固件文件名称:ROC-RK3588S-PC-RTLINUX_Ubuntu20.04-Gnome-r240_v1.1
固件下载地址:百度网盘
Log日志:log.tar
通过以下命令安装qtcreator
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install build-essential
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
sudo apt-get install qtcreator
sudo apt-get install qt5*
然后用 sudo qtcreator 打开报以下错误
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-root’
arm_release_ver of this libmali is ‘g6p0-01eac0’, rk_so_ver is ‘7’.
error: XDG_RUNTIME_DIR not set in the environment.
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
The X11 connection broke: Unsupported extension used (code 2)
XIO: fatal IO error 0 (成功) on X server “:0”
after 397 requests (6 known processed) with 0 events remaining.
ConnectionServer error: “QLocalSocket: Remote closed” “/tmp/QtCreator-NJNkVU/ClangBackEnd-195260”
我还使用了固件( ROC-RK3588S-PC_Ubuntu20.04-Gnome-r30028_v1.1.1b_230914)按照以上步骤是可以打开qtcreator的
所以是不是实时固件的问题?该如果解决?
log.tar (700 KB)
