以太网无法使用
SDK包名称:Firefly-RK356X_Android11.0
SDK修改内容:只有一个以太网;
Log日志:boot-21.rar
原理图使用RGMII Crystal 25M for PHY, RGMII_CLK input 125M for TX_CLK连接方式:连接方式和DEMO板一样;硬件连接的GMAC0;
软件按照文档已经配置了;
&gmac0 {
phy-mode = “rgmii”;
clock_in_out = “input”;
snps,reset-gpio = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>;
snps,reset-active-low;
/* Reset time is 20ms, 100ms for rtl8211f */
snps,reset-delays-us = <0 20000 100000>;
assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>;
assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&gmac0_clkin>;
assigned-clock-rates = <0>, <125000000>;
pinctrl-names = "default";
pinctrl-0 = <&gmac0_miim
	&gmac0_tx_bus2
	&gmac0_rx_bus2
	&gmac0_rgmii_clk
	&gmac0_rgmii_bus
	&gmac0_clkinout>;
tx_delay = <0x30>;
rx_delay = <0x10>;
phy-handle = <&rgmii_phy0>;
status = "okay";
gmac0: ethernet@fe2a0000 {
	compatible = "rockchip,rk3568-gmac", "snps,dwmac-4.20a";
	reg = <0x0 0xfe2a0000 0x0 0x10000>;
	interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>,
		     <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
	interrupt-names = "macirq", "eth_wake_irq";
	rockchip,grf = <&grf>;
	clocks = <&cru SCLK_GMAC0>, <&cru SCLK_GMAC0_RX_TX>,
		 <&cru SCLK_GMAC0_RX_TX>, <&cru CLK_MAC0_REFOUT>,
		 <&cru ACLK_GMAC0>, <&cru PCLK_GMAC0>,
		 <&cru SCLK_GMAC0_RX_TX>, <&cru CLK_GMAC0_PTP_REF>,
		 <&cru PCLK_XPCS>;
	clock-names = "stmmaceth", "mac_clk_rx",
		      "mac_clk_tx", "clk_mac_refout",
		      "aclk_mac", "pclk_mac",
		      "clk_mac_speed", "ptp_ref",
		      "pclk_xpcs";
	resets = <&cru SRST_A_GMAC0>;
	reset-names = "stmmaceth";
	snps,mixed-burst;
	snps,tso;
	snps,axi-config = <&gmac0_stmmac_axi_setup>;
	snps,mtl-rx-config = <&gmac0_mtl_rx_setup>;
	snps,mtl-tx-config = <&gmac0_mtl_tx_setup>;
	status = "disabled";
	mdio0: mdio {
		compatible = "snps,dwmac-mdio";
		#address-cells = <0x1>;
		#size-cells = <0x0>;
	gmac0_stmmac_axi_setup: stmmac-axi-config {
		snps,wr_osr_lmt = <4>;
		snps,rd_osr_lmt = <8>;
		snps,blen = <0 0 0 0 16 8 4>;
	gmac0_mtl_rx_setup: rx-queues-config {
		snps,rx-queues-to-use = <1>;
		queue0 {};
	gmac0_mtl_tx_setup: tx-queues-config {
		snps,tx-queues-to-use = <1>;
		queue0 {};
log显示
mdio关键字:
[ 0.256145] libphy: Fixed MDIO Bus: probed
[ 0.395107] mdio_bus stmmac-0: MDIO device at address 0 is missing.
phy:关键字
PHY drv:clk:38,ca:38,DQ:30,odt:0
PHY drv:clk:38,ca:38,DQ:30,odt:60
rockchip_vop2_init:No hdmiphypll clk0 found, use system clk
rockchip_vop2_init:No hdmiphypll clk1 found, use system clk
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
[ 0.189446] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.189580] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.190823] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.5
[ 0.191017] phy phy-fe8a0000.usb2-phy.1: Linked as a consumer to regulator.6
[ 0.192165] extcon extcon1: failed to create extcon usb2-phy link
[ 0.192265] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.5
[ 0.192383] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.5
[ 0.192467] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[ 0.204911] rochchip_p3phy_init: lock failed 0x6890000, check input refclk and power supply
[ 0.204937] phy phy-fe8c0000.phy.9: phy init failed → -110
[ 0.204953] rk-pcie 3c0800000.pcie: fail to init phy, err -110
[ 0.204966] rk-pcie 3c0800000.pcie: phy init failed
[ 0.225390] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x2a, primary plane phy id: 5
[ 0.225416] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4
[ 0.225437] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.227016] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.257692] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[ 0.257734] rk_gmac-dwmac fe2a0000.ethernet: clock input from PHY
[ 0.394845] libphy: stmmac: probed
[ 1.656955] phy phy-fe8a0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 4.845326] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x2a, primary plane phy id: 5
[ 4.845353] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x15, primary plane phy id: 4
[ 4.845373] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 4.847573] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 6.165941] rockchip-csi2-dphy0: No link between dphy and sensor
[ 6.166446] rockchip-csi2-dphy0: No link between dphy and sensor
[ 10.240619] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 10.244175] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[ 29.956018] rk_gmac-dwmac fe2a0000.ethernet eth0: Could not attach to PHY
[ 29.956052] rk_gmac-dwmac fe2a0000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
开机后没有eth0网络;原因就是
rk_gmac-dwmac fe2a0000.ethernet eth0: Could not attach to PHY;开机过程中量不到PHY送给GMAC的125MCLK;原因可能是什么呀?
boot-21.rar (19 KB)
有大佬帮忙看看吗?{:4_89:}
问题根源就是识别不到phy,时钟问题,供电问题,焊接问题,硬件连线错误问题等等一堆都有可能,所以需要你自己排查,什么可能都有,
请问下你的问题解决了吗?
