Ubuntu 系統下 Gstreamer H.264 硬體解碼 hang 住
固件文件名称:rk3588_linux_release_20230114_v1.0.6c
固件下载地址:百度網盤
Log日志:avdec_h264_rkmpp.log
在 Ubuntu 系統下使用 Gstreamer 調用 plug-in : avdec_h264_rkmpp 進行 H.264 硬體解碼會 hang 住不動
gst-launch-1.0 -vvv \
filesrc location="/home/firefly/1k30p.h264" \
! h264parse ! avdec_h264_rkmpp debug-mv=true ! videoconvert \
! fpsdisplaysink video-sink="kmssink plane-id=94" \
text-overlay=false sync=false
同樣以 plug-in : avdec_h264 進行軟解 mp4H264 raw data 可以正常運行顯示, cmd 如下 :
! h264parse ! avdec_h264 ! videoconvert \
filesrc location="/home/firefly/1k30p.mp4" ! qtdemux \
使用 avdec_h264_rkmpp 後 hang 住的 log 如下 :
firefly@firefly:~$ gst-launch-1.0 -vvv \
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: display-width = 1920
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: display-height = 1080
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstKMSSink:kmssink0: sync = false
/GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, profile=(string)high, level=(string)4, codec_data=(buffer)01640028ffe1001b67640028acd940780227e5c044000003000400000300f03c60c65801000668ebe3cb22c0
Redistribute latency...
/GstPipeline:pipeline0/avdec_h264_rkmpp:avdec_h264_rkmpp0.GstPad:sink: caps = video/x-h264, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)avc, alignment=(string)au, profile=(string)high, level=(string)4, codec_data=(buffer)01640028ffe1001b67640028acd940780227e5c044000003000400000300f03c60c65801000668ebe3cb22c0
想請教各位大佬 是我在 gstreamer 組成上有遺漏什麼造成 cmd hang 住?
avdec_h264_rkmpp.log (1.53 KB)
