固件文件名称:FFMedia
固件下载地址:Firefly-Linux / ffmedia_release · GitLab
Log日志:1.zip
在使用官方的FFMedia python demo中
cv_display.module = last_module.addExternalConsumer("Cv2Display", cv_display, cv2_extcall_back)
在cv2_extcall_back回调函数中,打印日志发现没有效果
firefly@firefly:~/project/ffmedia_release/demo$ python3 ./demo.py -i rtsp://admin:a88888888@192.168.10.10:554/Streaming/Channels/1 --rtsp_transport 1 -b RGB24 -c 1
Firefly FFMedia: v2.1.1
input source is a rtsp url
INFO: ff_media: connectToServer: connected to server 192.168.10.10:554
INFO: 16ModuleRtspClient: init: rtsp para w h: 1280 720, ws hs: 1280 720, format: H264
mpp[1411]: mpp_rt: NOT found ion allocator
mpp[1411]: mpp_rt: found drm allocator
mpp[1411]: mpp_info: mpp version: 8a85dc5d author: Herman Chen 2022-03-14 [mpp_enc]: Fix stuck on reset async mode encoder
librga fail to get driver version! Legacy mode will be enabled.
rga_api version 1.7.0_[1]
======================1====================================
wait...INFO: 10MppDecoder: getTimeoutSample: 0x1aeea80 frame info changed 1 error 0 discard 0
RgaBlit(1387) RGA_BLIT fail: Bad address
RgaBlit(1388) RGA_BLIT fail: Bad address
fd-vir-phy-hnd-format[18, (nil), (nil), (nil), 0]
rect[0, 0, 1280, 720, 1280, 720, 2560, 0]
f-blend-size-rotation-col-log-mmu[0, 0, 0, 0, 0, 0, 1]
fd-vir-phy-hnd-format[35, (nil), (nil), (nil), 0]
rect[0, 0, 1280, 720, 1280, 720, 1792, 0]
This output the user patamaters when rga call blit fail
ERROR: 9ModuleRga: work: Consume failed
fd-vir-phy-hnd-format[19, (nil), (nil), (nil), 0]
fd-vir-phy-hnd-format[20, (nil), (nil), (nil), 0]
fd-vir-phy-hnd-format[21, (nil), (nil), (nil), 0]
fd-vir-phy-hnd-format[22, (nil), (nil), (nil), 0]
fd-vir-phy-hnd-format[23, (nil), (nil), (nil), 0]
代码如下
def cv2_extcall_back(obj, VideoBuffer):
print('=========================2========================')
vb = m.VideoBuffer.from_base(VideoBuffer)
if obj.sync is not None:
delay = obj.sync.updateVideo(vb.getPUstimestamp(), 0)
if delay > 0:
time.sleep(delay/1000000)
data = vb.getActiveData()
try:
img = data.reshape((vb.getImagePara().vstride, vb.getImagePara().hstride, 3))
print("------------------------")
except ValueError:
print("Invalid image resolution!")
resolution = find_two_numbers(data.size//3, vb.getImagePara().hstride, vb.getImagePara().vstride)
print("Try the recommended resolution: -o {}x{}".format(resolution[0], resolution[1]))
exit(-1)
for i in range(obj.count):
cv2.imshow(obj.name + str(i), img)
cv2.waitKey(1)
1.zip (516 Bytes)
