802.11Ax standard IPQ6018 IPQ6010 QCN9074 Wifi Socs 1.5GMbp...
802.11Ax standard IPQ6018 IPQ6010 QCN9074 Wifi Socs: DR6018 DR9074-6E 1.5GMbps Throughput
Introduction
In this technical post, we will explore the powerful combination of a WiFi 6 routerboard and the DR9074-6E network card to achieve high-power throughput, long-range connectivity up to 23 kilometers, and efficient AP controller management in both Point-to-Point (PTP) and Point-to-MultiPoint (PTMP) network setups.
1. Hardware Components
1.1 WiFi 6 Routerboard
Select a WiFi 6 routerboard with support for high-gain antennas and robust processing capabilities.
Ensure it is compatible with the DR9074-6E network card.
1.2 DR9074-6E Network Card
The DR9074-6E network card is a powerful dual-band WiFi 6 (802.11ax) module designed for long-range, high-throughput applications.
It is equipped with multiple external antenna connectors for enhanced signal strength.
2. High-Power Throughput
2.1 Routerboard Configuration
Optimize router settings for high-power transmission and receive sensitivity.
Increase the TX power to the legal maximum while complying with local regulations.
Utilize MU-MIMO and beamforming technology to maximize the throughput by focusing the signal towards specific devices.
2.2 DR9074-6E Network Card Configuration
Enable the DR9074-6E network card’s advanced WiFi 6 capabilities.
Fine-tune the antenna settings to match the chosen high-gain antennas.
3. Long-Range Connectivity (Up to 23 Km)
3.1 Antenna Selection
Choose high-gain directional antennas for PTP scenarios, ensuring a narrow beamwidth to increase range.
In PTMP scenarios, select sector antennas for a broader coverage area.
3.2 Line of Sight (LOS)
Establish a clear line of sight between the transmitting and receiving points.
Use site survey tools to identify any potential obstructions, and plan your deployment accordingly.
3.3 Adjust Frequency and Channel Width
Utilize lower-frequency bands (e.g., 5 GHz) for improved long-range connectivity.
Narrow the channel width for greater signal stability, especially in PTP setups.
4. AP Controller Manager
4.1 Centralized Control
Implement an Access Point (AP) controller manager to centrally manage and monitor your network.
Ensure it is compatible with your routerboard and network card combination.
4.2 Configuration Management
Configure your AP controller to manage multiple access points, making it easier to control and monitor your network.
4.3 Security and Authentication
Implement strong security protocols for network access, including WPA3 encryption and enterprise-level authentication methods.
5. PTP and PTMP Configurations
5.1 PTP (Point-to-Point)
Set up the routerboard and network card in PTP mode for dedicated, high-speed connections between two locations.
Ensure accurate alignment between the directional antennas to establish a stable connection.
5.2 PTMP (Point-to-MultiPoint)
Use sector antennas and fine-tune their beamwidth to cover multiple client devices in a specific area.
Configure the routerboard and network card for efficient resource allocation among clients.
DR6018
Website:[b][u]https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html[/u][/b]
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Support Openwifi
Support QSDK
DR9074-TRIBAND
Website:
[b][u]https://www.wallystech.com/Network_Card/DR9074-Triband-Wifi6E-Qualcomm-QCN9024-Tri-Band-2.4G-5G-6GHz-4T4R-M-2-E-Key-Interface-802-11ax-Wallys.html[/u][/b]
Features
Qualcomm Atheros QCN9024
Maxim 23 dBm per chain,up to 4949Mbps
Data Rateup to 4949Mbps
Support Tri Band 2.4GHz&5GHz&6GHz 4x4 WiFi 6E (802.11ax)
4 spatial streams (4SS)
M.2 E Key Interface
PCI Express 3 .0 Interface
Applications
Security Surveillance
Commercial radio coverage
Hotel Wireless application
Forest fire protection engineering
Country coverage
Some special scene application
Conclusion
By combining a WiFi 6 routerboard with a high-performance network card like the DR9074-6E, it is possible to achieve impressive high-power throughput and long-range connectivity up to 23 kilometers. With the addition of AP controller management, you can streamline network administration and effectively deploy both PTP and PTMP solutions. This powerful combination opens up numerous possibilities for robust, long-range wireless networks in various applications, from rural internet connectivity to enterprise-level wireless infrastructure.
