New 802.11ac Standard with IPQ4018 IPQ4028 Dual Band Support|Wally DR40X8
Introduction
The demand for faster, more reliable wireless connectivity continues to escalate as the world becomes increasingly connected. To address these requirements, the networking industry has been diligently working on advancements in the 802.11ac standard. Among the significant improvements is the integration of dual-band support through Qualcomm Technologies’ IPQ4018 and IPQ4028 chipsets. This technical post delves into the features and capabilities of these chipsets and their contributions to the latest 802.11ac standard.
I. Overview of the 802.11ac Standard
The 802.11ac standard, also known as Wi-Fi 5, is the fifth-generation Wi-Fi technology, designed to enhance wireless performance and efficiency. It operates on both 2.4 GHz and 5 GHz frequency bands, enabling higher data rates and improved overall network performance. The 802.11ac standard uses Multiple Input Multiple Output (MIMO) technology to leverage multiple antennas for data transmission and reception, allowing for increased data throughput and better signal reception.
II. Introduction to IPQ4018 and IPQ4028 Chipsets
The IPQ4018 and IPQ4028 chipsets are innovative solutions from Qualcomm Technologies, purpose-built to support the 802.11ac standard with dual-band capabilities. These chipsets are designed to power next-generation routers, access points, and other wireless networking devices, bringing superior connectivity and performance to a wide range of applications.
1. IPQ4018 Chipset
The IPQ4018 is a highly integrated and power-efficient chipset designed for low-to-mid-range wireless networking devices. It features a quad-core ARM Cortex-A7 processor with a clock speed of up to 717 MHz, delivering ample processing power to handle various networking tasks. The chipset is equipped with advanced network acceleration and security features, ensuring optimal data throughput while maintaining robust security protocols.
2. IPQ4028 Chipset
The IPQ4028, an extension of the IPQ4018, is designed for more demanding networking applications. It retains the same quad-core ARM Cortex-A7 processor but offers a higher clock speed of up to 1.4 GHz, making it suitable for high-performance routers and enterprise-grade access points. With increased processing power, the IPQ4028 can handle a more extensive array of connected devices and bandwidth-intensive tasks with ease.
III. Dual-Band Support in IPQ4018 and IPQ4028
One of the standout features of the IPQ4018 and IPQ4028 chipsets is their support for both 2.4 GHz and 5 GHz frequency bands. This dual-band capability enables enhanced network flexibility and performance. Here’s a closer look at the benefits of dual-band support:
1. Increased Network Capacity: By operating on two separate frequency bands, devices can be efficiently distributed between 2.4 GHz and 5 GHz, reducing network congestion and improving overall network capacity.
2. Better Throughput and Performance: The 5 GHz band offers higher data rates and less interference compared to the crowded 2.4 GHz band. Devices that support 5 GHz can experience improved throughput and lower latency, resulting in smoother and more responsive connections.
3. Enhanced Device Compatibility: Dual-band support ensures that both legacy devices (compatible with 2.4 GHz) and newer, high-performance devices (compatible with 5 GHz) can connect to the network seamlessly.
4. Smart Band Steering: With dual-band support, routers and access points equipped with IPQ4018 and IPQ4028 can perform band steering, intelligently directing devices to the most suitable frequency band for their capabilities, thereby optimizing network performance.
Conclusion
The integration of the IPQ4018 and IPQ4028 chipsets with dual-band support marks a significant milestone in advancing the 802.11ac standard. These chipsets deliver robust processing power, improved network performance, and enhanced device compatibility, making them ideal solutions for various wireless networking applications. With the increasing demand for faster and more reliable wireless connectivity, the IPQ4018 and IPQ4028 chipsets play a crucial role in shaping the future of wireless networking technology.
Wallys//[b]IPQ4018[/b]/IPQ4028chipset/Routerboard/DR40X8H-high-powersupport-MU-MIMO-802.11ac
Website:
[u]https://www.wallystech.com/Routerboard/DR40X8H-Qualcomm-IPQ4018-IPQ4028-2T2R-Dual-Band-2-4GHz-5GHz-high-power-support-MU-MIMO-802.11ac-Wave-2.html[/u]
Product Parameter:
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Operating Temperature Range -40 to +60 ºC
Storage Temperature Range -65 to +105 ºC
Operating Humidity Range 5 to +95 (non-condensing )%
Hardware Specifications
Symbol Parameter
CPU IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional) 3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS Compliance YES
Dimension 115mm x 105mm x 16mm
Nor Flash 2MB~32MB
Nand Flash 128MB
DDR 256MB
EMAIL:​sales4@wallystech.com
