ffmedia的demo程序问题
执行# ./demo GuYongZhe.mp4 -o 1920x1080 -d 0
视频被加速播放了,怎么设置成正常播放速度?
Firefly FFMedia: v2.1.2
INFO: ff_media: start_instance:
INFO: ff_media: start_instance: enable file reader
mpp[977]: mpp_rt: NOT found ion allocator
mpp[977]: mpp_rt: found drm allocator
mpp[977]: mpp_info: mpp version: 8a85dc5d author: Herman Chen 2022-03-14 [mpp_enc]: Fix stuck on reset async mode encoder
INFO: 15DrmDisplayPlane: setupDisplayDevice: 0 0
INFO: 15DrmDisplayPlane: setupDisplayDevice: conn_id = 107 enc_id = 108 crtc_id = 71
INFO: 15DrmDisplayPlane: setup: plane_id = 73
INFO: ff_media: start_instance: t_h t_v 1920 1080
INFO: ff_media: start_instance: hc vc 1 1
INFO: ff_media: start_instance: dw dh 1920 1080
INFO: ff_media: start_instance: w h 1920 1080
INFO: ff_media: start_instance: x y w h 0 0 1920 1080
Input Source: GuYongZhe.mp4
Input format: 1920x1080 H264
Output format: 1920x1080 NV12
Encode type: H264
Decoder: enable
Rga: disable
Encoder: disable
RtspClient: disable
File writer: disable
File: disable
Rtsp push: disable
==================Pipe===================
ModuleFileReader (H264 1920x1080)
|—>ModuleMppDec (NV12 1920x1080)
|—>ModuleDrmDisplay (NV12 1920x1080)
rga_api version 1.3.0_[0] (RGA is compiling with meson base: $PRODUCT_BASE)
INFO: 16ModuleDrmDisplay: setupWindow: input NV12 0 0 1920 1080 1920 1088
INFO: 16ModuleDrmDisplay: setupWindow: output NV12 0 0 1920 1080 1920 1080
INFO: 10MppDecoder: getTimeoutSample: 0x5588f21080 frame info changed 1 error 0 discard 0
INFO: 12ModuleMppDec: work: Productor is EOS or Stoped
INFO: 12ModuleMppDec: work: Consume end of stream
INFO: 16ModuleDrmDisplay: work: Productor is EOS or Stoped
INFO: 16ModuleDrmDisplay: work: Consume end of stream
知道了,需要加同步,–sync=video
