See How EasyMesh Power to IPQ6018 IPQ6010 Qualcomm Chips on Routerboard|Wallys
What is EasyMesh?
EasyMesh is more than just a Wi-Fi standard; it’s a revolution in network connectivity. Developed by the Wi-Fi Alliance, EasyMesh offers a world of advantages for creating and maintaining robust industrial Wi-Fi networks.
Advantages of EasyMesh:
Interoperability: EasyMesh is all about compatibility. It ensures that devices from different manufacturers seamlessly work together. Say goodbye to vendor lock-in and embrace the freedom of choice.
Simplicity: Setting up and managing your Wi-Fi network has never been easier. With EasyMesh, you can expand your network effortlessly, configure devices with a breeze, and enjoy automatic onboarding.
Reliability: In the industrial world, downtime is not an option. EasyMesh ensures your network remains rock-solid, adapting to changes in real-time and providing consistent performance.
Scalability: As your industrial operations grow, so can your Wi-Fi network. EasyMesh is built for scalability, allowing you to add more devices and access points without breaking a sweat.
Industrial Applications:
Factory Automation: EasyMesh enables seamless communication between automated machinery, improving production efficiency and reducing downtime.
IoT Devices: Connect and manage IoT devices effortlessly, monitoring critical data for enhanced decision-making.
Wireless Sensor Networks: Deploy large-scale sensor networks for real-time monitoring of temperature, humidity, and other vital parameters.
Asset Tracking: Keep tabs on valuable assets throughout your industrial facility with EasyMesh-powered asset tracking solutions.
Embrace the future of industrial connectivity with EasyMesh. Say goodbye to network complexities and hello to a world of possibilities. EasyMesh isn’t just a standard; it’s your ticket to an efficient, reliable, and scalable industrial Wi-Fi network.
Are you ready to make the leap?
Wally’s IPQ6010/IPQ6018 Wireless Solution has already garnered attention for its exceptional performance, reliability, and advanced wireless capabilities. With the addition of SNMP support, it takes network management to the next level.
Whether you’re a small business, a large enterprise, or a service provider, Wally’s IPQ6010/IPQ6018 Wireless Solution with EasyMesh technology can help you achieve better network visibility, proactive monitoring, and streamlined management.
Upgrade your wireless network with Wally’s IPQ6010/IPQ6018 Wireless Solution today and experience the power of Mesh-enabled network management. Stay connected, stay efficient!
DR6018
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mmDR9074E
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
BY:https://www.wallystech.com/
More detail and opportunities attach Emile:sales4@wallystech.com. This is Jane for you
