IPQ9574,IPQ9274,QCN6274,QCN9274 Chipsets to IEEE 802.11be with 2.4G 5G 6E Support QSDK
In the world of wireless communication, advancements continue to push the boundaries of speed, capacity, and reliability. The IPQ9574, IPQ9274, QCN6274, and QCN9274 are cutting-edge chipsets designed to meet these demands, offering support for the IEEE 802.11be standard while providing compatibility with 2.4GHz, 5GHz, and 6GHz (6E) frequency bands. The Qualcomm Software Development Kit (QSDK) further enhances these chipsets by providing a comprehensive software framework for development and optimization.
Chipset Overview
IPQ9574 and IPQ9274:
These chipsets are built to deliver high-performance Wi-Fi connectivity. The IPQ9574 and IPQ9274 are engineered with a focus on performance and efficiency, featuring multiple data streams, advanced modulation techniques, and robust error correction mechanisms. These chipsets are capable of supporting multiple devices simultaneously, making them suitable for dense deployment scenarios like stadiums, airports, and smart cities.
QCN6274 and QCN9274:
The QCN series chipsets, including QCN6274 and QCN9274, inherit the advanced features of their IPQ counterparts but are specifically designed for applications in the Internet of Things (IoT) sector. These chipsets offer optimized power consumption, security features, and support for a wide range of IoT devices, from smart home appliances to industrial sensors.
IEEE 802.11be Standard
The IEEE 802.11be standard, also known as Wi-Fi 7, is the next evolution of wireless technology. It introduces several key improvements over its predecessor (802.11ax or Wi-Fi 6), such as increased data rates, enhanced spectral efficiency, and better performance in crowded environments. With support for higher modulation schemes, wider channel bandwidths, and improved multi-user capabilities, 802.11be aims to provide a more seamless and reliable wireless experience.
Software Support with QSDK
The Qualcomm Software Development Kit (QSDK) is an essential component for harnessing the full potential of these chipsets. QSDK provides a comprehensive set of tools, libraries, and APIs that enable developers to build, optimize, and deploy wireless applications efficiently. Key features of QSDK include:
Driver Support: QSDK provides well-tested and optimized drivers that enable seamless communication between the hardware and the operating system. These drivers ensure stability, performance, and compatibility.
Networking Stack: QSDK offers a robust networking stack that supports various protocols and services. It facilitates seamless integration of Wi-Fi capabilities into applications, whether they are consumer-oriented or industrial IoT solutions.
Security Features: Security is a critical aspect of wireless communication. QSDK includes encryption, authentication, and secure boot mechanisms to safeguard data transmission and device integrity.
Performance Optimization: QSDK provides tools for analyzing and optimizing the performance of Wi-Fi connections. This is particularly important in scenarios with high device density, where efficient spectrum utilization is crucial.
Firmware Updates:QSDK enables easy firmware updates, ensuring that devices stay up to date with the latest features, bug fixes, and security enhancements.
Frequency Bands: 2.4GHz, 5GHz, and 6GHz (6E)
The chipsets support multiple frequency bands, catering to various use cases:
2.4GHz:This band offers good coverage and compatibility with a wide range of devices. It’s suitable for applications with lower data rate requirements or devices that can’t utilize higher frequencies.
5GHz: The 5GHz band provides higher data rates and less interference than the 2.4GHz band. It’s suitable for applications that require higher performance, such as video streaming and online gaming.
6GHz (6E): This newly available spectrum offers even more capacity and reduced interference. It’s well-suited for high-performance applications that demand ultra-fast connections, making it an ideal choice for emerging technologies like virtual reality and augmented reality.
In conclusion, the IPQ9574, IPQ9274, QCN6274, and QCN9274 chipsets, combined with support for the IEEE 802.11be standard and a comprehensive software framework like QSDK, represent a significant leap forward in wireless communication technology. These chipsets offer unparalleled performance, efficiency, and flexibility across various frequency bands, catering to a wide range of applications, from high-density environments to IoT deployments.
Wallys wifi7 mainboard DR9574
Parameter
Rating
Unit
Operating Temperature Range
-20 ~ 70
ºC
Storage Temperature Range
-40 ~ 90
ºC
Operating Humidity Range
5 ~ 95 (non-condensing)
Storage Humidity Range
0 ~ 90 (non-condensing)
Symbol
Parameter
Chipset
Qualcomm IPQ9574 Quad-Core ARM-A73 @ 2.2GHz processor ‘Alder’ Series
WLAN Host Interface
PCI Express 3.0 Interface
System Memory
2GB (2x1GB), DDR4 32-bit (2x16-bit) interface
Standard?Operating Voltage
12V
Operating Systems
QSDK
Host Interface
Antenna Cable / Port
4x U.FL Connectors
Frequency Range
2.4GHz: 2.412~2.472GHz
Data Rates for WLAN
Supports 20/40MHz at 2.4GHz
Modulation Techniques
Temperature Range
Operating: -20 °C to 70 °C, Storage: -40 °C to 90?°C
Humidity
Certification
REACH & RoHS Compliance
Power Consumption
13W (Board only)
23W (with onboard WiFi, IPQ9574)
Dimensions (WxHxD)
203mm x 139mm x 20mm
Upgrade your WiFi experience with the Wallys DR9574 DR9274 WiFi 7 Networking Solution,Whether you’re a gamer, streamer, or someone who demands high-speed internet for work, this network card has got you covered. Say goodbye to sluggish connections and hello to lightning-fast speeds and seamless connectivity.
