SDK包名称:rk3588_linux_release_20231027_v1.1.1e
SDK修改内容:无
Log日志:无法开机日志.txt
编译出来成功烧录进系统,但是开机hdmi0无任何显示,并且卡在一下log处,
5.145535] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.150299] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.151385] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 5.151412] rockchip-suspend not set sleep-mode-config for mem-lite
[ 5.151422] rockchip-suspend not set wakeup-config for mem-lite
[ 5.151434] rockchip-suspend not set sleep-mode-config for mem-ultra
[ 5.151442] rockchip-suspend not set wakeup-config for mem-ultra
[ 5.152940] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 406; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘10:45:50’, on ‘Oct 31 2023’.
[ 5.153518] Mali:
[ 5.153521] Mali device driver loaded
[ 5.154651] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.154656] cfg80211: failed to load regulatory.db
[ 5.168258] vendor storage:20190527 ret = 0
v 5.170508]
这是为啥呢?
无法开机日志.txt (57.6 KB)
