固件文件名称:rk356x_linux5.10_release_20231027_v1.2.1b
Log日志:log.txt.zip
您好:
按照文档:1. 编译 Linux5.10 固件 — Firefly Wiki
使用docker编译的时候遇到如下错误:
Failed to build rockchip_rk3566:
# 2023-12-12 07:49:23
2023-12-12T07:49:23 make: Entering directory ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot’
2023-12-12T07:49:38 /usr/bin/make -j1 O=/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566 HOSTCC=“/usr/bin/gcc” HOSTCXX=“/usr/bin/g++” syncconfig
2023-12-12T07:49:38 make[1]: Entering directory ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot’
2023-12-12T07:49:39 GEN /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/Makefile
2023-12-12T07:49:41 make[1]: Leaving directory ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot’
2023-12-12T07:49:41 >>> host-m4 1.4.19 Extracting
2023-12-12T07:49:41 xzcat /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/dl/m4/m4-1.4.19.tar.xz | tar --strip-components=1 -C /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/build/host-m4-1.4.19 -xf -
2023-12-12T07:49:49 chmod: changing permissions of ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/build/host-m4-1.4.19/bootstrap’: Permission denied
2023-12-12T07:49:51 package/pkg-generic.mk:229: recipe for target ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/build/host-m4-1.4.19/.stamp_extracted’ failed
2023-12-12T07:49:51 make: *** [/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/build/host-m4-1.4.19/.stamp_extracted] Error 1
2023-12-12T07:49:51 make: Leaving directory ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot’
Please check details in /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/output/sessions/2023-12-12_07-47-23/br-rockchip_rk3566_2023-12-12_07-49-23.log
you take 0:36.20 to build buildroot
ERROR: Running /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/device/rockchip/common/scripts/mk-rootfs.sh - build_buildroot failed!
ERROR: exit code 1 from line 16:
/usr/bin/time -f "you take %E to build buildroot" "$SCRIPTS_DIR/mk-buildroot.sh" $RK_BUILDROOT_CFG "$ROOTFS_DIR"
ERROR: call stack:
mk-rootfs.sh: build_buildroot(16)
mk-rootfs.sh: build_hook(265)
mk-rootfs.sh: main(292)
ERROR: Running /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/device/rockchip/common/build-hooks/99-all.sh - build_all failed!
ERROR: exit code 1 from line 30:
"$SCRIPTS_DIR/mk-rootfs.sh"
ERROR: call stack:
99-all.sh: build_all(30)
99-all.sh: build_allsave(112)
99-all.sh: build_hook(137)
build-helper: try_func(63)
build-helper: try_hook(95)
build-helper: source(173)
99-all.sh: main(147)
ERROR: Running /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/device/rockchip/common/build-hooks/99-all.sh - try_func build_hook allsave failed!
ERROR: exit code 1 from line 67:
build_hook
ERROR: call stack:
build-helper: try_func(67)
ERROR: Running ./build.sh - run_hooks build allsave failed!
ERROR: exit code 1 from line 195:
/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/device/rockchip/common/build-hooks/99-all.sh build allsave
ERROR: call stack:
build.sh: run_hooks(195)
build.sh: run_build_hooks(214)
build.sh: main(495)
build.sh: main(510)
ERROR: Running ./build.sh - run_build_hooks build allsave failed!
ERROR: exit code 1 from line 217:
build
ERROR: call stack:
build.sh: run_build_hooks(217)
build.sh: main(495)
build.sh: main(510)
firefly@firefly:/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10$ lsattr chmod: changing permissions of ‘/home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/build/host-m4-1.4.19/bootstrap’: Permission denied
lsattr: No such file or directory while trying to stat chmod:
lsattr: No such file or directory while trying to stat changing
lsattr: No such file or directory while trying to stat permissions
lsattr: No such file or directory while trying to stat of
lsattr: No such file or directory while trying to stat /home/zhangchenyu/Desktop/firefly/RK3566/SDK/rk356x_sdk-linux5.10/buildroot/output/rockchip_rk3566/build/host-m4-1.4.19/bootstrap:
lsattr: No such file or directory while trying to stat Permission
lsattr: No such file or directory while trying to stat denied
请问应该如何解决?看起来是权限的问题。
log.txt.zip (3.56 KB)
