We are thrilled to announce the latest breakthrough in wireless technology - the 802.11ac standard with IPQ4019 and IPQ4029 Dual Band Support. This cutting-edge innovation is set to revolutionize the way we connect, communicate, and experience the internet.
With the ever-increasing demand for faster and more reliable wireless connectivity, the 802.11ac standard steps up to the plate, offering speeds that were once thought to be impossible. Whether you’re streaming high-definition videos, playing online games, or handling large data transfers, this new standard ensures seamless performance like never before.
One of the standout features of the 802.11ac standard is its dual-band support enabled by the powerful IPQ4019 and IPQ4029 chipsets. Operating on both the 2.4GHz and 5GHz frequency bands, these chipsets allow for more concurrent connections and less interference, providing a superior user experience in high-density environments.
Key highlights of the 802.11ac standard with IPQ4019 and IPQ4029 Dual Band Support:
Blazing-Fast Speeds: Experience lightning-fast wireless speeds of up to 1.3Gbps on the 5GHz band, ensuring smooth and lag-free browsing, streaming, and gaming.
Enhanced Coverage: The dual-band support and advanced beamforming technology extend the Wi-Fi coverage, ensuring a strong and stable connection throughout your home or office.
Multi-User MIMO (MU-MIMO): MU-MIMO technology allows multiple devices to connect simultaneously, reducing latency, and improving overall network efficiency.
Seamless Roaming: With support for 802.11k and 802.11v protocols, devices can seamlessly switch between access points without interruptions.
Improved Security: The new standard features the latest security enhancements, ensuring your network is protected from potential threats and unauthorized access.
IoT Ready: The IPQ4019 and IPQ4029 chipsets are designed to support the growing number of IoT devices, making your home smarter and more connected.
Energy-Efficient: Despite its powerful performance, the 802.11ac standard with IPQ4019 and IPQ4029 chipsets is designed to be energy-efficient, helping reduce power consumption and environmental impact.
As technology continues to advance, the demand for faster and more reliable wireless connectivity will only grow. The 802.11ac standard with IPQ4019 and IPQ4029 Dual Band Support is the perfect solution to meet these demands and take wireless networking to new heights.
Stay tuned as leading manufacturers start integrating this groundbreaking technology into their routers, access points, and other wireless devices. Prepare yourself for a whole new era of wireless connectivity, unlocking the true potential of the digital world!
Wallys IPQ4019 IPQ4029 Networking solution:
DR40X9:
DR40X9 is a high-performance, dual-band Wi-Fi5 router designed for both home and office use. It is equipped with two powerful processors - the IPQ4019 and IPQ4029 - which allow it to deliver exceptional wireless performance and coverage.
The IPQ4019 is a quad-core processor that runs at 1.8 GHz and is responsible for managing the router’s wireless connections. It supports 2x2 MU-MIMO (multi-user, multiple-input, multiple-output) technology, which allows the router to communicate with multiple devices simultaneously, improving overall network efficiency and reducing latency.
The IPQ4029, on the other hand, is a dual-core processor that runs at 1.4 GHz and is responsible for managing the router’s wired connections. It has four Gigabit Ethernet ports, which allow users to connect multiple devices directly to the router for faster and more reliable data transfer.
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Support Openwifi
Support QSDK
Support Openwrt
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Symbol
Parameter
CPU
IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector
1xSFP fiber module connector (optional)
3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector
1xUSB 3.0 connector
POE
24V~48V passive POE
DC Jack
24V~48V power supply
ROHS Compliance
YES
Dimension
115mm x 105mm x 16mm
Max Power
48.1V x 0.180A= 8.658W
Nor Flash
2MB~32MB
Nand Flash
128MB
DDR
256MB~512MB
Our products link:PRODUCTS_Wallys Communications (Suzhou ) Co., LTD
