WiFi 6E IoT Solutions: IPQ5018 QCN9074 vs. IPQ5018 QCN6122|DR5018 SOM
Next Frontier WiFi 6E IoT Solutions: IPQ5018 QCN9074 vs. IPQ5018 QCN6122|DR5018 SOM
In the rapidly evolving landscape of wireless technology, the emergence of WiFi 6E has ushered in a new era of connectivity, promising faster speeds, greater capacity, and reduced latency. Amid this revolution, two formidable contenders have stepped onto the stage: the IPQ5018 QCN9074 and the IPQ5018 QCN6122. These advanced IoT wireless solutions are poised to redefine how we connect, communicate, and collaborate in the Internet of Things (IoT) ecosystem.
IPQ5018 QCN9074: A Synonym for Seamless Connectivity
The IPQ5018 QCN9074 is a powerhouse in the world of wireless connectivity. Built on the foundation of WiFi 6E, this solution seamlessly integrates into the ever-growing IoT network, catering to the escalating demands of smart homes, industrial automation, healthcare, and more.
Key Features:
Tri-Band Advantage:Operating on the 2.4GHz, 5GHz, and 6GHz frequency bands, the IPQ5018 QCN9074 unlocks unparalleled connectivity options, reducing congestion and ensuring optimal performance for a multitude of devices.
Blazing-Fast Speeds: With support for multi-gigabit data rates, the IPQ5018 QCN9074 empowers data-intensive applications like 4K streaming, VR gaming, and large-scale data transfers, all with minimal lag.
Enhanced IoT Security: Security remains paramount, and the IPQ5018 QCN9074 delivers with robust WPA3 encryption, safeguarding data from potential threats and unauthorized access.
Intelligent MU-MIMO: Multi-User, Multiple Input, Multiple Output technology maximizes network efficiency by simultaneously serving multiple devices, minimizing wait times, and optimizing throughput.
IPQ5018 QCN6122: Redefining IoT Connectivity
The IPQ5018 QCN6122 takes a distinctive approach to IoT wireless solutions, addressing the unique challenges posed by a connected world. This chipset is engineered to power the most intricate and demanding IoT deployments with unmatched reliability and performance.
Key Features:
Advanced Power Management: IoT devices often require optimized power usage to extend battery life. The IPQ5018 QCN6122 excels in this regard, ensuring minimal power consumption without compromising on connectivity.
Edge Computing Capabilities: With integrated edge processing, the QCN6122 chipset reduces latency by processing critical data at the device level, enhancing real-time decision-making and response times.
Wide Range Coverage: From sprawling industrial complexes to remote agricultural setups, the IPQ5018 QCN6122 boasts exceptional coverage, ensuring that connectivity reaches every corner of your IoT deployment.
Seamless Roaming: Transitioning between access points is seamless and uninterrupted, making the IPQ5018 QCN6122 an ideal choice for IoT scenarios where devices are constantly on the move.
The Verdict: Making an Informed Choice
Choosing between the IPQ5018 QCN9074 and the IPQ5018 QCN6122 depends on the specific requirements of your IoT deployment. If you prioritize high-speed, tri-band connectivity for data-intensive applications, the QCN9074 is the frontrunner. On the other hand, if power efficiency, edge computing, and seamless roaming are your top concerns, the QCN6122 holds the key to unlocking unparalleled IoT connectivity.
As the world hurtles towards a more interconnected future, the IPQ5018 QCN9074 and IPQ5018 QCN6122 exemplify the relentless pursuit of innovation, propelling the IoT ecosystem into a realm of limitless possibilities. Your choice between these two solutions will undoubtedly shape the way your IoT devices communicate, collaborate, and contribute to a smarter, more connected world.
DR5018M|Wallys
Website:[u]https://www.wallystech.com/Routerboard/DR5018M-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-QCN6122-QCN6102-wifi-card.html[/u]
Dual-core ARM 64bit A53@1.0GHz Processor
1G DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for QCN6122-6E Card
M.2 Card Slot for QCN6102-5GCard
Support Openwifi
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V-48V(DC Jack)
V
Operating Temperature Range
-40 70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 ~95 (non-condensing)
Storage Humidity Range
0 ~ 90 (non-condensing
HardwareSpecifications
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ5018
CPU Frequency
Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory
512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports
PCIE3.0
1x PCIEx2 Interface
USB3.0
1x USB3.0 Interface
SGMII
1x SGMII Interface
UART
1x UART Interface
GPIO
13 x GPIOs
Wireless
On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax
max 21dBm per chain
2x IPEX Connectors
BLE
on board BLE
VDD OUT
5VDD
Nor Flash
8MB
Nand Flash
128 MB
DDR
512MB
Dimension
60mm x 10mm
EMAIL:​sales4@wallystech.com
