i2s_8ch_0: i2s 信号,8进8出配置
SDK包名称:rk3308_v1.5.0a
SDK修改内容:/dts-v1/;
#include "rk3308b-firefly.dtsi"
model = "Firefly ROC-RK3308B-CC-PLUS analog mic board";
compatible = "firefly,rk3308-roc-cc-plus-amic_emmc", "firefly,rk3308", "rockchip,rk3308";
chosen {
bootargs = "earlycon=uart8250,mmio32,0xff0e0000 swiotlb=1 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 rootwait snd_aloop.index=7 snd_aloop.use_raw_jiffies=1 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1";
pdm_i2s_dais: pdm-i2s-dais {
status = "disabled";
compatible = "rockchip,rk3308-multi-dais", "rockchip,multi-dais";
dais = <&pdm_8ch>, <&i2s_8ch_2>;
capture,channel-mapping = <6 2>;
playback,channel-mapping = <0 2>;
bitclock-inversion = <1 0>;
pdm-mic-array {
compatible = "simple-audio-card";
simple-audio-card,name = "rockchip,pdm-mic-array";
simple-audio-card,cpu {
sound-dai = <&pdm_8ch>;
simple-audio-card,codec {
sound-dai = <&dummy_codec>;
i2s-dmic-array {
status = "okay";
simple-audio-card,format = "i2s";
simple-audio-card,name = "rockchip,i2s-dmic-array";
simple-audio-card,mclk-fs = <256>;
sound-dai = <&i2s_8ch_0>;
vad-sound {
compatible = "rockchip,multicodecs-card";
rockchip,card-name = "rockchip,rk3308-vad";
rockchip,cpu = <&pdm_i2s_dais>;
rockchip,codec = <&acodec>, <&vad>;
vad_acodec_sound: vad-acodec-sound {
status = "okay";
rockchip,card-name = "rockchip,rk3308b-acodec";
rockchip,codec-hp-det;
rockchip,mclk-fs = <256>;
rockchip,cpu = <&i2s_8ch_2>;
ir_rx {
status = "okay";
compatible = "gpio-ir-receiver";
gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&ir_recv_pin>;
ir_tx {
status = "okay";
compatible = "pwm-ir-tx";
pwms = <&pwm5 0 25000 0>;
leds {
status = "okay";
compatible = "gpio-leds";
power {
label = "firefly:red:power";
linux,default-trigger = "ir-power-click";
default-state = "on";
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
user {
label = "firefly:blue:user";
linux,default-trigger = "ir-user-click";
default-state = "off";
gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_HIGH>;
&i2s_8ch_0 {
status = "okay";
rockchip,no-dmaengine;
#sound-dai-cells = <0>;
Log日志:log.txt
我想用i2s_8ch_0做数字音频同步录放,按照文档改了设备树,但是感觉文档和代码没对上。
文档是:
Rockchip Audio 开发指南
文件标识:RK-KF-YF-145
发布版本:V1.5.0
日期:2021-01-20
文件密级:□绝密 □秘密 □内部资料 ■公开
log.txt (36.6 KB)
