WiFi7-802.11BE-IPQ9574-support 4xM.2 moudle-QCN9274+QCN6274 For Industrial Grade
In the fast-paced world of technology, staying connected is paramount, especially in industrial settings. Say hello to the future of wireless connectivity: WiFi 7, also known as 802.11BE, featuring the IPQ9574 chipset. This cutting-edge technology is a game-changer for industrial-grade applications, providing unparalleled speed, reliability, and versatility. Here’s what you need to know:
The Power of WiFi 7 (802.11BE):
Blazing Speeds: WiFi 7 operates at multi-gigabit speeds, providing a bandwidth boost of up to 30 Gbps, making it perfect for data-intensive applications.
Low Latency:Reduced latency ensures real-time communication and minimizes lag, ideal for mission-critical industrial processes.
Enhanced Security: WiFi 7 incorporates the latest security protocols, safeguarding your data against threats and unauthorized access.
Improved Efficiency:Increased spectral efficiency optimizes network performance even in crowded environments.
Industrial-Grade with IPQ9574:
The IPQ9574 chipset is designed to meet the rigorous demands of industrial applications.
Robust and reliable, it’s built to withstand extreme conditions, ensuring uninterrupted connectivity in challenging environments.
4x M.2 Module Support:
WiFi 7 with IPQ9574 supports up to 4x M.2 modules, allowing for a versatile range of connectivity options.
This adaptability is perfect for industrial setups, where various modules can be used for specific tasks, such as sensors, cameras, or additional networking options.
QCN9274 + QCN6274:
The QCN9274 and QCN6274 modules offer high-performance wireless connectivity.
QCN9274 supports WiFi 7 (802.11BE), while QCN6274 supports legacy WiFi standards, ensuring compatibility with existing infrastructure.
Industrial Applications:
WiFi 7 with IPQ9574, QCN9274, and QCN6274 is tailored for a wide range of industrial use cases:
Manufacturing:Seamless communication between machines and sensors for process optimization.
Logistics:Real-time tracking and monitoring for efficient supply chain management.
Energy:Enhanced connectivity for remote monitoring and control of power grids and renewable energy sources.
Healthcare:Reliable connectivity for medical equipment and telemedicine applications.
Embrace the Future of Connectivity:
WiFi 7 (802.11BE) with IPQ9574 is set to revolutionize industrial-grade wireless communication.
It’s not just about speed; it’s about reliability, low latency, and security.
Whether you’re in manufacturing, logistics, energy, or healthcare, WiFi 7 with IPQ9574 is the solution that will elevate your industrial operations to the next level. Embrace the future of connectivity and unlock new possibilities for your business!
Wallys wifi7 mainboard DR9574
Parameter
Rating
Unit
Operating Temperature Range
-20 ~ 70
ºC
Storage Temperature Range
-40 ~ 90
ºC
Operating Humidity Range
5 ~ 95 (non-condensing)
Storage Humidity Range
0 ~ 90 (non-condensing)
Symbol
Parameter
Chipset
Qualcomm IPQ9574 Quad-Core ARM-A73 @ 2.2GHz processor ‘Alder’ Series
WLAN Host Interface
PCI Express 3.0 Interface
System Memory
2GB (2x1GB), DDR4 32-bit (2x16-bit) interface
Standard?Operating Voltage
12V
Operating Systems
QSDK
Host Interface
Antenna Cable / Port
4x U.FL Connectors
Frequency Range
2.4GHz: 2.412~2.472GHz
Data Rates for WLAN
Supports 20/40MHz at 2.4GHz
Modulation Techniques
Temperature Range
Operating: -20 °C to 70 °C, Storage: -40 °C to 90?°C
Humidity
Certification
REACH & RoHS Compliance
Power Consumption
13W (Board only)
23W (with onboard WiFi, IPQ9574)
Dimensions (WxHxD)
203mm x 139mm x 20mm
Upgrade your WiFi experience with the Wallys DR9574 DR9274 WiFi 7 Networking Solution,Whether you’re a gamer, streamer, or someone who demands high-speed internet for work, this network card has got you covered. Say goodbye to sluggish connections and hello to lightning-fast speeds and seamless connectivity.
[b]BY:https://www.wallystech.com/[/b]
Attach:sales4@wallystech.com
