编译AIO 3588Q Linux SDK时,按照网页维基教程编译buildroot固件,单步编译buildroot时,出现如下错误:
2023-08-02T10:00:06 wget --passive-ftp -nd -t 3 --no-check-certificate -O ‘/home/ubuntu/Desktop/project/rk3588_sdk/buildroot/output/firefly_rk3588/build/.SourceHanSansCN.zip.N8j49J/output’ ‘https://raw.githubusercontent.com/adobe-fonts/source-han-sans/2.001R/SubsetOTF/SourceHanSansCN.zip’
2023-08-02T10:00:06 --2023-08-02 10:00:06-- https://raw.githubusercontent.com/adobe-fonts/source-han-sans/2.001R/SubsetOTF/SourceHanSansCN.zip
2023-08-02T10:00:06 Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 0.0.0.0, ::
2023-08-02T10:00:06 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|0.0.0.0|:443… failed: Connection refused.
2023-08-02T10:00:06 Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|::|:443… failed: Connection refused.
2023-08-02T10:00:06 wget --passive-ftp -nd -t 3 --no-check-certificate -O ‘/home/ubuntu/Desktop/project/rk3588_sdk/buildroot/output/firefly_rk3588/build/.SourceHanSansCN.zip.zOHlg4/output’ ‘http://sources.buildroot.net/source-han-sans-cn/SourceHanSansCN.zip’
2023-08-02T10:00:06 --2023-08-02 10:00:06-- http://sources.buildroot.net/source-han-sans-cn/SourceHanSansCN.zip
2023-08-02T10:00:06 Resolving sources.buildroot.net (sources.buildroot.net)… 104.26.1.37, 104.26.0.37, 172.67.72.56, …
2023-08-02T10:00:06 Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.1.37|:80… connected.
2023-08-02T10:00:07 HTTP request sent, awaiting response… 404 Not Found
2023-08-02T10:00:07 2023-08-02 10:00:07 ERROR 404: Not Found.
2023-08-02T10:00:07
2023-08-02T10:00:07 wget --passive-ftp -nd -t 3 --no-check-certificate -O ‘/home/ubuntu/Desktop/project/rk3588_sdk/buildroot/output/firefly_rk3588/build/.SourceHanSansCN.zip.JhMcBn/output’ ‘http://sources.buildroot.net/SourceHanSansCN.zip’
2023-08-02T10:00:07 --2023-08-02 10:00:07-- http://sources.buildroot.net/SourceHanSansCN.zip
2023-08-02T10:00:07 Resolving sources.buildroot.net (sources.buildroot.net)… 104.26.1.37, 104.26.0.37, 172.67.72.56, …
2023-08-02T10:00:07 Connecting to sources.buildroot.net (sources.buildroot.net)|104.26.1.37|:80… connected.
2023-08-02T10:00:07
2023-08-02T10:00:07 make[1]: *** [package/pkg-generic.mk:207: /home/ubuntu/Desktop/project/rk3588_sdk/buildroot/output/firefly_rk3588/build/source-han-sans-cn-2.001R/.stamp_downloaded] Error 1
2023-08-02T10:00:07 make: *** [Makefile:110: _all] Error 2
2023-08-02T10:00:07 make: Leaving directory ‘/home/ubuntu/Desktop/project/rk3588_sdk/buildroot’
Please check details in /home/ubuntu/Desktop/project/rk3588_sdk/.buildroot/br.log
you take 0:13.87 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 1318:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $RK_CFG_BUILDROOT $DST_DIR
没有社区技术员来看一下吗?麻烦大家帮忙看看问题,感谢
这个社区只是发布问题的么?
