][ C7] x15: 80000000ffffc21a
[ 20.351027][ C3]
[ 20.351030][ C3] 8640 126b8638 ffffffc0
[ 20.351037][ C7] x14: 0000000000000003
[ 20.351039][ C3] 126b8648 ffffffc0 126b8648
[ 20.351045][ C7]
[ 20.351048][ C3] ffffffc0 126b8658 ffffffc0
[ 20.351054][ C7] x13: 0000000000000002
[ 20.351056][ C3]
[ 20.351059][ C3] 8660 126b8658 ffffffc0
[ 20.351066][ C7] x12: 000000000000021a
[ 20.351068][ C3] 126b8668 ffffffc0 126b8668
[ 20.351075][ C7]
[ 20.351077][ C3] ffffffc0 126b8678 ffffffc0
[ 20.351084][ C7] x11: ffffffc01228cd08
[ 20.351085][ C3]
[ 20.351088][ C3] 8680 126b8678 ffffffc0
[ 20.351095][ C7] x10: 00000000ffffffff
[ 20.351097][ C3] 126b8688 ffffffc0 126b8688
[ 20.351104][ C7]
[ 20.351106][ C3] ffffffc0 126b8698 ffffffc0
[ 20.351113][ C7] x9 : 4d4eac75e9b0c300
[ 20.351115][ C3]
[ 20.351118][ C3] 86a0 126b8698 ffffffc0
[ 20.351125][ C7] x8 : 4d4eac75e9b0c300
[ 20.351127][ C3] 126b86a8 ffffffc0 126b86a8
[ 20.351134][ C7]
[ 20.351136][ C3] ffffffc0 126b86b8 ffffffc0
[ 20.351143][ C7] x7 : 554b434f4c206472
[ 20.351144][ C3]
[ 20.351147][ C3] 86c0 126b86b8 ffffffc0
[ 20.351154][ C7] x6 : ffffffc01263b6b6
[ 20.351156][ C3] 126b86c8 ffffffc0 126b86c8
[ 20.351163][ C7]
[ 20.351165][ C3] ffffffc0 126b86d8 ffffffc0
[ 20.351172][ C7] x5 : ffffffffffffffff
[ 20.351174][ C3]
[ 20.351177][ C3] 86e0 126b86d8 ffffffc0
[ 20.351184][ C7] x4 : 0000000000000000
[ 20.351186][ C3] 126b86e8 ffffffc0 126b86e8
[ 20.351193][ C7]
[ 20.351196][ C3] ffffffc0 126b86f8 ffffffc0
[ 20.351202][ C7] x3 : ffffffc011eec419
[ 20.351204][ C3]
[ 20.351207][ C3] 8700 126b86f8 ffffffc0
[ 20.351214][ C7] x2 : 0000000000000000
[ 20.351216][ C3] 126b8708 ffffffc0 126b8708
[ 20.351222][ C7]
[ 20.351224][ C3] ffffffc0 126b8718 ffffffc0
[ 20.351231][ C7] x1 : 0000000000000000
[ 20.351233][ C3]
[ 20.351236][ C3] 8720 126b8718 ffffffc0
[ 20.351243][ C7] x0 : ffffffc0126b8780
[ 20.351245][ C3] 126b8728 ffffffc0 126b8728
[ 20.351252][ C7]
[ 20.351254][ C3] ffffffc0 126b8738 ffffffc0
[ 20.351261][ C7] Call trace:
[ 20.351263][ C3]
[ 20.351266][ C3] 8740 126b8738 ffffffc0
[ 20.351275][ C7] watchdog_timer_fn+0x168/0x3c8
[ 20.351278][ C3] 126b8748 ffffffc0 126b8748
[ 20.351287][ C7] __run_hrtimer+0xa8/0x2a8
[ 20.351289][ C3] ffffffc0 126b8758 ffffffc0
[ 20.351297][ C7] hrtimer_interrupt+0x174/0x3fc
[ 20.351299][ C3]
[ 20.351302][ C3] 8760 126b8758 ffffffc0
[ 20.351311][ C7] arch_timer_handler_phys+0x40/0x54
[ 20.351313][ C3] f0dbb000 ffffff81 f0e00ec0
[ 20.351321][ C7] handle_percpu_devid_irq+0x88/0x280
[ 20.351323][ C3] ffffff81 00000000 00000000
[ 20.351333][ C7] __handle_domain_irq+0x80/0xd0
[ 20.351334][ C3]
[ 20.351337][ C3] 8780* 00000000 00000000
[ 20.351346][ C7] gic_handle_irq+0x78/0x154
[ 20.351349][ C3] 124cebd0 ffffffc0 00000000
[ 20.351357][ C7] el1_irq+0xe4/0x1c0
[ 20.351359][ C3] 00000000 00000000 00000000
[ 20.351369][ C7] arch_cpu_idle+0x1c/0x40
[ 20.351370][ C3]
[ 20.351373][ C3] 87a0 00000000 00000000
[ 20.351381][ C7] default_idle_call+0x3c/0x194
[ 20.351384][ C3] f02a3700 ffffff81 00000000
[ 20.351393][ C7] cpuidle_idle_call+0x64/0x238
[ 20.351395][ C3] 00000000 f02a3600 ffffff81
[ 20.351404][ C7] do_idle+0xac/0xfc
[ 20.351406][ C3]
[ 20.351409][ C3] 87c0 00000000 00000000
[ 20.351418][ C7] cpu_startup_entry+0x28/0x2c
[ 20.351420][ C3] 00000000 00000001 00000000
[ 20.351429][ C7] secondary_start_kernel+0x1b4/0x274
[ 20.351431][ C3] 00000000 00000000 00000000
[ 20.351440][ C7]
[ 20.351440][ C7] PC: 0xffffffc0101523dc:
[ 20.351445][ C7] 21dc
[ 20.351451][ C3] 87e0 00000000
[ 20.351455][ C7] a9034ff4
[ 20.351458][ C3] 00000000 00000000 00000000
[ 20.351465][ C7] 910003fd
[ 20.351467][ C3] 00000000 00000000 00000000
[ 20.351474][ C7] aa0003f7
[ 20.351476][ C3] 00000000
[ 20.351481][ C3] 8800 00000000
[ 20.351486][ C7] f0011520
[ 20.351488][ C3] 00000000 00000000 00000000
[ 20.351494][ C7] 91172000
[ 20.351496][ C3] 00000000 00000000 00000000
[ 20.351503][ C7] aa0403f3
[ 20.351505][ C3] 00000000
[ 20.351510][ C3] 8820 00000000
[ 20.351514][ C7] aa0303f4
[ 20.351516][ C3] 00000000 00000000 00000000
[ 20.351524][ C7] aa0203f5
[ 20.351526][ C3] 00000000 00000000 00000000
[ 20.351532][ C7]
[ 20.351535][ C3] 00000000
[ 20.351540][ C3] 8840 00000000
[ 20.351544][ C7] 21fc
[ 20.351546][ C3] 00000000 00000000 00000000
[ 20.351553][ C7] 2a0103f6
[ 20.351555][ C3] 00000000 00000000 00000000
[ 20.351562][ C7] 944d4906
[ 20.351564][ C3] 00000000
[ 20.351569][ C3] 8860 00000000
[ 20.351573][ C7] aa1703e0
[ 20.351575][ C3] 00000000 00000001 00000000
[ 20.351582][ C7] 2a1603e1
[ 20.351584][ C3] 00000000 00000000 00000000
[ 20.351591][ C7] aa1503e2
[ 20.351593][ C3] 00000000
[ 20.351598][ C3] 8880 00000000
[ 20.351602][ C7] aa1403e3
[ 20.351605][ C3] 00000000 00000000 00000000
[ 20.351611][ C7] aa1303e4
[ 20.351614][ C3] f0004000 ffffff81 00000000
[ 20.351620][ C7] 97fc18ff
[ 20.351622][ C3] 00000000
[ 20.351627][ C3] 88a0 00000000
[ 20.351631][ C7]
[ 20.351634][ C3] 00000000 00000000 00000000
[ 20.351640][ C7] 221c
[ 20.351642][ C3] 00000000 00000000 00000000
[ 20.351649][ C7] 2a0003f3
[ 20.351651][ C3] 00000000
[ 20.351657][ C3] 88c0 00000000
[ 20.351661][ C7] 34000156
[ 20.351663][ C3] 00000000 00000000 00000000
[ 20.351669][ C7] 35000133
[ 20.351672][ C3] 00000000 00000000 00000000
[ 20.351678][ C7] f00105a8
[ 20.351680][ C3] 00000000
[ 20.351685][ C3] 88e0 00000000
[ 20.351689][ C7] f00105a9
[ 20.351692][ C3] 00000000 00000000 00000000
[ 20.351698][ C7] b94fe10a
[ 20.351700][ C3] 00000000 00000000 00000000
[ 20.351707][ C7] b94dd129
[ 20.351709][ C3] 00000000
[ 20.351714][ C3] 8900 00000000
[ 20.351718][ C7] 0a090149
[ 20.351720][ C3] 00000000 00000000 00000000
[ 20.351726][ C7]
[ 20.351728][ C3] 00000000 00000000 00000000
[ 20.351735][ C7] 223c
[ 20.351737][ C3] 00000000
[ 20.351742][ C3] 8920 00000000
[ 20.351747][ C7] 92401d29
[ 20.351749][ C3] 00000000 00000000 00000000
[ 20.351756][ C7] f907f109
[ 20.351758][ C3] 00000000 00000000 00000000
[ 20.351765][ C7] 94000112
[ 20.351767][ C3] 00000000
[ 20.351772][ C3] 8940 00000000
[ 20.351776][ C7] f0011520
[ 20.351778][ C3] 00000000 00000000 00000000
[ 20.351785][ C7] 91172000
[ 20.351787][ C3] 00000000 00000000 00000000
[ 20.351793][ C7] 944d4915
[ 20.351795][ C3] 00000000
[ 20.351801][ C3] 8960 00000000
[ 20.351805][ C7] 2a1303e0
[ 20.351807][ C3] 00000000 00000000 00000000
[ 20.351813][ C7] a9434ff4
[ 20.351815][ C3] 00000000 00000000 00000000
[ 20.351822][ C7]
[ 20.351824][ C3] 00000000
[ 20.351831][ C3]
[ 20.351831][ C3] X3: 0xffffffc011eec419:
[ 20.351833][ C3] c218 20726576
[ 20.351838][ C7] 225c
[ 20.351840][ C3] 6c696166 3a657275 0a642520
[ 20.351847][ C7] a94257f6
[ 20.351849][ C3] 616e6500 5f656c62 63616562
[ 20.351855][ C7] f9400bf7
[ 20.351858][ C3] 73006e6f
[ 20.351863][ C3] c238 5f636e79
[ 20.351867][ C7] a8c47bfd
[ 20.351869][ C3] 00667374 635f636d 746e756f
[ 20.351877][ C7] f85f8e5e
[ 20.351879][ C3] 25360100 66203a73 656c6961
[ 20.351886][ C7] d50323bf
[ 20.351888][ C3] 6f742064
[ 20.351893][ C3] c258 73657220
[ 20.351897][ C7] d65f03c0
[ 20.351899][ C3] 65767265 61686320 6c656e6e
[ 20.351906][ C7] d503233f
[ 20.351908][ C3] 6e6f6320 74786574 726f6620
[ 20.351916][ C7] d101c3ff
[ 20.351918][ C3] 61686320
[ 20.351923][ C3] c278 6c656e6e
[ 20.351927][ C7]
[ 20.351929][ C3] 69777320 2c686374 73696420
[ 20.351935][ C7] 227c
[ 20.351937][ C3] 6e6e6f63 69746365 2820676e
[ 20.351944][ C7] f800865e
[ 20.351946][ C3] 3d727265
[ 20.351951][ C3] c298 0a296425
[ 20.351956][ C7] a9017bfd
[ 20.351958][ C3] 25360100 61203a73 65687475
[ 20.351965][ C7] a9026ffc
[ 20.351967][ C3] 6369746e 6f697461 6977206e
[ 20.351973][ C7] a90367fa
[ 20.351976][ C3] 25206874
[ 20.351981][ C3] c2b8 74204d70
[ 20.351985][ C7] a9045ff8
[ 20.351987][ C3] 64656d69 74756f20 7325000a
[ 20.351994][ C7] a90557f6
[ 20.351996][ C3] 5453203a 70252041 6f6e204d
[ 20.352003][ C7] a9064ff4
[ 20.352005][ C3] 6f662074
[ 20.352010][ C3] c2d8 00646e75
[ 20.352014][ C7] 910043fd
[ 20.352016][ C3] 494b4652 4e5f4c4c 3d454d41
[ 20.352023][ C7]
[ 20.352025][ C3] 01007325 4c575b36 525f4e41
[ 20.352032][ C7] 229c
[ 20.352034][ C3] 4c494b46
[ 20.352039][ C3] c2f8 203a5d4c
[ 20.352043][ C7] b000eee8
[ 20.352045][ C3] 74697845 0a732520 5b360100
[ 20.352052][ C7] f9427908
[ 20.352054][ C3] 4e414c57 4b46525f 5d4c4c49
[ 20.352060][ C7] 900105d9
[ 20.352063][ C3] 7325203a
[ 20.352067][ C3] c318 6e65203a
[ 20.352072][ C7] f90007e8
[ 20.352074][ C3] 656c6261 66657220 6b6c6320
[ 20.352081][ C7] d53cd048
[ 20.352083][ C3] 72726520 0a21726f 5b360100
[ 20.352090][ C7] f9400729
[ 20.352092][ C3] 4e414c57
[ 20.352097][ C3] c338 4b46525f
[ 20.352101][ C7] b4000669
[ 20.352103][ C3] 5d4c4c49 6146203a 64656c69
[ 20.352110][ C7] b001041a
[ 20.352112][ C3] 206f7420 20746567 67207325
[ 20.352118][ C7]
[ 20.352120][ C3] 2e6f6970
[ 20.352125][ C3] c358 6672000a
[ 20.352130][ C7] 22bc
[ 20.352132][ C3] 6c6c696b 616c775f 65725f6e
[ 20.352138][ C7] 9121035a
[ 20.352140][ C3] 65766f6d 6b667200 5f6c6c69
[ 20.352147][ C7] b0010417
[ 20.352149][ C3] 6e616c77
[ 20.352154][ C3] c378 7375735f
[ 20.352159][ C7] f0010449
[ 20.352161][ C3] 646e6570 72617500 74725f74
[ 20.352168][ C7] f87a690c
[ 20.352170][ C3] 70675f73 00736f69 425b3601
[ 20.352177][ C7] 9120c2f7
[ 20.352179][ C3] 46525f54
[ 20.352184][ C3] c398 4c4c494b
[ 20.352188][ C7] 9136e129
[ 20.352190][ C3] 46203a5d 656c6961 6f742064
[ 20.352197][ C7] 900105ca
[ 20.352199][ C3] 74656720 20732520 6f697067
[ 20.352206][ C7] b201f3eb
[ 20.352208][ C3] 64000a2e
[ 20.352213][ C3] c3b8 7265736e
[ 20.352217][ C7]
[ 20.352219][ C3] 00726f72 255b3701 362e362d
[ 20.352225][ C7] 22dc
[ 20.352228][ C3] 3c205d73 25203d3d 20292873
[ 20.352234][ C7] f8776918
[ 20.352236][ C3] 6425203d
[ 20.352242][ C3] c3d8 3301000a
[ 20.352246][ C7] f8696913
[ 20.352248][ C3] 72617453 676e6974 696e6920
[ 20.352254][ C7] b9401956
[ 20.352257][ C3] 25203a74 78652073 73747369
[ 20.352263][ C7] f295556b
[ 20.352265][ C3] 74756220
[ 20.352271][ C3] c3f8 756f6320
[ 20.352275][ C7] 9b0b7d89
[ 20.352277][ C3] 276e646c 78652074 74756365
[ 20.352284][ C7] b200f3ea
[ 20.352286][ C3] 74692065 72652820 20726f72
[ 20.352292][ C7] aa0003f4
[ 20.352295][ C3] 0a296425
[ 20.352299][ C3] c418* 33010000
[ 20.352303][ C7] eb0a013f
[ 20.352306][ C3] 444d4152 3a4b5349 756f6320
[ 20.352312][ C7]
[ 20.352314][ C3] 6e20646c 6120746f 636f6c6c
[ 20.352321][ C7] 22fc
[ 20.352323][ C3] 20657461
[ 20.352328][ C3] c438 66667562
[ 20.352333][ C7] 54000868
[ 20.352335][ C3] 000a7265 6e493001 696c6176
[ 20.352342][ C7] b00103c9
[ 20.352344][ C3] 61722064 7369646d 6564206b
[ 20.352351][ C7] 91002129
[ 20.352353][ C3] 706d6f63
[ 20.352358][ C3] c458 73736572
[ 20.352362][ C7] f00105aa
[ 20.352364][ C3] 206e6f69 74756f72 2e656e69
[ 20.352371][ C7] b8696915
[ 20.352373][ C3] 65532020 7463656c 70706120
[ 20.352379][ C7] f947f94a
[ 20.352382][ C3] 72706f72
[ 20.352387][ C3] c478 65746169
[ 20.352391][ C7] 910003e1
[ 20.352393][ C3] 6e6f6320 20676966 6974706f
[ 20.352400][ C7] 2a1503e0
[ 20.352402][ C3] 0a2e6e6f 002e2e00 74697277
[ 20.352408][ C7]
[ 20.352411][ C3] 72652065
[ 20.352416][ C3] c498 00726f72
[ 20.352420][ C7] 231c
[ 20.352422][ C3] 61433601 7262696c 6e697461
[ 20.352429][ C7] f90003ea
[ 20.352431][ C3] 65642067 2079616c 706f6f6c
[ 20.352438][ C7] 94169465
[ 20.352440][ C3] 202e2e2e
[ 20.352445][ C3] c4b8 00367800
[ 20.352449][ C7] f00105bb
[ 20.352452][ C3] 20435648 72414128 32336863
[ 20.352459][ C7] b94f8b68
[ 20.352461][ C3] 457f0029 0100464c 3a732533
[ 20.352468][ C7] 6b08001f
[ 20.352470][ C3] 6b6e7520
[ 20.352475][ C3] c4d8 6e776f6e
[ 20.352480][ C7] 540000c3
[ 20.352482][ C3] 72617620 746e6169 636e6520
[ 20.352488][ C7] 910003e0
[ 20.352491][ C3] 6e69646f 64252067 6161000a
[ 20.352498][ C7] 52800101
[ 20.352500][ C3] 36686372
[ 20.352505][ C3] c4f8 6e695f34
[ 20.352509][ C7]
[ 20.352511][ C3] 675f6e73 6c5f6e65 64646164
[ 20.352518][ C7] 233c
[ 20.352520][ C3] 6f727000 73736563 3a09726f
[ 20.352526][ C7] aa1f03e2
[ 20.352529][ C3] 0a642520
[ 20.352533][ C3] c518 75706300
[ 20.352538][ C7] 94159a85
[ 20.352540][ C3] 56006469 54504950 4d524100
[ 20.352547][ C7] b94f8b68
[ 20.352549][ C3] 72726520 6d757461 38353820
[ 20.352557][ C7] 6b15001f
[ 20.352559][ C3] 00313239
[ 20.352564][ C3] c538 5f535953
[ 20.352568][ C7] 1a800101
[ 20.352570][ C3] 415f4449 44343641 5f315246
[ 20.352577][ C7] 6b08003f
[ 20.352579][ C3] 00314c45 6f6d654d 54207972
[ 20.352586][ C7] 540005a2
[ 20.352588][ C3] 69676761
[ 20.352593][ C3] c558 4520676e
[ 20.352597][ C7] 900105d5
[ 20.352599][ C3] 6e657478 6e6f6973 52454b00
[ 20.352606][ C7]
[ 20.352608][ C3] 5f4c454e 41435748 38495f50
[ 20.352615][ C7] 235c
[ 20.352617][ C3] 61004d4d
[ 20.352622][ C3] c578 2f686372
[ 20.352627][ C7] d50339bf
[ 20.352629][ C3] 366d7261 656b2f34 6c656e72
[ 20.352636][ C7] 9116a2b5
[ 20.352638][ C3] 746c612f 616e7265 65766974
[ 20.352645][ C7] f8615aa8
[ 20.352647][ C3] 0100632e
[ 20.352652][ C3] c598 55504332
[ 20.352657][ C7] b0010409
[ 20.352659][ C3] 203a7525 6c696166 74206465
[ 20.352665][ C7] 9120a129
[ 20.352668][ C3] 6f63206f 6f20656d 6e696c6e
[ 20.352674][ C7] 3869690a
[ 20.352677][ C3] 01000a65
[ 20.352682][ C3] c5b8 55504333
[ 20.352686][ C7] 340000aa
[ 20.352688][ C3] 203a7525 6c696166 69206465
[ 20.352694][ C7] 3828693f
[ 20.352697][ C3] 6e75206e 776f6e6b 7473206e
[ 20.352703][ C7]
[ 20.352705][ C3] 20657461
[ 20.352710][ C3] c5d8 7830203a
[ 20.352714][ C7] 237c
[ 20.352717][ C3] 0a786c25 69707300 61742d6e
[ 20.352724][ C7] 14000023
[ 20.352726][ C3] 00656c62 6e6c7556 62617265
[ 20.352733][ C7] 2a1f03e0
[ 20.352735][ C3] 203a656c
[ 20.352740][ C3] c5f8 72706e55
[ 20.352744][ C7] 1400008a
[ 20.352747][ C3] 6c697669 64656765 50426520
[ 20.352753][ C7] b001040a
[ 20.352755][ C3] 6e652046 656c6261 2c000a64
[ 20.352762][ C7] 9121214a
[ 20.352764][ C3] 42484220
[ 20.352769][ C3] c618 64336c00
[ 20.352774][ C7] f87a6909
[ 20.352776][ C3] 6361635f 725f6568 6c696665
[ 20.352783][ C7] f86a690b
[ 20.352785][ C3] 326c006c 61635f69 5f656863
[ 20.352792][ C7] 2a0103fb
[ 20.352794][ C3] 73696d6c
[ 20.352802][ C3]
[ 20.352802][ C3] X6: 0xffffffc012638eb6:
[ 20.352805][ C3] 8cb4
[ 20.352806][ C7]
[ 20.352808][ C3] 00000000 702d6b72 20656963
[ 20.352815][ C7] 239c
[ 20.352817][ C3] 37316566 30303030 6963702e
[ 20.352824][ C7] eb09017f
[ 20.352826][ C3] 50203a65 20654943
[ 20.352834][ C3] 8cd4
[ 20.352836][ C7] 540002a1
[ 20.352838][ C3] 6b6e694c 2e676e69 4c202e2e
[ 20.352845][ C7] b001041c
[ 20.352848][ C3] 4d535354 20736920 00337830
[ 20.352854][ C7] 9123639c
[ 20.352856][ C3] 00000000 ffffc18b
[ 20.352865][ C3] 8cf4
[ 20.352866][ C7] 387c6908
[ 20.352868][ C3] 00000000 702d6b72 20656963
[ 20.352874][ C7] 350002c8
[ 20.352876][ C3] 37316566 30303030 6963702e
[ 20.352883][ C7] f00105a8
[ 20.352886][ C3] 50203a65 20654943
[ 20.352894][ C3] 8d14
[ 20.352895][ C7] b94fe908
[ 20.352897][ C3] 6b6e694c 2e676e69 4c202e2e
[ 20.352904][ C7]
[ 20.352906][ C3] 4d535354 20736920 00337830
[ 20.352913][ C7] 23bc
[ 20.352915][ C3] 00000000 ffffc18c
[ 20.352923][ C3] 8d34
[ 20.352924][ C7] 35001228
[ 20.352926][ C3] 00000000 702d6b72 20656963
[ 20.352933][ C7] b000ec60
[ 20.352935][ C3] 37316566 30303030 6963702e
[ 20.352942][ C7] 91255400
[ 20.352944][ C3] 50203a65 20654943
[ 20.352952][ C3] 8d54
[ 20.352953][ C7] 97fbdf47
[ 20.352955][ C3] 6b6e694c 2e676e69 4c202e2e
[ 20.352962][ C7] d0012b20
[ 20.352964][ C3] 4d535354 20736920 00337830
[ 20.352971][ C7] 911e0000
[ 20.352973][ C3] 00000000 ffffc18d
[ 20.352981][ C3] 8d74
[ 20.352983][ C7] aa1f03e1
[ 20.352985][ C3] 00000000 702d6b72 20656963
[ 20.352991][ C7] aa1f03e2
[ 20.352993][ C3] 37316566 30303030 6963702e
[ 20.353000][ C7]
[ 20.353002][ C3] 50203a65 20654943
[ 20.353010][ C3] 8d94
[ 20.353011][ C7] 23dc*
[ 20.353014][ C3] 6b6e694c 2e676e69 4c202e2e
[ 20.353020][ C7] d4210000
[ 20.353022][ C3] 4d535354 20736920 00337830
[ 20.353029][ C7] 97fcb563
[ 20.353031][ C3] 00000000 ffffc18e
[ 20.353039][ C3] 8db4
[ 20.353041][ C7] f87b7aa8
[ 20.353043][ C3] 00000000 702d6b72 20656963
[ 20.353050][ C7] 52800029
[ 20.353052][ C3] 37316566 30303030 6963702e
[ 20.353058][ C7] 383c6909
[ 20.353061][ C3] 50203a65 20654943
[ 20.353068][ C3] 8dd4
[ 20.353070][ C7] 14000006
[ 20.353072][ C3] 6b6e694c 2e676e69 4c202e2e
[ 20.353079][ C7] f87b7aab
[ 20.353081][ C3] 4d535354 20736920 00337830
[ 20.353088][ C7] f8286949
[ 20.353090][ C3] 00000000 ffffc18f
[ 20.353098][ C3] 8df4
[ 20.353099][ C7]
[ 20.353101][ C3] 00000000 702d6b72 20656963
[ 20.353108][ C7] 23fc
[ 20.353110][ C3] 37316566 30303030 6963702e
[ 20.353117][ C7] b0010408
[ 20.353119][ C3] 50203a65 20654943
[ 20.353127][ C3] 8e14
[ 20.353129][ C7] 91236108
[ 20.353131][ C3] 6b6e694c 69614620 0000006c
[ 20.353138][ C7] 3828697f
[ 20.353140][ C3] ffffc190 00000000 702d6b72
[ 20.353147][ C7] d53cd048
[ 20.353149][ C3] 20656963 37316566
[ 20.353156][ C3] 8e34
[ 20.353158][ C7] f87a6909
[ 20.353160][ C3] 30303030 6963702e 66203a65
[ 20.353167][ C7] b0010415
[ 20.353169][ C3] 656c6961 6f742064 696e6920
[ 20.353176][ C7] 912242b5
[ 20.353178][ C3] 6c616974 20657a69
[ 20.353186][ C3] 8e54
[ 20.353188][ C7] 91000529
[ 20.353190][ C3] 74736f68 ffffc191 00000000
[ 20.353196][ C7]
[ 20.353198][ C3] 2d2d2d2d 2d2d2d2d 2d2d2d2d
[ 20.353205][ C7] 241c
[ 20.353207][ C3] 7563205b 65682074
[ 20.353215][ C3] 8e74
[ 20.353217][ C7] f83a6909
[ 20.353219][ C3] 5d206572 2d2d2d2d 2d2d2d2d
[ 20.353226][ C7] d53cd048
[ 20.353228][ C3] 2d2d2d2d 00000000 ffffc192
[ 20.353234][ C7] 8b150100
[ 20.353237][ C3] 00000000 63746157
[ 20.353244][ C3] 8e94
[ 20.353246][ C7] 97fd6846
[ 20.353248][ C3] 676f6468 74656420 65746365
[ 20.353255][ C7] 360001c0
[ 20.353257][ C3] 61682064 4c206472 554b434f
[ 20.353264][ C7] b00103c9
[ 20.353266][ C3] 6e6f2050 75706320
[ 20.353274][ C3] 8eb4*
[ 20.353275][ C7] d53cd048
[ 20.353277][ C3] 00003420 ffffc193 00000000
[ 20.353285][ C7] b835691f
[ 20.353287][ C3] 4e524157 3a474e49 55504320
[ 20.353294][ C7]
[ 20.353296][ C3] 2033203a 3a444950
[ 20.353303][ C3] 8ed4
[ 20.353305][ C7] 243c
[ 20.353307][ C3] 61203020 656b2074 6c656e72
[ 20.353314][ C7] 91002129
[ 20.353316][ C3] 7461772f 6f646863 3a632e67
[ 20.353323][ C7] d53cd048
[ 20.353325][ C3] 20383134 63746177
[ 20.353333][ C3] 8ef4
[ 20.353334][ C7] b8696900
[ 20.353337][ C3] 676f6468 6d69745f 665f7265
[ 20.353343][ C7] b0010409
[ 20.353345][ C3] 78302b6e 2f383631 63337830
[ 20.353353][ C7] 9122c129
[ 20.353355][ C3] 00000038 ffffc194
[ 20.353363][ C3] 8f14
[ 20.353364][ C7] 90000001
[ 20.353366][ C3] 00000000 75646f4d 2073656c
[ 20.353373][ C7] 8b090103
[ 20.353375][ C3] 6b6e696c 69206465 00003a6e
[ 20.353383][ C7] 9118f021
[ 20.353385][ C3] 00000000 ffffc195
[ 20.353392][ C3] 8f34
[ 20.353394][ C7]
[ 20.353396][ C3] 00000000 3a555043 50203320
[ 20.353402][ C7] 245c
[ 20.353405][ C3] 203a4449 6f432030 203a6d6d
[ 20.353411][ C7] aa1f03e2
[ 20.353413][ C3] 70617773 2f726570
[ 20.353422][ C3] 8f54
[ 20.353423][ C7] 97ffbd7b
[ 20.353425][ C3] 6f4e2033 61742074 65746e69
[ 20.353432][ C7] f9401a88
[ 20.353434][ C3] 2e352064 312e3031 23203031
[ 20.353441][ C7] 900105c9
[ 20.353443][ C3] 00393336 ffffc196
[ 20.353451][ C3] 8f74
[ 20.353452][ C7] f9401135
[ 20.353455][ C3] 00000000 64726148 65726177
[ 20.353461][ C7] f9401908
[ 20.353463][ C3] 6d616e20 46203a65 66657269
[ 20.353470][ C7] d63f0100
[ 20.353472][ C3] 4120796c 332d4f49
[ 20.353480][ C3] 8f94
[ 20.353482][ C7] aa0003e1
[ 20.353484][ C3] 51383835 4d444820 6e412849
[ 20.353490][ C7]
[ 20.353492][ C3] 696f7264 28202964 00295444
[ 20.353499][ C7] 247c
[ 20.353501][ C3] 00000000 ffffc197
[ 20.353509][ C3] 8fb4
[ 20.353510][ C7] aa1403e0
[ 20.353512][ C3] 00000000 61747370 203a6574
[ 20.353520][ C7] aa1503e2
[ 20.353522][ C3] 30343036 39383030 5a6e2820
[ 20.353528][ C7] 97feabce
[ 20.353530][ C3] 64207643 20664961
[ 20.353538][ C3] 8fd4
[ 20.353540][ C7] b100071f
[ 20.353542][ C3] 4e41502b 41552d20 542d204f
[ 20.353549][ C7] 540007c0
[ 20.353551][ C3] 42204f43 45505954 292d2d3d
[ 20.353558][ C7] 97fd0e05
[ 20.353560][ C3] 00000000 ffffc198
[ 20.353568][ C3] 8ff4
[ 20.353569][ C7] 39402329
[ 20.353572][ C3] 00000000 3a206370 74617720
[ 20.353578][ C7] aa0003e8
[ 20.353580][ C3] 6f646863 69745f67 5f72656d
[ 20.353588][ C7]
[ 20.353590][ C3] 302b6e66 38363178
[ 20.353597][ C3] 9014
[ 20.353599][ C7] 249c
[ 20.353601][ C3] 3378302f 00003863 00000000
[ 20.353608][ C7] 52800020
[ 20.353610][ C3] ffffc199 00000000 3a20726c
[ 20.353616][ C7] 36080869
[ 20.353619][ C3] 74617720 6f646863
[ 20.353627][ C3] 9034
[ 20.353628][ C7] f00105a9
[ 20.353630][ C3] 69745f67 5f72656d 302b6e66
[ 20.353637][ C7] b94fdd29
[ 20.353639][ C3] 38353178 3378302f 00003863
[ 20.353646][ C7] 34000809
[ 20.353648][ C3] 00000000 ffffc19a
[ 20.353656][ C3] 9054
[ 20.353657][ C7] d35efd08
[ 20.353660][ C3] 00000000 3a207073 66666620
[ 20.353666][ C7] 531f7929
[ 20.353668][ C3] 63666666 37323130 32653335
[ 20.353675][ C7] cb08030a
[ 20.353677][ C3] 00000030 ffffc19b
[ 20.353685][ C3] 9074
[ 20.353686][ C7]
[ 20.353689][ C3] 00000000 3a393278 66666620
[ 20.353695][ C7] 24bc
[ 20.353698][ C3] 63666666 37323130 33653335
[ 20.353704][ C7] ab29c15f
[ 20.353707][ C3] 32782030 66203a38
[ 20.353714][ C3] 9094
[ 20.353716][ C7] 54000745
[ 20.353718][ C3] 66666666 31306366 33643132
[ 20.353725][ C7] 6b180114
[ 20.353727][ C3] 20386438 00000000 ffffc19c
[ 20.353733][ C7] 54000700
[ 20.353736][ C3] 00000000 3a373278
[ 20.353743][ C3] 90b4
[ 20.353745][ C7] 34000176
[ 20.353747][ C3] 30303020 30303030 30303030
[ 20.353754][ C7] d0012b28
[ 20.353756][ C3] 30303030 32782034 66203a36
[ 20.353763][ C7] f943cd08
[ 20.353765][ C3] 66666666 31306366
[ 20.353774][ C7] 37000688
[ 20.353777][ C3]
[ 20.353777][ C3] X13: 0xffffffc01228ccf0:
[ 20.353777][ C7]
[ 20.353782][ C7] 24dc
[ 20.353787][ C3] caf0 00000000 00000000
[ 20.353794][ C7] d503201f
[ 20.353796][ C3] 00000000 00000000 00000000
[ 20.353803][ C7] d503201f
[ 20.353805][ C3] 00000000 00000000 00000000
[ 20.353812][ C7] d0012b29
[ 20.353814][ C3]
[ 20.353817][ C3] cb10 00000000 00000000
[ 20.353824][ C7] 52800028
[ 20.353826][ C3] 00000000 00000000 00000000
[ 20.353833][ C7] 911e6129
[ 20.353835][ C3] 00000000 00000000 00000000
[ 20.353841][ C7] f8a83128
[ 20.353843][ C3]
[ 20.353846][ C3] cb30 00000000 00000000
[ 20.353852][ C7] 370005a8
[ 20.353855][ C3] 00000000 00000000 00000000
[ 20.353861][ C7] 97fd0deb
[ 20.353863][ C3] 00000000 00000000 00000000
[ 20.353870][ C7]
[ 20.353871][ C3]
[ 20.353874][ C3] cb50 00000000 00000000
[ 20.353880][ C7] 24fc
[ 20.353882][ C3] 00000000 00000000 00000000
[ 20.353889][ C7] d35efc09
[ 20.353891][ C3] 00000000 00000000 00000000
[ 20.353898][ C7] d53cd048
[ 20.353899][ C3]
[ 20.353902][ C3] cb70 00000000 00000000
[ 20.353909][ C7] f8376909
[ 20.353911][ C3] 00000000 00000000 00000000
[ 20.353918][ C7] b00103c9
[ 20.353920][ C3] 00000000 00000000 00000000
[ 20.353927][ C7] 91002129
[ 20.353929][ C3]
[ 20.353931][ C3] cb90 00000000 00000000
[ 20.353938][ C7] d53cd048
[ 20.353940][ C3] 00000000 00000000 00000000
[ 20.353947][ C7] d538410a
[ 20.353949][ C3] 00000000 00000000 00000000
[ 20.353956][ C7] b8696901
[ 20.353957][ C3]
[ 20.353960][ C3] cbb0 00000000 00000000
[ 20.353966][ C7]
[ 20.353969][ C3] 00000000 00000000 00000000
[ 20.353975][ C7] 251c
[ 20.353978][ C3] 00000000 00000000 00000000
[ 20.353984][ C7] b9455144
[ 20.353986][ C3]
[ 20.353989][ C3] cbd0 00000000 00000000
[ 20.353996][ C7] f000e420
[ 20.353998][ C3] 00000000 00000000 00000000
[ 20.354004][ C7] 911c6143
[ 20.354006][ C3] 00000000 00000000 00000000
[ 20.354013][ C7] 910a8c00
[ 20.354015][ C3]
[ 20.354017][ C3] cbf0 00000000 00000000
[ 20.354024][ C7] 2a1403e2
[ 20.354026][ C3] 00000000 00000000 00000000
[ 20.354033][ C7] 944d2ef9
[ 20.354035][ C3] 00000000 00000000 00000000
[ 20.354041][ C7] 97ff3879
[ 20.354043][ C3]
[ 20.354046][ C3] cc10 00000000 00000000
[ 20.354053][ C7] b40005f3
[ 20.354055][ C3] 00000000 00000000 00000000
[ 20.354062][ C7]
[ 20.354064][ C3] 00000000 00000000 00000000
[ 20.354071][ C7] 253c
[ 20.354073][ C3]
[ 20.354075][ C3] cc30 00000000 00000000
[ 20.354082][ C7] aa1303e0
[ 20.354084][ C3] 00000000 00000000 00000000
[ 20.354091][ C7] 97fae056
[ 20.354093][ C3] 00000000 00000000 00000000
[ 20.354099][ C7] 340000f6
[ 20.354101][ C3]
[ 20.354104][ C3] cc50 00000000 00000000
[ 20.354110][ C7] d503201f
[ 20.354112][ C3] 00000000 00000000 00000000
[ 20.354119][ C7] d503201f
[ 20.354121][ C3] 00000000 00000000 00000000
[ 20.354128][ C7] d0012b28
[ 20.354129][ C3]
[ 20.354132][ C3] cc70 00000000 00000000
[ 20.354139][ C7] 52800029
[ 20.354141][ C3] 00000000 00000000 00000000
[ 20.354148][ C7] 911e6108
[ 20.354150][ C3] 00000000 00000000 00000000
[ 20.354157][ C7]
[ 20.354158][ C3]
[ 20.354161][ C3] cc90 00000000 00000000
[ 20.354168][ C7] 255c
[ 20.354170][ C3] 00000000 00000000 00000000
[ 20.354176][ C7] f8691109
[ 20.354179][ C3] 00000000 00000000 00000000
[ 20.354185][ C7] 528001c0
[ 20.354187][ C3]
[ 20.354190][ C3] ccb0 00000000 00000000
[ 20.354196][ C7] 2a1f03e1
[ 20.354198][ C3] 00000000 00000000 00000000
[ 20.354205][ C7] 97fbddbb
[ 20.354207][ C3] 00000000 00000000 00000000
[ 20.354213][ C7] f00105a8
[ 20.354215][ C3]
[ 20.354218][ C3] ccd0 00000000 00000000
[ 20.354225][ C7] b94ff908
[ 20.354227][ C3] 00000000 00000000 00000000
[ 20.354233][ C7] 340001a8
[ 20.354236][ C3] 00000000 00000000 00000000
[ 20.354243][ C7] d000e8a0
[ 20.354244][ C3]
[ 20.354247][ C3] ccf0* ffffbfff c0000000
[ 20.354254][ C7]
[ 20.354256][ C3] 00000001 00000000 00000001
[ 20.354262][ C7] 257c
[ 20.354264][ C3] 00000000 00000000 00000000
[ 20.354271][ C7] 9112dc00
[ 20.354272][ C3]
[ 20.354275][ C3] cd10 eb1bf365 00000000
[ 20.354283][ C7] 944d2dfc
[ 20.354285][ C3] c2000037 00000000 00000000
[ 20.354291][ C7] b0010409
[ 20.354293][ C3] 00000000 00000000 00000000
[ 20.354300][ C7] 9120e129
[ 20.354302][ C3]
[ 20.354304][ C3] cd30 00000000 00000000
[ 20.354311][ C7] d53cd048
[ 20.354313][ C3] 00000000 00000000 00000000
[ 20.354320][ C7] 3869690a
[ 20.354322][ C3] 00000000 00000000 00000000
[ 20.354328][ C7] 350002aa
[ 20.354330][ C3]
[ 20.354332][ C3] cd50 00000000 00000000
[ 20.354339][ C7] 97fd0dc3
[ 20.354342][ C3] 00000000 00000000 00000001
[ 20.354348][ C7]
[ 20.354350][ C3] 00000000 eb1c456d 00000000
[ 20.354357][ C7] 259c
[ 20.354358][ C3]
[ 20.354361][ C3] cd70 a200016c 00000000
[ 20.354368][ C7] d35efc09
[ 20.354370][ C3] 00000000 00000000 00000000
[ 20.354377][ C7] d53cd048
[ 20.354379][ C3] 00000000 00000000 00000000
[ 20.354385][ C7] f8376909
[ 20.354387][ C3]
[ 20.354390][ C3] cd90 00000000 00000000
[ 20.354397][ C7] 52800020
[ 20.354399][ C3] 00000000 00000000 00000000
[ 20.354406][ C7] b000eee9
[ 20.354408][ C3] 00000000 00000000 00000000
[ 20.354415][ C7] f94007e8
[ 20.354416][ C3]
[ 20.354419][ C3] cdb0 00000000 00000000
[ 20.354426][ C7] f9427929
[ 20.354428][ C3] 00000002 00000000 ebf20cce
[ 20.354434][ C7] eb08013f
[ 20.354436][ C3] 00000000 c200002e 00000000
[ 20.354443][ C7]
[ 20.354444][ C3]
[ 20.354447][ C3] cdd0 00000000 00000000
[ 20.354454][ C7] 25bc
[ 20.354456][ C3] 00000000 00000000 00000000
[ 20.354463][ C7] 540001a1
[ 20.354465][ C3] 00000000 00000000 00000000
[ 20.354472][ C7] a9417bfd
[ 20.354473][ C3]
[ 20.354476][ C3] cdf0 00000000 00000000
[ 20.354483][ C7] a9464ff4
[ 20.354485][ C3] 00000000 00000000 00000000
[ 20.354491][ C7] a94557f6
[ 20.354493][ C3] 00000000 00000000 00000000
[ 20.354500][ C7] a9445ff8
[ 20.354502][ C3]
[ 20.354504][ C3] ce10 00000003 00000000
[ 20.354511][ C7] a94367fa
[ 20.354513][ C3] ee7a1d97 00000000 c200003c
[ 20.354520][ C7] a9426ffc
[ 20.354522][ C3] 00000000 00000000 00000000
[ 20.354528][ C7] f85f8e5e
[ 20.354530][ C3]
[ 20.354533][ C3] ce30 00000000 00000000
[ 20.354540][ C7]
[ 20.354542][ C3] 00000000 00000000 00000000
[ 20.354549][ C7]
[ 20.354549][ C7] LR: 0xffffffc0101523cc:
[ 20.354551][ C3] 00000000 00000000 00000000
[ 20.354557][ C7] 21cc
[ 20.354559][ C3]
[ 20.354562][ C3] ce50 00000000 00000000
[ 20.354568][ C7] f800865e
[ 20.354571][ C3] 00000000 00000000 00000000
[ 20.354578][ C7] a9bc7bfd
[ 20.354580][ C3] 00000000 00000004 00000000
[ 20.354587][ C7] f9000bf7
[ 20.354589][ C3]
[ 20.354591][ C3] ce70 eec615d5 00000000
[ 20.354598][ C7] a90257f6
[ 20.354600][ C3] c2000026 00000000 00000000
[ 20.354607][ C7] a9034ff4
[ 20.354609][ C3] 00000000 00000000 00000000
[ 20.354616][ C7] 910003fd
[ 20.354617][ C3]
[ 20.354620][ C3] ce90 00000000 00000000
[ 20.354627][ C7] aa0003f7
[ 20.354629][ C3] 00000000 00000000 00000000
[ 20.354636][ C7] f0011520
[ 20.354638][ C3] 00000000 00000000 00000000
[ 20.354644][ C7]
[ 20.354646][ C3]
[ 20.354649][ C3] ceb0 00000000 00000000
[ 20.354655][ C7] 21ec
[ 20.354658][ C3] 00000000 00000000 00000005
[ 20.354664][ C7] 91172000
[ 20.354666][ C3] 00000000 ef407b7d 00000000
[ 20.354673][ C7] aa0403f3
[ 20.354675][ C3]
[ 20.354678][ C3] ced0 c2000079 00000000
[ 20.354685][ C7] aa0303f4
[ 20.354687][ C3] 00000000 00000000 00000000
[ 20.354693][ C7] aa0203f5
[ 20.354695][ C3] 00000000 00000000 00000000
[ 20.354702][ C7] 2a0103f6
[ 20.354704][ C3]
[ 20.354710][ C3]
[ 20.354710][ C3] X18: 0xffffffc01273d038:
[ 20.354713][ C3] ce38 ********
[ 20.354718][ C7] 944d4906 aa1703e0 2a1603e1
[ 20.354728][ C3] ********
[ 20.354729][ C7]
[ 20.354734][ C7] 220c
[ 20.354738][ C3] ******** ******** ********
[ 20.354745][ C7] aa1503e2
[ 20.354749][ C3] ******** ********
[ 20.354753][ C7] aa1403e3
[ 20.354756][ C3] ********
[ 20.354761][ C3] ce58
[ 20.354763][ C7] aa1303e4
[ 20.354766][ C3] ******** ********
[ 20.354770][ C7] 97fc18ff
[ 20.354773][ C3] ******** ********
[ 20.354778][ C7] 2a0003f3
[ 20.354781][ C3] ******** ********
[ 20.354785][ C7] 34000156
[ 20.354788][ C3] ******** ********
[ 20.354793][ C7] 35000133
[ 20.354794][ C3]
[ 20.354797][ C3] ce78 ******** ********
[ 20.354805][ C7] f00105a8
[ 20.354808][ C3] ******** ********
[ 20.354812][ C7]
[ 20.354815][ C3] ******** ********
[ 20.354819][ C7] 222c
[ 20.354822][ C3] ******** ********
[ 20.354827][ C7] f00105a9
[ 20.354828][ C3]
[ 20.354831][ C3] ce98 ******** ********
[ 20.354839][ C7] b94fe10a
[ 20.354841][ C3] ******** ********
[ 20.354846][ C7] b94dd129
[ 20.354849][ C3] ******** ********
[ 20.354853][ C7] 0a090149
[ 20.354856][ C3] ******** ********
[ 20.354861][ C7] 92401d29
[ 20.354862][ C3]
[ 20.354865][ C3] ceb8 ******** ********
[ 20.354872][ C7] f907f109
[ 20.354875][ C3] ******** ********
[ 20.354880][ C7] 94000112
[ 20.354882][ C3] ******** ********
[ 20.354887][ C7] f0011520
[ 20.354890][ C3] ******** ********
[ 20.354894][ C7]
[ 20.354896][ C3]
[ 20.354898][ C3] ced8 ******** ********
[ 20.354906][ C7] 224c
[ 20.354909][ C3] ******** ********
[ 20.354913][ C7] 91172000
[ 20.354916][ C3] ******** ********
[ 20.354921][ C7] 944d4915
[ 20.354924][ C3] ******** ********
[ 20.354929][ C7] 2a1303e0
[ 20.354930][ C3]
[ 20.354933][ C3] cef8 ******** ********
[ 20.354940][ C7] a9434ff4
[ 20.354943][ C3] ******** ********
[ 20.354948][ C7] a94257f6
[ 20.354951][ C3] ******** ********
[ 20.354955][ C7] f9400bf7
[ 20.354958][ C3] ******** ********
[ 20.354962][ C7] a8c47bfd
[ 20.354964][ C3]
[ 20.354967][ C3] cf18 ******** ********
[ 20.354974][ C7] f85f8e5e
[ 20.354977][ C3] ******** ********
[ 20.354981][ C7]
[ 20.354984][ C3] ******** ********
[ 20.354989][ C7] 226c
[ 20.354992][ C3] ******** ********
[ 20.354996][ C7] d50323bf
[ 20.354998][ C3]
[ 20.355000][ C3] cf38 ******** ********
[ 20.355008][ C7] d65f03c0
[ 20.355011][ C3] ******** ********
[ 20.355015][ C7] d503233f
[ 20.355018][ C3] ******** ********
[ 20.355023][ C7] d101c3ff
[ 20.355025][ C3] ******** ********
[ 20.355030][ C7] f800865e
[ 20.355031][ C3]
[ 20.355034][ C3] cf58 ******** ********
[ 20.355041][ C7] a9017bfd
[ 20.355044][ C3] ******** ********
[ 20.355049][ C7] a9026ffc
[ 20.355052][ C3] ******** ********
[ 20.355056][ C7] a90367fa
[ 20.355059][ C3] ******** ********
[ 20.355063][ C7]
[ 20.355065][ C3]
[ 20.355067][ C3] cf78 ******** ********
[ 20.355075][ C7] 228c
[ 20.355078][ C3] ******** ********
[ 20.355082][ C7] a9045ff8
[ 20.355085][ C3] ******** ********
[ 20.355089][ C7] a90557f6
[ 20.355092][ C3] ******** ********
[ 20.355097][ C7] a9064ff4
[ 20.355098][ C3]
[ 20.355101][ C3] cf98 ******** ********
[ 20.355109][ C7] 910043fd
[ 20.355112][ C3] ******** ********
[ 20.355116][ C7] b000eee8
[ 20.355119][ C3] ******** ********
[ 20.355123][ C7] f9427908
[ 20.355127][ C3] ******** ********
[ 20.355131][ C7] 900105d9
[ 20.355133][ C3]
[ 20.355135][ C3] cfb8 ******** ********
[ 20.355143][ C7] f90007e8
[ 20.355146][ C3] ******** ********
[ 20.355150][ C7]
[ 20.355153][ C3] ******** ********
[ 20.355157][ C7] 22ac
[ 20.355160][ C3] ******** ********
[ 20.355165][ C7] d53cd048
[ 20.355166][ C3]
[ 20.355169][ C3] cfd8 ******** ********
[ 20.355176][ C7] f9400729
[ 20.355179][ C3] ******** ********
[ 20.355184][ C7] b4000669
[ 20.355186][ C3] ******** ********
[ 20.355191][ C7] b001041a
[ 20.355194][ C3] ******** ********
[ 20.355199][ C7] 9121035a
[ 20.355201][ C3]
[ 20.355204][ C3] cff8 ******** ********
[ 20.355211][ C7] b0010417
[ 20.355213][ C3] 100025e4 ffffffc0 107150a0
[ 20.355220][ C7] f0010449
[ 20.355222][ C3] ffffffc0 100cbc70 ffffffc0
[ 20.355229][ C7] f87a690c
[ 20.355231][ C3]
[ 20.355234][ C3] d018 100d30fc ffffffc0
[ 20.355240][ C7]
[ 20.355242][ C3] 10f15f70 ffffffc0 100fe358
[ 20.355249][ C7] 22cc
[ 20.355252][ C3] ffffffc0 100ff6ec ffffffc0
[ 20.355258][ C7] 9120c2f7
[ 20.355260][ C3]
[ 20.355263][ C3] d038* 1000244c ffffffc0
[ 20.355269][ C7] 9136e129
[ 20.355271][ C3] 1149fd18 ffffffc0 114a0018
[ 20.355278][ C7] 900105ca
[ 20.355280][ C3] ffffffc0 100336c0 ffffffc0
[ 20.355287][ C7] b201f3eb
[ 20.355288][ C3]
[ 20.355291][ C3] d058 10007984 ffffffc0
[ 20.355298][ C7] f8776918
[ 20.355301][ C3] 10016e0c ffffffc0 106f6e04
[ 20.355307][ C7] f8696913
[ 20.355309][ C3] ffffffc0 10049ff8 ffffffc0
[ 20.355316][ C7] b9401956
[ 20.355318][ C3]
[ 20.355320][ C3] d078 1000a6dc ffffffc0
[ 20.355327][ C7] f295556b
[ 20.355329][ C3] 1000a7b8 ffffffc0 1000b48c
[ 20.355336][ C7]
[ 20.355338][ C3] ffffffc0 10018874 ffffffc0
[ 20.355345][ C7] 22ec
[ 20.355346][ C3]
[ 20.355349][ C3] d098 100c9c80 ffffffc0
[ 20.355356][ C7] 9b0b7d89
[ 20.355359][ C3] 100c6f3c ffffffc0 100c6570
[ 20.355365][ C7] b200f3ea
[ 20.355368][ C3] ffffffc0 100c66c0 ffffffc0
[ 20.355374][ C7] aa0003f4
[ 20.355376][ C3]
[ 20.355379][ C3] d0b8 100c739c ffffffc0
[ 20.355385][ C7] eb0a013f
[ 20.355388][ C3] 100bb1c8 ffffffc0 10033ed8
[ 20.355395][ C7] 54000868
[ 20.355397][ C3] ffffffc0 1003305c ffffffc0
[ 20.355404][ C7] b00103c9
[ 20.355406][ C3]
[ 20.355408][ C3] d0d8 100795e4 ffffffc0
[ 20.355415][ C7] 91002129
[ 20.355417][ C3] 106f7eb8 ffffffc0 10709280
[ 20.355424][ C7] f00105aa
[ 20.355426][ C3] ffffffc0 00000000 00000000
[ 20.355433][ C7]
[ 20.355435][ C3]
[ 20.355438][ C3] d0f8 00000000 00000000
[ 20.355444][ C7] 230c
[ 20.355446][ C3] 00000000 00000000 00000000
[ 20.355452][ C7] b8696915
[ 20.355454][ C3] 00000000 00000000 00000000
[ 20.355461][ C7] f947f94a
[ 20.355463][ C3]
[ 20.355465][ C3] d118 00000000 00000000
[ 20.355472][ C7] 910003e1
[ 20.355474][ C3] 00000000 00000000 00000000
[ 20.355481][ C7] 2a1503e0
[ 20.355483][ C3] 00000000 00000000 00000000
[ 20.355490][ C7] f90003ea
[ 20.355491][ C3]
[ 20.355494][ C3] d138 00000000 00000000
[ 20.355500][ C7] 94169465
[ 20.355502][ C3] 00000000 00000000 00000000
[ 20.355509][ C7] f00105bb
[ 20.355511][ C3] 00000000 00000000 00000000
[ 20.355518][ C7] b94f8b68
[ 20.355520][ C3]
[ 20.355522][ C3] d158 00000000 00000000
[ 20.355529][ C7]
[ 20.355531][ C3] 00000000 00000000 00000000
[ 20.355537][ C7] 232c
[ 20.355539][ C3] 00000000 00000000 00000000
[ 20.355546][ C7] 6b08001f
[ 20.355548][ C3]
[ 20.355550][ C3] d178 00000000 00000000
[ 20.355557][ C7] 540000c3
[ 20.355559][ C3] 00000000 00000000 00000000
[ 20.355565][ C7] 910003e0
[ 20.355567][ C3] 00000000 00000000 00000000
[ 20.355574][ C7] 52800101
[ 20.355575][ C3]
[ 20.355578][ C3] d198 00000000 00000000
[ 20.355585][ C7] aa1f03e2
[ 20.355587][ C3] 00000000 00000000 00000000
[ 20.355593][ C7] 94159a85
[ 20.355595][ C3] 00000000 00000000 00000000
[ 20.355602][ C7] b94f8b68
[ 20.355604][ C3]
[ 20.355607][ C3] d1b8 00000000 00000000
[ 20.355613][ C7] 6b15001f
[ 20.355616][ C3] 00000000 00000000 00000000
[ 20.355622][ C7]
[ 20.355624][ C3] 00000000 00000000 00000000
[ 20.355631][ C7] 234c
[ 20.355632][ C3]
[ 20.355635][ C3] d1d8 00000000 00000000
[ 20.355642][ C7] 1a800101
[ 20.355644][ C3] 00000000 00000000 00000000
[ 20.355651][ C7] 6b08003f
[ 20.355653][ C3] 00000000 00000000 00000000
[ 20.355659][ C7] 540005a2
[ 20.355661][ C3]
[ 20.355663][ C3] d1f8 00000000 00000000
[ 20.355670][ C7] 900105d5
[ 20.355672][ C3] 00000000 00000000 00000000
[ 20.355679][ C7] d50339bf
[ 20.355681][ C3] 00000000 00000000 00000000
[ 20.355687][ C7] 9116a2b5
[ 20.355689][ C3]
[ 20.355692][ C3] d218 00000000 00000000
[ 20.355699][ C7] f8615aa8
[ 20.355701][ C3] 00000000 00000000 00000000
[ 20.355707][ C7] b0010409
[ 20.355710][ C3] 00000000 00000000 00000000
[ 20.355716][ C7]
[ 20.355718][ C3]
[ 20.355722][ C3]
[ 20.355722][ C3] X19: 0xffffffc012953da0:
[ 20.355724][ C3] 3ba0 12953bb0 ffffffc0
[ 20.355731][ C7] 236c
[ 20.355733][ C3] 1009f338 ffffffc0 12953c10
[ 20.355740][ C7] 9120a129
[ 20.355742][ C3] ffffffc0 10099fe8 ffffffc0
[ 20.355749][ C7] 3869690a
[ 20.355750][ C3]
[ 20.355753][ C3] 3bc0 f0368ed8 ffffff81
[ 20.355760][ C7] 340000aa
[ 20.355762][ C3] 123f48b0 ffffffc0 f0368ec0
[ 20.355768][ C7] 3828693f
[ 20.355770][ C3] ffffff81 00000000 00000000
[ 20.355777][ C7] 14000023
[ 20.355779][ C3]
[ 20.355781][ C3] 3be0 12953c10 ffffffc0
[ 20.355789][ C7] 2a1f03e0
[ 20.355791][ C3] 1009a048 ffffffc0 fb5796c0
[ 20.355798][ C7] 1400008a
[ 20.355800][ C3] ffffff81 fb5796c0 ffffff81
[ 20.355807][ C7] b001040a
[ 20.355808][ C3]
[ 20.355811][ C3] 3c00 12953c50 00000023
[ 20.355818][ C7]
[ 20.355820][ C3] 80000000 ffffffc0 12953c50
[ 20.355827][ C7] 238c
[ 20.355829][ C3] ffffffc0 10089888 ffffffc0
[ 20.355835][ C7] 9121214a
[ 20.355837][ C3]
[ 20.355840][ C3] 3c20 f0368ec0 ffffff81
[ 20.355846][ C7] f87a6909
[ 20.355848][ C3] 00000009 00000000 12953c40
[ 20.355855][ C7] f86a690b
[ 20.355857][ C3] ffffffc0 100933a0 ffffffc0
[ 20.355864][ C7] 2a0103fb
[ 20.355865][ C3]
[ 20.355868][ C3] 3c40 12953c80 ffffffc0
[ 20.355875][ C7] eb09017f
[ 20.355877][ C3] 1008b204 ffffffc0 00000009
[ 20.355884][ C7] 540002a1
[ 20.355886][ C3] 00000000 1008b1f0 ffffffc0
[ 20.355893][ C7] b001041c
[ 20.355895][ C3]
[ 20.355897][ C3] 3c60 fb5796c0 ffffff81
[ 20.355904][ C7] 9123639c
[ 20.355906][ C3] f0d3e740 ffffff81 00000000
[ 20.355912][ C7]
[ 20.355914][ C3] 00000000 12953cc8 ffffffc0
[ 20.355922][ C7] 23ac
[ 20.355924][ C3]
[ 20.355926][ C3] 3c80 12953ce0 ffffffc0
[ 20.355933][ C7] 387c6908
[ 20.355935][ C3] 10093888 ffffffc0 00000003
[ 20.355941][ C7] 350002c8
[ 20.355944][ C3] 00000000 10093874 ffffffc0
[ 20.355950][ C7] f00105a8
[ 20.355952][ C3]
[ 20.355954][ C3] 3ca0 00000080 00000000
[ 20.355961][ C7] b94fe908
[ 20.355963][ C3] fb5796c0 ffffff81 12953ce0
[ 20.355970][ C7] 35001228
[ 20.355973][ C3] ffffffc0 10093890 ffffffc0
[ 20.355979][ C7] b000ec60
[ 20.355981][ C3]
[ 20.355984][ C3] 3cc0 12953e00 ffffffc0
[ 20.355990][ C7] 91255400
[ 20.355992][ C3] 10002608 ffffffc0 12953cf0
[ 20.355999][ C7] 97fbdf47
[ 20.356001][ C3] ffffffc0 114a1788 ffffffc0
[ 20.356008][ C7]
[ 20.356010][ C3]
[ 20.356012][ C3] 3ce0 12953d00 ffffffc0
[ 20.356019][ C7] 23cc*
[ 20.356021][ C3] 114a14c0 ffffffc0 12953d30
[ 20.356028][ C7] d0012b20
[ 20.356030][ C3] ffffffc0 1149fbfc ffffffc0
[ 20.356037][ C7] 911e0000
[ 20.356038][ C3]
[ 20.356041][ C3] 3d00 12953d10 ffffffc0
[ 20.356048][ C7] aa1f03e1
[ 20.356050][ C3] 1149fca0 ffffffc0 12953d20
[ 20.356057][ C7] aa1f03e2
[ 20.356059][ C3] ffffffc0 1149fc3c ffffffc0
[ 20.356065][ C7] d4210000
[ 20.356067][ C3]
[ 20.356070][ C3] 3d20 12953e60 ffffffc0
[ 20.356076][ C7] 97fcb563
[ 20.356078][ C3] 10002608 ffffffc0 fb5796c0
[ 20.356085][ C7] f87b7aa8
[ 20.356087][ C3] ffffff81 f0368ec0 ffffff81
[ 20.356094][ C7] 52800029
[ 20.356096][ C3]
[ 20.356098][ C3] 3d40 12953d60 ffffffc0
[ 20.356105][ C7]
[ 20.356107][ C3] 114a1788 ffffffc0 ffffffff
[ 20.356114][ C7] 23ec
[ 20.356116][ C3] 0000007f 12953da0 ffffffc0
[ 20.356123][ C7] 383c6909
[ 20.356124][ C3]
[ 20.356127][ C3] 3d60 12953d70 ffffffc0
[ 20.356134][ C7] 14000006
[ 20.356136][ C3] 1149fbfc ffffffc0 12953d90
[ 20.356143][ C7] f87b7aab
[ 20.356145][ C3] ffffffc0 1149fb98 ffffffc0
[ 20.356152][ C7] f8286949
[ 20.356153][ C3]
[ 20.356156][ C3] 3d80 f0368ec0 ffffff81
[ 20.356163][ C7] b0010408
[ 20.356165][ C3] 1149fc3c ffffffc0 12953ed0
[ 20.356171][ C7] 91236108
[ 20.356174][ C3] ffffffc0 10002590 ffffffc0
[ 20.356180][ C7] 3828697f
[ 20.356182][ C3]
[ 20.356185][ C3] 3da0* f0368ec0 ffffff81
[ 20.356192][ C7] d53cd048
[ 20.356194][ C3] 11dcc94e ffffffc0 00000003
[ 20.356200][ C7]
[ 20.356202][ C3] 00000000 00000008 00000000
[ 20.356209][ C7] 240c
[ 20.356210][ C3]
[ 20.356213][ C3] 3dc0 00009c7a 00000000
[ 20.356220][ C7] f87a6909
[ 20.356222][ C3] e5b906e6 00000000 5faf672a
[ 20.356228][ C7] b0010415
[ 20.356230][ C3] 0292a3e0 20654943 6b6e694c
[ 20.356237][ C7] 912242b5
[ 20.356239][ C3]
[ 20.356242][ C3] 3de0 000000e0 00000000
[ 20.356249][ C7] 91000529
[ 20.356251][ C3] 00009c7c 00000000 00009c7a
[ 20.356258][ C7] f83a6909
[ 20.356260][ C3] 00000000 00000000 40000000
[ 20.356266][ C7] d53cd048
[ 20.356268][ C3]
[ 20.356271][ C3] 3e00 000025b8 00000000
[ 20.356278][ C7] 8b150100
[ 20.356280][ C3] 00002462 00000000 00000064
[ 20.356287][ C7] 97fd6846
[ 20.356289][ C3] 00000000 00000002 00000000
[ 20.356295][ C7]
[ 20.356296][ C3]
[ 20.356299][ C3] 3e20 00000001 00000000
[ 20.356306][ C7] 242c
[ 20.356308][ C3] 000002b9 00000000 127fd030
[ 20.356315][ C7] 360001c0
[ 20.356317][ C3] ffffffc0 f0368ec0 ffffff81
[ 20.356324][ C7] b00103c9
[ 20.356325][ C3]
[ 20.356328][ C3] 3e40 121cb008 ffffffc0
[ 20.356335][ C7] d53cd048
[ 20.356337][ C3] 00000008 00000000 f0368ec0
[ 20.356344][ C7] b835691f
[ 20.356347][ C3] ffffff81 12209000 ffffffc0
[ 20.356353][ C7] 91002129
[ 20.356355][ C3]
[ 20.356358][ C3] 3e60 00000000 00000000
[ 20.356364][ C7] d53cd048
[ 20.356366][ C3] 00000000 00000000 00000000
[ 20.356373][ C7] b8696900
[ 20.356375][ C3] 00000000 00000000 00000000
[ 20.356382][ C7] b0010409
[ 20.356383][ C3]
[ 20.356386][ C3] 3e80 00000000 00000000
[ 20.356393][ C7]
[ 20.356395][ C3] 12953ef0 ffffffc0 114a0be8
[ 20.356402][ C7] 244c
[ 20.356404][ C3] ffffffc0 12953ef0 ffffffc0
[ 20.356411][ C7] 9122c129
[ 20.356413][ C3]
[ 20.356416][ C3] 3ea0 114a0bf0 ffffffc0
[ 20.356423][ C7] 90000001
[ 20.356425][ C3] 60800009 00000000 12953ef0
[ 20.356431][ C7] 8b090103
[ 20.356434][ C3] ffffffc0 10111b94 ffffffc0
[ 20.356440][ C7] 9118f021
[ 20.356442][ C3]
[ 20.356445][ C3] 3ec0 ffffffff ffffffff
[ 20.356451][ C7] aa1f03e2
[ 20.356453][ C3] fb5796c0 ffffff81 12953ef0
[ 20.356460][ C7] 97ffbd7b
[ 20.356462][ C3] ffffffc0 114a0bf0 ffffffc0
[ 20.356469][ C7] f9401a88
[ 20.356470][ C3]
[ 20.356473][ C3] 3ee0 12953ef0 ffffffc0
[ 20.356480][ C7] 900105c9
[ 20.356482][ C3] 00000001 00000000 12953f00
[ 20.356488][ C7]
[ 20.356491][ C3] ffffffc0 114a8c04 ffffffc0
[ 20.356497][ C7] 246c
[ 20.356499][ C3]
[ 20.356502][ C3] 3f00 12953f30 ffffffc0
[ 20.356509][ C7] f9401135
[ 20.356511][ C3] 10096eac ffffffc0 00000000
[ 20.356518][ C7] f9401908
[ 20.356520][ C3] 00000000 00000000 00000000
[ 20.356526][ C7] d63f0100
[ 20.356528][ C3]
[ 20.356531][ C3] 3f20 00000000 00000000
[ 20.356537][ C7] aa0003e1
[ 20.356540][ C3] e9b0c300 4d4eac75 12953f60
[ 20.356547][ C7] aa1403e0
[ 20.356549][ C3] ffffffc0 10096cb0 ffffffc0
[ 20.356556][ C7] aa1503e2
[ 20.356558][ C3]
[ 20.356561][ C3] 3f40 00000000 00000000
[ 20.356567][ C7] 97feabce
[ 20.356569][ C3] 00000008 00000000 12209db8
[ 20.356576][ C7] b100071f
[ 20.356579][ C3] ffffffc0 f0368ec0 ffffff81
[ 20.356585][ C7]
[ 20.356587][ C3]
[ 20.356589][ C3] 3f60 12953fa0 ffffffc0
[ 20.356596][ C7] 248c
[ 20.356598][ C3] 10096d28 ffffffc0 00000007
[ 20.356605][ C7] 540007c0
[ 20.356607][ C3] 00000000 10096d24 ffffffc0
[ 20.356614][ C7] 97fd0e05
[ 20.356616][ C3]
[ 20.356619][ C3] 3f80 12209000 ffffffc0
[ 20.356626][ C7] 39402329
[ 20.356628][ C3] 12209000 ffffffc0 00000300
[ 20.356635][ C7] aa0003e8
[ 20.356637][ C3] 00000000 00000092 00000000
[ 20.356643][ C7] 52800020
[ 20.356645][ C3]
[ 20.356649][ C3]
[ 20.356649][ C3] X20: 0xffffff81fb56d850:
[ 20.356659][ C7] 36080869
[ 20.363300][ C7] c238 5f636e79 00667374 635f636d 746e756f 25360100 66203a73 656c6961 6f742064
[ 20.363312][ C7] c258 73657220 65767265 61686320 6c656e6e 6e6f6320 74786574 726f6620 61686320
[ 20.363323][ C7] c278 6c656e6e 69777320 2c686374 73696420 6e6e6f63 69746365 2820676e 3d727265
[ 20.363334][ C7] c298
[ 20.363336][ C3]
[ 20.363337][ C7] 0a296425 25360100
[ 20.363347][ C3] CPU1 online:1
[ 20.363359][ C3] EL2(NS) PC: <0xffffffc010035060> __set_fixmap+0xec/0x108
[ 20.363362][ C7] 61203a73 65687475 6369746e 6f697461 6977206e 25206874
[ 20.363371][ C7] c2b8 74204d70 64656d69 74756f20 7325000a 5453203a 70252041 6f6e204d 6f662074
[ 20.363382][ C7] c2d8 00646e75 494b4652 4e5f4c4c 3d454d41 01007325 4c575b36 525f4e41 4c494b46
[ 20.363393][ C7] c2f8 203a5d4c 74697845 0a732520 5b360100 4e414c57 4b46525f 5d4c4c49 7325203a
[ 20.363404][ C7] c318 6e65203a 656c6261 66657220 6b6c6320 72726520 0a21726f 5b360100 4e414c57
[ 20.363477][ C3]
** 2225 console messages dropped **
[ 21.365516][ C3] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 21.365544][ C3] 13: 192 97 55 4709 153 7383 5028 5149 GICv3 26 Level arch_timer
[ 21.365561][ C3] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 21.365578][ C3] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 21.365598][ C3] 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 21.365617][ C3] 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 21.365633][ C3] 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 21.365650][ C3] 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 21.365667][ C3] 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu
[ 21.365683][ C3] 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 21.365700][ C3] 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 21.365716][ C3] 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu
[ 21.365733][ C3] 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu
[ 21.365750][ C3] 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 21.365766][ C3] 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 21.365783][ C3] 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 21.365800][ C3] 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 21.365816][ C3] 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 21.365832][ C3] 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 21.365849][ C3] 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 21.365865][ C3] 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 21.365881][ C3] 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 21.365898][ C3] 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 21.365915][ C3] 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 21.365932][ C3] 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 21.365949][ C3] 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 21.365965][ C3] 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 21.365982][ C3] 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 21.365998][ C3] 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 21.366014][ C3] 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 21.366031][ C3] 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 21.366047][ C3] 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 21.366063][ C3] 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 21.366080][ C3] 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 21.366096][ C3] 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 21.366113][ C3] 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 21.366130][ C3] 64: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 21.366147][ C3] 67: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu
[ 21.366171][ C3] 83: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 21.366187][ C3] 84: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 21.366204][ C3] 85: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 21.366220][ C3] 86: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 21.366243][ C3] 100: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 21.366259][ C3] 101: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 21.366276][ C3] 102: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 21.366292][ C3] 103: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 21.366308][ C3] 104: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 21.366324][ C3] 105: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 21.366341][ C3] 106: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 21.366360][ C3] 114: 0 0 0 0 0 0 0 0 GICv3 295 Level pcie-sys
[ 21.366378][ C3] 119: 0 0 0 0 0 0 0 0 GICv3 275 Level pcie-sys
[ 21.366395][ C3] 122: 0 0 0 0 0 0 0 0 GICv3 272 Level (null)
[ 21.366413][ C3] 126: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 21.366429][ C3] 127: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 21.366438][ C3] PMU:
[ 21.366455][ C3] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 21.366471][ C3] 00000020: 00000000 00000000 00000000 00000000 000000c0 000000c0 000000c0 000000c0
[ 21.366487][ C3] 00000040: 000000c0 000000c0 000000c0 000000c0 00000008 00000008 00000000 00000000
[ 21.366502][ C3] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 21.366518][ C3] 00000080: 064ff800 00000000 00000000 08080808 08080808 0000003c 000000ff 00000000
[ 21.366534][ C3] 000000a0: 00000000 00000000 00000000 00000000 000fffff 00005dc0 00005dc0 000fffff
[ 21.366549][ C3] 000000c0: 00005dc0 00005dc0 000fffff 00005dc0 00005dc0 000fffff 000fffff 000fffff
[ 21.366565][ C3] 000000e0: 000fffff 000fffff 000fffff 000fffff 000fffff 00000000 00000000 00000000
[ 21.366573][ C3] Kernel Offset: disabled
[ 21.366582][ C3] CPU features: 0x000,48040026,6a00aa38
[ 21.366590][ C3] Memory Limit: none
[ 21.370163][ C7] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 21.370172][ C7] 13: 192 97 55 4710 153 7403 5029 5149 GICv3 26 Level arch_timer
[ 21.370179][ C7] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 21.370186][ C7] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 21.370193][ C7] 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 21.370200][ C7] 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 21.370207][ C7] 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 21.370214][ C7] 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 21.370220][ C7] 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu
[ 21.370227][ C7] 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 21.370233][ C7] 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 21.370240][ C7] 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu
[ 21.370246][ C7] 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu
[ 21.370253][ C7] 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 21.370259][ C7] 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 21.370266][ C7] 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 21.370272][ C7] 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 21.370279][ C7] 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 21.370285][ C7] 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 21.370291][ C7] 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 21.370298][ C7] 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 21.370305][ C7] 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 21.370311][ C7] 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 21.370318][ C7] 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 21.370324][ C7] 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 21.370331][ C7] 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 21.370337][ C7] 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 21.370344][ C7] 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 21.370350][ C7] 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 21.370357][ C7] 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 21.370363][ C7] 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 21.370370][ C7] 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 21.370377][ C7] 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 21.370383][ C7] 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 21.370389][ C7] 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 21.370396][ C7] 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 21.370403][ C7] 64: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 21.370409][ C7] 67: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu
[ 21.370418][ C7] 83: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 21.370425][ C7] 84: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 21.370431][ C7] 85: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 21.370438][ C7] 86: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 21.370446][ C7] 100: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 21.370453][ C7] 101: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 21.370459][ C7] 102: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 21.370466][ C7] 103: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 21.370472][ C7] 104: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 21.370479][ C7] 105: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 21.370485][ C7] 106: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 21.370493][ C7] 114: 0 0 0 0 0 0 0 0 GICv3 295 Level pcie-sys
[ 21.370500][ C7] 119: 0 0 0 0 0 0 0 0 GICv3 275 Level pcie-sys
[ 21.370507][ C7] 122: 0 0 0 0 0 0 0 0 GICv3 272 Level (null)
[ 21.370514][ C7] 126: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 21.370520][ C7] 127: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 21.370524][ C7] PMU:
[ 21.370532][ C7] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 21.370540][ C7] 00000020: 00000000 00000000 00000000 00000000 000000c0 000000c0 000000c0 000000c0
[ 21.370548][ C7] 00000040: 000000c0 000000c0 000000c0 000000c0 00000008 00000008 00000000 00000000
[ 21.370556][ C7] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 21.370563][ C7] 00000080: 04cff800 00000000 00000000 08080808 08080808 0000003c 000000ff 00000000
[ 21.370571][ C7] 000000a0: 00000000 00000000 00000000 00000000 000fffff 00005dc0 00005dc0 000fffff
[ 21.370578][ C7] 000000c0: 00005dc0 00005dc0 000fffff 00005dc0 00005dc0 000fffff 000fffff 000fffff
[ 21.370585][ C7] 000000e0: 000fffff 000fffff 000fffff 000fffff 000fffff 00000000 00000000 00000000
[ 21.370589][ C7] Kernel Offset: disabled
[ 21.370593][ C7] CPU features: 0x000,48040026,6a00aa38
[ 21.370596][ C7] Memory Limit: none
[ 25.860700][ C5] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 25.860710][ C5] rcu: 0-…0: (0 ticks this GP) idle=aba/1/0x4000000000000000 softirq=26/26 fqs=1978
[ 25.860716][ C5] (detected by 5, t=6302 jiffies, g=-1151, q=27)
[ 25.860720][ C5] Task dump for CPU 0:
[ 25.860724][ C5] task:rk-pcie state:R running task stack: 0 pid: 148 ppid: 2 flags:0x0000000a
[ 25.860733][ C5] Call trace:
[ 25.860740][ C5] __switch_to+0x178/0x224
[ 25.860747][ C5] of_parse_phandle_with_args+0xc4/0x1b4
[ 25.860752][ C5] 0x0
[ 25.860756][ C5] CPU0 online:1
[ 25.860766][ C5] EL2(NS) PC: <0xffffffc01079e9e8> dw_pcie_read_dbi+0x68/0xd4
[ 25.860888][ C5]
[ 25.860892][ C5] CPU1 online:1
[ 25.860900][ C5] EL2(NS) PC: <0xffffffc010035060> __set_fixmap+0xec/0x108
[ 25.861022][ C5]
[ 25.861025][ C5] CPU2 online:1
[ 25.861033][ C5] EL2(NS) PC: <0xffffffc0114a0bc8> __cpu_do_idle+0x8/0x14
[ 25.861156][ C5]
[ 25.861159][ C5] CPU3 online:1
[ 25.861166][ C5] EL2(NS) PC: <0xffffffc0114a0bc8> __cpu_do_idle+0x8/0x14
[ 25.861288][ C5]
[ 25.861292][ C5] CPU4 online:1
[ 25.861300][ C5] EL2(NS) PC: <0xffffffc010259670> unmap_kernel_range+0x74/0x90
[ 25.861425][ C5]
[ 25.861428][ C5] CPU5 online:1
[ 25.861436][ C5] EL2(NS) PC: <0xffffffc010823f80> rockchip_panic_notify+0x278/0x39c
[ 25.861561][ C5]
[ 25.861565][ C5] CPU6 online:1
[ 25.861572][ C5] EL2(NS) PC: <0xffffffc0114a0bc0> __cpu_do_idle+0x0/0x14
[ 25.861698][ C5]
[ 25.861701][ C5] CPU7 online:1
[ 25.861708][ C5] EL2(NS) PC: <0xffffffc0114a0bc0> __cpu_do_idle+0x0/0x14
[ 25.861833][ C5]
[ 25.861840][ C5] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 25.861850][ C5] 13: 192 97 207 6058 153 9354 6377 6497 GICv3 26 Level arch_timer
[ 25.861858][ C5] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 25.861865][ C5] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 25.861874][ C5] 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 25.861881][ C5] 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 25.861888][ C5] 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 25.861894][ C5] 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 25.861901][ C5] 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu
[ 25.861907][ C5] 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 25.861914][ C5] 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 25.861921][ C5] 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu
[ 25.861927][ C5] 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu
[ 25.861934][ C5] 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 25.861940][ C5] 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 25.861946][ C5] 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 25.861953][ C5] 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 25.861960][ C5] 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 25.861967][ C5] 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 25.861973][ C5] 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 25.861980][ C5] 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 25.861987][ C5] 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 25.861993][ C5] 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 25.862000][ C5] 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 25.862007][ C5] 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 25.862014][ C5] 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 25.862021][ C5] 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 25.862028][ C5] 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 25.862034][ C5] 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 25.862041][ C5] 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 25.862047][ C5] 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 25.862054][ C5] 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 25.862061][ C5] 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 25.862067][ C5] 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 25.862074][ C5] 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 25.862081][ C5] 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 25.862087][ C5] 64: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 25.862095][ C5] 67: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu
[ 25.862104][ C5] 83: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 25.862110][ C5] 84: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 25.862117][ C5] 85: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 25.862124][ C5] 86: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 25.862133][ C5] 100: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 25.862140][ C5] 101: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 25.862146][ C5] 102: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 25.862153][ C5] 103: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 25.862159][ C5] 104: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 25.862166][ C5] 105: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 25.862172][ C5] 106: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 25.862180][ C5] 114: 0 0 0 0 0 0 0 0 GICv3 295 Level pcie-sys
[ 25.862187][ C5] 119: 0 0 0 0 0 0 0 0 GICv3 275 Level pcie-sys
[ 25.862194][ C5] 122: 0 0 0 0 0 0 0 0 GICv3 272 Level (null)
[ 25.862201][ C5] 126: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 25.862208][ C5] 127: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 26.862339][ C5] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 26.862347][ C5] 13: 192 97 307 6358 153 9354 6677 6797 GICv3 26 Level arch_timer
[ 26.862354][ C5] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 26.862360][ C5] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 26.862368][ C5] 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 26.862375][ C5] 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 26.862382][ C5] 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 26.862389][ C5] 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 26.862395][ C5] 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu
[ 26.862402][ C5] 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 26.862408][ C5] 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 26.862415][ C5] 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu
[ 26.862421][ C5] 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu
[ 26.862428][ C5] 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 26.862434][ C5] 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 26.862441][ C5] 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 26.862447][ C5] 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 26.862454][ C5] 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 26.862460][ C5] 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 26.862467][ C5] 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 26.862473][ C5] 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 26.862480][ C5] 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 26.862486][ C5] 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 26.862493][ C5] 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 26.862500][ C5] 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 26.862507][ C5] 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 26.862513][ C5] 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 26.862520][ C5] 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 26.862526][ C5] 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 26.862533][ C5] 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 26.862539][ C5] 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 26.862546][ C5] 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 26.862552][ C5] 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 26.862559][ C5] 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 26.862566][ C5] 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 26.862572][ C5] 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 26.862579][ C5] 64: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 26.862586][ C5] 67: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu
[ 26.862594][ C5] 83: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 26.862601][ C5] 84: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 26.862608][ C5] 85: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 26.862614][ C5] 86: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 26.862623][ C5] 100: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 26.862630][ C5] 101: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 26.862636][ C5] 102: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 26.862643][ C5] 103: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 26.862650][ C5] 104: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 26.862656][ C5] 105: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 26.862662][ C5] 106: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 26.862670][ C5] 114: 0 0 0 0 0 0 0 0 GICv3 295 Level pcie-sys
[ 26.862677][ C5] 119: 0 0 0 0 0 0 0 0 GICv3 275 Level pcie-sys
[ 26.862684][ C5] 122: 0 0 0 0 0 0 0 0 GICv3 272 Level (null)
[ 26.862691][ C5] 126: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 26.862698][ C5] 127: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 26.862702][ C5] PMU:
[ 26.862710][ C5] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 26.862718][ C5] 00000020: 00000000 00000000 00000000 00000000 000000c0 000000c0 000000c0 000000c0
[ 26.862725][ C5] 00000040: 000000c0 000000c0 000000c0 000000c0 00000008 00000008 00000000 00000000
[ 26.862732][ C5] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 26.862740][ C5] 00000080: 0ccff800 00000000 00000000 08080808 08080808 0000003c 000000ff 00000000
[ 26.862747][ C5] 000000a0: 00000000 00000000 00000000 00000000 000fffff 00005dc0 00005dc0 000fffff
[ 26.862755][ C5] 000000c0: 00005dc0 00005dc0 000fffff 00005dc0 00005dc0 000fffff 000fffff 000fffff
[ 26.862762][ C5] 000000e0: 000fffff 000fffff 000fffff 000fffff 000fffff 00000000 00000000 00000000
[ 26.862765][ C5] Kernel Offset: disabled
[ 26.862769][ C5] CPU features: 0x000,48040026,6a00aa38
[ 26.862773][ C5] Memory Limit: none
[ 88.877353][ C7] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 88.877363][ C7] rcu: 0-…0: (0 ticks this GP) idle=aba/1/0x4000000000000000 softirq=26/26 fqs=8281
[ 88.877369][ C7] (detected by 7, t=25207 jiffies, g=-1151, q=27)
[ 88.877373][ C7] Task dump for CPU 0:
[ 88.877377][ C7] task:rk-pcie state:R running task stack: 0 pid: 148 ppid: 2 flags:0x0000000a
[ 88.877384][ C7] Call trace:
[ 88.877391][ C7] __switch_to+0x178/0x224
[ 88.877398][ C7] of_parse_phandle_with_args+0xc4/0x1b4
[ 88.877402][ C7] 0x0
[ 88.877406][ C7] CPU0 online:1
[ 88.877414][ C7] EL2(NS) PC: <0xffffffc01079e9e8> dw_pcie_read_dbi+0x68/0xd4
[ 88.877536][ C7]
[ 88.877540][ C7] CPU1 online:1
[ 88.877547][ C7] EL2(NS) PC: <0xffffffc010035060> __set_fixmap+0xec/0x108
[ 88.877669][ C7]
[ 88.877673][ C7] CPU2 online:1
[ 88.877680][ C7] EL2(NS) PC: <0xffffffc0114a0bc8> __cpu_do_idle+0x8/0x14
[ 88.877802][ C7]
[ 88.877805][ C7] CPU3 online:1
[ 88.877813][ C7] EL2(NS) PC: <0xffffffc0114a0bc8> __cpu_do_idle+0x8/0x14
[ 88.877935][ C7]
[ 88.877938][ C7] CPU4 online:1
[ 88.877946][ C7] EL2(NS) PC: <0xffffffc010259670> unmap_kernel_range+0x74/0x90
[ 88.878071][ C7]
[ 88.878074][ C7] CPU5 online:1
[ 88.878081][ C7] EL2(NS) PC: <0xffffffc0114a0bc0> __cpu_do_idle+0x0/0x14
[ 88.878207][ C7]
[ 88.878210][ C7] CPU6 online:1
[ 88.878217][ C7] EL2(NS) PC: <0xffffffc0114a0bc0> __cpu_do_idle+0x0/0x14
[ 88.878290][ C7] EL2(NS) PC: <0xffffffc010715088> gic_handle_irq+0x60/0x154
[ 88.878296][ C7] EL2(NS) PC: <0xffffffc01081a72c> console_put+0xa0/0x164
[ 88.878303][ C7] EL2(NS) PC: <0xffffffc01081a6e4> console_put+0x58/0x164
[ 88.878309][ C7] EL2(NS) PC: <0xffffffc01000ac18> __switch_to+0x90/0x224
[ 88.878316][ C7] EL2(NS) PC: <0xffffffc0114a0bc0> __cpu_do_idle+0x0/0x14
[ 88.878368][ C7]
[ 88.878372][ C7] CPU7 online:1
[ 88.878379][ C7] EL2(NS) PC: <0xffffffc010823f80> rockchip_panic_notify+0x278/0x39c
[ 88.878504][ C7]
[ 88.878510][ C7] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 88.878518][ C7] 13: 192 97 6524 24973 153 28595 25330 25418 GICv3 26 Level arch_timer
[ 88.878525][ C7] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 88.878532][ C7] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 88.878540][ C7] 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 88.878547][ C7] 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 88.878554][ C7] 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 88.878560][ C7] 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 88.878567][ C7] 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu
[ 88.878573][ C7] 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 88.878580][ C7] 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 88.878586][ C7] 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu
[ 88.878592][ C7] 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu
[ 88.878599][ C7] 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 88.878606][ C7] 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 88.878612][ C7] 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 88.878619][ C7] 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 88.878625][ C7] 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 88.878632][ C7] 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 88.878638][ C7] 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 88.878645][ C7] 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 88.878651][ C7] 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 88.878658][ C7] 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 88.878664][ C7] 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 88.878671][ C7] 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 88.878678][ C7] 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 88.878684][ C7] 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 88.878691][ C7] 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 88.878697][ C7] 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 88.878704][ C7] 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 88.878710][ C7] 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 88.878717][ C7] 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 88.878723][ C7] 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 88.878730][ C7] 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 88.878736][ C7] 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 88.878743][ C7] 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 88.878750][ C7] 64: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 88.878757][ C7] 67: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu
[ 88.878765][ C7] 83: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 88.878772][ C7] 84: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 88.878779][ C7] 85: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 88.878785][ C7] 86: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 88.878794][ C7] 100: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 88.878800][ C7] 101: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 88.878807][ C7] 102: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 88.878814][ C7] 103: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 88.878820][ C7] 104: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 88.878826][ C7] 105: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 88.878833][ C7] 106: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 88.878840][ C7] 114: 0 0 0 0 0 0 0 0 GICv3 295 Level pcie-sys
[ 88.878847][ C7] 119: 0 0 0 0 0 0 0 0 GICv3 275 Level pcie-sys
[ 88.878854][ C7] 122: 0 0 0 0 0 0 0 0 GICv3 272 Level (null)
[ 88.878861][ C7] 126: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 88.878868][ C7] 127: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 89.878999][ C7] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[ 89.879009][ C7] 13: 192 97 6624 25273 153 28895 25974 25418 GICv3 26 Level arch_timer
[ 89.879016][ C7] 14: 0 0 0 0 0 0 0 0 GICv3 321 Level rk_timer
[ 89.879022][ C7] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[ 89.879030][ C7] 24: 0 0 0 0 0 0 0 0 GICv3 425 Level rockchip_usb2phy
[ 89.879038][ C7] 29: 0 0 0 0 0 0 0 0 GICv3 142 Level fdab9000.iommu
[ 89.879044][ C7] 30: 0 0 0 0 0 0 0 0 GICv3 143 Level fdab9000.iommu
[ 89.879051][ C7] 31: 0 0 0 0 0 0 0 0 GICv3 144 Level fdab9000.iommu
[ 89.879058][ C7] 32: 0 0 0 0 0 0 0 0 GICv3 152 Level fdb50000.vepu
[ 89.879064][ C7] 33: 0 0 0 0 0 0 0 0 GICv3 151 Level fdb50400.vdpu
[ 89.879070][ C7] 34: 0 0 0 0 0 0 0 0 GICv3 150 Level fdb50800.iommu
[ 89.879077][ C7] 35: 0 0 0 0 0 0 0 0 GICv3 146 Level fdb60f00.iommu
[ 89.879083][ C7] 36: 0 0 0 0 0 0 0 0 GICv3 147 Level fdb70f00.iommu
[ 89.879090][ C7] 38: 0 0 0 0 0 0 0 0 GICv3 161 Level fdb90000.jpegd
[ 89.879096][ C7] 39: 0 0 0 0 0 0 0 0 GICv3 162 Level fdb90480.iommu
[ 89.879103][ C7] 40: 0 0 0 0 0 0 0 0 GICv3 154 Level fdba0000.jpege-core
[ 89.879109][ C7] 41: 0 0 0 0 0 0 0 0 GICv3 153 Level fdba0800.iommu
[ 89.879116][ C7] 42: 0 0 0 0 0 0 0 0 GICv3 156 Level fdba4000.jpege-core
[ 89.879123][ C7] 43: 0 0 0 0 0 0 0 0 GICv3 155 Level fdba4800.iommu
[ 89.879129][ C7] 44: 0 0 0 0 0 0 0 0 GICv3 158 Level fdba8000.jpege-core
[ 89.879135][ C7] 45: 0 0 0 0 0 0 0 0 GICv3 157 Level fdba8800.iommu
[ 89.879142][ C7] 46: 0 0 0 0 0 0 0 0 GICv3 160 Level fdbac000.jpege-core
[ 89.879148][ C7] 47: 0 0 0 0 0 0 0 0 GICv3 159 Level fdbac800.iommu
[ 89.879155][ C7] 48: 0 0 0 0 0 0 0 0 GICv3 149 Level fdbb0800.iommu, fdbb0000.iep
[ 89.879162][ C7] 49: 0 0 0 0 0 0 0 0 GICv3 133 Level fdbd0000.rkvenc-core
[ 89.879168][ C7] 50: 0 0 0 0 0 0 0 0 GICv3 131 Level fdbdf000.iommu
[ 89.879175][ C7] 51: 0 0 0 0 0 0 0 0 GICv3 132 Level fdbdf000.iommu
[ 89.879181][ C7] 52: 0 0 0 0 0 0 0 0 GICv3 136 Level fdbe0000.rkvenc-core
[ 89.879188][ C7] 53: 0 0 0 0 0 0 0 0 GICv3 134 Level fdbef000.iommu
[ 89.879194][ C7] 54: 0 0 0 0 0 0 0 0 GICv3 135 Level fdbef000.iommu
[ 89.879201][ C7] 55: 0 0 0 0 0 0 0 0 GICv3 127 Level fdc38100.rkvdec-core
[ 89.879207][ C7] 56: 0 0 0 0 0 0 0 0 GICv3 128 Level fdc38700.iommu
[ 89.879214][ C7] 57: 0 0 0 0 0 0 0 0 GICv3 129 Level fdc48100.rkvdec-core
[ 89.879220][ C7] 58: 0 0 0 0 0 0 0 0 GICv3 130 Level fdc48700.iommu
[ 89.879227][ C7] 59: 0 0 0 0 0 0 0 0 GICv3 140 Level av1d-master
[ 89.879234][ C7] 62: 0 0 0 0 0 0 0 0 GICv3 141 Level fdca0000.iommu
[ 89.879241][ C7] 64: 0 0 0 0 0 0 0 0 GICv3 145 Level fdce0800.iommu
[ 89.879247][ C7] 67: 0 0 0 0 0 0 0 0 GICv3 188 Level fdd97e00.iommu
[ 89.879256][ C7] 83: 0 0 0 0 0 0 0 0 GICv3 118 Level fea10000.dma-controller
[ 89.879263][ C7] 84: 0 0 0 0 0 0 0 0 GICv3 119 Level fea10000.dma-controller
[ 89.879270][ C7] 85: 0 0 0 0 0 0 0 0 GICv3 120 Level fea30000.dma-controller
[ 89.879277][ C7] 86: 0 0 0 0 0 0 0 0 GICv3 121 Level fea30000.dma-controller
[ 89.879285][ C7] 100: 0 0 0 0 0 0 0 0 GICv3 122 Level fed10000.dma-controller
[ 89.879292][ C7] 101: 0 0 0 0 0 0 0 0 GICv3 123 Level fed10000.dma-controller
[ 89.879298][ C7] 102: 0 0 0 0 0 0 0 0 GICv3 309 Level (null)
[ 89.879305][ C7] 103: 0 0 0 0 0 0 0 0 GICv3 310 Level (null)
[ 89.879312][ C7] 104: 0 0 0 0 0 0 0 0 GICv3 311 Level (null)
[ 89.879318][ C7] 105: 0 0 0 0 0 0 0 0 GICv3 312 Level (null)
[ 89.879324][ C7] 106: 0 0 0 0 0 0 0 0 GICv3 313 Level (null)
[ 89.879332][ C7] 114: 0 0 0 0 0 0 0 0 GICv3 295 Level pcie-sys
[ 89.879339][ C7] 119: 0 0 0 0 0 0 0 0 GICv3 275 Level pcie-sys
[ 89.879346][ C7] 122: 0 0 0 0 0 0 0 0 GICv3 272 Level (null)
[ 89.879353][ C7] 126: 0 0 0 0 0 0 0 0 GICv3 455 Edge debug-signal
[ 89.879359][ C7] 127: 0 0 0 0 0 0 0 0 GICv3 365 Level debug
[ 89.879363][ C7] PMU:
[ 89.879371][ C7] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 89.879378][ C7] 00000020: 00000000 00000000 00000000 00000000 000000c0 000000c0 000000c0 000000c0
[ 89.879386][ C7] 00000040: 000000c0 000000c0 000000c0 000000c0 00000008 00000008 00000000 00000000
[ 89.879392][ C7] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 89.879400][ C7] 00000080: 06cff800 00000000 00000000 08080808 08080808 0000003c 000000ff 00000000
[ 89.879407][ C7] 000000a0: 00000000 00000000 00000000 00000000 000fffff 00005dc0 00005dc0 000fffff
[ 89.879414][ C7] 000000c0: 00005dc0 00005dc0 000fffff 00005dc0 00005dc0 000fffff 000fffff 000fffff
[ 89.879421][ C7] 000000e0: 000fffff 000fffff 000fffff 000fffff 000fffff 00000000 00000000 00000000
[ 89.879425][ C7] Kernel Offset: disabled
[ 89.879429][ C7] CPU features: 0x000,48040026,6a00aa38
[ 89.879432][ C7] Memory Limit: none
rk3588_728_.zip (26.2 KB)
