eDP LCD 分辨率 1920 x 1080 正常启动可以启动,但是adb shell 后敲reboot命令屏幕黑屏,串口打印信息如下
DDR Version 1.00 20150318
SRX
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=14 CS=1 Die Bus-Width=16 Size=512MB
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-09-svn72 (Aug 13 2015 - 12:44:18)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
Adding bank:0000000000000000(0000000040000000)
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2015-08-13#2.19
sn:1111222233334444
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo_on switch from dts [1]
pll_src = 0, dclk_hz = 136620000, dclk_div = 3
edp pll locked
Aux Transaction fail!
hw lt err:1
link train failed!
unable to config video
no fuel gauge found
failed to find part:logo
ERROR: [get_entry_ram]: Cannot find logo.bmp!
ERROR: [show_resource_image]: Failed to load image:logo.bmp
rk_pwm_config:brightness:102
Secure Boot state: 0
kernel @ 0x02000000 (0x00693498)
ramdisk @ 0x05bf0000 (0x00134854)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0563c6e8 … OK
Add bank:0000000000000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (dyhui@dyhui-HP-Pro-3380-MT) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #484 SMP PREEMPT Fri Nov 13 16:58:26 CST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@3dc00000, offset:0 [ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@3dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(8000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 128 MiB at 35c00000 [ 0.000000] ion_reserve: cma reserved base 35c00000 size 134217728 [ 0.000000] cma: CMA: reserved 16 MiB at 1e000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1652000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261152 [ 0.000000] Kernel command line: vmalloc=512M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00004 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 841392k/841392k available, 207184k reserved, 376832K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xdf800000 - 0xff000000 ( 504 MB) [ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b8dbc8 (11799 kB) [ 0.000000] .init : 0xc0b8e000 - 0xc0be66c0 ( 354 kB) [ 0.000000] .data : 0xc0be8000 - 0xc0cfb078 (1101 kB) [ 0.000000] .bss : 0xc0cfb078 - 0xc0e1cb3c (1159 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 2 [ 0.000000] channel:0, lkg:24 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:80 [ 0.000000] channel:0, lkg:24 [ 0.000000] target-temp:80 [ 0.000000] channel:1, lkg:20 [ 0.000000] target-temp:80 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.205660] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.205676] pid_max: default: 32768 minimum: 301 [ 0.205789] Security Framework initialized [ 0.205806] SELinux: Initializing. [ 0.205869] Mount-cache hash table entries: 512 [ 0.206499] Initializing cgroup subsys debug [ 0.206514] Initializing cgroup subsys memory [ 0.206541] Initializing cgroup subsys freezer
