Wi-Fi 6 Or Wi-Fi 6E?|Introducing IPQ6018 IPQ6010 IPQ5018 Qualcomm SoCs WiFi6 family
Introduction
Wi-Fi technology has come a long way since its inception, with each new generation offering improved performance and capabilities. Two of the latest iterations, Wi-Fi 6 (802.11ax) and Wi-Fi 6E, have garnered significant attention due to their potential to revolutionize wireless connectivity. In this technical post, we will delve into the key features, benefits, and differences between Wi-Fi 6 and Wi-Fi 6E.
Wi-Fi 6 (802.11ax)
1. Enhanced Speed and Efficiency:
Wi-Fi 6 introduces several key enhancements over its predecessor, Wi-Fi 5 (802.11ac). It offers higher data rates, with peak speeds of up to 9.6 Gbps, thanks to technologies like Orthogonal Frequency Division Multiple Access (OFDMA) and Basic Service Set (BSS) Coloring. These features allow more devices to connect simultaneously while maintaining high data throughput.
2. Improved Capacity:
One of the most significant improvements of Wi-Fi 6 is its ability to handle a larger number of devices within the same network. It employs MU-MIMO (Multi-User, Multiple Input, Multiple Output) technology to send data to multiple devices simultaneously, reducing network congestion and enhancing overall performance.
3.Better Range:
Wi-Fi 6 incorporates Target Wake Time (TWT) scheduling, which enables devices to negotiate when and how often they wake up to transmit data. This reduces unnecessary device wake-ups, conserves power, and improves the range of Wi-Fi connections.
4. Enhanced Security:
WPA3, the latest encryption protocol, is mandated for Wi-Fi 6 devices, offering stronger protection against common security threats like brute-force attacks. Additionally, the Opportunistic Wireless Encryption (OWE) feature enhances privacy on open networks.
5. Backward Compatibility:
Wi-Fi 6 routers and access points are designed to be backward compatible with Wi-Fi 5 and older devices. This ensures that older devices can still connect to the network, albeit at their respective speeds.
Wi-Fi 6E (802.11ax Extended)
1.Frequency Band Extension:
The most significant difference between Wi-Fi 6 and Wi-Fi 6E is the frequency band. While Wi-Fi 6 operates in the 2.4 GHz and 5 GHz bands, Wi-Fi 6E extends into the 6 GHz band. This additional spectrum offers more channels and less interference, making it ideal for high-density environments.
2. Increased Channel Width:
Wi-Fi 6E supports wider channel widths, up to 160 MHz, allowing for even higher data rates. This is particularly beneficial for applications that demand ultra-fast wireless connections, such as 4K and 8K video streaming and augmented reality.
3. Low Latency and Reduced Interference:
The 6 GHz band is relatively uncrowded, leading to lower interference and reduced latency. This makes Wi-Fi 6E suitable for latency-sensitive applications like online gaming and real-time video conferencing.
4. Support for New Use Cases:
The additional bandwidth of Wi-Fi 6E opens up possibilities for new use cases, such as wireless VR and AR experiences, industrial IoT deployments, and smart city applications, which require a high degree of reliability and bandwidth.
Conclusion
Wi-Fi 6 and Wi-Fi 6E represent significant advancements in wireless networking technology. Wi-Fi 6 offers enhanced speed, efficiency, and improved device handling, while Wi-Fi 6E takes these benefits a step further with the introduction of the 6 GHz band, offering more spectrum, reduced interference, and support for emerging applications. The choice between the two depends on specific use cases and the need for extended bandwidth and reduced congestion, making Wi-Fi 6E an attractive option for businesses and power users seeking cutting-edge wireless performance.
1.DR6018
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
2 DR5018
Feature:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Absolute Maximum Rating:
Supply Voltage 12 V
Storage Temperature Range -45 to +105ºC
Hardware Specifications:
CPU: Qualcomm-Atheros IPQ5018
CPU Frequency: Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory:512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port:4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot:M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
EMMC:4G/8G(optional)
USB /header:1x USB 3.0 Port
POE:NA
DC Jack:12V power supply
LED header LED for power ,Wifi strength
Serial Port support
Wireless:On-board 2x22.4GHz MU-MIMO OFDMA: 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
Bluetooth: BT5.1
Nor Flash: 8MB
Nand Flash: 128 MB
DDR: 512MB
Dimension:170mm x 120mm x 15mm
More detail and opportunities attach Emile :sales4@wallystech.com. This is Jane for you
Connect. Innovate. Thrive. Together with Wallys.
