SDK包名称:rk3399_linux_release_v2.5.1_20210301
SDK修改内容:添加了IMX581.C,索尼sensor的摄像头模组
Log日志:log+source_code.zip
在此之前添加过索尼IMX709 sensor摄像头的CSI驱动,能够点亮出图
在IMX709的基础上修改setting等配置参数,编译驱动后无法出图。
imx581: imx581@1a { compatible = "ovti,imx581"; status = "disabled"; reg = <0x1a>; clocks = <&cru SCLK_CIF_OUT>; clock-names = "xvclk"; reset-gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>; pwdn-gpios = <&gpio2 0 GPIO_ACTIVE_HIGH>; pinctrl-names = "rockchip,camera_default", "rockchip,camera_sleep"; //pinctrl-0 = <&cif_clkout>; pinctrl-0 = <&cam0_default_pins>; pinctrl-1 = <&cam0_sleep_pins>; rockchip,camera-module-index = <0>; rockchip,camera-module-facing = "back"; rockchip,camera-module-name = "CMK-CT0116"; rockchip,camera-module-lens-name = "Largan-50013A1"; avdd-supply = <&vcc_mipi>; dovdd-supply = <&vcc_mipi>; dvdd-supply = <&dvdd_1v2>; port { ucam_out0: endpoint { remote-endpoint = <&mipi_in_ucam0>; data-lanes = <1 2 3 4>; }; };
&imx581 {
pwdn-gpios = <&gpio2 12 GPIO_ACTIVE_HIGH>;
status = “okay”;
log+source_code.zip (12.2 KB)
