Introduction
In the ever-evolving world of wireless networking, the demand for faster, more reliable, and efficient routers is continually increasing. The IPQ8072 CPU, paired with the 802.11ax standard, has emerged as a formidable solution to meet these demands. In this technical post, we delve into the capabilities and features of the IPQ8072 CPU on an 802.11ax routerboard, specifically focusing on its support for 4x4 MIMO in both the 2.4GHz and 5GHz bands.
The IPQ8072 CPU
The IPQ8072 is a high-powered system-on-chip (SoC) designed by Qualcomm Atheros, tailored for use in advanced wireless routers. This chip incorporates a quad-core ARM Cortex-A53 CPU, clocked at impressive speeds, making it capable of handling the complex processing required for today’s bandwidth-intensive applications.
Key Features of the IPQ8072 CPU:
Quad-Core Processing Power: The four ARM Cortex-A53 cores enable efficient multitasking and ensure that the router can handle multiple concurrent data streams without slowing down.
High Clock Speeds: The CPU operates at high clock speeds, ensuring low latency and rapid data processing, critical for real-time applications like online gaming and video streaming.
Hardware Acceleration: The IPQ8072 includes hardware acceleration for encryption, decryption, and QoS (Quality of Service), further boosting network performance.
Integrated Connectivity: The SoC boasts integrated radios for both 2.4GHz and 5GHz bands, supporting 4x4 MIMO (Multiple-Input, Multiple-Output) configurations for each band.
802.11ax (Wi-Fi 6) Standard
The IPQ8072 routerboard supports the 802.11ax standard, also known as Wi-Fi 6, which is a significant advancement in wireless networking. Key features of 802.11ax include:
Improved Efficiency: 802.11ax introduces technologies like Orthogonal Frequency Division Multiple Access (OFDMA) and Basic Service Set (BSS) Coloring, which enhance efficiency in crowded network environments.
Higher Throughput: With support for higher bandwidth channels and 1024-QAM modulation, 802.11ax offers significantly higher throughput compared to previous Wi-Fi standards.
Increased Capacity: MU-MIMO (Multi-User, Multiple Input, Multiple Output) technology enables simultaneous communication with multiple devices, increasing network capacity.
Enhanced Range: Beamforming and improved signal processing algorithms extend the effective range of Wi-Fi signals.
4x4 MIMO in 2.4GHz & 5GHz Bands
One of the standout features of the IPQ8072 CPU is its support for 4x4 MIMO in both the 2.4GHz and 5GHz bands. This configuration has several advantages:
Faster Wireless Speeds: With four transmit and four receive antennas, the router can achieve higher data rates, ensuring a faster and more responsive network experience.
Improved Signal Coverage: 4x4 MIMO enhances signal coverage, reducing dead spots and ensuring consistent connectivity throughout your home or office.
Enhanced Device Compatibility: Many modern devices, such as smartphones and laptops, support 4x4 MIMO. This means that they can take full advantage of the router’s capabilities, resulting in better overall performance.
Conclusion
The IPQ8072 CPU on an 802.11ax routerboard, with its 4x4 MIMO support in both the 2.4GHz and 5GHz bands, represents a high-powered solution for meeting the demands of today’s wireless networking needs. With its quad-core CPU, hardware acceleration, and support for the latest Wi-Fi 6 standard, it offers faster speeds, increased capacity, and improved coverage, making it an excellent choice for those seeking a high-performance router for their home or office network. As technology continues to evolve, routers like these are at the forefront, paving the way for the future of wireless connectivity.
1.DR8072V01
Website:
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
NOR Flash: 8 MB
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
EMAIL:sales4@wallystech.com
