固件文件名称:AIO-3588Q_Buildroot_v1.0.6f_230819.7z
固件下载地址:百度网盘
Log日志:log.zip
环境 Ubuntu18/x86_64
版本 rk3588
Linux SDK rk3588_linux_release_20231027_v1.1.1e
编译目标 buildroot
操作步骤 按照 2. 编译 Linux 固件 (内核版本 5.10) — Firefly Wiki
日志, 单独uboot/kernel已经编译成功
buildroot 失败
请问还需要其他配置吗
2023-12-16T08:16:29 Found pkg-config: /DATA2/rk3588/buildroot/output/firefly_rk3588/host/bin/pkgconf (1.6.3)
2023-12-16T08:16:29 Run-time dependency gstreamer-1.0 found: YES 1.22.0
2023-12-16T08:16:29 Run-time dependency gstreamer-base-1.0 found: YES 1.22.0
2023-12-16T08:16:29 Run-time dependency gstreamer-allocators-1.0 found: YES 1.22.0
2023-12-16T08:16:29 Run-time dependency gstreamer-video-1.0 found: YES 1.22.0
2023-12-16T08:16:29 Run-time dependency gstreamer-pbutils-1.0 found: YES 1.22.0
2023-12-16T08:16:29 Run-time dependency glib-2.0 found: YES 2.68.4
2023-12-16T08:16:29 Found CMake: /home/usr/bin/cmake (3.18.2)
2023-12-16T08:16:30 Run-time dependency x11 found: NO (tried pkgconfig and cmake)
2023-12-16T08:16:30 Run-time dependency libdrm found: YES 2.4.115
2023-12-16T08:16:30 Run-time dependency rockchip_mpp found: NO (tried pkgconfig and cmake)
2023-12-16T08:16:30
2023-12-16T08:16:30 output/firefly_rk3588/build/gstreamer1-rockchip-master/meson.build:88:0: ERROR: Dependency “rockchip_mpp” not found, tried pkgconfig and cmake
2023-12-16T08:16:30
2023-12-16T08:16:30 A full log can be found at /DATA2/rk3588/buildroot/output/firefly_rk3588/build/gstreamer1-rockchip-master/build/meson-logs/meson-log.txt
2023-12-16T08:16:30 package/pkg-generic.mk:293: recipe for target ‘/DATA2/rk3588/buildroot/output/firefly_rk3588/build/gstreamer1-rockchip-master/.stamp_configured’ failed
2023-12-16T08:16:30 make: *** [/DATA2/rk3588/buildroot/output/firefly_rk3588/build/gstreamer1-rockchip-master/.stamp_configured] Error 1
2023-12-16T08:16:30 make: Leaving directory ‘/DATA2/rk3588/buildroot’
Please check details in /DATA2/rk3588/.buildroot/br.log
you take 0:13.20 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 1320:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $RK_CFG_BUILDROOT $DST_DIR
log.zip (780 Bytes)
