更新resource.img和kernel.img没变化
按着这哩弄hello-led,http://developer.t-firefly.com/forum.php?mod=viewthread&tid=648&extra=page%3D1
1、在drivers文件夹下建文件夹sai
2、在sai下放好hello.c,makefile,kconfig
3、在dirvers下的makefile,kconfig添加好东西
4、在kernel下make menuconfig设置hello编译到内核
5、make
6、烧录resource.img和kernel.img
重启板子,发现led并没有闪
dts我是这样改的:
firefly-led{
compatible = “firefly,led”;
led-work = <&gpio1 GPIO_C7 GPIO_ACTIVE_LOW>;
led-power = <&gpio1 GPIO_C6 GPIO_ACTIVE_LOW>;
status = “disabled”;
    hello-led{
            compatible = "firefly,hello_led";
            led= <&gpio1 GPIO_C6 GPIO_ACTIVE_LOW>;//这里我改成黄色的灯
            status = "okay";
    leds {
   compatible = "gpio-leds";
   power {
       label = "firefly:blue:power";
       linux,default-trigger = "ir-power-click";
       default-state = "on";
       gpios = <&gpio1 GPIO_C7 GPIO_ACTIVE_LOW>;
    user {
       label = "firefly:yellow:user";
       linux,default-trigger = "ir-user-click";
       default-state = "off";
       gpios = <&gpio1 GPIO_C6 GPIO_ACTIVE_LOW>;
hello.c里关键是这样的:
#ifdef CONFIG_OF
static const struct of_device_id of_firefly_hello_match = {
{ .compatible = “firefly,hello_led” },
{ /* Sentinel */ }
#endif
static struct platform_driver firefly_hello_driver = {
.probe = firefly_hello_probe,
.remove = firefly_hello_remove,
.driver = {
.name = “firefly_hello”,
.owner = THIS_MODULE,
#ifdef CONFIG_OF
.of_match_table = of_firefly_hello_match,
#endif
查看板子的dmesg也没看到hello模块加载的printk,请问我哪里弄错了呢?
补充一下,在源码目录里可以看到hello.c文件有被编译
有可能是boot。img里面包含了kernel,会默认先使用里面的kernel,不包含kernel的boot一般1点多m
接串口看一下log信息,看打印出来的内核编译时间是不是你编译的时间,可以确定板子是否运行你编译的内核
请问怎么看内核编译的时间?
Terminal ready
reboot
[ 89.642991] SysRq : Emergency Remount R/O
[ 89.648292] EXT4-fs (rknand_cache): re-mounted. Opts: (null)
[ 89.650026] EXT4-fs (rknand_metadata): re-mounted. Opts: (null)
[ 89.658454] EXT4-fs (rknand_userdata): re-mounted. Opts: (null)
[ 89.673848] Emergency Remount complete
[ 89.766100] cpufreq: cpufreq: reboot set core rate=1008000000, volt=1175000
[ 89.786169] rk-hdmi 20034000.hdmi: rk hdmi shut down.
[ 89.792260] dwc_otg_driver_shutdown: disconnect USB device mode
[ 89.798119] rknand_shutdown…
[ 89.801165] nand th quited
[ 89.803832] wait for rk nand bg quit
[ 89.806076] nand_blktrans_bg_thread quit
[ 89.856758] rknand_shutdown:OK
[ 89.859802] rk818_shutdown
[ 89.962006] Restarting system with command ‘’.
DDR Version 2.04 20150121
1A1A2A2B 0
1A1A2A2A 3
LPDDR2
2A2A2A2A F
Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB
mach:14
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1374
No.1 FLASH ID:ad de 14 a7 42 4a
ECC:60
*V«k%¹¥Ñõ0 20
StorageInit ok = 703407
theL¿HšHšÕœœÑ2014.10-RK3128-10 (Jun 12 2015 - 09:11:25)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dmaü.×K…•init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
++++ LDO3 write 0x03 to regular
cpu_det GPIO pull up
pmic:rk818
can’t find dts node for ADC
#Boot ver: 2015-06-12#2.25
empty serial no.
checkKey
vbus = 1
read logo_on switch from dts [1]
failed to find part:logo
Hit any key to stop autoboot: 1  0
Secure Boot state: 0
kernel @ 0x62000000 (0x00690a08)
ramdisk @ 0x65bf0000 (0x00159884)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 65616309 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #55 SMP PREEMPT Thu Aug 6 12:04:20 CST 2015
mianhuacar 发表于 2015-11-16 23:02
请问怎么看内核编译的时间?
Terminal ready
这里编译时间:Aug 6 12:04:20 CST 2015
linjc 发表于 2015-11-17 17:17
Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) …
谢谢linjc,之前是出厂的双系统,现在更新到官方的案桌单系统就可以了,终于看到黄色的LED闪10下。
学习了
