[已解决]: ./build.sh uboot失败
固件文件名称:rk3288_linux_release_v2.5.0a_20230510
Log日志:firefly-rk3288-ubuntu.mk.tar
我按照官方wiki配置的编译环境。编译uboot出错,编译kernel和recovery无异常。
求大佬指点,谢谢!
./build.sh uboot 错误信息如下:
COPY spl/u-boot-spl.bin
CFGCHK u-boot.cfg
awk: line 2: function strtonum never defined
ERROR: Running build_uboot failed!
ERROR: exit code 2 from line 522:
./make.sh $RK_UBOOT_DEFCONFIG $UBOOT_COMPILE_COMMANDS
已解决:
问题出现在:awk: line 2: function strtonum never defined
解决办法:sudo apt-get install gawk
目录结构
t@N5110:~/proj/rk3288_linux_release_v2.5.0a_20230510$ tree -L 1.
├── app
├── buildroot
├── build.sh → device/rockchip/common/build.sh
├── device
├── docs
├── envsetup.sh → buildroot/build/envsetup.sh
├── external
├── kernel
├── Makefile → buildroot/build/Makefile
├── mkfirmware.sh → device/rockchip/common/mkfirmware.sh
├── prebuilts
├── rkbin
├── rkflash.sh → device/rockchip/common/rkflash.sh
├── rockdev
├── tools
└── u-boot
编译前配置
t@N5110:~/proj/rk3288_linux_release_v2.5.0a_20230510$ ./build.sh firefly-rk3288-ubuntu.mk
processing option: firefly-rk3288-ubuntu.mk
switching to board: /home/tang/proj/rk3288_linux_release_v2.5.0a_20230510/device/rockchip/rk3288/firefly-rk3288-ubuntu.mk
t@N5110:~/proj/rk3288_linux_release_v2.5.0a_20230510$ vim device/rockchip/.BoardConfig.mk
[b]#!/bin/bash
CMD=realpath $BASH_SOURCE
CUR_DIR=dirname $CMD
source $CUR_DIR/BoardConfig.mk
# Uboot defconfig
export RK_UBOOT_DEFCONFIG=firefly-rk3288
# Kernel defconfig
export RK_KERNEL_DEFCONFIG=firefly_linux_defconfig
# Kernel dts
export RK_KERNEL_DTS=rk3288-firefly
# PRODUCT MODEL
export RK_PRODUCT_MODEL=FIREFLY_RK3288
# parameter for GPT table
export RK_PARAMETER=parameter-ubuntu.txt
# packagefile for pack image files
export RK_PACKAGE_FILE=rk3288-ubuntu-package-file
# Set rootfs type, including ext2 ext4 squashfs
export RK_ROOTFS_TYPE=ext4
# rootfs image path
[/b]
firefly-rk3288-ubuntu.mk.tar (2.5 KB)
可能是是awk的版本有问题,没有定义strtonum 函数
怎么解呢,求指点!
