RK3308B内核不能启动。
固件文件名称:ROC-RK3308B-CC-PLUS_ROOTFS-EXT2-Noui-20201022
Log日志:RK3308打印信息.zip
基于RK3308B自研板子,CPU和FLASH选型和core3308Y一样。烧写官方固件,系统卡死。
如果将CPU和Flash更换为核心板上的器件,系统启动正常。
如果将核心板的CPU或者FLASH器件中的某一个更换为同型号的自购器件,系统也会卡死在相同的位置。
打印信息如下所示。
DDR Version V1.29 20190730
REG2C: 0x00000037, 0x00000037
589MHz
DDR3
Col=10 Bank=3 Row=15 Size=512MB
msch:1
Boot1 Release Time: Oct 28 2019 20:02:13, version: 1.19
chip_id:330800,0
ChipType = 0x13, 35790968
DPLL = 1300 MHz
sfc nor id: ff ff ff
DPLL = 1300 MHz
sfc_nand id: ff ff ff
DPLL = 1300 MHz
…nandc_flash_init enter…
NeedKHz=200KHz,clock=12000KHz
DPLL = 1300 MHz
NeedKHz=18000KHz,clock=650000KHz
DPLL = 1300 MHz
NeedKHz=48000KHz,clock=650000KHz
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=7456MB
FwPartOffset=2000 , 2000
SdmmcInit=0 NOT PRESENT
StorageInit ok = 35778250
SecureMode = 0
Secure read PBA: 0x4
Secure read PBA: 0x404
Secure read PBA: 0x804
Secure read PBA: 0xc04
Secure read PBA: 0x1004
atags_set_bootdev: ret:(0)
GPT part: 0, name: uboot, start:0x2000, size:0x1000
GPT part: 1, name: trust, start:0x3000, size:0x1000
GPT part: 2, name: misc, start:0x4000, size:0x800
GPT part: 3, name: recovery, start:0x4800, size:0x6000
GPT part: 4, name: boot, start:0xa800, size:0x4800
GPT part: 5, name: rootfs, start:0xf000, size:0x80000
GPT part: 6, name: oem, start:0x8f000, size:0x20000
GPT part: 7, name: userdata, start:0xaf000, size:0xde0fdf
find part:uboot OK. first_lba:0x2000.
find part:trust OK. first_lba:0x3000.
LoadTrust Addr:0x3000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x600000, size=0xa5e24
RunBL31 0x40000 @ 35738900 us
INFO: Preloader serial: 4
NOTICE: BL31: v1.3(release):30f1405
NOTICE: BL31: Built : 17:08:28, Sep 23 2019
INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe b
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: Entry point address = 0x600000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Oct 21 2020 - 17:26:19 +0800)
Model: Rockchip RK3308 EVB
PreSerial: 4
DRAM: 510 MiB
Sysmem: init
Relocation Offset is: 1f90c000
dwmmc@ff480000: 1, dwmmc@ff490000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
Error binding driver ‘fixed regulator’: -22
Some drivers failed to bind
vdd_core init 1015000 uV
DVFS: cpu: low=0.0’c, high=55.0’c, Vmax=1340000uV, tz_temp=55.0’c, h_repeat=0, l_repeat=0
DVFS: 25.0’c
Model: Firefly ROC-RK3308B-CC-PLUS analog mic board
CLK: (uboot. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 1300000 KHz
vpll0 1177823 KHz
vpll1 901583 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98151 KHz
pclk_audio 98151 KHz
Net: eth0: ethernet@ff4e0000
DVFS: cpu 25.909’c, 816000000 Hz, 1015000 uV
Fdt Ramdisk skip relocation
Booting LZ4 kernel at 0x02480000(Uncompress to 0x00280000) with fdt at 0x1f00000…
## Booting Android Image at 0x0247f800 …
Kernel load addr 0x00280000 size 5241 KiB
RAM disk load addr 0x04000000 size 6047 KiB
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Uncompressing Kernel Image … OK
Using Device Tree in place at 0000000001f00000, end 0000000001f15884
Adding bank: 0x00200000 - 0x20000000 (size: 0x1fe00000)
Total: 530.931 ms
[ 0.000000] Linux version 4.4.143 (zhengyk@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #214 SMP PREEMPT Tue Oct 20 09:48:07 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0e0000 (options ‘’)
[ 0.000000] PERCPU: Embedded 19 pages/cpu @ffffffc01ff45000 s40088 r8192 d29544 u77824
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 128520
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 rootwait earlycon=uart8250,mmio32,0xff0e0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext2 snd_aloop.index=7 snd_aloop.use_raw_jiffies=1
[ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] software IO TLB [mem 0x1fe41000-0x1fe81000] (0MB) mapped at [ffffffc01fe41000-ffffffc01fe80fff]
[ 0.000000] Memory: 495528K/522240K available (6462K kernel code, 690K rwdata, 2436K rodata, 384K init, 511K bss, 26712K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8008940000 - 0xffffff80089a0000 ( 384 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80086d0000 ( 6464 KB)
[ 0.000000] .rodata : 0xffffff80086d0000 - 0xffffff8008940000 ( 2496 KB)
[ 0.000000] .data : 0xffffff80089a0000 - 0xffffff8008a4c808 ( 691 KB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc020000000 ( 510 MB)
[ 0.000000] tchip_askquestions
RK3308打印信息.zip (66.2 KB)
qq2317783075 发表于 2023-12-14 16:28
换官方rk的sdk吧,就不会有这个限制,我们都已经量产了
厉害!我们还在探索呢。感谢!
**** 作者被禁止或删除 内容自动屏蔽 ****
请问下RK官方的SDK在哪下载?
