Analysis of 802.11ac Wave 2 MU-MIMO Onboard Chipsets: IPQ4019 vs. IPQ4029 vs. IPQ4018
Abstract:
The evolution of wireless communication technologies has led to the development of advanced Wi-Fi standards, such as 802.11ac Wave 2, which incorporates Multi-User Multiple Input Multiple Output (MU-MIMO) technology for improved throughput and efficiency. This technical post delves into a comparative analysis of three prominent onboard chipsets - IPQ4019, IPQ4029, and IPQ4018 - designed to drive 802.11ac Wave 2 MU-MIMO implementations. We explore their specifications, capabilities, and potential use cases in modern networking scenarios.
Introduction:
802.11ac Wave 2 is a significant advancement in the Wi-Fi landscape, enabling increased network capacity and efficiency through MU-MIMO technology. Onboard chipsets play a crucial role in realizing the potential of this standard. This post focuses on comparing three key onboard chipsets: IPQ4019, IPQ4029, and IPQ4018. We’ll delve into their technical specifications, performance characteristics, and potential applications.
IPQ4019:
The IPQ4019 is a versatile onboard chipset designed for 802.11ac Wave 2 MU-MIMO applications. It features a quad-core ARM Cortex-A7 processor running at speeds up to 716 MHz. With dual-band concurrent operation (2.4 GHz and 5 GHz), it offers up to 2 spatial streams and supports a peak data rate of 1.733 Gbps. The chipset integrates a range of interfaces, including Gigabit Ethernet ports, PCIe, USB 3.0, and more, making it suitable for various networking scenarios. Its advanced packet processing capabilities contribute to efficient data handling in congested environments.
IPQ4029:
The IPQ4029 represents a higher tier of performance compared to the IPQ4019. It boasts a quad-core ARM Cortex-A53 processor running at speeds up to 717 MHz. This chipset supports dual-band operation and up to 4 spatial streams, enabling a peak data rate of 3.467 Gbps. With enhanced processing power and memory, the IPQ4029 is capable of handling complex networking tasks with ease. It offers a similar set of interfaces as the IPQ4019, ensuring compatibility with a wide range of network setups.
IPQ4018:
The IPQ4018 is another contender in the 802.11ac Wave 2 MU-MIMO onboard chipset arena. It features a dual-core Krait processor running at speeds up to 717 MHz. The chipset supports dual-band operation and up to 2 spatial streams, providing a peak data rate of 1.733 Gbps. Although slightly less powerful than the IPQ4019 and IPQ4029, the IPQ4018 is still suitable for various mid-tier networking deployments.
Comparative Analysis:
When comparing these three chipsets, it’s clear that each serves a specific niche within the 802.11ac Wave 2 MU-MIMO landscape. The IPQ4019 strikes a balance between performance and cost-effectiveness, making it suitable for medium-scale networks. The IPQ4029 excels in high-performance scenarios, offering increased processing power and spatial streams. The IPQ4018 caters to smaller-scale networks where a slightly lower data rate is acceptable.
Use Cases:
IPQ4019: Small to medium-sized businesses, home offices, and public Wi-Fi installations.
IPQ4029: Enterprises, large campuses, high-density venues, and applications demanding high throughput.
IPQ4018: Residential setups, small businesses, and environments with moderate network demands.
Conclusion:
In the realm of 802.11ac Wave 2 MU-MIMO onboard chipsets, the IPQ4019, IPQ4029, and IPQ4018 each bring their own set of features and capabilities to the table. Network architects and administrators must carefully consider their specific requirements and budget constraints when selecting a chipset for their deployments. With the ongoing evolution of wireless technologies, these chipsets play a vital role in shaping the future of high-performance Wi-Fi networks.
Wallys//[b]IPQ4018[/b]/IPQ4028chipset/Routerboard/DR40X8H-high-powersupport-MU-MIMO-802.11ac
Website:
Product Parameter:
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Operating Temperature Range -40 to +60 ºC
Storage Temperature Range -65 to +105 ºC
Operating Humidity Range 5 to +95 (non-condensing )%
Hardware Specifications
Symbol Parameter
CPU IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional) 3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS Compliance YES
Dimension 115mm x 105mm x 16mm
Nor Flash 2MB~32MB
Nand Flash 128MB
DDR 256MB
