使用了rk628官方的demo板子连接Core-1126-JD4的官方底板做hdmi in,用到了MIPI1,rk628的demo板只改了一个电阻让reset引脚引出(原来是rc复位),系统是官方的debain,dts文件修改如下:
i2c1 {
clock-frequency = <400000>;
status = "okay";
rk628: rk628@50 {
reg = <0x50>;
interrupt-parent = <&gpio3>;
interrupts = <RK_PA5 IRQ_TYPE_LEVEL_HIGH>;
reset-gpios = <&gpio4 RK_PA1 GPIO_ACTIVE_LOW>;
status = "okay";
#include <arm/rk628.dtsi>
&rk628_combtxphy {
status = "okay";
&rk628_combrxphy {
status = "okay";
&rk628_csi {
status = "okay";
plugin-det-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_LOW>;
// power-gpios = <&gpio0 17 GPIO_ACTIVE_HIGH>;
rockchip,camera-module-index = <0>;
rockchip,camera-module-facing = "back";
rockchip,camera-module-name = "RK628-CSI";
rockchip,camera-module-lens-name = "NC";
port {
hdmiin_out1: endpoint {
remote-endpoint = <&mipi_in1>;
data-lanes = <1 2 3 4>;
&csi_dphy1 {
status = "okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
mipi_in1: endpoint@1 {
reg = <1>; // reg = <1>?????
remote-endpoint = <&hdmiin_out1>;
port@1 {
reg = <1>;
#size-cells = <0>;
csidphy1_out: endpoint@0 {
reg = <0>;
remote-endpoint = <&isp1_in>;
&rkisp {
status = "okay";
&rkisp_mmu {
status = "okay";
&rkisp_vir1 {
status = "okay";
port {
#size-cells = <0>;
isp1_in: endpoint@0 {
reg = <0>;
remote-endpoint = <&csidphy1_out>;
目前状态是,可以在demsg中看到输入视频的分辨率和帧率,但是看不到video4linux设备。
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.19.111 (msmmbl@MKJ) (kernel commit id: 85988bd7b1fc67ac96e868b90f4e676f44c713ae) (sdk version: rv1126_rv1109_linux_release_20220324_v2.2.5b.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #6 SMP PREEMPT Sun Sep 3 15:10:57 CST 2023
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] OF: fdt: Machine model: Firefly Core-RV1126-JD4 Board MSM
[ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x00000000, size 0 MiB
[ 0.000000] Reserved memory: created CMA memory pool at 0x3f800000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x2f800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 261560
[ 0.000000] Normal zone: 2048 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 261560 pages, LIFO batch:63
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
[ 0.000000] pcpu-alloc: s32204 r8192 d21044 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 259512
[ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal ro rootwait earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 cgroup_enable=memory swapaccount=1 snd_aloop.index=7
[ 0.000000] Memory: 741732K/1046240K available (9216K kernel code, 427K rwdata, 2496K rodata, 1024K init, 321K bss, 34172K reserved, 270336K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
modules : 0xaf000000 - 0xafe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 428 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 322 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000754] Switching to timer-based delay loop, resolution 41ns
[ 0.002765] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003723] pid_max: default: 4096 minimum: 301
[ 0.004328] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004953] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.006412] CPU: Testing write buffer coherency: ok
[ 0.007254] /cpus/cpu@f00 missing clock-frequency property
[ 0.007779] /cpus/cpu@f01 missing clock-frequency property
[ 0.008298] /cpus/cpu@f02 missing clock-frequency property
[ 0.008818] /cpus/cpu@f03 missing clock-frequency property
[ 0.009334] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.010627] Setting up static identity map for 0x100000 - 0x100060
[ 0.011367] rcu: Hierarchical SRCU implementation.
[ 0.012453] smp: Bringing up secondary CPUs ...
[ 0.014513] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.016245] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.017982] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.018124] smp: Brought up 1 node, 4 CPUs
[ 0.020123] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.020702] CPU: All CPU(s) started in SVC mode.
[ 0.022034] devtmpfs: initialized
[ 0.051280] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.051327] Unpacking initramfs...
[ 0.052738] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.053643] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 0.054528] pinctrl core: initialized pinctrl subsystem
[ 0.056309] NET: Registered protocol family 16
[ 0.057524] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.060242] cpuidle: using governor menu
[ 0.060648] Registered FIQ tty driver
[ 0.061783] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.062524] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.065441] console [pstore-1] enabled
[ 0.066110] pstore: Registered ramoops as persistent store backend
[ 0.066693] ramoops: attached 0x100000@0x8000000, ecc: 0/0
[ 0.094742] gpio gpiochip0: (gpio0): added GPIO chardev (254:0)
[ 0.094871] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio0)
[ 0.095139] gpio gpiochip1: (gpio1): added GPIO chardev (254:1)
[ 0.095260] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio1)
[ 0.095457] gpio gpiochip2: (gpio2): added GPIO chardev (254:2)
[ 0.095587] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio2)
[ 0.095795] gpio gpiochip3: (gpio3): added GPIO chardev (254:3)
[ 0.095919] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio3)
[ 0.096121] gpio gpiochip4: (gpio4): added GPIO chardev (254:4)
[ 0.096230] gpiochip_setup_dev: registered GPIOs 128 to 129 on device: gpiochip4 (gpio4)
[ 0.116208] cryptd: max_cpu_qlen set to 1000
[ 0.117591] fiq debugger fiq mode enabled
[ 0.118486] console [ttyFIQ0] enabled
[ 0.119175] bootconsole [uart8250] disabled
[ 0.119887] Registered fiq debugger ttyFIQ0
[ 0.120545] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 0.121917] of_get_named_gpiod_flags: parsed 'gpio' property of node '/lcd-n[0]' - status (0)
[ 0.122486] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vccsys[0]'
[ 0.123010] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-4g[0]' - status (0)
[ 0.123568] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc5v0-usb2-host-regulator[0]' - status (0)
[ 0.124137] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[ 0.124672] of_get_named_gpiod_flags: parsed 'gpio' property of node '/gpio-fan[0]' - status (0)
[ 0.125161] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vdd-logic[0]'
[ 0.126242] rk_iommu ffb00f00.iommu: version = 1
[ 0.126965] rk_iommu ffb20800.iommu: version = 1
[ 0.127468] rk_iommu ffb51a00.iommu: version = 1
[ 0.127923] rk_iommu ffb60e00.iommu: version = 1
[ 0.128490] rk_iommu ffb80480.iommu: version = 1
[ 0.128974] rk_iommu ffb90800.iommu: version = 1
[ 0.129394] rk_iommu ffbb0f00.iommu: version = 1
[ 0.130394] SCSI subsystem initialized
[ 0.130740] usbcore: registered new interface driver usbfs
[ 0.130849] usbcore: registered new interface driver hub
[ 0.130984] usbcore: registered new device driver usb
[ 0.131098] media: Linux media interface: v0.10
[ 0.131169] videodev: Linux video capture interface: v2.00
[ 0.131238] pps_core: LinuxPPS API ver. 1 registered
[ 0.131261] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.131305] PTP clock support registered
[ 0.132901] Advanced Linux Sound Architecture Driver Initialized.
[ 0.133602] Bluetooth: Core ver 2.22
[ 0.133699] NET: Registered protocol family 31
[ 0.133724] Bluetooth: HCI device and connection manager initialized
[ 0.133755] Bluetooth: HCI socket layer initialized
[ 0.133781] Bluetooth: L2CAP socket layer initialized
[ 0.133844] Bluetooth: SCO socket layer initialized
[ 0.134381] rockchip-cpuinfo cpuinfo: SoC : 11260000
[ 0.134420] rockchip-cpuinfo cpuinfo: Serial : e6a3a37512dc2a6f
[ 0.135703] clocksource: Switched to clocksource arch_sys_counter
[ 0.138282] NET: Registered protocol family 2
[ 0.139277] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.139341] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.139498] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.139702] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.139876] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.139949] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.140218] NET: Registered protocol family 1
[ 0.142330] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.145048] Initialise system trusted keyrings
[ 0.145363] workingset: timestamp_bits=29 max_order=18 bucket_order=0
[ 0.152927] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.155804] Key type asymmetric registered
[ 0.155846] Asymmetric key parser 'x509' registered
[ 0.155936] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.155957] io scheduler noop registered
[ 0.155980] io scheduler deadline registered
[ 0.156169] io scheduler cfq registered (default)
[ 0.156192] io scheduler mq-deadline registered
[ 0.156208] io scheduler kyber registered
[ 0.156384] io scheduler bfq registered
[ 0.159634] rockchip-usb2phy-naneng ff4c0000.usb2-phy: GPIO lookup for consumer vup
[ 0.159648] rockchip-usb2phy-naneng ff4c0000.usb2-phy: using device tree for GPIO lookup
[ 0.159677] of_get_named_gpiod_flags: can't parse 'vup-gpios' property of node '/usb2-phy@ff4c0000[0]'
[ 0.159697] of_get_named_gpiod_flags: can't parse 'vup-gpio' property of node '/usb2-phy@ff4c0000[0]'
[ 0.159710] rockchip-usb2phy-naneng ff4c0000.usb2-phy: using lookup tables for GPIO lookup
[ 0.159720] rockchip-usb2phy-naneng ff4c0000.usb2-phy: No GPIO consumer vup found
[ 0.160671] phy phy-ff4c0000.usb2-phy.1: Linked as a consumer to regulator.5
[ 0.162687] rockchip-usb2phy-naneng ff4c8000.usb2-phy: GPIO lookup for consumer vup
[ 0.162701] rockchip-usb2phy-naneng ff4c8000.usb2-phy: using device tree for GPIO lookup
[ 0.162730] of_get_named_gpiod_flags: can't parse 'vup-gpios' property of node '/usb2-phy@ff4c8000[0]'
[ 0.162750] of_get_named_gpiod_flags: can't parse 'vup-gpio' property of node '/usb2-phy@ff4c8000[0]'
[ 0.162763] rockchip-usb2phy-naneng ff4c8000.usb2-phy: using lookup tables for GPIO lookup
[ 0.162774] rockchip-usb2phy-naneng ff4c8000.usb2-phy: No GPIO consumer vup found
[ 0.162943] phy phy-ff4c8000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.167042] pwm-backlight backlight: GPIO lookup for consumer enable
[ 0.167056] pwm-backlight backlight: using device tree for GPIO lookup
[ 0.167099] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/backlight[0]' - status (0)
[ 0.167126] gpio gpiochip1: Persistence not supported for GPIO 3
[ 0.167130] no flags found for enable
[ 0.167173] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.167340] pwm-backlight backlight: Linked as a consumer to regulator.0
[ 0.167760] mpp_service mpp-srv: 92c80ddf68f6 author: Yandong Lin 2021-08-10 video: rockchip: mpp: workaround patch for rv1126 iommu issue
[ 0.167796] mpp_service mpp-srv: probe start
[ 0.168797] iommu: Adding device ffb80000.rkvdec to group 4
[ 0.168858] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
[ 0.169119] mpp_rkvdec ffb80000.rkvdec: probing start
[ 0.169815] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
[ 0.169853] rkvdec_init:1190: No niu aclk reset resource define
[ 0.169881] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
[ 0.169902] rkvdec_init:1193: No niu hclk reset resource define
[ 0.170221] mpp_rkvdec ffb80000.rkvdec: probing finish
[ 0.171049] iommu: Adding device ffbb0000.rkvenc to group 6
[ 0.171113] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
[ 0.171455] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 0.172078] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
[ 0.172113] rkvenc_init:1202: failed to add venc devfreq
[ 0.173407] iommu: Adding device ffb90400.vdpu to group 5
[ 0.173474] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
[ 0.173584] mpp_vdpu2 ffb90400.vdpu: probe device
[ 0.174157] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.174211] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
[ 0.174484] mpp_vdpu2 ffb90400.vdpu: probing finish
[ 0.175144] iommu: Adding device ffb90000.vepu to group 5
[ 0.175202] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
[ 0.175355] mpp_vepu2 ffb90000.vepu: probe device
[ 0.175933] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.175979] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
[ 0.176238] mpp_vepu2 ffb90000.vepu: probing finish
[ 0.176811] iommu: Adding device ffb20000.iep to group 1
[ 0.176874] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
[ 0.177003] mpp-iep2 ffb20000.iep: probe device
[ 0.177749] mpp-iep2 ffb20000.iep: allocate roi buffer failed
[ 0.177972] mpp-iep2 ffb20000.iep: probing finish
[ 0.178287] mpp_service mpp-srv: probe success
[ 0.183775] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.183825] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.185949] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.186900] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.187834] ff410000.serial: ttyS1 at MMIO 0xff410000 (irq = 30, base_baud = 1500000) is a 16550A
[ 0.188658] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 33, base_baud = 1500000) is a 16550A
[ 0.189553] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 34, base_baud = 1500000) is a 16550A
[ 0.191769] random: fast init done
[ 0.192175] random: crng init done
[ 0.192675] iommu: Adding device ffb00000.vop to group 0
[ 0.192740] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
[ 0.210709] loop: module loaded
[ 0.211462] zram: Added device: zram0
[ 0.214083] mdio_bus fixed-0: GPIO lookup for consumer reset
[ 0.214097] mdio_bus fixed-0: using lookup tables for GPIO lookup
[ 0.214108] mdio_bus fixed-0: No GPIO consumer reset found
[ 0.214146] libphy: Fixed MDIO Bus: probed
[ 0.216269] rk_gmac-dwmac ffc40000.ethernet: no regulator found
[ 0.216323] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (output).
[ 0.216346] rk_gmac-dwmac ffc40000.ethernet: TX delay(0x2a).
[ 0.216374] rk_gmac-dwmac ffc40000.ethernet: RX delay(0x1a).
[ 0.216404] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
[ 0.221510] rk_gmac-dwmac ffc40000.ethernet: init for RGMII
[ 0.221891] rk_gmac-dwmac ffc40000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.221929] rk_gmac-dwmac ffc40000.ethernet: DWMAC4/5
[ 0.221956] rk_gmac-dwmac ffc40000.ethernet: DMA HW capability register supported
[ 0.221981] rk_gmac-dwmac ffc40000.ethernet: RX Checksum Offload Engine supported
[ 0.222004] rk_gmac-dwmac ffc40000.ethernet: TX Checksum insertion supported
[ 0.222026] rk_gmac-dwmac ffc40000.ethernet: Wake-Up On Lan supported
[ 0.222093] rk_gmac-dwmac ffc40000.ethernet: TSO supported
[ 0.222120] rk_gmac-dwmac ffc40000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.222146] rk_gmac-dwmac ffc40000.ethernet: TSO feature enabled
[ 0.222332] mdio_bus stmmac-0: GPIO lookup for consumer reset
[ 0.222341] mdio_bus stmmac-0: using device tree for GPIO lookup
[ 0.222409] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@ffc40000/mdio[0]'
[ 0.222429] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ethernet@ffc40000/mdio[0]'
[ 0.222443] mdio_bus stmmac-0: using lookup tables for GPIO lookup
[ 0.222453] mdio_bus stmmac-0: No GPIO consumer reset found
[ 0.222491] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@ffc40000[0]' - status (0)
[ 0.359098] libphy: stmmac: probed
[ 0.359882] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@ffc40000/mdio/phy@0[0]'
[ 0.361160] PPP generic driver version 2.4.2
[ 0.361471] PPP BSD Compression module registered
[ 0.361501] PPP Deflate Compression module registered
[ 0.361544] PPP MPPE Compression module registered
[ 0.361568] NET: Registered protocol family 24
[ 0.361710] usbcore: registered new interface driver r8152
[ 0.361795] usbcore: registered new interface driver asix
[ 0.361885] usbcore: registered new interface driver ax88179_178a
[ 0.361967] usbcore: registered new interface driver cdc_ether
[ 0.362051] usbcore: registered new interface driver net1080
[ 0.362125] usbcore: registered new interface driver cdc_subset
[ 0.362196] usbcore: registered new interface driver zaurus
[ 0.362287] usbcore: registered new interface driver cdc_ncm
[ 0.362458] usbcore: registered new interface driver qmi_wwan
[ 0.364359] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
[ 0.370954] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.371006] ehci-platform: EHCI generic platform driver
[ 0.374660] ehci-platform ffe00000.usb: EHCI Host Controller
[ 0.374752] ehci-platform ffe00000.usb: new USB bus registered, assigned bus number 1
[ 0.374948] ehci-platform ffe00000.usb: irq 67, io mem 0xffe00000
[ 0.385776] ehci-platform ffe00000.usb: USB 2.0 started, EHCI 1.00
[ 0.386126] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.386160] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.386185] usb usb1: Product: EHCI Host Controller
[ 0.386209] usb usb1: Manufacturer: Linux 4.19.111 ehci_hcd
[ 0.386232] usb usb1: SerialNumber: ffe00000.usb
[ 0.387071] hub 1-0:1.0: USB hub found
[ 0.387157] hub 1-0:1.0: 1 port detected
[ 0.387959] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.388018] ohci-platform: OHCI generic platform driver
[ 0.388675] ohci-platform ffe10000.usb: Generic Platform OHCI controller
[ 0.388748] ohci-platform ffe10000.usb: new USB bus registered, assigned bus number 2
[ 0.388954] ohci-platform ffe10000.usb: irq 68, io mem 0xffe10000
[ 0.446747] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 0.446801] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.446821] usb usb2: Product: Generic Platform OHCI controller
[ 0.446866] usb usb2: Manufacturer: Linux 4.19.111 ohci_hcd
[ 0.446886] usb usb2: SerialNumber: ffe10000.usb
[ 0.447736] hub 2-0:1.0: USB hub found
[ 0.447819] hub 2-0:1.0: 1 port detected
[ 0.449636] usbcore: registered new interface driver cdc_wdm
[ 0.449801] usbcore: registered new interface driver usb-storage
[ 0.449974] usbcore: registered new interface driver option
[ 0.450049] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.451174] i2c /dev entries driver
[ 0.453240] rk808 0-0020: chip id: 0x8090
[ 0.453357] rk808 0-0020: No cache defaults, reading back from HW
[ 0.459803] rk808 0-0020: source: on=0x40, off=0x00
[ 0.459855] rk808 0-0020: support dcdc3 fb mode:-22, -1329954244
[ 0.459879] rk808 0-0020: support pmic reset mode:0,0
[ 0.460530] gpiochip_find_base: found new base at 511
[ 0.460787] gpio gpiochip5: (rk817-gpio): added GPIO chardev (254:5)
[ 0.460923] gpiochip_setup_dev: registered GPIOs 511 to 511 on device: gpiochip5 (rk817-gpio)
[ 0.461070] gpio gpiochip5: (rk817-gpio): created GPIO range 0->0 ==> rk805-pinctrl PIN 0->0
[ 0.464328] rk808 0-0020: GPIO lookup for consumer dvs
[ 0.464341] rk808 0-0020: using device tree for GPIO lookup
[ 0.464374] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3f0000/pmic@20[0]'
[ 0.464395] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3f0000/pmic@20[0]'
[ 0.464410] rk808 0-0020: using lookup tables for GPIO lookup
[ 0.464419] rk808 0-0020: No GPIO consumer dvs found
[ 0.464431] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.464491] rk808 0-0020: GPIO lookup for consumer dvs
[ 0.464499] rk808 0-0020: using device tree for GPIO lookup
[ 0.464522] of_get_named_gpiod_flags: can't parse 'dvs-gpios' property of node '/i2c@ff3f0000/pmic@20[1]'
[ 0.464542] of_get_named_gpiod_flags: can't parse 'dvs-gpio' property of node '/i2c@ff3f0000/pmic@20[1]'
[ 0.464552] rk808 0-0020: using lookup tables for GPIO lookup
[ 0.464561] rk808 0-0020: No GPIO consumer dvs found
[ 0.464571] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.464685] DCDC_REG1: supplied by vcc5v0_sys
[ 0.465429] DCDC_REG2: supplied by vcc5v0_sys
[ 0.466149] DCDC_REG3: supplied by vcc5v0_sys
[ 0.466658] DCDC_REG4: supplied by vcc5v0_sys
[ 0.467192] DCDC_REG5: supplied by vcc5v0_sys
[ 0.467863] LDO_REG1: supplied by vcc_buck5
[ 0.468508] LDO_REG2: supplied by vcc_buck5
[ 0.469074] LDO_REG3: supplied by vcc_buck5
[ 0.469603] LDO_REG4: supplied by vcc_buck5
[ 0.470115] LDO_REG5: supplied by vcc_buck5
[ 0.470630] LDO_REG6: supplied by vcc_buck5
[ 0.470714] vcc_dvdd: Bringing 1100000uV into 1200000-1200000uV
[ 0.471316] LDO_REG7: supplied by vcc5v0_sys
[ 0.471844] LDO_REG8: supplied by vcc5v0_sys
[ 0.472548] LDO_REG9: supplied by vcc5v0_sys
[ 0.473200] SWITCH_REG1: supplied by vcc5v0_sys
[ 0.473674] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.476048] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[ 0.479102] rk808-rtc rk808-rtc: registered as rtc0
[ 0.479703] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:02 UTC (1501837202)
[ 0.481874] pca953x 1-0020: GPIO lookup for consumer reset
[ 0.481887] pca953x 1-0020: using device tree for GPIO lookup
[ 0.481915] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/i2c@ff510000/i2c1gpio@27[0]'
[ 0.481935] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/i2c@ff510000/i2c1gpio@27[0]'
[ 0.481947] pca953x 1-0020: using lookup tables for GPIO lookup
[ 0.481957] pca953x 1-0020: No GPIO consumer reset found
[ 0.482000] pca953x 1-0020: 1-0020 supply vcc not found, using dummy regulator
[ 0.482130] pca953x 1-0020: Linked as a consumer to regulator.0
[ 0.482250] pca953x 1-0020: failed reading register
[ 0.482391] pca953x 1-0020: Dropping the link to regulator.0
[ 0.482835] rk628 1-0050: GPIO lookup for consumer enable
[ 0.482845] rk628 1-0050: using device tree for GPIO lookup
[ 0.482871] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/i2c@ff510000/rk628@50[0]'
[ 0.482891] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/i2c@ff510000/rk628@50[0]'
[ 0.482902] rk628 1-0050: using lookup tables for GPIO lookup
[ 0.482911] rk628 1-0050: No GPIO consumer enable found
[ 0.482921] rk628 1-0050: GPIO lookup for consumer reset
[ 0.482929] rk628 1-0050: using device tree for GPIO lookup
[ 0.482966] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/i2c@ff510000/rk628@50[0]' - status (0)
[ 0.482995] gpio gpiochip4: Persistence not supported for GPIO 1
[ 0.528801] rk628-cru rk628-cru: DMA mask not set
[ 0.572636] rk628-pinctrl rk628-pinctrl: DMA mask not set
[ 0.574143] gpiochip_find_base: found new base at 499
[ 0.574430] gpio gpiochip6: (rk628-gpio0): added GPIO chardev (254:6)
[ 0.574558] gpiochip_setup_dev: registered GPIOs 499 to 510 on device: gpiochip6 (rk628-gpio0)
[ 0.574587] gpiochip_find_base: found new base at 485
[ 0.574797] gpio gpiochip7: (rk628-gpio1): added GPIO chardev (254:7)
[ 0.574924] gpiochip_setup_dev: registered GPIOs 485 to 498 on device: gpiochip7 (rk628-gpio1)
[ 0.574942] gpiochip_find_base: found new base at 461
[ 0.575176] gpio gpiochip8: (rk628-gpio2): added GPIO chardev (254:8)
[ 0.575303] gpiochip_setup_dev: registered GPIOs 461 to 484 on device: gpiochip8 (rk628-gpio2)
[ 0.575322] gpiochip_find_base: found new base at 448
[ 0.575530] gpio gpiochip9: (rk628-gpio3): added GPIO chardev (254:9)
[ 0.575654] gpiochip_setup_dev: registered GPIOs 448 to 460 on device: gpiochip9 (rk628-gpio3)
[ 0.578745] rk628-combrxphy rk628-combrxphy: DMA mask not set
[ 0.579590] rk628-combtxphy rk628-combtxphy: DMA mask not set
[ 0.581342] rk628-hdmirx rk628-hdmirx: DMA mask not set
[ 0.581983] rk628-dsi rk628-dsi1: DMA mask not set
[ 0.582691] rk628-dsi rk628-dsi0: DMA mask not set
[ 0.583301] rk628-rgb rk628-rgb-tx: DMA mask not set
[ 0.583893] rk628-rgb rk628-yuv-rx: DMA mask not set
[ 0.584481] rk628-rgb rk628-yuv-tx: DMA mask not set
[ 0.585037] rk628-rgb rk628-bt1120-rx: DMA mask not set
[ 0.585605] rk628-rgb rk628-bt1120-tx: DMA mask not set
[ 0.586223] rk628-lvds rk628-lvds: DMA mask not set
[ 0.586854] rk628-gvi rk628-gvi: DMA mask not set
[ 0.590104] rk628-hdmi rk628-hdmi: DMA mask not set
[ 0.591356] rk628-post-process rk628-post-process: DMA mask not set
[ 0.591861] rockchip-pinctrl pinctrl: pin gpio3-0 already requested by ff580000.serial; cannot claim for ff530000.i2c
[ 0.591899] rockchip-pinctrl pinctrl: pin-96 (ff530000.i2c) status -22
[ 0.591929] rockchip-pinctrl pinctrl: could not request pin 96 (gpio3-0) from group i2c4m0-xfer on device rockchip-pinctrl
[ 0.591954] rk3x-i2c ff530000.i2c: Error applying setting, reverse things back
[ 0.591996] rk3x-i2c: probe of ff530000.i2c failed with error -22
[ 0.596169] rk628-csi rk628-csi: DMA mask not set
[ 0.597365] rk628-csi rk628-csi: driver version: 00.00.03
[ 0.597569] rk628-csi rk628-csi: GPIO lookup for consumer power
[ 0.597580] rk628-csi rk628-csi: using device tree for GPIO lookup
[ 0.597615] of_get_named_gpiod_flags: can't parse 'power-gpios' property of node '/i2c@ff510000/rk628@50/csi[0]'
[ 0.597636] of_get_named_gpiod_flags: can't parse 'power-gpio' property of node '/i2c@ff510000/rk628@50/csi[0]'
[ 0.597650] rk628-csi rk628-csi: using lookup tables for GPIO lookup
[ 0.597661] rk628-csi rk628-csi: No GPIO consumer power found
[ 0.597671] rk628-csi rk628-csi: GPIO lookup for consumer plugin-det
[ 0.597679] rk628-csi rk628-csi: using device tree for GPIO lookup
[ 0.597716] of_get_named_gpiod_flags: parsed 'plugin-det-gpios' property of node '/i2c@ff510000/rk628@50/csi[0]' - status (0)
[ 0.597744] gpio gpiochip2: Persistence not supported for GPIO 2
[ 0.715762] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 0.732461] rk628-csi rk628-csi: lane module is not in stop state, ret=0, val=61444
[ 0.798361] Freeing initrd memory: 8948K
[ 0.864275] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 0.864323] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.864343] usb 1-1: Product: USB2.0 Hub
[ 0.865472] hub 1-1:1.0: USB hub found
[ 0.865890] hub 1-1:1.0: 4 ports detected
[ 1.145752] usb 1-1.3: new high-speed USB device number 3 using ehci-platform
[ 1.243767] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8152, bcdDevice=20.00
[ 1.243803] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.243823] usb 1-1.3: Product: USB 10/100 LAN
[ 1.243841] usb 1-1.3: Manufacturer: Realtek
[ 1.243865] usb 1-1.3: SerialNumber: 00E04CF2DBDC
[ 1.325798] usb 1-1.3: reset high-speed USB device number 3 using ehci-platform
[ 1.490822] r8152 1-1.3:1.0 eth1: v2.12.0 (2019/04/29)
[ 1.490862] r8152 1-1.3:1.0 eth1: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 1.599086] phy phy-ff4c0000.usb2-phy.1: charger = USB_SDP_CHARGER
[ 1.906468] rk628-combrxphy rk628-combrxphy: clk det over cnt:10, reg_0x6654:0x501f0000
[ 1.906816] rk628-combrxphy rk628-combrxphy: clock detected failed, cfg resistance manual!
[ 1.944756] rk628-combrxphy rk628-combrxphy: err, clk not stable, reg_0x6630:0x87000d, reg_0x6608:0x110100
[ 1.944790] phy phy-rk628-combrxphy.3: phy poweron failed --> -22
[ 1.944808] m00_b_rk628-csi rk628-csi: hdmi rxphy power on failed
[ 2.286423] m00_b_rk628-csi rk628-csi: rk628_hdmirx_phy_setup hdmi rxphy lock failed, retry:0
[ 3.421949] rk628-combrxphy rk628-combrxphy: clk det over cnt:10, reg_0x6654:0x501f0000
[ 3.422290] rk628-combrxphy rk628-combrxphy: clock detected failed, cfg resistance manual!
[ 3.460175] rk628-combrxphy rk628-combrxphy: err, clk not stable, reg_0x6630:0x87000d, reg_0x6608:0x110100
[ 3.460208] phy phy-rk628-combrxphy.3: phy poweron failed --> -22
[ 3.460224] m00_b_rk628-csi rk628-csi: hdmi rxphy power on failed
[ 3.801925] m00_b_rk628-csi rk628-csi: rk628_hdmirx_phy_setup hdmi rxphy lock failed, retry:1
[ 4.937495] rk628-combrxphy rk628-combrxphy: clk det over cnt:10, reg_0x6654:0x80070141
[ 4.937836] rk628-combrxphy rk628-combrxphy: clock detected failed, cfg resistance manual!
[ 4.943342] rk628-combrxphy rk628-combrxphy: clock stable!
[ 4.943684] rk628-combrxphy rk628-combrxphy: cdr_mode:7, cdr_data:321
[ 4.944227] rk628-combrxphy rk628-combrxphy: cdr_mode:7, pll_man:0x7964c
[ 4.949534] rk628-combrxphy rk628-combrxphy: cdr_mode:7, dc_gain:0, rd_offset:0, edge:0x25c3f8
[ 5.306137] rk628-combrxphy rk628-combrxphy: last equ gain ch0:0, ch1:0, ch2:3
[ 5.430451] rk628-combrxphy rk628-combrxphy: channel alignment done
[ 5.430485] rk628-combrxphy rk628-combrxphy: rx initial done
[ 5.457510] m00_b_rk628-csi rk628-csi: rk628_csi_format_change: New format: 1280x720p60.0 (1650x750)
[ 5.487027] m00_b_rk628-csi rk628-csi: rk628 found @ 0xa0 (rk3x-i2c)
[ 5.489180] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
[ 5.489240] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
[ 5.489388] rkcif rkcif_dvp: rkcif driver version: v00.01.0a
[ 5.489495] rkcif rkcif_dvp: attach to cif hw node
[ 5.489527] rkcif rkcif_dvp: rkcif wait line 0
[ 5.490666] rkcif_dvp: cif_subdev_notifier: no subdev be found!
[ 5.490696] rkcif_dvp: Failed to register subdev notifier(-19)
[ 5.491679] rkcif rkcif_dvp: detach to cif hw node
[ 5.493881] iommu: Adding device ffb50000.rkisp to group 2
[ 5.493944] rkisp_hw ffb50000.rkisp: Linked as a consumer to ffb51a00.iommu
[ 5.494300] rkisp_hw ffb50000.rkisp: is_thunderboot: 0
[ 5.494336] rkisp_hw ffb50000.rkisp: Missing rockchip,grf property
[ 5.494379] rkisp_hw ffb50000.rkisp: can't request region for resource [mem 0xffb50000-0xffb5ffff]
[ 5.494738] rkisp_hw ffb50000.rkisp: assigned reserved memory node isp
[ 5.495065] rkisp rkisp-vir1: rkisp driver version: v01.06.02
[ 5.495171] rkisp rkisp-vir1: GPIO lookup for consumer vsirq
[ 5.495181] rkisp rkisp-vir1: using device tree for GPIO lookup
[ 5.495207] of_get_named_gpiod_flags: can't parse 'vsirq-gpios' property of node '/rkisp-vir1[0]'
[ 5.495228] of_get_named_gpiod_flags: can't parse 'vsirq-gpio' property of node '/rkisp-vir1[0]'
[ 5.495240] rkisp rkisp-vir1: using lookup tables for GPIO lookup
[ 5.495250] rkisp rkisp-vir1: No GPIO consumer vsirq found
[ 5.495307] rkisp rkisp-vir1: No memory-region-thunderboot specified
[ 5.495572] rkisp rkisp-vir1: Entity type for entity rkisp-isp-subdev was not initialized!
[ 5.495618] rkisp rkisp-vir1: Entity type for entity rkisp-csi-subdev was not initialized!
[ 5.495651] rkisp rkisp-vir1: Entity type for entity rkisp-bridge-ispp was not initialized!
[ 5.499591] iommu: Adding device ffb60000.rkispp to group 3
[ 5.499657] rkispp_hw ffb60000.rkispp: Linked as a consumer to ffb60e00.iommu
[ 5.500116] rkispp_hw ffb60000.rkispp: max input:0x0@0fps
[ 5.500165] rkispp_hw ffb60000.rkispp: can't request region for resource [mem 0xffb60000-0xffb7ffff]
[ 5.500424] rkispp_hw ffb60000.rkispp: failed to get cru reset
[ 5.500718] rkispp rkispp-vir0: rkispp driver version: v01.06.02
[ 5.503488] usbcore: registered new interface driver uvcvideo
[ 5.503522] USB Video Class driver (1.1.1)
[ 5.503993] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.20
[ 5.504050] rockchip-iodomain fe020000.syscon:io-domains: vccio2(3300000 uV) supplied by vccio_sd
[ 5.504205] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.16
[ 5.504266] rockchip-iodomain fe020000.syscon:io-domains: vccio3(1800000 uV) supplied by vcc_1v8
[ 5.504401] rockchip-iodomain fe020000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[ 5.504566] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.23
[ 5.504628] rockchip-iodomain fe020000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[ 5.504825] rockchip-iodomain fe020000.syscon:io-domains: vccio6(3300000 uV) supplied by vcc_3v3
[ 5.504993] rockchip-iodomain fe020000.syscon:io-domains: vccio7(1800000 uV) supplied by vcc_1v8
[ 5.505114] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.14
[ 5.505168] rockchip-iodomain fe020000.syscon:io-domains: pmuio0(1800000 uV) supplied by vcc1v8_pmu
[ 5.505336] rockchip-iodomain fe020000.syscon:io-domains: Linked as a consumer to regulator.11
[ 5.505391] rockchip-iodomain fe020000.syscon:io-domains: pmuio1(3300000 uV) supplied by vcc3v3_sys
[ 5.509068] rockchip-thermal ff5f0000.tsadc: tsadc trimmed value = -11
[ 5.509463] rockchip-thermal ff5f0000.tsadc: tsadc is probed successfully!
[ 5.509959] rockchip-thermal ff5f8000.tsadc: tsadc trimmed value = -11
[ 5.510250] rockchip-thermal ff5f8000.tsadc: tsadc is probed successfully!
[ 5.511454] Bluetooth: HCI UART driver ver 2.3
[ 5.511486] Bluetooth: HCI UART protocol H4 registered
[ 5.511842] cpu cpu0: bin=0
[ 5.511902] cpu cpu0: leakage=1.375
[ 5.512047] cpu cpu0: Linked as a consumer to regulator.9
[ 5.523747] cpu cpu0: temp=45200, pvtm=100616 (100512 + 104)
[ 5.523865] cpu cpu0: pvtm-volt-sel=1
[ 5.523969] cpu cpu0: Dropping the link to regulator.9
[ 5.524035] cpu cpu0: bin-scale=5
[ 5.524438] cpu cpu0: Linked as a consumer to regulator.9
[ 5.524524] cpu cpu0: Dropping the link to regulator.9
[ 5.524764] cpu cpu0: Linked as a consumer to regulator.9
[ 5.526062] cpu cpu0: avs=0
[ 5.526497] energy_model: Created perf domain 0-3
[ 5.526562] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.526609] cpu cpu0: failed to read out thermal zone (-22)
[ 5.527504] cpu cpu0: failed to find power_model node
[ 5.527587] cpuidle: enable-method property 'psci' found operations
[ 5.527670] cpuidle: enable-method property 'psci' found operations
[ 5.527750] cpuidle: enable-method property 'psci' found operations
[ 5.527816] cpuidle: enable-method property 'psci' found operations
[ 5.528171] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[ 5.528176] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[ 5.528198] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[ 5.528213] gpio gpiochip0: Persistence not supported for GPIO 6
[ 5.528497] Synopsys Designware Multimedia Card Interface Driver
[ 5.529001] dwmmc_rockchip ffc50000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.529126] dwmmc_rockchip ffc50000.dwmmc: Using internal DMA controller.
[ 5.529184] dwmmc_rockchip ffc50000.dwmmc: Version ID is 270a
[ 5.529273] dwmmc_rockchip ffc50000.dwmmc: DW MMC controller at irq 62,32 bit host data width,256 deep fifo
[ 5.529366] dwmmc_rockchip ffc50000.dwmmc: GPIO lookup for consumer wp
[ 5.529372] dwmmc_rockchip ffc50000.dwmmc: using device tree for GPIO lookup
[ 5.529388] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ffc50000[0]'
[ 5.529396] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ffc50000[0]'
[ 5.529404] dwmmc_rockchip ffc50000.dwmmc: using lookup tables for GPIO lookup
[ 5.529409] dwmmc_rockchip ffc50000.dwmmc: No GPIO consumer wp found
[ 5.529437] mmc_host mmc0: card is non-removable.
[ 5.542685] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 5.556678] dwmmc_rockchip ffc60000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.556761] dwmmc_rockchip ffc60000.dwmmc: Using internal DMA controller.
[ 5.556791] dwmmc_rockchip ffc60000.dwmmc: Version ID is 270a
[ 5.556893] dwmmc_rockchip ffc60000.dwmmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[ 5.557136] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.21
[ 5.557258] dwmmc_rockchip ffc60000.dwmmc: Linked as a consumer to regulator.20
[ 5.557339] dwmmc_rockchip ffc60000.dwmmc: GPIO lookup for consumer cd
[ 5.557349] dwmmc_rockchip ffc60000.dwmmc: using device tree for GPIO lookup
[ 5.557380] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@ffc60000[0]'
[ 5.557401] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@ffc60000[0]'
[ 5.557414] dwmmc_rockchip ffc60000.dwmmc: using lookup tables for GPIO lookup
[ 5.557424] dwmmc_rockchip ffc60000.dwmmc: No GPIO consumer cd found
[ 5.557437] dwmmc_rockchip ffc60000.dwmmc: GPIO lookup for consumer wp
[ 5.557446] dwmmc_rockchip ffc60000.dwmmc: using device tree for GPIO lookup
[ 5.557466] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ffc60000[0]'
[ 5.557485] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ffc60000[0]'
[ 5.557496] dwmmc_rockchip ffc60000.dwmmc: using lookup tables for GPIO lookup
[ 5.557506] dwmmc_rockchip ffc60000.dwmmc: No GPIO consumer wp found
[ 5.569290] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 5.583252] dwmmc_rockchip ffc70000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.583343] dwmmc_rockchip ffc70000.dwmmc: Using internal DMA controller.
[ 5.583380] dwmmc_rockchip ffc70000.dwmmc: Version ID is 270a
[ 5.583493] dwmmc_rockchip ffc70000.dwmmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[ 5.583652] dwmmc_rockchip ffc70000.dwmmc: GPIO lookup for consumer wp
[ 5.583664] dwmmc_rockchip ffc70000.dwmmc: using device tree for GPIO lookup
[ 5.583699] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ffc70000[0]'
[ 5.583720] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ffc70000[0]'
[ 5.583736] dwmmc_rockchip ffc70000.dwmmc: using lookup tables for GPIO lookup
[ 5.583747] dwmmc_rockchip ffc70000.dwmmc: No GPIO consumer wp found
[ 5.583812] dwmmc_rockchip ffc70000.dwmmc: allocated mmc-pwrseq
[ 5.583868] mmc_host mmc1: card is non-removable.
[ 5.588581] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 200000000Hz, actual 198000000HZ div = 0)
[ 5.588644] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 5.588766] mmc0: new HS200 MMC card at address 0001
[ 5.590759] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 5.592094] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[ 5.593499] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[ 5.594752] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (241:0)
[ 5.597073] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 5.604573] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 5.610420] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/work[0]' - status (0)
[ 5.610446] gpio gpiochip0: Persistence not supported for GPIO 4
[ 5.610449] no flags found for gpios
[ 5.610584] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/user[0]' - status (0)
[ 5.610598] gpio gpiochip0: Persistence not supported for GPIO 16
[ 5.610602] no flags found for gpios
[ 5.611058] usbcore: registered new interface driver usbkbd
[ 5.611130] usbcore: registered new interface driver usbmouse
[ 5.613113] rockchip-saradc ff5e0000.saradc: Linked as a consumer to regulator.16
[ 5.614237] rksfc_base v1.1 2016-01-08
[ 5.614840] rksfc ffc90000.sfc: rksfc_probe clk rate = 79200000
[ 5.614932] rkflash_dev_init enter
[ 5.614957] sfc nor id: 0 0 0
[ 5.614971] rkflash[1] is invalid
[ 5.614975] rkflash_dev_init enter
[ 5.614996] sfc_nand id: 0 0 0
[ 5.615004] rkflash[2] is invalid
[ 5.621575] rk817-codec rk817-codec: DMA mask not set
[ 5.621724] rk817_codec_parse_dt_property: rk809 have no io-channels defined
[ 5.621765] of_get_named_gpiod_flags: parsed 'hp-det' property of node '/i2c@ff3f0000/pmic@20/codec[0]' - status (0)
[ 5.621789] rk817-codec rk817-codec: GPIO lookup for consumer hp-ctl
[ 5.621794] rk817-codec rk817-codec: using device tree for GPIO lookup
[ 5.621812] of_get_named_gpiod_flags: parsed 'hp-ctl-gpios' property of node '/i2c@ff3f0000/pmic@20/codec[0]' - status (0)
[ 5.621823] gpio gpiochip1: Persistence not supported for GPIO 23
[ 5.621835] rk817-codec rk817-codec: GPIO lookup for consumer spk-ctl
[ 5.621839] rk817-codec rk817-codec: using device tree for GPIO lookup
[ 5.621857] of_get_named_gpiod_flags: parsed 'spk-ctl-gpios' property of node '/i2c@ff3f0000/pmic@20/codec[0]' - status (0)
[ 5.621867] gpio gpiochip3: Persistence not supported for GPIO 30
[ 5.627325] NET: Registered protocol family 17
[ 5.627407] NET: Registered protocol family 15
[ 5.627979] Bluetooth: RFCOMM TTY layer initialized
[ 5.628025] Bluetooth: RFCOMM socket layer initialized
[ 5.628130] Bluetooth: RFCOMM ver 1.11
[ 5.628152] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.628168] Bluetooth: HIDP socket layer initialized
[ 5.628179] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.628189] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.628498] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.628543] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6236
[ 5.628556] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.628567] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.628589] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[ 5.628598] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[ 5.628606] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[ 5.628625] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[ 5.628629] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 8, flags = 0.
[ 5.628658] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.628670] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.629180] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0)
[ 5.629190] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 48.
[ 5.629273] of_get_named_gpiod_flags: parsed 'BT,power_gpio' property of node '/wireless-bluetooth[0]' - status (0)
[ 5.629278] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 7.
[ 5.629305] of_get_named_gpiod_flags: can't parse 'BT,reset_gpio' property of node '/wireless-bluetooth[0]'
[ 5.629315] of_get_named_gpiod_flags: can't parse 'BT,wake_gpio' property of node '/wireless-bluetooth[0]'
[ 5.629335] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0)
[ 5.629339] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[ 5.629386] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 5.629476] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.629676] [BT_RFKILL]: ** disable irq
[ 5.629805] [BT_RFKILL]: bt shut off power
[ 5.629866] [BT_RFKILL]: bt_default device registered.
[ 5.631449] flash vendor_init_thread!
[ 5.631480] flash vendor storage:20170308 ret = -1
[ 5.632317] Registering SWP/SWPB emulation handler
[ 5.633352] Loading compiled-in X.509 certificates
[ 5.634738] rga2: Driver loaded successfully ver:3.2.56726
[ 5.635078] rga2: Module initialized.
[ 5.640624] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 5.642330] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 5.644242] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 5.647147] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 5.651272] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 5.651563] vendor storage:20190527 ret = 0
[ 5.662561] mpp_rkvenc ffbb0000.rkvenc: probing start
[ 5.663586] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to regulator.8
[ 5.663663] mpp_rkvenc ffbb0000.rkvenc: bin=0
[ 5.663689] mpp_rkvenc ffbb0000.rkvenc: leakage=1.375
[ 5.663738] mpp_rkvenc ffbb0000.rkvenc: Failed to get pvtm
[ 5.663765] mpp_rkvenc ffbb0000.rkvenc: bin-scale=37
[ 5.664040] mpp_rkvenc ffbb0000.rkvenc: avs=0
[ 5.664294] mpp_rkvenc ffbb0000.rkvenc: failed to find power_model node
[ 5.664309] mpp_rkvenc ffbb0000.rkvenc: failed to initialize power model
[ 5.664433] mpp_rkvenc ffbb0000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.664455] mpp_rkvenc ffbb0000.rkvenc: failed to read out thermal zone (-22)
[ 5.664740] mpp_rkvenc ffbb0000.rkvenc: probing finish
[ 5.665189] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 5.665853] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/rk809-sound[0]'
[ 5.665878] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/rk809-sound[0]'
[ 5.667821] asoc-simple-card rk809-sound: rk817-hifi <-> ff800000.i2s mapping ok
[ 5.667861] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 5.667874] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[ 5.667885] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 5.667893] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[ 5.667904] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 5.667914] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[ 5.667924] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 5.667934] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[ 5.668444] input: rockchip,rk809-codec Headphone Jack as /devices/platform/rk809-sound/sound/card0/input2
[ 5.670937] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 5.670970] ======== dhd_wlan_init_plat_data ========
[ 5.670982] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 5.671050] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=122, oob_irq_flags=0x414
[ 5.671063] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 5.671073] dhd_wifi_platform_load: Enter
[ 5.671084] Power-up adapter 'DHD generic adapter'
[ 5.671123] wifi_platform_set_power = 1
[ 5.671135] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 5.671145] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 5.671157] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 5.671265] ==gsl_ts_init==
[ 5.671316] ret=0
[ 5.671999] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.681330] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.681785] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.681802] cfg80211: failed to load regulatory.db
[ 5.691359] rkisp rkisp-vir1: clear unready subdev num: 1
[ 5.691790] rkisp0: update sensor failed
[ 5.746055] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 5.747839] mmc1: new high speed SDIO card at address 0001
[ 5.789697] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 270
[ 5.792017] dwmmc_rockchip ffc50000.dwmmc: Successfully tuned phase to 90
[ 5.794053] ret 1024 0
[ 5.795256] ALSA device list:
[ 5.795334] #0: rockchip,rk809-codec
[ 5.795349] #7: Loopback 1
[ 5.797480] Freeing unused kernel memory: 1024K
[ 5.797937] Run /init as init process
[ 5.975729] wifi_platform_bus_enumerate device present 1
[ 5.975758] ======== Card detection to detect SDIO card! ========
[ 5.975767] mmc1:mmc host rescan start!
[ 5.991940] bcmsdh_register: register client driver
[ 5.992254] bcmsdh_sdmmc_probe: Enter num=1
[ 5.992935] bcmsdh_sdmmc_probe: Enter num=2
[ 5.992959] bus num (host idx)=1, slot num (rca)=1
[ 5.992968] found adapter info 'DHD generic adapter'
[ 5.993052] sdioh_attach: set sd_f2_blocksize 256
[ 5.993110] sdioh_attach: sd clock rate = 0
[ 5.993643] dhdsdio_probe : no mutex held. set lock
[ 5.993781] F1 signature read @0x18000000=0x1542a9a6
[ 5.999503] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x2 pkg:0x4
[ 6.001602] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 6.001791] [dhd] dhd_conf_set_chiprev : chip=0xa9a6, chiprev=2
[ 6.001966] [dhd] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 6.002398] [dhd] CFG80211-ERROR) wl_setup_wiphy : SAE support
[ 6.002644] [dhd] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 6.003289] dhd_attach(): thread:dhd_watchdog_thread:7b started
[ 6.003418] dhd_attach(): thread:dhd_dpc:7c started
[ 6.003551] dhd_attach(): thread:dhd_rxf:7d started
[ 6.003576] dhd_deferred_work_init: work queue initialized
[ 6.003591] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 -> mode 2
[ 6.003632] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 6.003948] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 6.012445] Dongle Host Driver, version 1.579.77.41.22 (r-20191105-2)(20191120-1)
[ 6.013077] Register interface [wlan0] MAC: 70:4a:0e:5f:9e:ae
[ 6.013148] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 -> mode 0
[ 6.013170] dhd_wl_ioctl: returning as busstate=0
[ 6.013183] dhd_dbg_detach_pkt_monitor, 2204
[ 6.013194] dhd_bus_devreset: == Power OFF ==
[ 6.013443] bcmsdh_oob_intr_unregister: Enter
[ 6.013455] bcmsdh_oob_intr_unregister: irq is not registered
[ 6.013466] dhd_txglom_enable: enable 0
[ 6.013472] dhd_bus_devreset: WLAN OFF DONE
[ 6.013515] wifi_platform_set_power = 0
[ 6.013530] ======== PULL WL_REG_ON(-1) LOW! ========
[ 6.013542] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 6.013562] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 6.013574] dhdsdio_probe : the lock is released.
[ 6.013965] dhd_module_init: Exit err=0
[ 6.510926] m00_b_rk628-csi rk628-csi: rk628_csi_delayed_work_audio: HDMI_RX_AUD_FIFO_ISTS:0x1f, underflow or overflow
[ 8.371004] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 8.511116] EXT4-fs (mmcblk0p8): warning: mounting unchecked fs, running e2fsck is recommended
[ 8.515146] EXT4-fs (mmcblk0p8): mounted filesystem without journal. Opts: (null)
[ 8.534387] EXT4-fs error (device mmcblk0p8): ext4_mb_generate_buddy:747: group 548, block bitmap and bg descriptor inconsistent: 7788 vs 7790 free clusters
[ 8.534474] EXT4-fs error (device mmcblk0p8): ext4_mb_generate_buddy:747: group 549, block bitmap and bg descriptor inconsistent: 7864 vs 7866 free clusters
[ 8.535019] EXT4-fs error (device mmcblk0p8): ext4_mb_generate_buddy:747: group 550, block bitmap and bg descriptor inconsistent: 7902 vs 7904 free clusters
[ 8.535062] EXT4-fs error (device mmcblk0p8): ext4_mb_generate_buddy:747: group 551, block bitmap and bg descriptor inconsistent: 7847 vs 7849 free clusters
[ 8.855991] systemd[1]: System time before build time, advancing clock.
[ 8.864425] systemd[1]: Failed to lookup module alias 'autofs4': Function not implemented
[ 8.880368] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.881638] systemd[1]: Detected architecture arm.
[ 8.887294] systemd[1]: Set hostname to <firefly>.
[ 9.051595] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.051642] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 9.348561] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.349852] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.351034] systemd[1]: Listening on udev Control Socket.
[ 9.351271] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 9.351990] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 9.836495] systemd-journald[414]: Received request to flush runtime journal from PID 1
[ 10.296770] galcore: loading out-of-tree module taints kernel.
[ 10.340759] r8152 1-1.3:1.0 enx00e04cf2dbdc: renamed from eth1
[ 10.343743] galcore: npu init.
[ 10.344783] galcore: start npu probe.
[ 10.344991] galcore ffbc0000.npu: Linked as a consumer to regulator.8
[ 10.376011] npu: platform_get_irq irq = 66
[ 10.376059] Galcore version 6.4.3.5.293908
可以看到已经获取到了分辨率信息
但是mdedia-ctl似乎找不到节点
media-ctl -d /dev/media0 -p
Media controller API version 4.19.111
Media device information
driver rkisp
model rkisp0
serial
bus info
hw revision 0x0
driver version 4.19.111
Device topology
- entity 1: rkisp-isp-subdev (4 pads, 9 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev1
pad0: Sink
[fmt:SBGGR10_1X10/800x600 field:none
crop.bounds:(0,0)/800x600
crop:(0,0)/800x600]
<- "rkisp_rawrd0_m":0 []
<- "rkisp_rawrd2_s":0 []
<- "rkisp_rawrd1_l":0 []
pad1: Sink
<- "rkisp-input-params":0 [ENABLED]
pad2: Source
[fmt:YUYV8_2X8/800x600 field:none colorspace:smpte170m quantization:full-range
crop:(0,0)/800x600]
-> "rkisp-bridge-ispp":0 [ENABLED]
-> "rkisp_mainpath":0 []
-> "rkisp_selfpath":0 [ENABLED]
pad3: Source
-> "rkisp-statistics":0 [ENABLED]
-> "rkisp-mipi-luma":0 [ENABLED]
- entity 6: rkisp-csi-subdev (6 pads, 4 links)
device node name /dev/v4l-subdev2
pad0: Sink
pad1: Source
pad2: Source
-> "rkisp_rawwr0":0 [ENABLED]
pad3: Source
-> "rkisp_rawwr1":0 [ENABLED]
pad4: Source
-> "rkisp_rawwr2":0 [ENABLED]
pad5: Source
-> "rkisp_rawwr3":0 [ENABLED]
- entity 13: rkisp-bridge-ispp (1 pad, 1 link)
pad0: Sink
<- "rkisp-isp-subdev":2 [ENABLED]
- entity 17: rkisp_mainpath (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "rkisp-isp-subdev":2 []
- entity 23: rkisp_selfpath (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
- entity 29: rkisp_rawwr0 (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "rkisp-csi-subdev":2 [ENABLED]
- entity 35: rkisp_rawwr1 (1 pad, 1 link)
device node name /dev/video3
pad0: Sink
<- "rkisp-csi-subdev":3 [ENABLED]
- entity 41: rkisp_rawwr2 (1 pad, 1 link)
device node name /dev/video4
pad0: Sink
<- "rkisp-csi-subdev":4 [ENABLED]
- entity 47: rkisp_rawwr3 (1 pad, 1 link)
device node name /dev/video5
pad0: Sink
<- "rkisp-csi-subdev":5 [ENABLED]
- entity 53: rkisp_rawrd0_m (1 pad, 1 link)
device node name /dev/video6
pad0: Source
-> "rkisp-isp-subdev":0 []
- entity 59: rkisp_rawrd2_s (1 pad, 1 link)
device node name /dev/video7
pad0: Source
- entity 65: rkisp_rawrd1_l (1 pad, 1 link)
device node name /dev/video8
pad0: Source
- entity 71: rkisp-statistics (1 pad, 1 link)
device node name /dev/video9
pad0: Sink
<- "rkisp-isp-subdev":3 [ENABLED]
- entity 77: rkisp-input-params (1 pad, 1 link)
device node name /dev/video10
pad0: Source
-> "rkisp-isp-subdev":1 [ENABLED]
- entity 83: rkisp-mipi-luma (1 pad, 1 link)
device node name /dev/video11
pad0: Sink
media-ctl -d /dev/media1 -p
driver rkispp
model rkispp0
serial
bus info
hw revision 0x0
Device topology
- entity 1: rkispp_input_image (1 pad, 1 link)
device node name /dev/video12
pad0: Source
-> "rkispp-subdev":0 [ENABLED]
- entity 5: rkispp_m_bypass (1 pad, 1 link)
device node name /dev/video13
pad0: Sink
<- "rkispp-subdev":2 [ENABLED]
- entity 9: rkispp_scale0 (1 pad, 1 link)
device node name /dev/video14
pad0: Sink
- entity 13: rkispp_scale1 (1 pad, 1 link)
device node name /dev/video15
pad0: Sink
- entity 17: rkispp_scale2 (1 pad, 1 link)
device node name /dev/video16
pad0: Sink
- entity 21: rkispp_iqtool (1 pad, 1 link)
device node name /dev/video17
pad0: Sink
- entity 25: rkispp_input_params (1 pad, 1 link)
device node name /dev/video18
pad0: Source
-> "rkispp-subdev":1 [ENABLED]
- entity 29: rkispp-stats (1 pad, 1 link)
device node name /dev/video19
pad0: Sink
<- "rkispp-subdev":3 [ENABLED]
- entity 33: rkispp-subdev (4 pads, 8 links)
device node name /dev/v4l-subdev0
pad0: Sink
[fmt:unknown/0x0
crop.bounds:(0,0)/0x0
crop:(0,0)/0x0
compose.bounds:(0,0)/0x0
compose:(0,0)/0x0]
<- "rkispp_input_image":0 [ENABLED]
pad1: Sink
<- "rkispp_input_params":0 [ENABLED]
pad2: Source
[fmt:unknown/0x0]
-> "rkispp_m_bypass":0 [ENABLED]
-> "rkispp_scale0":0 [ENABLED]
-> "rkispp_scale1":0 [ENABLED]
-> "rkispp_scale2":0 [ENABLED]
-> "rkispp_iqtool":0 [ENABLED]
pad3: Source
-> "rkispp-stats":0 [ENABLED]
目前感觉和这个报错有关
看了下驱动源码,似乎mipi_dphy重置不正常
static int mipi_dphy_reset(struct rk628_csi *csi)
u32 val, mask;
int ret;
mipi_dphy_enableclk_deassert(csi);
mipi_dphy_shutdownz_assert(csi);
mipi_dphy_rstz_assert(csi);
testif_testclr_assert(csi);
/* Set all REQUEST inputs to zero */
regmap_update_bits(csi->grf, GRF_MIPI_TX0_CON,
FORCETXSTOPMODE_MASK | FORCERXMODE_MASK,
FORCETXSTOPMODE(0) | FORCERXMODE(0));
udelay(1);
testif_testclr_deassert(csi);
mipi_dphy_enableclk_assert(csi);
mipi_dphy_shutdownz_deassert(csi);
mipi_dphy_rstz_deassert(csi);
usleep_range(1500, 2000);
mask = STOPSTATE_CLK | STOPSTATE_LANE0;
ret = regmap_read_poll_timeout(csi->csi_regmap, CSITX_CSITX_STATUS1,
val, (val & mask) == mask,
0, 1000);
if (ret < 0) {
int ___ret;
___ret = regmap_read(csi->csi_regmap, CSITX_CSITX_STATUS1, &val);
dev_err(csi->dev, "lane module is not in stop state, ret=%d, val=%u\n", ___ret, val);
return ret;
return 0;
通过查手册CSITX_CSITX_STATUS1目前处于 4个lane和时钟的 txuppsactivenot状态,不是想要的stopstate状态。
因为不大清楚txuppsactivenot是什么,现在有点怀疑是MIPI信号线的转接板做的不好,就是Core-1126-JD4的MIPI是排针,但是RK628D是排线,做了一个小板子,导致MIPI。
有大佬调通过这个板子吗,你们有lane module is not in stop state这个报错不。是否可以上传下日志供参考下,谢谢。
