IPQ5018 Mainboard SocS: A Versatile Support for QCN9074, QCN6122, QCN6012 M.2 Cards
Introduction:
In the rapidly evolving landscape of wireless technologies, the demand for versatile and high-performance mainboard solutions is ever-increasing. The IPQ5018 mainboard stands out as a powerful solution that supports an array of M.2 cards, including the QCN9074, QCN6122, and QCN6012. This technical post delves into the capabilities of this mainboard and the seamless integration it offers for these cutting-edge M.2 cards.
IPQ5018 Mainboard Overview:
The IPQ5018 mainboard is a product of meticulous engineering, designed to provide a robust foundation for a wide range of applications, including networking, IoT, and industrial automation. Powered by Qualcomm’s IPQ5018 chipset, this mainboard boasts impressive processing capabilities, advanced connectivity features, and a flexible architecture that accommodates various M.2 card configurations.
Support for QCN9074 M.2 Card:
The QCN9074 M.2 card is a high-performance wireless module that supports Wi-Fi 6E and Bluetooth 5.2. With the IPQ5018 mainboard’s support for QCN9074, users can harness the benefits of ultra-fast and low-latency wireless connectivity. The mainboard’s interface allows seamless integration of the QCN9074 card, enabling applications that demand high-speed data transfers, low-latency communication, and reliable connectivity.
Integration of QCN6122 M.2 Card:
For applications requiring multi-gigabit Ethernet connectivity, the QCN6122 M.2 card is a compelling choice. The IPQ5018 mainboard facilitates the integration of the QCN6122 card, unlocking the potential for high-speed data networking, real-time video streaming, and low-latency communication. The mainboard’s design ensures optimal signal integrity, minimizing packet loss and maximizing network efficiency when utilizing the QCN6122 card.
Seamless Support for QCN6012 M.2 Card:
The QCN6012 M.2 card targets low-power, high-efficiency IoT applications. With the IPQ5018 mainboard’s support for the QCN6012 card, developers can create energy-efficient solutions without compromising on wireless connectivity. The mainboard’s architecture optimizes power delivery and management for the QCN6012 card, making it an ideal choice for battery-powered devices and IoT deployments.
Flexibility and Scalability:
One of the standout features of the IPQ5018 mainboard is its inherent flexibility and scalability. The M.2 slot design allows for easy swapping and upgrading of M.2 cards, enabling users to adapt their systems to evolving technological requirements. This flexibility future-proofs investments and simplifies the process of incorporating new wireless technologies as they emerge.
Conclusion:
The IPQ5018 mainboard solution presents an impressive platform for various applications that demand powerful processing, advanced wireless connectivity, and efficient networking capabilities. Its seamless integration with the QCN9074, QCN6122, and QCN6012 M.2 cards showcases its adaptability to a diverse range of use cases, from high-speed networking to energy-efficient IoT solutions. As technology continues to evolve, the IPQ5018 mainboard stands as a testament to the potential of versatile mainboard solutions in driving innovation across industries.
DR5018M
Dual-core ARM 64bit A53@1.0GHz Processor
1G DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for QCN6122-6E Card
M.2 Card Slot for QCN6102-5GCard
Support Openwifi
DR5018 based on IPQ5018 chipset is an enterprise wireless module integrated with BT5 .1 Radio module and 2x2 2.4 G high power Radio module designed specifically to provide users with mobile access to high - bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
With radio card DR6102-5G, you can get access to 5G radio . If you need to use 6GHz for your application, please use DR6122-6E radio card.
Parameter
Rating
Unit
Supply Voltage
24V-48V(DC Jack)
V
Operating Temperature Range
-40 70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 ~95 (non-condensing)
Storage Humidity Range
0 ~ 90 (non-condensing
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ5018
CPU Frequency
Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory
512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports
PCIE3.0
1x PCIEx2 Interface
USB3.0
1x USB3.0 Interface
SGMII
1x SGMII Interface
UART
1x UART Interface
GPIO
13 x GPIOs
Wireless
On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax
max 21dBm per chain
2x IPEX Connectors
BLE
on board BLE
VDD OUT
5VDD
Nor Flash
8MB
Nand Flash
128 MB
DDR
512MB
Dimension
60mm x 10mm
BY:https://www.wallystech.com/
Attach at :sales4@wallystech.com
