SDK包名称:rk3288_linux_release_20220304_v2.5.0a
SDK修改内容:没做任何修改
Log日志:[Com COM4] (2023-12-21_164502).zip
官网下载的源码,直接编译完成,启动卡在WiFi。【用官方提供的img镜像可以正常启动】
=~=~=~=~=~=~=~=~=~=~=~= MobaXterm log 2023.12.21 14:31:10 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version 1.11 20210818
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Jul 22 2021 09:08:57, version: 2.63
ChipType = 0x8, 241
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd8,400
mmc0:cmd8,400
mmc0:cmd8,400
SdmmcInit=0 1
StorageInit ok = 23528
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x3fe800
GPT part: 7, name: userdata, start:0x458800, size:0x18c67df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LOADER Check OK! 0x4000, 137655
TOS Check OK! 0x6000, 174087
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:381: Initializing (1.1.0-394-gbe1b074d #29 Thu Aug 15 00:42:35 UTC 2019 arm)
INF [0x0] TEE-CORE:init_primary_helper:382: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:383: Next entry point address: 0x200000
U-Boot 2017.09(u-boot commit id: e4da79f87a88e70b076e97de82fc8ece3b6d6ea9)(sdk version: rk3288_linux_release_20220304_v2.5.0a.xml)-ge4da79f87a #root (Dec 21 2023 - 14:27:13 +0800)
Model: Firefly-RK3288
PreSerial: 2, raw, 0xff690000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bddb6d0 - 7bddcdd1
CR: M/C/I
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(s): OK
I2c0 speed: 400000Hz
vdd_log 1100000 uV
In: serial
Out: vidconsole
Err: vidconsole
Model: AIO-3288J Board LVDS HSX101H40C (Linux Opensource)
hdmi@ff980000 disconnected
Using display timing dts
lvds: detailed mode clock 65000 kHz, flags[a]
H: 0800 0832 0840 0848
V: 1280 1297 1301 1312
bus_format: 1009
CLK: (uboot. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
apll 1000000 KHz
dpll 396000 KHz
cpll 650000 KHz
gpll 594000 KHz
npll 24000 KHz
aclk_bus 198000 KHz
Net: eth0: ethernet@ff290000
Hit key to stop autoboot('CTRL+C'): 3 2 1 0
ANDROID: reboot reason: "recovery"
Booting ZIMAGE kernel at 0x02008000(Uncompress to 0) with fdt at 0x08300000...
## Booting Android Image at 0x02007800 ...
Kernel load addr 0x02008000 size 7599 KiB
RAM disk load addr 0x0a200000 size 6779 KiB
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
XIP Kernel Image from 0x02008000 to 0x02008000 ... OK
'reserved-memory' dma-unusable@fe000000: addr=fe000000 size=1000000
'reserved-memory' ramoops@00000000: addr=8000000 size=f0000
Loading Ramdisk to 0ffff000, end 1069dafb ... OK
Loading Device Tree to 0ffe7000, end 0fffed43 ... OK
No file: logo_kernel.bmp
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09200000 - 0x80000000 (size: 0x76e00000)
Total: 4796.506 ms
Starting kernel ...
[ 0.000000] Linux version 4.4.194 (root@wx-All-Series) (kernel commit id: ebb6f60626788430b3eebadd4d1fe01365685be8) (sdk version: rk3288_linux_release_20220304_v2.5.0a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Thu Dec 21 14:00:45 CST 2023
[ 0.000000] Machine model: AIO-3288J Board LVDS HSX101H40C (Linux Opensource)
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 14 pages/cpu @eef75000 s24728 r8192 d24424 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519168
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal verbose androidboot.slot_suffix= androidboot.serialno=ef2adc9b89831515 earlyprintk ro rootwait console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 swiotlb=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] Memory: 2021352K/2082816K available (11264K kernel code, 1006K rwdata, 3304K rodata, 1024K init, 564K bss, 45080K reserved, 16384K cma-reserved, 1293716K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB)
[ 0.000000] .init : 0xc1100000 - 0xc1200000 (1024 kB)
[ 0.000000] .data : 0xc1200000 - 0xc12fb86c (1007 kB)
[ 0.000000] .bss : 0xc12fd000 - 0xc138a390 ( 565 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000030] Switching to timer-based delay loop, resolution 41ns
[ 0.004135] Console: colour dummy device 80x30
[ 0.004179] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.004203] pid_max: default: 32768 minimum: 301
[ 0.004335] Security Framework initialized
[ 0.004352] Yama: becoming mindful.
[ 0.004470] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004495] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005669] Initializing cgroup subsys devices
[ 0.005702] Initializing cgroup subsys freezer
[ 0.005761] CPU: Testing write buffer coherency: ok
[ 0.005816] ftrace: allocating 42452 entries in 125 pages
[ 0.132000] CPU0: update cpu_capacity 430
[ 0.132022] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.132119] Setting up static identity map for 0x100000 - 0x100058
[ 0.135448] CPU1: update cpu_capacity 430
[ 0.135458] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.136685] CPU2: update cpu_capacity 430
[ 0.136694] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.137929] CPU3: update cpu_capacity 430
[ 0.137939] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.138121] Brought up 4 CPUs
[ 0.138165] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.138175] CPU: All CPU(s) started in SVC mode.
[ 0.140272] devtmpfs: initialized
[ 0.175175] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.175758] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.175799] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.177291] pinctrl core: initialized pinctrl subsystem
[ 0.178915] NET: Registered protocol family 16
[ 0.183260] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.211864] cpuidle: using governor ladder
[ 0.241909] cpuidle: using governor menu
[ 0.241959] Registered FIQ tty driver
[ 0.297437] console [pstore-1] enabled
[ 0.297452] pstore: Registered ramoops as persistent store backend
[ 0.297467] ramoops: attached 0xf0000@0x8000000, ecc: 0/0
[ 0.298983] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.299004] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.300151] fiq debugger fiq mode enabled
[ 0.796914] console [ttyFIQ0] enabled
[ 0.800950] Registered fiq debugger ttyFIQ0
[ 0.881659] vcc_flash: regulator get failed, ret=-517
[ 0.887487] vcc_sd: regulator get failed, ret=-517
[ 0.893015] vcc28_dvp: regulator get failed, ret=-517
[ 0.898833] dovdd_1v8: regulator get failed, ret=-517
[ 0.907561] vcc_lcd: regulator get failed, ret=-517
[ 0.913570] iommu: Adding device ff910000.rkisp1 to group 0
[ 0.919310] iommu: Adding device ff930000.vop to group 1
[ 0.924818] iommu: Adding device ff940000.vop to group 2
[ 0.930295] iommu: Adding device ff9a0000.vpu-service to group 3
[ 0.936512] iommu: Adding device ff9c0000.hevc-service to group 4
[ 0.943517] rk_iommu ff914000.iommu: can't get sclk
[ 0.949087] rk_iommu ff930300.iommu: can't get sclk
[ 0.954406] rk_iommu ff940300.iommu: can't get sclk
[ 0.959779] rk_iommu ff9a0800.iommu: can't get sclk
[ 0.965174] rk_iommu ff9c0440.iommu: can't get sclk
[ 0.971053] SCSI subsystem initialized
[ 0.975195] usbcore: registered new interface driver usbfs
[ 0.980834] usbcore: registered new interface driver hub
[ 0.986315] usbcore: registered new device driver usb
[ 0.991628] media: Linux media interface: v0.10
[ 0.996236] Linux video capture interface: v2.00
[ 1.001009] pps_core: LinuxPPS API ver. 1 registered
[ 1.006017] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.015185] PTP clock support registered
[ 1.021754] Advanced Linux Sound Architecture Driver Initialized.
[ 1.028895] Bluetooth: Core ver 2.21
[ 1.032583] NET: Registered protocol family 31
[ 1.037036] Bluetooth: HCI device and connection manager initialized
[ 1.043439] Bluetooth: HCI socket layer initialized
[ 1.048330] Bluetooth: L2CAP socket layer initialized
[ 1.053463] Bluetooth: SCO socket layer initialized
[ 1.060018] rockchip-cpuinfo cpuinfo: Serial: ef2adc9b89831515
[ 1.068132] clocksource: Switched to clocksource arch_sys_counter
[ 1.160939] NET: Registered protocol family 2
[ 1.166240] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.173455] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.180290] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.186741] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 1.192771] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 1.199511] NET: Registered protocol family 1
[ 1.204416] RPC: Registered named UNIX socket transport module.
[ 1.210399] RPC: Registered udp transport module.
[ 1.215112] RPC: Registered tcp transport module.
[ 1.219852] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.226631] Trying to unpack rootfs image as initramfs...
[ 2.001904] Freeing initrd memory: 6780K
[ 2.007944] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 2.020041] Initialise system trusted keyring
[ 2.039948] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.049215] NFS: Registering the id_resolver key type
[ 2.054320] Key type id_resolver registered
[ 2.058571] Key type id_legacy registered
[ 2.062623] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 2.070410] fuse init (API version 7.23)
[ 2.083778] NET: Registered protocol family 38
[ 2.088389] Key type asymmetric registered
[ 2.092506] Asymmetric key parser 'x509' registered
[ 2.097517] bounce: pool size: 64 pages
[ 2.101788] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.109312] io scheduler noop registered
[ 2.113260] io scheduler deadline registered
[ 2.117855] io scheduler cfq registered (default)
[ 2.131894] backlight supply power not found, using dummy regulator
[ 2.139309] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
[ 2.146002] rk-vcodec ff9a0000.vpu-service: probe device
[ 2.151833] rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
[ 2.159958] rk-vcodec ff9a0000.vpu-service: could not find power_model node
[ 2.166933] rk-vcodec ff9a0000.vpu-service: init success
[ 2.172843] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
[ 2.179763] rk-vcodec ff9c0000.hevc-service: probe device
[ 2.185588] rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
[ 2.193472] rk-vcodec ff9c0000.hevc-service: could not find power_model node
[ 2.200601] rk-vcodec ff9c0000.hevc-service: init success
[ 2.210218] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.217807] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.228616] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.236208] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 2.247494] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.256307] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.263858] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 2.273824] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[ 2.283825] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 2.296494] [drm] Initialized drm 1.1.0 20060810
[ 2.309267] [drm] Rockchip DRM driver version: v1.0.1
[ 2.314853] rockchip-drm display-subsystem: devfreq is not set
[ 2.322457] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0c67340)
[ 2.331078] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c67340)
[ 2.338839] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 2.345474] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.353403] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
[ 2.364275] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0c5dda0)
[ 2.371870] rockchip-drm display-subsystem: failed to bind ff770000.syscon:lvds (ops 0xc0c5f54c): -517
[ 2.382659] rockchip-drm display-subsystem: master bind failed: -517
[ 2.390289] usbcore: registered new interface driver udl
[ 2.398294] panel-simple lvds-panel: failed to get power regulator: -517
[ 2.407266] mali ffa30000.gpu: Failed to get regulator
[ 2.412459] mali ffa30000.gpu: Power control initialization failed
[ 2.420833] brd: module loaded
[ 2.435011] loop: module loaded
[ 2.439510] zram: Added device: zram0
[ 2.443234] lkdtm: No crash points registered, enable through debugfs
[ 2.451181] rockchip-spi ff110000.spi: no high_speed pinctrl state
[ 2.459572] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 2.636647] wk2xxx_probe() GENA = 0xFF
[ 2.640538] spi driver error!!!!
[ 2.643899] wk2xxxspi: probe of spi0.0 failed with error 1
[ 2.649478] register spi return v = :0
[ 2.653344] tun: Universal TUN/TAP device driver, 1.6
[ 2.658443] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.667255] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 2.673967] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 2.684811] PPP generic driver version 2.4.2
[ 2.689658] usbcore: registered new interface driver rndis_wlan
[ 2.696006] usbcore: registered new interface driver rt2800usb
[ 2.702044] Rockchip WiFi SYS interface (V1.00) ...
[ 2.707081] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.714608] usbcore: registered new interface driver pegasus
[ 2.720404] usbcore: registered new interface driver rtl8150
[ 2.726161] usbcore: registered new interface driver r8152
[ 2.731795] usbcore: registered new interface driver asix
[ 2.737298] usbcore: registered new interface driver ax88179_178a
[ 2.743522] usbcore: registered new interface driver cdc_ether
[ 2.749514] usbcore: registered new interface driver dm9601
[ 2.755209] usbcore: registered new interface driver smsc75xx
[ 2.761111] usbcore: registered new interface driver smsc95xx
[ 2.766953] usbcore: registered new interface driver net1080
[ 2.772758] usbcore: registered new interface driver rndis_host
[ 2.778828] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.786352] usbcore: registered new interface driver sierra_net
[ 2.792452] usbcore: registered new interface driver cdc_ncm
[ 2.798259] usbcore: registered new interface driver qmi_wwan
[ 2.804104] usbcore: registered new interface driver cdc_mbim
[ 2.810551] ff540000.usb supply vusb_d not found, using dummy regulator
[ 2.817280] ff540000.usb supply vusb_a not found, using dummy regulator
[ 2.938816] dwc2 ff540000.usb: DWC OTG Controller
[ 2.943569] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 2.950718] dwc2 ff540000.usb: irq 45, io mem 0xff540000
[ 2.956441] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.963293] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.970554] usb usb1: Product: DWC OTG Controller
[ 2.975270] usb usb1: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 2.980960] usb usb1: SerialNumber: ff540000.usb
[ 2.986663] hub 1-0:1.0: USB hub found
[ 2.990535] hub 1-0:1.0: 1 port detected
[ 2.995480] ff580000.usb supply vusb_d not found, using dummy regulator
[ 3.002258] ff580000.usb supply vusb_a not found, using dummy regulator
[ 3.019750] dwc2 ff580000.usb: DWC OTG Controller
[ 3.024505] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.031661] dwc2 ff580000.usb: irq 46, io mem 0xff580000
[ 3.037339] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.044191] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.051453] usb usb2: Product: DWC OTG Controller
[ 3.056169] usb usb2: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.061861] usb usb2: SerialNumber: ff580000.usb
[ 3.067542] hub 2-0:1.0: USB hub found
[ 3.071433] hub 2-0:1.0: 1 port detected
[ 3.077857] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.084461] ehci-platform: EHCI generic platform driver
[ 3.090387] ehci-platform ff500000.usb: EHCI Host Controller
[ 3.096463] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 3.104624] ehci-platform ff500000.usb: irq 43, io mem 0xff500000
[ 3.128201] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 3.134716] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.141569] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.148835] usb usb3: Product: EHCI Host Controller
[ 3.153720] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[ 3.159243] usb usb3: SerialNumber: ff500000.usb
[ 3.164928] hub 3-0:1.0: USB hub found
[ 3.169005] hub 3-0:1.0: 1 port detected
[ 3.174100] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.180386] ohci-platform: OHCI generic platform driver
[ 3.186273] usbcore: registered new interface driver cdc_acm
[ 3.191988] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.200142] usbcore: registered new interface driver cdc_wdm
[ 3.205987] usbcore: registered new interface driver usb-storage
[ 3.212147] usbcore: registered new interface driver ums-realtek
[ 3.218371] usbcore: registered new interface driver usbserial
[ 3.224301] usbcore: registered new interface driver usbserial_generic
[ 3.230929] usbserial: USB Serial support registered for generic
[ 3.237055] usbcore: registered new interface driver ch341
[ 3.242654] usbserial: USB Serial support registered for ch341-uart
[ 3.249073] usbcore: registered new interface driver cp210x
[ 3.254703] usbserial: USB Serial support registered for cp210x
[ 3.260801] usbcore: registered new interface driver ftdi_sio
[ 3.266605] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.274382] usbcore: registered new interface driver keyspan
[ 3.280157] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.288041] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.295446] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.302840] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.310309] usbcore: registered new interface driver option
[ 3.315944] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.323247] usbcore: registered new interface driver oti6858
[ 3.329010] usbserial: USB Serial support registered for oti6858
[ 3.335124] usbcore: registered new interface driver pl2303
[ 3.340797] usbserial: USB Serial support registered for pl2303
[ 3.346834] usbcore: registered new interface driver qcserial
[ 3.352680] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.359803] usbcore: registered new interface driver sierra
[ 3.365437] usbserial: USB Serial support registered for Sierra USB modem
[ 3.374308] usbcore: registered new interface driver iforce
[ 3.380114] usbcore: registered new interface driver xpad
[ 3.385663] ==gsl_ts_init==
[ 3.388615] ret=0
[ 3.391067] usbcore: registered new interface driver usbtouchscreen
[ 3.397703] .. rk pwm remotectl v1.1 init
[ 3.402255] input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
[ 3.410351] sensor_register_slave:mma8452,id=17
[ 3.414900] sensor_register_slave:lis3dh,id=7
[ 3.419321] sensor_register_slave:mma7660,id=18
[ 3.423865] sensor_register_slave:lsm303d,id=23
[ 3.428779] sensor_register_slave:gs_mc3230,id=24
[ 3.433495] [Gsensor] gsensor_init
[ 3.437087] sensor_register_slave:mpu6880_acc,id=25
[ 3.442027] sensor_register_slave:mpu6500_acc,id=26
[ 3.446918] sensor_register_slave:lsm330_acc,id=27
[ 3.451753] sensor_register_slave:akm8975,id=31
[ 3.456294] sensor_register_slave:akm8963,id=32
[ 3.460859] sensor_register_slave:l3g4200d,id=46
[ 3.465494] sensor_register_slave:l3g20d,id=47
[ 3.469972] sensor_register_slave:ewtsa,id=48
[ 3.474344] sensor_register_slave:lsm330_gyro,id=52
[ 3.479255] sensor_register_slave:cm3217,id=54
[ 3.483712] sensor_register_slave:cm3218,id=55
[ 3.488230] usb 3-1: new high-speed USB device number 2 using ehci-platform
[ 3.496555] i2c /dev entries driver
[ 3.502120] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 3.509169] fan53555-reg: supplied by vcc_sys
[ 3.517303] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 3.524341] fan53555-reg: supplied by vcc_sys
[ 3.535386] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 3.543350] REG1: supplied by vcc_sys
[ 3.549104] REG2: supplied by vcc_sys
[ 3.554212] vcc_flash: supplied by vcc_io
[ 3.558572] vcc_sd: supplied by vcc_io
[ 3.562608] vcc28_dvp: supplied by vcc_io
[ 3.566988] dovdd_1v8: supplied by vcc28_dvp
[ 3.571431] vcc_lcd: supplied by vcc_io
[ 3.575639] REG3: supplied by vcc_sys
[ 3.581039] REG4: supplied by vcc_sys
[ 3.586196] REG5: supplied by vcc_sys
[ 3.591599] REG6: supplied by vcc_sys
[ 3.596769] REG7: supplied by vcc_sys
[ 3.601981] REG8: supplied by vcc_sys
[ 3.607106] REG9: supplied by vcc_sys
[ 3.612376] REG10: supplied by vcc_20
[ 3.617614] REG11: supplied by vcc_20
[ 3.623049] REG12: supplied by vcc_20
[ 3.628347] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0ae6000
[ 3.636426] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f0ae8000
[ 3.645015] GSLX680 Enter gsl_ts_probe
[ 3.648899] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608
[ 3.655636] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.662827] usb 3-1: Product: USB2.0 Hub
[ 3.668001] hub 3-1:1.0: USB hub found
[ 3.672211] hub 3-1:1.0: 4 ports detected
[ 3.958189] usb 3-1.1: new high-speed USB device number 3 using ehci-platform
[ 3.978178] gsl_ts_probe--1300, i2c_master_recv fail
[ 3.983498] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0aea000
[ 3.991770] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0aec000
[ 4.001374] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 4.007782] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 4.017688] usbcore: registered new interface driver uvcvideo
[ 4.023494] USB Video Class driver (1.1.1)
[ 4.032939] Boot mode: coldboot
[ 4.037483] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[ 4.044524] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 4.053705] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[ 4.062662] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 4.071472] Bluetooth: Virtual HCI driver ver 1.5
[ 4.076481] Bluetooth: HCI UART driver ver 2.3
[ 4.080991] Bluetooth: HCI UART protocol H4 registered
[ 4.086139] Bluetooth: HCI UART protocol LL registered
[ 4.091354] Bluetooth: HCI UART protocol ATH3K registered
[ 4.096928] usbcore: registered new interface driver bfusb
[ 4.102655] usbcore: registered new interface driver btusb
[ 4.108596] usb 3-1.1: New USB device found, idVendor=05e3, idProduct=0608
[ 4.108854] cpu cpu0: bin=1
[ 4.109054] cpu cpu0: leakage=12
[ 4.121557] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.121997] cpu cpu0: temp=37272, pvtm=14897 (14933 + -36)
[ 4.122061] rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
[ 4.122109] cpu cpu0: pvtm-volt-sel=0
[ 4.122235] cpu cpu0: bin-scale=25
[ 4.125102] cpu cpu0: avs=0
[ 4.125147] cpu cpu0: scale_rate=1512000000
[ 4.125449] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 4.125477] cpu cpu0: failed to read out thermal zone (-22)
[ 4.127011] cpu cpu0: failed to find power_model node
[ 4.127482] sdhci: Secure Digital Host Controller Interface driver
[ 4.127486] sdhci: Copyright(c) Pierre Ossman
[ 4.127501] Synopsys Designware Multimedia Card Interface Driver
[ 4.129358] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.129458] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 4.129480] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 4.129574] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 4.129607] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.228809] usb 3-1.1: Product: USB2.0 Hub
[ 4.234583] hub 3-1.1:1.0: USB hub found
[ 4.238553] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 4.246176] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 4.254050] hub 3-1.1:1.0: 4 ports detected
[ 4.266227] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.288055] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 4.294259] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.301534] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 4.308346] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 4.314140] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 4.323917] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.332066] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 4.338278] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 4.344828] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[ 4.348132] usb 3-1.4: new high-speed USB device number 4 using ehci-platform
[ 4.370634] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.392512] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 4.399058] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.406343] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 4.413165] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 4.418980] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 4.428764] dwmmc_rockchip ff0f0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.436900] dwmmc_rockchip ff0f0000.dwmmc: No vmmc regulator found
[ 4.443111] dwmmc_rockchip ff0f0000.dwmmc: No vqmmc regulator found
[ 4.462160] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.471473] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 4.484066] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 4.490122] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.496349] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.502380] usbcore: registered new interface driver usbhid
[ 4.507979] usbhid: USB HID core driver
[ 4.512069] ashmem: initialized
[ 4.515750] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 4.522328] usb 3-1.4: New USB device found, idVendor=1e0e, idProduct=9001
[ 4.523416] rknandbase v1.2 2018-05-08
[ 4.523899] usbcore: registered new interface driver snd-usb-audio
[ 4.527209] u32 classifier
[ 4.527215] Netfilter messages via NETLINK v0.30.
[ 4.527260] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.527460] ctnetlink v0.93: registering with nfnetlink.
[ 4.527551] ip_set: protocol 6
[ 4.527560] IPVS: Registered protocols ()
[ 4.527584] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 4.527649] IPVS: Creating netns size=1104 id=0
[ 4.527671] IPVS: ipvs loaded.
[ 4.527904] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.528085] Initializing XFRM netlink socket
[ 4.528624] NET: Registered protocol family 10
[ 4.529075] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.529175] sit: IPv6 over IPv4 tunneling driver
[ 4.529532] NET: Registered protocol family 17
[ 4.529546] NET: Registered protocol family 15
[ 4.529570] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.529589] Bridge firewalling registered
[ 4.529654] Bluetooth: RFCOMM socket layer initialized
[ 4.529677] Bluetooth: RFCOMM ver 1.11
[ 4.529686] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.529692] Bluetooth: HIDP socket layer initialized
[ 4.529724] 8021q: 802.1Q VLAN Support v1.8
[ 4.529739] lib80211: common routines for IEEE802.11 drivers
[ 4.529763] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 4.529935] [BT_RFKILL]: Enter rfkill_rk_init
[ 4.530060] Key type dns_resolver registered
[ 4.530128] sensor_register_slave:mpu6880_gyro,id=51
[ 4.530201] ov13850 3-0010: driver version: 00.01.03
[ 4.530469] ov13850 3-0010: could not get default pinstate
[ 4.530472] ov13850 3-0010: could not get sleep pinstate
[ 4.532437] ov13850 3-0010: Unexpected sensor id(000000), ret(-5)
[ 4.533183] ThumbEE CPU extension supported.
[ 4.533194] Registering SWP/SWPB emulation handler
[ 4.533631] Loading compiled-in X.509 certificates
[ 4.534208] rga2: Driver loaded successfully ver:2.0.00000
[ 4.534290] rga2: Module initialized.
[ 4.534523] [drm] Rockchip DRM driver version: v1.0.1
[ 4.534711] rockchip-drm display-subsystem: devfreq is not set
[ 4.535306] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0c67340)
[ 4.535710] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c67340)
[ 4.535980] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 4.536028] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
[ 4.537014] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0c5dda0)
[ 4.537072] rockchip-drm display-subsystem: failed to bind ff770000.syscon:lvds (ops 0xc0c5f54c): -517
[ 4.537889] rockchip-drm display-subsystem: master bind failed: -517
[ 4.538764] mali ffa30000.gpu: bin=0
[ 4.538777] mali ffa30000.gpu: Failed to get leakage
[ 4.538932] mali ffa30000.gpu: Failed to get pvtm
[ 4.538944] mali ffa30000.gpu: bin-scale=55
[ 4.539157] mali ffa30000.gpu: avs=0
[ 4.539183] W : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 114; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 4.539424] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 4.539520] mali ffa30000.gpu: Protected mode not available
[ 4.539736] mali ffa30000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 4.539757] mali ffa30000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 4.539843] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 4.540122] mali ffa30000.gpu: Probed as mali0
[ 4.540935] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 4.540936] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 4.540941] rk_gmac-dwmac ff290000.ethernet: TX delay(0x1d).
[ 4.540944] rk_gmac-dwmac ff290000.ethernet: RX delay(0x16).
[ 4.540956] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[ 4.541027] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[ 4.541030] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 4.543161] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 4.545918] mmc_host mmc2: Bus speed (slot 0) = 99000000Hz (slot req 100000000Hz, actual 99000000HZ div = 0)
[ 4.546039] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 4.546096] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 4.546097] Ring mode enabled
[ 4.546100] DMA HW capability register supported
[ 4.546100] Normal descriptors
[ 4.546102] RX Checksum Offload Engine supported (type 2)
[ 4.546103] Wake-Up On Lan supported
[ 4.546129] Enable RX Mitigation via HW Watchdog Timer
[ 4.558890] devfreq ffa30000.gpu: Couldn't update frequency transition information.
[ 4.980935] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.988245] usb 3-1.4: Product: SimTech, Incorporated
[ 4.993292] usb 3-1.4: Manufacturer: SimTech, Incorporated
[ 4.998774] usb 3-1.4: SerialNumber: 0123456789ABCDEF
[ 5.004741] option 3-1.4:1.0: GSM modem (1-port) converter detected
[ 5.011202] usb 3-1.4: GSM modem (1-port) converter now attached to ttyUSB0
[ 5.018472] option 3-1.4:1.1: GSM modem (1-port) converter detected
[ 5.024902] usb 3-1.4: GSM modem (1-port) converter now attached to ttyUSB1
[ 5.032230] option 3-1.4:1.2: GSM modem (1-port) converter detected
[ 5.038665] usb 3-1.4: GSM modem (1-port) converter now attached to ttyUSB2
[ 5.045965] option 3-1.4:1.3: GSM modem (1-port) converter detected
[ 5.052401] usb 3-1.4: GSM modem (1-port) converter now attached to ttyUSB3
[ 5.059711] option 3-1.4:1.4: GSM modem (1-port) converter detected
[ 5.066130] usb 3-1.4: GSM modem (1-port) converter now attached to ttyUSB4
[ 5.073346] idVendor 7694 idP 36865 bnum 6 ec20 det false
[ 5.079043] qmi_wwan 3-1.4:1.5: cdc-wdm0: USB WDM device
[ 5.084916] qmi_wwan 3-1.4:1.5 wwan0: register 'qmi_wwan' at usb-ff500000.usb-1.4, WWAN/QMI device, 0a:b9:88:2f:35:25
[ 5.128200] dwmmc_rockchip ff0f0000.dwmmc: Successfully tuned phase to 115
[ 5.135150] mmc2: new HS200 MMC card at address 0001
[ 5.140444] mmcblk2: mmc2:0001 AGND3R 14.6 GiB
[ 5.145100] mmcblk2boot0: mmc2:0001 AGND3R partition 1 4.00 MiB
[ 5.151168] mmcblk2boot1: mmc2:0001 AGND3R partition 2 4.00 MiB
[ 5.157203] mmcblk2rpmb: mmc2:0001 AGND3R partition 3 4.00 MiB
[ 5.165263] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[ 5.575770] libphy: stmmac: probed
[ 5.579195] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 5.585630] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 5.588216] vendor storage:20190527 ret = 0
[ 5.596338] input: adc-keys as /devices/platform/adc-keys/input/input1
[ 5.603514] rockchip-dmc dmc: Get drm_device fail
[ 5.608679] [drm] Rockchip DRM driver version: v1.0.1
[ 5.613904] rockchip-drm display-subsystem: devfreq is not set
[ 5.620331] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0c67340)
[ 5.628022] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c67340)
[ 5.635615] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 5.643411] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
[ 5.653601] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0c5dda0)
[ 5.661097] rockchip-drm display-subsystem: bound ff770000.syscon:lvds (ops 0xc0c5f54c)
[ 5.669112] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.675715] [drm] No driver support for vblank timestamp query.
[ 5.681795] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[ 5.712522] rockchip-drm display-subsystem: fb0: frame buffer device
[ 5.759109] rockchip-dmc dmc: Failed to get leakage
[ 5.764184] rockchip-dmc dmc: Failed to get pvtm
[ 5.769057] rockchip-dmc dmc: avs=0
[ 5.772562] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 5.779003] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 5.784891] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 5.793428] rockchip-dmc dmc: could not find power_model node
[ 5.935420] asoc-simple-card sound: ES8323 HiFi <-> ff890000.i2s mapping ok
[ 5.943937] asoc-simple-card sound: i2s-hifi <-> ff890000.i2s mapping ok
[ 5.950729] asoc-simple-card sound: ASoC: no sink widget found for MIC1
[ 5.957361] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack -> direct -> MIC1
[ 5.966095] asoc-simple-card sound: ASoC: no sink widget found for MIC2
[ 5.972765] asoc-simple-card sound: ASoC: Failed to add route Microphone Jack -> direct -> MIC2
[ 5.981474] asoc-simple-card sound: ASoC: no source widget found for micbias1
[ 5.988625] asoc-simple-card sound: ASoC: Failed to add route micbias1 -> direct -> Microphone Jack
[ 5.997658] asoc-simple-card sound: ASoC: no source widget found for HPOL
[ 6.004456] asoc-simple-card sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[ 6.013079] asoc-simple-card sound: ASoC: no source widget found for HPOR
[ 6.019878] asoc-simple-card sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[ 6.030961] input: rockchip,firefly-codec Headphone Jack as /devices/platform/sound/sound/card0/input2
[ 6.040982] input: gpio-keys as /devices/platform/gpio-keys/input/input3
[ 6.047971] i2c i2c-4: sensor_probe: gs_mc3230,ed948200
[ 6.053244] sensors 4-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0xc12b1ce0
[ 6.118729] [Gsensor] init_3230_ctl_data 445 : error: -6
[ 6.124085] sensors 4-004c: sensor_initial:fail to init sensor
[ 6.129997] sensors 4-004c: sensor_chip_init:fail to init sensor
[ 6.136014] i2c i2c-4: sensor_probe failed -2
[ 6.136014]
[ 6.141919] sensors: probe of 4-004c failed with error -2
[ 6.147741] rtc-hym8563 0-0051: setting system clock to 2023-12-21 06:31:30 UTC (1703140290)
[ 6.170319] vcc_sd: disabling
[ 6.173305] vcc_mipi: disabling
[ 6.176449] dvdd_1v2: disabling
[ 6.180346] u
修改WiFi驱动后,卡在:
[ 5.559384] vcc_sd: disabling
[ 5.562361] vcc_mipi: disabling
[ 5.565503] dvdd_1v2: disabling
u▒ 5.569140]
Com COM4 (2023-12-21_164502).zip (12.7 KB)
