Introduction:
The Internet of Things (IoT) has become a critical technology that enables the connection and communication of various devices in a seamless and efficient manner. Choosing the right hardware components is essential for building robust IoT solutions. In this technical post, we will compare two popular IoT solutions: Qualcomm’s IPQ9574 and IPQ8072, focusing on their performance on a 2x2 WiFi board supporting both 2.4GHz and 5GHz bands.
1. IPQ9574 Overview:
The IPQ9574 is a highly integrated and powerful SoC (System on Chip) designed for high-performance IoT applications. It comes equipped with:
Quad-core ARM Cortex-A53 processors for robust processing capabilities.
Dual-core network accelerators for efficient data processing.
A dedicated GPU for multimedia capabilities.
Support for dual-band 2.4GHz and 5GHz WiFi, making it suitable for IoT devices requiring high data throughput.
Key Features:
2x2 MU-MIMO (Multiple User, Multiple Input, Multiple Output) technology for improved network efficiency.
Support for advanced WiFi security protocols like WPA3.
Low-power operation for energy-efficient IoT devices.
Extensive I/O capabilities, making it versatile for various applications.
2. IPQ8072 Overview:
The IPQ8072 is another powerful IoT SoC from Qualcomm, designed for applications requiring high performance and reliability. It offers:
Quad-core ARM Cortex-A53 processors for efficient multitasking and data processing.
Dual-core network accelerators for optimized network performance.
A dedicated GPU for graphical tasks.
Dual-band 2.4GHz and 5GHz WiFi support, ensuring connectivity in a wide range of environments.
Key Features:
2x2 MU-MIMO technology for simultaneous data transfer to multiple devices.
Support for the latest WiFi security standards, enhancing data protection.
Efficient power management for extended device lifecycles.
Comprehensive peripheral connectivity options.
3. Comparative Analysis:
a. Performance: Both IPQ9574 and IPQ8072 offer similar quad-core ARM Cortex-A53 processors and dual-core network accelerators. This results in comparable processing performance for IoT applications.
b. WiFi Capabilities: Both SoCs support 2x2 MU-MIMO and dual-band WiFi, making them suitable for IoT devices that require high-speed wireless communication. Their support for advanced security protocols ensures data protection.
c. Power Efficiency: Both SoCs are designed with low-power operation in mind, enhancing the longevity of battery-powered IoT devices.
d. Versatility: Both SoCs provide extensive I/O options, making them versatile for various IoT applications, including smart home devices, industrial sensors, and more.
Conclusion:
The IPQ9574 and IPQ8072 are powerful IoT SoCs designed to meet the high-performance demands of IoT applications. Choosing between them will depend on the specific requirements of your project and the availability of these SoCs in the market. Both offer similar processing capabilities, WiFi support, power efficiency, and versatility, making them suitable for a wide range of IoT solutions.
Ultimately, the choice between IPQ9574 and IPQ8072 should be based on your specific project needs, availability, and pricing considerations. These SoCs represent Qualcomm’s commitment to providing robust solutions for the growing IoT ecosystem.
1.DR8072V01
Website:
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualco…
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
NOR Flash: 8 MB
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR9074-6E(PN02.7)
Link here get more information
https://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qual…
Features
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Operating Temperature Range -20 to 70 ºC
Storage Temperature Range -40 to 90 ºC
Symbol Parameter
Chipset Qualcomm Atheros QCN9074
WLAN Host Interface PCI Express 3.0 Interface
ystem Memory 2Mbit serial I²C bus EEPROM
Standard Operating Voltage 5V
Operating Systems QSDK
Host Interface M.2 E Key
Antenna Cable / Port 4 x MMCX Connectors,4T4R
Frequency Range 5.925GHz-7.125GHz
Data Rates for WALN 6GHz, max 23dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz at 6GHz
Modulation Techniques OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification TBD
Reference Design PN02.7
Dimensions (WxHxD) 57mm x 63mm x 6mm
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
