IPQ6018 vs. IPQ6010 vs. IPQ8072/IPQ8074| Comparative Analysis of Latest 802.11ax Solutions
Introduction:
The evolution of wireless technology has given rise to the latest 802.11ax (Wi-Fi 6) solutions, bringing enhanced speed, capacity, and overall performance to wireless networks. Qualcomm, a prominent player in the field, has developed a series of advanced Wi-Fi 6 solutions, including the IPQ6018, IPQ6010, IPQ8072, and IPQ8074. This technical post aims to provide a comprehensive comparison of these solutions, highlighting their key features, specifications, and potential use cases.
1. IPQ6018:
The IPQ6018 is a powerful 802.11ax SoC designed to deliver high-performance wireless connectivity for residential and commercial applications. It features a quad-core ARM Cortex-A53 CPU running at up to 2.2 GHz, combined with a dual-core network accelerator, ensuring efficient data processing and network management. The solution offers support for up to 8x8 MU-MIMO streams, enabling simultaneous communication with multiple devices. Additionally, it includes hardware acceleration for secure encryption protocols, enhancing network security without sacrificing performance.
2. IPQ6010:
The IPQ6010, also part of Qualcomm’s 802.11ax portfolio, is tailored for mid-range applications. It is equipped with a dual-core Kryo CPU, providing processing power up to 1.8 GHz. The solution supports up to 4x4 MU-MIMO streams, making it suitable for scenarios with moderate device density. The IPQ6010 maintains the essential features of Wi-Fi 6, such as OFDMA and improved spectral efficiency, while being optimized for a more cost-effective and power-efficient implementation.
3. IPQ8072 and IPQ8074:
The IPQ8072 and IPQ8074 are advanced solutions targeted at high-density and enterprise-grade wireless deployments. Both solutions incorporate a quad-core Kryo CPU clocked at up to 2.2 GHz, ensuring robust performance for demanding networking tasks. These SoCs offer support for up to 16x16 MU-MIMO streams, catering to environments with a significant number of connected devices. The IPQ8072 and IPQ8074 also feature 5th generation Qualcomm Wi-Fi security, WPA3, and enhanced encryption algorithms, bolstering network security.
Use Cases:
IPQ6018: The IPQ6018 suits scenarios requiring high-density connections such as crowded public spaces, campuses, and smart homes. Its robust processing capabilities and extensive MU-MIMO support make it ideal for handling a large number of devices simultaneously.
IPQ6010: The IPQ6010 caters to mid-range applications where cost-effectiveness and moderate device density are the main considerations. It offers a balance between performance and affordability, making it suitable for small to medium-sized businesses and homes.
IPQ8072/IPQ8074: These solutions are engineered for enterprise-grade deployments with dense device connectivity demands. Large corporate environments, stadiums, convention centers, and other settings benefit from their advanced processing power, security features, and extensive MU-MIMO support.
Conclusion:
The 802.11ax solutions offered by Qualcomm, namely IPQ6018, IPQ6010, IPQ8072, and IPQ8074, cover a wide range of use cases, from high-density deployments to cost-effective mid-range applications and enterprise-grade settings. Choosing the right solution depends on the specific requirements of the network in terms of device density, performance, and budget.
1.DR8072V01
Website:
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
NOR Flash: 8 MB
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
EMAIL:sales4@wallystech.com
