固件文件名称:ROC-RK3399-PC-PLUS_Industry7.1.2_HDMI_200810.img
固件下载地址:官方下载
Log日志:rk3399log.txt
型号 rk3399-pc plus ,没有emmc,用的SDDiskTool_v1.7,勾选了sd启动,蓝色灯亮,串口打印重复txt文件内容,请问是什么问题?
rk3399log.txt (3.13 KB)
固件下载地址:官方下载
Log日志:rk3399log.txt
0 /mnt/internal_sd vfat /dev/block/platform/fe320000.dwmmc/by-name/user 0
1 /system ext4 /dev/block/platform/fe320000.dwmmc/by-name/system 0
2 /cache ext4 /dev/block/platform/fe320000.dwmmc/by-name/cache 0
3 /metadata ext4 /dev/block/platform/fe320000.dwmmc/by-name/metadata 0
4 /data ext4 /dev/block/platform/fe320000.dwmmc/by-name/userdata 0
5 /cust ext4 /dev/block/platform/fe320000.dwmmc/by-name/cust 0
6 /custom ext4 /dev/block/platform/fe320000.dwmmc/by-name/custom 0
7 /radical_update ext4 /dev/block/platform/fe320000.dwmmc/by-name/radical_update 0
8 /misc emmc /dev/block/platform/fe320000.dwmmc/by-name/misc 0
9 /uboot emmc /dev/block/platform/fe320000.dwmmc/by-name/uboot 0
10 /charge emmc /dev/block/platform/fe320000.dwmmc/by-name/charge 0
11 /resource emmc /dev/block/platform/fe320000.dwmmc/by-name/resource 0
12 /parameter emmc /dev/block/platform/fe320000.dwmmc/by-name/parameter 0
13 /boot emmc /dev/block/platform/fe320000.dwmmc/by-name/boot 0
14 /recovery emmc /dev/block/platform/fe320000.dwmmc/by-name/recovery 0
15 /backup emmc /dev/block/platform/fe320000.dwmmc/by-name/backup 0
16 /trust emmc /dev/block/platform/fe320000.dwmmc/by-name/trust 0
17 /baseparamer emmc /dev/block/platform/fe320000.dwmmc/by-name/baseparamer 0
18 /tmp ramdisk ramdisk 0
emmc_point is
sd_point is (null)
sd_point_2 is (null)
I:InternalSD_ROOT: /mnt/internal_sd
I:ExternalSD_ROOT: /mnt/external_sd
read cmdline
[ 266.345020] fs_mgr: Warning: unknown flag resize
E:failed to stat /dev/block/platform/fe320000.dwmmc/by-name/misc try 1: No such file or directory
failed to stat /dev/block/platform/fe320000.dwmmc/by-name/misc try 2: No such file or directory
failed to stat /dev/block/platform/fe320000.dwmmc/by-name/misE:failed to mount /cache (No such file or directory)
E:Can’t mount /cache/recovery/command
[ 276.350655] fs_mgr: WEa:rfnaiinlge:d uto open /dev/block/platform/fe320000.dwmmc/by-name/misc: No such filne or directory
=== start void dumpCmdArgs(int, char **):296 ===
argv[0] = /sbin/recovery.
lockale is [en_US]
stage is
reasonn is [(null)]
own flag resize
cannot find/open a drm device: No such file or directory
fb0 reports (possibly inaccurate):
vi.bits_per_pixel = 32
vi.red.offset = 16 .length = 8
vi.green.offset = 8 .length = 8
vi.blue.offset = 0 .length = 8
fi.line_length = 4096
framebuffer: 0 (1024 x 768)
erasing_text: en_US (68 x 29 @ 900)
no_command_text: en_US (124 x 29 @ 900)
error_text: en_US (48 x 29 @ 900)
installing_text: en_US (228 x 29 @ 900)
mount cache fail,so formate…
error: make_ext4fs_directory: open: No such file or directory
[ 276.806492] init: Service ‘recovery’ (pid 259) killed by signal 11
[ 276.806559] init: Service ‘recovery’ (pid 259) killing any children in process group
[ 276.806704] init: Starting service ‘recovery’…
__bionic_open_tzdata: couldn’t find any tzdata when looking for GMT!
