roc-rk3588s主板运行rk_mpi_vi_test错误
固件文件名称:ROC-RK3588S-PC_Buildroot_v1.0.6f_230819.img
固件下载地址:百度网盘
Log日志:log.txt
ROC-RK3588主板,带有摄像头XC7160,运行自带的rk_mpi_vi_test程序失败,如下:
root@rk3588:/usr/bin# rk_mpi_vi_test -w 1920 -h 1080 -n /dev/video0
vi 09:44:27-325 {main :1381} test running enter!
vi 09:44:27-325 {main :1487} test running enter ctx->aEntityName=/dev/video0!
cmd parse result:
output file open : 0
yuv output file name : /
enc0 output file path : //
enc1 output file path : //
loop count : 100
enMode : 1
dev : 0
pipe : 0
channel : 1
width : 1920
height : 1080
enCompressMode : 0
enMemoryType : 4
aEntityName : /dev/video0
depth : 0
enPixelFormat : 0
bFreeze : 0
src_frame rate : -1
dst frame rate : -1
out buf count : 3
bUserPicEnabled : 0
bEnRgn : 0
rgn count : 1
rgn type : 5
bGetConnecInfo : 0
bGetEdid : 0
bSetEdid : 0
RKSockServer 09:44:27-326 {initServer :056} proto:tcp, hostname:127.0.0.1, path:, port:3893
RKSockServer 09:44:27-326 {initNetServer :071} binding to host:127.0.0.1, port:3893
RKSockServer 09:44:27-326 {initNetServer :093} sock server initialize succeed
Segmentation fault
log.txt (1.29 KB)
