SDK包名称:rk3288_linux_release_v2.5.0a_20230510
SDK修改内容:未作任何修改
Log日志:[Com COM4] (2023-12-21_164502).zip
哪位好心人能提供下rk3288_linux_release_20210304的源码?
官方最新源码我编译后,无法启动。。
Com COM4 (2023-12-21_164502).zip (12.7 KB)
SDK修改内容:未作任何修改
官方最新源码我编译后,无法启动。。
qq2317783075 发表于 2023-12-29 16:58
为什么无法启动呢?看看log
./card/block.c第2857行
mmc_blk_emmc_add函数报空指针异常。
我看只有./card/queue.h里有这个函数的定义,其余地方都没这个函数的实现
为什么无法启动呢?看看log
=~=~=~=~=~=~=~=~=~=~=~= MobaXterm log 2023.12.29 18:14:48 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version 1.11 20210818
SRX
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Boot1 Release Time: Jul 22 2021 09:08:57, version: 2.63
ChipType = 0x8, 241
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd8,400
mmc0:cmd8,400
mmc0:cmd8,400
SdmmcInit=0 1
StorageInit ok = 23541
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: rootfs, start:0x5a000, size:0x3b2400
GPT part: 7, name: userdata, start:0x40c400, size:0x1912bdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LOADER Check OK! 0x4000, 137647
TOS Check OK! 0x6000, 174056
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:381: Initializing (1.1.0-394-gbe1b074d #29 Thu Aug 15 00:42:35 UTC 2019 arm)
INF [0x0] TEE-CORE:init_primary_helper:382: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:383: Next entry point address: 0x200000
U-Boot 2017.09(u-boot commit id: e4da79f87a88e70b076e97de82fc8ece3b6d6ea9)(sdk version: rk3288_linux_release_20220304_v2.5.0a.xml)-ge4da79f87a #wx (Dec 29 2023 - 18:07:38 +0800)
Model: Firefly-RK3288
PreSerial: 2, raw, 0xff690000
DRAM: 2 GiB
Sysmem: init
Relocation Offset: 00000000
Relocation fdt: 7bddb6d0 - 7bddcdd1
CR: M/C/I
dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
Bootdev(atags): mmc 0
MMC0: High Speed, 52Mhz
PartType: EFI
boot mode: recovery (misc)
Found DTB in recovery part
DTB: rk-kernel.dtb
HASH(s): OK
I2c0 speed: 400000Hz
vdd_log 1100000 uV
In: serial
Out: vidconsole
Err: vidconsole
Model: Firefly-RK3288 Board (Linux Opensource)
hdmi@ff980000 disconnected
CLK: (uboot. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
apll 1000000 KHz
dpll 396000 KHz
cpll 24000 KHz
gpll 594000 KHz
npll 24000 KHz
aclk_bus 198000 KHz
Net: eth0: ethernet@ff290000
Unknown command 'usb' - try 'help'
Hit key to stop autoboot('CTRL+C'): 3 2 1 0
ANDROID: reboot reason: "recovery"
Booting ZIMAGE kernel at 0x02008000(Uncompress to 0) with fdt at 0x08300000...
## Booting Android Image at 0x02007800 ...
Kernel load addr 0x02008000 size 8295 KiB
RAM disk load addr 0x0a200000 size 6779 KiB
## Flattened Device Tree blob at 0x08300000
Booting using the fdt blob at 0x08300000
XIP Kernel Image from 0x02008000 to 0x02008000 ... OK
'reserved-memory' dma-unusable@fe000000: addr=fe000000 size=1000000
'reserved-memory' ramoops@00000000: addr=8000000 size=f0000
Loading Ramdisk to 0ffff000, end 1069dafb ... OK
Loading Device Tree to 0ffe7000, end 0fffe095 ... OK
No file: logo_kernel.bmp
failed to reserve drm-cubic-lut memory
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09200000 - 0x80000000 (size: 0x76e00000)
Total: 4765.630 ms
Starting kernel ...
[ 0.000000] [0: swapper: 0] Booting Linux on physical CPU 0x500
[ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpuset
[ 0.000000] [0: swapper: 0] Initializing cgroup subsys cpuacct
[ 0.000000] [0: swapper: 0] Linux version 4.4.194 (wx@wx-All-Series) (kernel commit id: ebb6f60626788430b3eebadd4d1fe01365685be8) (sdk version: rk3288_linux_release_20220304_v2.5.0a.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Fri Dec 29 18:11:48 CST 2023
[ 0.000000] [0: swapper: 0] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] [0: swapper: 0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] [0: swapper: 0] Machine model: Firefly-RK3288 Board (Linux Opensource)
[ 0.000000] [0: swapper: 0] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] [0: swapper: 0] Memory policy: Data cache writealloc
[ 0.000000] [0: swapper: 0] psci: probing for conduit method from DT.
[ 0.000000] [0: swapper: 0] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] [0: swapper: 0] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] [0: swapper: 0] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] [0: swapper: 0] PERCPU: Embedded 14 pages/cpu @eef77000 s24728 r8192 d24424 u57344
[ 0.000000] [0: swapper: 0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519168
[ 0.000000] [0: swapper: 0] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal verbose androidboot.slot_suffix= androidboot.serialno=ef2adc9b89831515 earlyprintk ro rootwait console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 swiotlb=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 0.000000] [0: swapper: 0] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] [0: swapper: 0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] [0: swapper: 0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] [0: swapper: 0] Memory: 2020204K/2082816K available (12288K kernel code, 1118K rwdata, 3668K rodata, 1024K init, 590K bss, 46228K reserved, 16384K cma-reserved, 1293716K highmem)
[ 0.000000] [0: swapper: 0] Virtual kernel memory layout:
[ 0.000000] [0: swapper: 0] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] [0: swapper: 0] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] [0: swapper: 0] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] [0: swapper: 0] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] [0: swapper: 0] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] [0: swapper: 0] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] [0: swapper: 0] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] [0: swapper: 0] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] [0: swapper: 0] .data : 0xc1300000 - 0xc141784c (1119 kB)
[ 0.000000] [0: swapper: 0] .bss : 0xc1419000 - 0xc14ac890 ( 591 kB)
[ 0.000000] [0: swapper: 0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] [0: swapper/0: 0] Hierarchical RCU implementation.
[ 0.000000] [0: swapper/0: 0] Build-time adjustment of leaf fanout to 32.
[ 0.000000] [0: swapper/0: 0] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] [0: swapper/0: 0] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] [0: swapper/0: 0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000010] [0: swapper/0: 0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000038] [0: swapper/0: 0] Switching to timer-based delay loop, resolution 41ns
[ 0.004017] [0: swapper/0: 0] Console: colour dummy device 80x30
[ 0.004069] [0: swapper/0: 0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.004097] [0: swapper/0: 0] pid_max: default: 32768 minimum: 301
[ 0.004236] [0: swapper/0: 0] Security Framework initialized
[ 0.004262] [0: swapper/0: 0] Yama: becoming mindful.
[ 0.004387] [0: swapper/0: 0] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004416] [0: swapper/0: 0] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005574] [0: swapper/0: 0] Initializing cgroup subsys devices
[ 0.005613] [0: swapper/0: 0] Initializing cgroup subsys freezer
[ 0.005681] [0: swapper/0: 0] CPU: Testing write buffer coherency: ok
[ 0.005739] [0: swapper/0: 0] ftrace: allocating 44276 entries in 130 pages
[ 0.137691] [0: swapper/0: 1] CPU0: update cpu_capacity 430
[ 0.137720] [0: swapper/0: 1] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.137828] [0: swapper/0: 1] Setting up static identity map for 0x100000 - 0x100058
[ 0.146485] [1: swapper/1: 0] CPU1: update cpu_capacity 430
[ 0.146495] [1: swapper/1: 0] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.147831] [2: swapper/2: 0] CPU2: update cpu_capacity 430
[ 0.147841] [2: swapper/2: 0] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.149134] [3: swapper/3: 0] CPU3: update cpu_capacity 430
[ 0.149145] [3: swapper/3: 0] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.149312] [0: swapper/0: 1] Brought up 4 CPUs
[ 0.149396] [0: swapper/0: 1] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.149412] [0: swapper/0: 1] CPU: All CPU(s) started in SVC mode.
[ 0.151510] [0: swapper/0: 1] devtmpfs: initialized
[ 0.187141] [0: swapper/0: 1] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.187779] [0: swapper/0: 1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.187834] [0: swapper/0: 1] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.189365] [0: swapper/0: 1] pinctrl core: initialized pinctrl subsystem
[ 0.191043] [0: swapper/0: 1] NET: Registered protocol family 16
[ 0.195507] [0: swapper/0: 1] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.227583] [0: swapper/0: 1] cpuidle: using governor ladder
[ 0.257636] [0: swapper/0: 1] cpuidle: using governor menu
[ 0.257697] [0: swapper/0: 1] Registered FIQ tty driver
[ 0.315870] [0: swapper/0: 1] console [pstore-1] enabled
[ 0.315891] [0: swapper/0: 1] pstore: Registered ramoops as persistent store backend
[ 0.315913] [0: swapper/0: 1] ramoops: attached 0xf0000@0x8000000, ecc: 0/0
[ 0.317365] [0: swapper/0: 1] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.317394] [0: swapper/0: 1] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.318632] [0: swapper/0: 1] fiq debugger fiq mode enabled
[ 0.999909] [0: swapper/0: 1] console [ttyFIQ0] enabled
[ 1.006321] [0: swapper/0: 1] Registered fiq debugger ttyFIQ0
[ 1.099779] [0: swapper/0: 1] vcc_flash: regulator get failed, ret=-517
[ 1.108022] [0: swapper/0: 1] vcc_sd: regulator get failed, ret=-517
[ 1.115952] [0: swapper/0: 1] vcc28_dvp: regulator get failed, ret=-517
[ 1.124139] [0: swapper/0: 1] dovdd_1v8: regulator get failed, ret=-517
[ 1.131844] [0: swapper/0: 1] rockchip-pinctrl pinctrl: pin gpio0-11 already requested by vcc28-dvp-regulator; cannot claim for vcc-mipi
[ 1.144938] [0: swapper/0: 1] rockchip-pinctrl pinctrl: pin-11 (vcc-mipi) status -22
[ 1.153483] [0: swapper/0: 1] rockchip-pinctrl pinctrl: could not request pin 11 (gpio0-11) from group mipi-pwr on device rockchip-pinctrl
[ 1.166814] [0: swapper/0: 1] reg-fixed-voltage vcc-mipi: Error applying setting, reverse things back
[ 1.179508] [0: swapper/0: 1] iommu: Adding device ff910000.rkisp1 to group 0
[ 1.187648] [0: swapper/0: 1] iommu: Adding device ff930000.vop to group 1
[ 1.195469] [0: swapper/0: 1] iommu: Adding device ff940000.vop to group 2
[ 1.203349] [0: swapper/0: 1] iommu: Adding device ff9a0000.vpu-service to group 3
[ 1.211871] [0: swapper/0: 1] iommu: Adding device ff9c0000.hevc-service to group 4
[ 1.221289] [0: swapper/0: 1] rk_iommu ff914000.iommu: can't get sclk
[ 1.229236] [0: swapper/0: 1] rk_iommu ff930300.iommu: can't get sclk
[ 1.236990] [0: swapper/0: 1] rk_iommu ff940300.iommu: can't get sclk
[ 1.244691] [0: swapper/0: 1] rk_iommu ff9a0800.iommu: can't get sclk
[ 1.252530] [0: swapper/0: 1] rk_iommu ff9c0440.iommu: can't get sclk
[ 1.260688] [0: swapper/0: 1] SCSI subsystem initialized
[ 1.267251] [0: swapper/0: 1] usbcore: registered new interface driver usbfs
[ 1.275196] [0: swapper/0: 1] usbcore: registered new interface driver hub
[ 1.283079] [0: swapper/0: 1] usbcore: registered new device driver usb
[ 1.290711] [0: swapper/0: 1] media: Linux media interface: v0.10
[ 1.297718] [0: swapper/0: 1] Linux video capture interface: v2.00
[ 1.304847] [0: swapper/0: 1] pps_core: LinuxPPS API ver. 1 registered
[ 1.312203] [0: swapper/0: 1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.323755] [0: swapper/0: 1] PTP clock support registered
[ 1.332725] [0: swapper/0: 1] Advanced Linux Sound Architecture Driver Initialized.
[ 1.342302] [0: swapper/0: 1] Bluetooth: Core ver 2.21
[ 1.348298] [0: swapper/0: 1] NET: Registered protocol family 31
[ 1.355141] [0: swapper/0: 1] Bluetooth: HCI device and connection manager initialized
[ 1.363860] [0: swapper/0: 1] Bluetooth: HCI socket layer initialized
[ 1.371131] [0: swapper/0: 1] Bluetooth: L2CAP socket layer initialized
[ 1.378586] [0: swapper/0: 1] Bluetooth: SCO socket layer initialized
[ 1.387595] [0: swapper/0: 1] rockchip-cpuinfo cpuinfo: Serial: ef2adc9b89831515
[ 1.398060] [0: swapper/0: 1] clocksource: Switched to clocksource arch_sys_counter
[ 1.499711] [0: swapper/0: 1] NET: Registered protocol family 2
[ 1.507368] [0: swapper/0: 1] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.516947] [0: swapper/0: 1] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.526128] [0: swapper/0: 1] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.534954] [0: swapper/0: 1] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 1.543320] [0: swapper/0: 1] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 1.552394] [0: swapper/0: 1] NET: Registered protocol family 1
[ 1.559714] [0: swapper/0: 1] RPC: Registered named UNIX socket transport module.
[ 1.567990] [0: swapper/0: 1] RPC: Registered udp transport module.
[ 1.575090] [0: swapper/0: 1] RPC: Registered tcp transport module.
[ 1.582172] [0: swapper/0: 1] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.591357] [0: swapper/0: 1] Trying to unpack rootfs image as initramfs...
[ 2.372513] [0: swapper/0: 1] Freeing initrd memory: 6780K
[ 2.380931] [0: swapper/0: 1] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 2.395236] [0: swapper/0: 1] Initialise system trusted keyring
[ 2.417483] [0: swapper/0: 1] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.429237] [1: swapper/0: 1] NFS: Registering the id_resolver key type
[ 2.436686] [1: swapper/0: 1] Key type id_resolver registered
[ 2.443276] [1: swapper/0: 1] Key type id_legacy registered
[ 2.449708] [1: swapper/0: 1] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 2.459846] [1: swapper/0: 1] fuse init (API version 7.23)
[ 2.476179] [1: swapper/0: 1] NET: Registered protocol family 38
[ 2.483064] [1: swapper/0: 1] Key type asymmetric registered
[ 2.489566] [1: swapper/0: 1] Asymmetric key parser 'x509' registered
[ 2.496931] [1: swapper/0: 1] bounce: pool size: 64 pages
[ 2.503531] [1: swapper/0: 1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.513346] [1: swapper/0: 1] io scheduler noop registered
[ 2.519663] [1: swapper/0: 1] io scheduler deadline registered
[ 2.526577] [1: swapper/0: 1] io scheduler cfq registered (default)
[ 2.559714] [1: swapper/0: 1] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
[ 2.568839] [1: swapper/0: 1] rk-vcodec ff9a0000.vpu-service: probe device
[ 2.576970] [1: swapper/0: 1] rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
[ 2.587623] [1: swapper/0: 1] rk-vcodec ff9a0000.vpu-service: could not find power_model node
[ 2.597012] [1: swapper/0: 1] rk-vcodec ff9a0000.vpu-service: init success
[ 2.605310] [1: swapper/0: 1] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
[ 2.614562] [1: swapper/0: 1] rk-vcodec ff9c0000.hevc-service: probe device
[ 2.622807] [1: swapper/0: 1] rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
[ 2.633155] [1: swapper/0: 1] rk-vcodec ff9c0000.hevc-service: could not find power_model node
[ 2.642621] [1: swapper/0: 1] rk-vcodec ff9c0000.hevc-service: init success
[ 2.654763] [3: swapper/0: 1] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.664758] [3: swapper/0: 1] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.677953] [3: swapper/0: 1] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.687942] [3: swapper/0: 1] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 2.701631] [3: swapper/0: 1] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 2.712919] [3: swapper/0: 1] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 2.722864] [3: swapper/0: 1] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 2.735198] [3: swapper/0: 1] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A
[ 2.750393] [3: swapper/0: 1] [drm] Initialized drm 1.1.0 20060810
[ 2.765431] [3: swapper/0: 1] [drm] Rockchip DRM driver version: v1.0.1
[ 2.773425] [3: swapper/0: 1] rockchip-drm display-subsystem: devfreq is not set
[ 2.783454] [3: swapper/0: 1] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d69424)
[ 2.794404] [3: swapper/0: 1] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d69424)
[ 2.804532] [3: swapper/0: 1] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 2.813567] [3: swapper/0: 1] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.823845] [3: swapper/0: 1] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
[ 2.837043] [3: swapper/0: 1] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d5fba0)
[ 2.846849] [3: swapper/0: 1] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.855878] [3: swapper/0: 1] [drm] No driver support for vblank timestamp query.
[ 2.864674] [1: swapper/0: 1] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[ 2.874966] [1: swapper/0: 1] rockchip-drm display-subsystem: can't not find any loader display
[ 2.884529] [1: swapper/0: 1] rockchip-drm display-subsystem: failed to show loader logo
[ 2.893682] [1: swapper/0: 1] Freeing drm_logo memory: 616K
[ 2.900116] [1: swapper/0: 1] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 2.910505] [1: swapper/0: 1] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.929214] [1: swapper/0: 1] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.961073] [1: swapper/0: 1] usbcore: registered new interface driver udl
[ 2.974907] [1: swapper/0: 1] mali ffa30000.gpu: Failed to get regulator
[ 2.982466] [1: swapper/0: 1] mali ffa30000.gpu: Power control initialization failed
[ 2.993159] [1: swapper/0: 1] brd: module loaded
[ 3.010144] [1: swapper/0: 1] loop: module loaded
[ 3.016951] [1: swapper/0: 1] zram: Added device: zram0
[ 3.023078] [1: swapper/0: 1] lkdtm: No crash points registered, enable through debugfs
[ 3.033289] [1: swapper/0: 1] rockchip-spi ff110000.spi: no high_speed pinctrl state
[ 3.043622] [1: swapper/0: 1] register spi return v = :0
[ 3.049897] [1: swapper/0: 1] tun: Universal TUN/TAP device driver, 1.6
[ 3.057304] [1: swapper/0: 1] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.068588] [1: swapper/0: 1] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 3.077601] [1: swapper/0: 1] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 3.090855] [1: swapper/0: 1] PPP generic driver version 2.4.2
[ 3.097989] [1: swapper/0: 1] usbcore: registered new interface driver rndis_wlan
[ 3.106728] [1: swapper/0: 1] usbcore: registered new interface driver rt2800usb
[ 3.115184] [1: swapper/0: 1] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.125078] [1: swapper/0: 1] usbcore: registered new interface driver pegasus
[ 3.133253] [1: swapper/0: 1] usbcore: registered new interface driver rtl8150
[ 3.141415] [1: swapper/0: 1] usbcore: registered new interface driver r8152
[ 3.149402] [1: swapper/0: 1] usbcore: registered new interface driver asix
[ 3.157249] [1: swapper/0: 1] usbcore: registered new interface driver ax88179_178a
[ 3.165835] [1: swapper/0: 1] usbcore: registered new interface driver cdc_ether
[ 3.174157] [1: swapper/0: 1] usbcore: registered new interface driver dm9601
[ 3.182236] [1: swapper/0: 1] usbcore: registered new interface driver smsc75xx
[ 3.190507] [1: swapper/0: 1] usbcore: registered new interface driver smsc95xx
[ 3.198752] [1: swapper/0: 1] usbcore: registered new interface driver net1080
[ 3.206864] [1: swapper/0: 1] usbcore: registered new interface driver rndis_host
[ 3.215275] [1: swapper/0: 1] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.225230] [1: swapper/0: 1] usbcore: registered new interface driver cdc_ncm
[ 3.233395] [1: swapper/0: 1] usbcore: registered new interface driver qmi_wwan
[ 3.241636] [1: swapper/0: 1] usbcore: registered new interface driver cdc_mbim
[ 3.250421] [1: swapper/0: 1] ff540000.usb supply vusb_d not found, using dummy regulator
[ 3.259546] [1: swapper/0: 1] ff540000.usb supply vusb_a not found, using dummy regulator
[ 3.388807] [1: swapper/0: 1] dwc2 ff540000.usb: DWC OTG Controller
[ 3.395905] [1: swapper/0: 1] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 3.405435] [1: swapper/0: 1] dwc2 ff540000.usb: irq 44, io mem 0xff540000
[ 3.413593] [1: swapper/0: 1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.422783] [1: swapper/0: 1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.432387] [1: swapper/0: 1] usb usb1: Product: DWC OTG Controller
[ 3.439470] [1: swapper/0: 1] usb usb1: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.447489] [1: swapper/0: 1] usb usb1: SerialNumber: ff540000.usb
[ 3.455569] [1: swapper/0: 1] hub 1-0:1.0: USB hub found
[ 3.461799] [1: swapper/0: 1] hub 1-0:1.0: 1 port detected
[ 3.469164] [1: swapper/0: 1] ff580000.usb supply vusb_d not found, using dummy regulator
[ 3.478295] [1: swapper/0: 1] ff580000.usb supply vusb_a not found, using dummy regulator
[ 3.598186] [1: swapper/0: 1] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 3.608575] [1: swapper/0: 1] dwc2 ff580000.usb: DWC OTG Controller
[ 3.615671] [1: swapper/0: 1] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.625175] [1: swapper/0: 1] dwc2 ff580000.usb: irq 45, io mem 0xff580000
[ 3.633224] [1: swapper/0: 1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.642416] [1: swapper/0: 1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.652021] [1: swapper/0: 1] usb usb2: Product: DWC OTG Controller
[ 3.659105] [1: swapper/0: 1] usb usb2: Manufacturer: Linux 4.4.194 dwc2_hsotg
[ 3.667123] [1: swapper/0: 1] usb usb2: SerialNumber: ff580000.usb
[ 3.675186] [1: swapper/0: 1] hub 2-0:1.0: USB hub found
[ 3.681417] [1: swapper/0: 1] hub 2-0:1.0: 1 port detected
[ 3.690451] [1: swapper/0: 1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.699423] [1: swapper/0: 1] ehci-platform: EHCI generic platform driver
[ 3.707484] [1: swapper/0: 1] ehci-platform ff500000.usb: EHCI Host Controller
[ 3.715976] [1: swapper/0: 1] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 3.726498] [1: swapper/0: 1] ehci-platform ff500000.usb: irq 42, io mem 0xff500000
[ 3.748135] [1: swapper/0: 1] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 3.757094] [1: swapper/0: 1] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.766294] [1: swapper/0: 1] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.775902] [1: swapper/0: 1] usb usb3: Product: EHCI Host Controller
[ 3.783167] [1: swapper/0: 1] usb usb3: Manufacturer: Linux 4.4.194 ehci_hcd
[ 3.791050] [1: swapper/0: 1] usb usb3: SerialNumber: ff500000.usb
[ 3.799395] [1: swapper/0: 1] hub 3-0:1.0: USB hub found
[ 3.805584] [1: swapper/0: 1] hub 3-0:1.0: 1 port detected
[ 3.813150] [1: swapper/0: 1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.821785] [1: swapper/0: 1] ohci-platform: OHCI generic platform driver
[ 3.830098] [1: swapper/0: 1] usbcore: registered new interface driver cdc_acm
[ 3.838164] [1: swapper/0: 1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.848669] [1: swapper/0: 1] usbcore: registered new interface driver cdc_wdm
[ 3.856897] [1: swapper/0: 1] usbcore: registered new interface driver usb-storage
[ 3.865480] [1: swapper/0: 1] usbcore: registered new interface driver usbserial
[ 3.873795] [1: swapper/0: 1] usbcore: registered new interface driver usbserial_generic
[ 3.882800] [1: swapper/0: 1] usbserial: USB Serial support registered for generic
[ 3.891323] [1: swapper/0: 1] usbcore: registered new interface driver ch341
[ 3.899266] [1: swapper/0: 1] usbserial: USB Serial support registered for ch341-uart
[ 3.907998] [1: swapper/0: 1] usbcore: registered new interface driver cp210x
[ 3.916241] [1: swapper/0: 1] usbserial: USB Serial support registered for cp210x
[ 3.924711] [1: swapper/0: 1] usbcore: registered new interface driver ftdi_sio
[ 3.932922] [1: swapper/0: 1] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.942857] [1: swapper/0: 1] usbcore: registered new interface driver keyspan
[ 3.950975] [1: swapper/0: 1] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 3.961250] [1: swapper/0: 1] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 3.970995] [1: swapper/0: 1] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 3.980753] [1: swapper/0: 1] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 3.990564] [1: swapper/0: 1] usbcore: registered new interface driver option
[ 3.998587] [1: swapper/0: 1] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.008514] [1: swapper/0: 1] usbcore: registered new interface driver oti6858
[ 4.016585] [1: swapper/0: 1] usbserial: USB Serial support registered for oti6858
[ 4.025106] [1: swapper/0: 1] usbcore: registered new interface driver pl2303
[ 4.033131] [1: swapper/0: 1] usbserial: USB Serial support registered for pl2303
[ 4.041561] [1: swapper/0: 1] usbcore: registered new interface driver qcserial
[ 4.049763] [1: swapper/0: 1] usbserial: USB Serial support registered for Qualcomm USB modem
[ 4.059250] [1: swapper/0: 1] usbcore: registered new interface driver sierra
[ 4.067230] [1: swapper/0: 1] usbserial: USB Serial support registered for Sierra USB modem
[ 4.078780] [1: swapper/0: 1] usbcore: registered new interface driver iforce
[ 4.086851] [1: swapper/0: 1] usbcore: registered new interface driver xpad
[ 4.095607] [2: swapper/0: 1] usbcore: registered new interface driver usbtouchscreen
[ 4.104662] [2: swapper/0: 1] .. rk pwm remotectl v1.1 init
[ 4.111581] [2: swapper/0: 1] input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
[ 4.122079] [2: swapper/0: 1] sensor_register_slave:mma8452,id=17
[ 4.128134] [1: kworker/1:1: 75] usb 3-1: new high-speed USB device number 2 using ehci-platform
[ 4.138476] [2: swapper/0: 1] sensor_register_slave:lis3dh,id=7
[ 4.145311] [2: swapper/0: 1] sensor_register_slave:mma7660,id=18
[ 4.152272] [2: swapper/0: 1] sensor_register_slave:lsm303d,id=23
[ 4.159244] [2: swapper/0: 1] sensor_register_slave:gs_mc3230,id=24
[ 4.166299] [2: swapper/0: 1] [Gsensor] gsensor_init
[ 4.172296] [2: swapper/0: 1] sensor_register_slave:mpu6880_acc,id=25
[ 4.179581] [2: swapper/0: 1] sensor_register_slave:mpu6500_acc,id=26
[ 4.186827] [2: swapper/0: 1] sensor_register_slave:lsm330_acc,id=27
[ 4.194012] [2: swapper/0: 1] sensor_register_slave:akm8975,id=31
[ 4.200937] [2: swapper/0: 1] sensor_register_slave:akm8963,id=32
[ 4.207832] [2: swapper/0: 1] sensor_register_slave:l3g4200d,id=46
[ 4.214839] [2: swapper/0: 1] sensor_register_slave:l3g20d,id=47
[ 4.221696] [2: swapper/0: 1] sensor_register_slave:ewtsa,id=48
[ 4.228459] [2: swapper/0: 1] sensor_register_slave:lsm330_gyro,id=52
[ 4.235704] [2: swapper/0: 1] sensor_register_slave:cm3217,id=54
[ 4.242544] [2: swapper/0: 1] sensor_register_slave:cm3218,id=55
[ 4.250775] [2: swapper/0: 1] i2c /dev entries driver
[ 4.259130] [2: swapper/0: 1] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 4.268518] [2: swapper/0: 1] fan53555-reg: supplied by vcc_sys
[ 4.279122] [2: swapper/0: 1] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 4.279936] [1: kworker/1:1: 75] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608
[ 4.279949] [1: kworker/1:1: 75] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.279958] [1: kworker/1:1: 75] usb 3-1: Product: USB2.0 Hub
[ 4.281246] [1: kworker/1:1: 75] hub 3-1:1.0: USB hub found
[ 4.281683] [1: kworker/1:1: 75] hub 3-1:1.0: 4 ports detected
[ 4.325826] [2: swapper/0: 1] fan53555-reg: supplied by vcc_sys
[ 4.339232] [2: swapper/0: 1] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 4.349582] [2: swapper/0: 1] REG1: supplied by vcc_sys
[ 4.357289] [2: swapper/0: 1] REG2: supplied by vcc_sys
[ 4.364818] [2: swapper/0: 1] vcc_flash: supplied by vcc_io
[ 4.371559] [2: swapper/0: 1] vcc_sd: supplied by vcc_io
[ 4.377950] [2: swapper/0: 1] vcc28_dvp: supplied by vcc_io
[ 4.384715] [2: swapper/0: 1] dovdd_1v8: supplied by vcc28_dvp
[ 4.391572] [2: swapper/0: 1] REG3: supplied by vcc_sys
[ 4.399367] [2: swapper/0: 1] REG4: supplied by vcc_sys
[ 4.406920] [2: swapper/0: 1] REG5: supplied by vcc_sys
[ 4.414687] [2: swapper/0: 1] REG6: supplied by vcc_sys
[ 4.422307] [2: swapper/0: 1] REG7: supplied by vcc_sys
[ 4.429919] [2: swapper/0: 1] REG8: supplied by vcc_sys
[ 4.437482] [2: swapper/0: 1] REG9: supplied by vcc_sys
[ 4.445051] [2: swapper/0: 1] REG10: supplied by vcc_20
[ 4.452805] [2: swapper/0: 1] REG11: supplied by vcc_20
[ 4.460541] [2: swapper/0: 1] REG12: supplied by vcc_20
[ 4.468243] [2: swapper/0: 1] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0de4000
[ 4.478724] [2: swapper/0: 1] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f0de6000
[ 4.489032] [2: swapper/0: 1] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0de8000
[ 4.499622] [2: swapper/0: 1] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0dea000
[ 4.511697] [2: swapper/0: 1] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.05
[ 4.520509] [2: swapper/0: 1] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 4.532996] [2: swapper/0: 1] usbcore: registered new interface driver uvcvideo
[ 4.541154] [2: swapper/0: 1] USB Video Class driver (1.1.1)
[ 4.552960] [2: swapper/0: 1] Boot mode: normal
[ 4.558125] [1: kworker/1:1: 75] usb 3-1.1: new high-speed USB device number 3 using ehci-platform
[ 4.569351] [2: swapper/0: 1] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[ 4.578738] [2: swapper/0: 1] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 4.590226] [2: swapper/0: 1] rockchip-thermal ff280000.tsadc: tsadc is probed successfully!
[ 4.601671] [2: swapper/0: 1] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 4.612911] [2: swapper/0: 1] Bluetooth: Virtual HCI driver ver 1.5
[ 4.620338] [2: swapper/0: 1] Bluetooth: HCI UART driver ver 2.3
[ 4.627146] [2: swapper/0: 1] Bluetooth: HCI UART protocol H4 registered
[ 4.634674] [2: swapper/0: 1] Bluetooth: HCI UART protocol LL registered
[ 4.642186] [2: swapper/0: 1] Bluetooth: HCI UART protocol ATH3K registered
[ 4.650123] [2: swapper/0: 1] usbcore: registered new interface driver bfusb
[ 4.658194] [2: swapper/0: 1] usbcore: registered new interface driver btusb
[ 4.666611] [2: swapper/0: 1] cpu cpu0: bin=1
[ 4.672038] [2: swapper/0: 1] cpu cpu0: leakage=12
[ 4.679940] [1: kworker/1:1: 75] usb 3-1.1: New USB device found, idVendor=05e3, idProduct=0608
[ 4.689228] [1: kworker/1:1: 75] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.690744] [2: swapper/0: 1] cpu cpu0: temp=42727, pvtm=14907 (15033 + -126)
[ 4.690808] [2: swapper/0: 1] rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
[ 4.690858] [2: swapper/0: 1] cpu cpu0: pvtm-volt-sel=0
[ 4.690991] [2: swapper/0: 1] cpu cpu0: bin-scale=25
[ 4.694024] [2: swapper/0: 1] cpu cpu0: avs=0
[ 4.694070] [2: swapper/0: 1] cpu cpu0: scale_rate=1512000000
[ 4.694410] [2: swapper/0: 1] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 4.694439] [2: swapper/0: 1] cpu cpu0: failed to read out thermal zone (-22)
[ 4.695989] [2: swapper/0: 1] cpu cpu0: failed to find power_model node
[ 4.696479] [2: swapper/0: 1] sdhci: Secure Digital Host Controller Interface driver
[ 4.696484] [2: swapper/0: 1] sdhci: Copyright(c) Pierre Ossman
[ 4.696496] [2: swapper/0: 1] Synopsys Designware Multimedia Card Interface Driver
[ 4.698387] [2: swapper/0: 1] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.698492] [2: swapper/0: 1] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[ 4.698512] [2: swapper/0: 1] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[ 4.698596] [2: swapper/0: 1] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[ 4.698651] [2: swapper/0: 1] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.818678] [2: swapper/0: 1] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 4.818858] [2: swapper/0: 1] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 4.831481] [2: swapper/0: 1] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.844275] [2: swapper/0: 1] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[ 4.845309] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.845414] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[ 4.845469] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[ 4.845587] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[ 4.845620] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.845707] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found
[ 4.845718] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
[ 4.846223] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[ 4.858192] [2: swapper/0: 1] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.870833] [2: kworker/2:1: 103] mmc1: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 4.870962] [2: swapper/0: 1] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[ 4.872120] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.872207] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[ 4.872228] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[ 4.872308] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[ 4.872340] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 4.872422] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: No vmmc regulator found
[ 4.872432] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: No vqmmc regulator found
[ 4.882695] [2: kworker/2:1: 103] mmc1: mmc_rescan_try_freq: trying to init card at 300000 Hz
[ 4.885484] [2: swapper/0: 1] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 4.895374] [2: kworker/2:1: 103] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 4.898256] [2: swapper/0: 1] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[ 4.898855] [2: kworker/2:0: 19] mmc2: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 4.898979] [2: swapper/0: 1] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.900862] [2: swapper/0: 1] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.902872] [2: swapper/0: 1] usbcore: registered new interface driver usbhid
[ 4.902876] [2: swapper/0: 1] usbhid: USB HID core driver
[ 4.903658] [2: swapper/0: 1] ashmem: initialized
[ 4.905422] [2: swapper/0: 1] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 4.909718] [2: swapper/0: 1] rknandbase v1.2 2018-05-08
[ 4.911555] [2: swapper/0: 1] usbcore: registered new interface driver snd-usb-audio
[ 4.913414] [2: swapper/0: 1] ES8323 2-0010: Can not read property spk_ctl_gpio
[ 4.914113] [2: swapper/0: 1] ES8323 2-0010: Can not read property aux_det_gpio
[ 4.923072] [2: swapper/0: 1] u32 classifier
[ 4.923089] [2: swapper/0: 1] Netfilter messages via NETLINK v0.30.
[ 4.923209] [2: swapper/0: 1] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.924105] [2: swapper/0: 1] ctnetlink v0.93: registering with nfnetlink.
[ 4.924331] [2: swapper/0: 1] ip_set: protocol 6
[ 4.924351] [2: swapper/0: 1] IPVS: Registered protocols ()
[ 4.924439] [2: swapper/0: 1] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 4.924727] [2: swapper/0: 1] IPVS: Creating netns size=1104 id=0
[ 4.924788] [2: swapper/0: 1] IPVS: ipvs loaded.
[ 4.925719] [2: swapper/0: 1] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.926088] [2: swapper/0: 1] Initializing XFRM netlink socket
[ 4.928098] [2: swapper/0: 1] NET: Registered protocol family 10
[ 4.928937] [2: kworker/2:1: 103] mmc1: mmc_rescan_try_freq: trying to init card at 200000 Hz
[ 4.929598] [2: swapper/0: 1] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.929955] [2: swapper/0: 1] sit: IPv6 over IPv4 tunneling driver
[ 4.931133] [2: swapper/0: 1] NET: Registered protocol family 17
[ 4.931185] [2: swapper/0: 1] NET: Registered protocol family 15
[ 4.931257] [2: swapper/0: 1] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.931317] [2: swapper/0: 1] Bridge firewalling registered
[ 4.931516] [2: swapper/0: 1] Bluetooth: RFCOMM socket layer initialized
[ 4.931551] [2: swapper/0: 1] Bluetooth: RFCOMM ver 1.11
[ 4.931587] [2: swapper/0: 1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.931607] [2: swapper/0: 1] Bluetooth: HIDP socket layer initialized
[ 4.931729] [2: swapper/0: 1] 8021q: 802.1Q VLAN Support v1.8
[ 4.931775] [2: swapper/0: 1] lib80211: common routines for IEEE802.11 drivers
[ 4.931849] [2: swapper/0: 1] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 4.932337] [2: swapper/0: 1] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 4.932378] [2: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 4.932386] [2: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 4.932393] [2: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 4.932494] [2: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
[ 4.932508] [2: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 4.932514] [2: swapper/0: 1] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 4.932524] [2: swapper/0: 1] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 4.932661] [2: swapper/0: 1] [BT_RFKILL]: Enter rfkill_rk_init
[ 4.933441] [2: swapper/0: 1] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[ 4.933514] [2: swapper/0: 1] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[ 4.933562] [2: swapper/0: 1] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[ 4.933609] [2: swapper/0: 1] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[ 4.933633] [2: swapper/0: 1] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 4.933752] [2: swapper/0: 1] [BT_RFKILL]: Request irq for bt wakeup host
[ 4.933845] [2: swapper/0: 1] [BT_RFKILL]: ** disable irq
[ 4.934142] [2: swapper/0: 1] [BT_RFKILL]: bt_default device registered.
[ 4.934315] [2: swapper/0: 1] Key type dns_resolver registered
[ 4.934534] [2: swapper/0: 1] sensor_register_slave:mpu6880_gyro,id=51
[ 4.934710] [2: swapper/0: 1] ov13850 3-0010: driver version: 00.01.03
[ 4.935443] [2: swapper/0: 1] ov13850 3-0010: could not get default pinstate
[ 4.935453] [2: swapper/0: 1] ov13850 3-0010: could not get sleep pinstate
[ 4.935467] [2: swapper/0: 1] ov13850 3-0010: GPIO lookup for consumer pwdn
[ 4.935477] [2: swapper/0: 1] ov13850 3-0010: using device tree for GPIO lookup
[ 4.935530] [2: swapper/0: 1] of_get_named_gpiod_flags: parsed 'pwdn-gpios' property of node '/i2c@ff150000/ov13850@10[0]' - status (0)
[ 4.935764] I[0: kworker/u8:0: 6] mmc2: req done (CMD8): 0: 00000900 00000000 00000000 00000000
[ 4.935773] I[0: kworker/u8:0: 6] mmc2: 512 bytes transferred: 0
[ 4.935827] [2: kworker/2:0: 19] mmc2: MAN_BKOPS_EN bit is not set
[ 4.935847] [2: kworker/2:0: 19] mmc2: starting CMD6 arg 03220101 flags 0000049d
[ 4.935864] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.936199] I[0: swapper/0: 0] mmc2: req done (CMD6): 0: 00000900 00000000 00000000 00000000
[ 4.936238] [2: kworker/2:0: 19] mmc2: starting CMD13 arg 00010000 flags 00000195
[ 4.936252] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.936582] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 4.936622] [2: kworker/2:0: 19] mmc2: starting CMD6 arg 03b70201 flags 0000049d
[ 4.936635] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.936963] I[0: swapper/0: 0] mmc2: req done (CMD6): 0: 00000900 00000000 00000000 00000000
[ 4.936998] [2: kworker/2:0: 19] mmc2: starting CMD13 arg 00010000 flags 00000195
[ 4.937012] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.937341] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 4.937380] [2: kworker/2:0: 19] mmc2: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 8 timing 0
[ 4.937401] [2: kworker/2:0: 19] mmc2: starting CMD8 arg 00000000 flags 000000b5
[ 4.937413] [2: kworker/2:0: 19] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 4.937426] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.937716] [2: swapper/0: 1] ov13850 3-0010: Unexpected sensor id(000000), ret(-5)
[ 4.939123] I[0: swapper/0: 0] mmc2: req done (CMD8): 0: 00000900 00000000 00000000 00000000
[ 4.939132] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 4.940394] [2: kworker/2:0: 19] mmc2: starting CMD6 arg 03b90201 flags 0000049d
[ 4.940410] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.940469] [2: swapper/0: 1] ThumbEE CPU extension supported.
[ 4.940504] [2: swapper/0: 1] Registering SWP/SWPB emulation handler
[ 4.940741] I[0: swapper/0: 0] mmc2: req done (CMD6): 0: 00000900 00000000 00000000 00000000
[ 4.940793] [2: kworker/2:0: 19] mmc2: clock 400000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 8 timing 9
[ 4.940812] [2: kworker/2:0: 19] mmc2: clock 100000000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 8 timing 9
[ 4.940875] [2: kworker/2:0: 19] mmc_host mmc2: Bus speed (slot 0) = 99000000Hz (slot req 100000000Hz, actual 99000000HZ div = 0)
[ 4.940897] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.940908] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.940923] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.940970] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.940977] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.941026] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.941038] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.941052] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.941095] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.941103] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.941152] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.941163] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.941177] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
** 127 printk messages dropped ** [ 4.944400] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
** 134 printk messages dropped ** [ 4.948137] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.948190] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.948198] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.948270] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.948281] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.948295] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.948341] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.948349] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.948395] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.948406] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.948419] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.948462] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.948470] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.948523] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.948535] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.948548] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.948591] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.948598] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.948662] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.948673] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.948687] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.948729] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.948736] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.948801] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.948813] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.948826] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.948868] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.948875] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.948953] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.948964] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.948977] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949023] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949030] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.949075] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949086] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949099] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949142] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949149] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.949206] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949217] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949230] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949272] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949279] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.949321] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949332] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949345] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949387] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949394] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.949503] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949514] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949528] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949569] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949577] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.949645] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949656] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949670] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949735] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949744] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.949819] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949830] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949844] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.949890] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.949898] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.949947] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.949958] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.949972] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950017] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950024] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950070] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950082] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950094] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950137] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950144] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950191] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950202] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950215] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950257] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950265] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950309] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950320] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950334] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950377] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950384] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950431] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950442] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950455] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950497] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950504] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950548] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950558] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950572] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950614] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950621] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950663] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950674] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950687] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950729] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950736] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950782] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950793] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950806] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950848] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950855] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.950897] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.950908] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.950921] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.950962] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.950970] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951025] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951036] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951050] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951091] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951099] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951146] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951157] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951171] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951212] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951220] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951267] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951279] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951293] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951335] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951342] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951387] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951398] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951412] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951454] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951461] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951504] [2: swapper/0: 1] rga2: Driver loaded successfully ver:2.0.00000
[ 4.951541] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951552] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951566] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951608] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951615] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951701] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951713] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951726] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951769] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951776] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.951824] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.951835] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.951848] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.951889] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.951896] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952135] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952147] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952161] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952203] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952210] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952256] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952267] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952280] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952322] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952329] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952377] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952389] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952403] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952445] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952453] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952457] [2: swapper/0: 1] rga2: Module initialized.
[ 4.952510] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952522] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952535] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952577] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952584] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952665] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952676] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952690] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952732] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952739] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952790] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952801] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952814] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952857] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952864] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.952924] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.952935] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.952948] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.952990] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.952997] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.953041] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953052] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953065] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953107] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953128] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.953187] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953198] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953212] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953265] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953273] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.953321] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953332] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953356] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953403] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953412] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.953464] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953475] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953488] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953538] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953547] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.953591] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953602] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953615] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953665] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953673] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.953715] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953726] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953739] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953787] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953794] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.953864] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.953886] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.953899] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.953941] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.953948] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.953992] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954003] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954016] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954107] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954114] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.954157] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954168] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954180] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954224] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954232] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.954279] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954290] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954330] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954372] [2: kworker/2:1: 103] mmc1: starting CMD52 arg 00000c00 flags 00000195
[ 4.954385] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954390] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.954397] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.954430] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954441] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954453] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954501] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954508] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.954555] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954567] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954580] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954627] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954635] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.954679] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954690] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954703] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954750] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954757] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.954801] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954812] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954825] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.954906] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.954914] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.954959] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.954970] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.954983] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955031] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955038] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.955082] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955093] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955106] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955151] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955159] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.955201] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955211] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955224] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955272] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955279] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.955323] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955334] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955346] [0: kworker/u8:0: 6] mali ffa30000.gpu: bin=0
[ 4.955351] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955408] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955416] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.955441] [0: kworker/u8:0: 6] mali ffa30000.gpu: Failed to get leakage
[ 4.955460] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955470] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955483] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955528] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955536] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.955580] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955591] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955604] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955656] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955664] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.955708] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955719] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955732] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955775] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955783] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.955827] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955833] [0: kworker/u8:0: 6] mali ffa30000.gpu: Failed to get pvtm
[ 4.955843] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955856] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.955903] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.955911] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.955929] [0: kworker/u8:0: 6] mali ffa30000.gpu: bin-scale=55
[ 4.955954] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.955965] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.955978] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956024] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956032] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956076] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956087] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956100] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956147] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956154] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956198] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956209] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956222] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956266] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956274] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956318] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956329] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956341] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956391] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956398] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956428] I[0: kworker/u8:0: 6] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 4.956441] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956464] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956476] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956515] [2: kworker/2:1: 103] mmc1: starting CMD52 arg 80000c08 flags 00000195
[ 4.956526] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956532] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.956538] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956571] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956582] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956594] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956638] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956646] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956690] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956702] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956714] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956760] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956768] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956811] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956823] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956835] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956879] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.956886] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.956930] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.956940] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.956953] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.956997] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957005] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.957047] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957057] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957070] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957112] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957120] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.957163] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957173] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957186] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957259] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957267] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.957304] [0: kworker/u8:0: 6] mali ffa30000.gpu: avs=0
[ 4.957315] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957326] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957339] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957384] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957392] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.957436] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957447] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957458] [0: kworker/u8:0: 6] W : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_config_rk.c; [Line] : 114; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 4.957463] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957509] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957516] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.957565] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957576] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957590] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957642] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957650] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.957695] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957706] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957719] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957789] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957797] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.957841] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957864] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.957877] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.957927] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.957935] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.957978] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.957989] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958002] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958092] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958100] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.958148] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958160] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958176] I[0: rcu_sched: 7] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 4.958182] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958237] [2: kworker/2:1: 103] mmc1: clock 200000Hz busmode 2 powermode 2 cs 1 Vdd 21 width 1 timing 0
[ 4.958250] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958258] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.958282] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958293] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958307] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958355] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958363] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.958412] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958423] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958437] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958501] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958509] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.958555] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958566] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958580] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958628] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958636] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.958679] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958690] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958703] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958748] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958756] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.958797] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958808] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958821] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958865] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958872] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.958914] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.958925] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.958935] [0: kworker/u8:0: 6] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 4.958941] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.958985] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.958992] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.959036] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959047] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.959081] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.959131] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.959139] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.959211] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959240] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.959254] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.959302] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.959310] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.959355] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959366] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.959397] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.959446] I[0: kworker/0:1: 34] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.959454] I[0: kworker/0:1: 34] mmc2: 128 bytes transferred: 0
[ 4.959500] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959535] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.959566] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.959606] [2: kworker/2:1: 103] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 4.959619] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.959625] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.959631] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.959672] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959683] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.959696] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.959766] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.959774] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.959824] [0: kworker/u8:0: 6] mali ffa30000.gpu: Protected mode not available
[ 4.959845] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959856] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.959870] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.959917] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.959926] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.959965] I[0: kworker/u8:0: 6] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 4.959975] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.959998] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960011] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960058] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960066] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960112] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960123] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960137] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960232] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960241] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960285] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960297] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960310] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960360] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960368] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960412] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960423] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960436] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960481] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960510] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960555] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960567] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960580] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960628] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960636] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960678] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960689] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960702] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960744] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960751] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960794] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960805] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960818] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960866] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960874] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.960917] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.960928] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.960941] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.960987] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.960995] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961040] [0: kworker/u8:0: 6] mali ffa30000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[ 4.961049] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961060] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961073] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961118] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961126] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961169] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961179] [0: kworker/u8:0: 6] mali ffa30000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 4.961189] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961203] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961250] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961258] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961322] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961334] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961347] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961388] [2: kworker/2:1: 103] mmc1: clock 200000Hz busmode 2 powermode 2 cs 0 Vdd 21 width 1 timing 0
[ 4.961400] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961408] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961429] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961439] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961453] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961497] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961504] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961550] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961561] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961574] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961621] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961629] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961673] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961684] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961697] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961709] [0: kworker/u8:0: 6] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 4.961742] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961750] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.961794] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961806] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961819] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.961869] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.961877] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.961923] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.961933] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.961947] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962000] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962009] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.962053] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962085] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962099] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962150] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962158] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.962206] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962218] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962231] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962280] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962288] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.962332] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962343] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962356] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962407] I[0: kthreadd: 2] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962415] I[0: kthreadd: 2] mmc2: 128 bytes transferred: 0
[ 4.962460] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962471] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962484] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962539] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962547] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.962591] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962602] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962615] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962662] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962670] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.962701] [2: kworker/2:1: 103] mmc1: starting CMD8 arg 000001aa flags 000002f5
[ 4.962715] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.962756] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962767] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962779] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962825] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962833] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.962876] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.962887] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.962901] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.962946] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.962954] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.962997] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963008] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963021] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963068] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963076] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.963118] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963129] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963142] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963184] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963191] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.963234] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963244] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963257] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963303] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963310] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.963354] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963364] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963378] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963424] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963432] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.963473] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963484] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963497] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963541] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963549] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.963593] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963604] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963618] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963698] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963706] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.963750] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963760] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963774] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963782] [0: kworker/u8:0: 6] mali ffa30000.gpu: Probed as mali0
[ 4.963834] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963842] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.963912] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.963924] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.963937] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.963986] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.963993] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964037] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964047] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964061] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964105] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964112] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964154] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964165] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964178] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964221] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964228] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964269] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964280] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964293] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964332] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964346] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964365] I[0: kworker/u8:0: 6] mmc1: req done (CMD8): -110: 00000000 00000000 00000000 00000000
[ 4.964408] [2: kworker/2:1: 103] mmc1: starting CMD5 arg 00000000 flags 000002e1
[ 4.964422] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.964453] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964464] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964476] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964528] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964535] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964580] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964591] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964604] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964670] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964678] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964722] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964733] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964746] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964807] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964814] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964861] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964872] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.964885] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.964929] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.964937] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.964979] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.964990] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965002] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965046] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965053] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965096] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965107] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965120] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965163] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965170] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965213] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965224] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965237] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965279] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965286] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965328] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965338] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965351] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965392] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965399] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965441] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965452] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965480] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965522] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965529] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965571] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965582] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965594] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965635] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965642] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965683] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965694] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965707] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965748] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965755] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965796] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965807] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965820] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965860] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965867] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.965911] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.965922] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.965935] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.965977] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.965984] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966026] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966037] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966050] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966096] [2: kworker/2:1: 103] mmc1: req failed (CMD5): -110, retrying...
[ 4.966106] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966112] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.966118] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966150] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966161] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966174] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966215] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966222] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966265] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966276] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966289] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966332] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966340] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966382] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966393] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966406] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966448] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966455] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966497] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966508] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966521] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966567] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966574] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966617] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966628] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966642] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966716] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966724] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966767] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966778] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966791] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966835] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966843] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.966886] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.966897] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.966910] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.966954] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.966962] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967006] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967017] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967030] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967088] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967095] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967139] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967150] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967163] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967208] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967216] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967258] [2: kworker/2:0: 19] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 4.967260] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967271] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967284] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967328] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967336] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967379] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967389] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967403] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967449] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967457] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967500] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967512] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967525] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967573] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967581] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 4.967625] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967636] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967649] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967697] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967712] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967755] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 4.967770] [2: kworker/2:1: 103] mmc1: req failed (CMD5): -110, retrying...
[ 4.967778] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: TX delay(0x1d).
[ 4.967783] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.967793] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: RX delay(0x16).
[ 4.967814] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967825] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967834] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[ 4.967840] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.967884] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.967892] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.967937] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.967948] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.967961] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968004] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968012] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968085] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968097] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968111] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968161] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968169] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968216] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968227] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968239] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968284] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968291] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968334] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968345] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968358] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968402] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968410] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968452] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968463] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968477] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[ 4.968483] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968489] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 4.968526] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968534] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968576] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968587] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968600] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968640] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968648] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968689] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968700] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968712] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968751] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968758] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968799] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968810] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968823] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968861] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968868] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.968909] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.968919] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.968932] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.968970] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.968977] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969018] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969029] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969041] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969079] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969086] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969128] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969138] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969151] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969189] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969196] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969236] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969247] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969260] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969297] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969304] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969345] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969356] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969369] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969406] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969418] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969457] [2: kworker/2:1: 103] mmc1: req failed (CMD5): -110, retrying...
[ 4.969470] I[2: kworker/2:1: 103] mmc_host mmc1: card is present
[ 4.969508] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969519] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969532] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969570] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969577] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969619] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969630] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969642] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969680] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969687] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969729] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969739] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969752] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969790] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969797] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969838] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969850] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969862] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.969900] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.969907] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.969947] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.969958] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.969971] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970009] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970015] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970056] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970067] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970079] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970117] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970124] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970164] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970175] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970188] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970225] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970232] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970273] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970284] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970296] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970334] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970341] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970381] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970392] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970405] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970448] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970455] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970496] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970507] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970520] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970558] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970565] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970606] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970617] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970629] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970668] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970675] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970715] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970725] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970738] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970776] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970783] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970825] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970836] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970849] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970886] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.970893] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.970934] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.970944] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.970957] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.970995] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.971002] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.971042] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.971053] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.971066] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.971107] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.971114] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.971131] I[0: kworker/u8:0: 6] mmc1: req done (CMD5): -110: 00000000 00000000 00000000 00000000
[ 4.971193] [2: kworker/2:1: 103] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 4.971251] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.971262] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.971276] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.971315] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.971322] I[0: kworker/u8:0: 6] mmc2: 128 bytes transferred: 0
[ 4.971367] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.971378] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.971391] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.971445] I[0: kworker/u8:0: 6] dwmmc_rockchip ff0f0000.dwmmc: data error, status 0x00000088
[ 4.971475] I[0: kworker/u8:0: 6] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 4.971483] I[0: kworker/u8:0: 6] mmc2: 0 bytes transferred: -84
[ 4.971523] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 4.971535] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 4.971547] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 4.973598] [0: kworker/u8:0: 6] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 4.973777] [0: kworker/u8:0: 6] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 4.973782] [0: kworker/u8:0: 6] Ring mode enabled
[ 4.973790] [0: kworker/u8:0: 6] DMA HW capability register supported
[ 4.973791] [0: kworker/u8:0: 6] Normal descriptors
[ 4.973796] [0: kworker/u8:0: 6] RX Checksum Offload Engine supported (type 2)
[ 4.973800] [0: kworker/u8:0: 6] Wake-Up On Lan supported
[ 4.973889] [0: kworker/u8:0: 6] Enable RX Mitigation via HW Watchdog Timer
[ 4.974134] [0: kworker/u8:0: 6] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@ff290000[0]' - status (0)
[ 4.979351] [2: kworker/u8:1: 101] devfreq ffa30000.gpu: Couldn't update frequency transition information.
[ 5.148098] I[0: ksoftirqd/0: 3] dwmmc_rockchip ff0f0000.dwmmc: data error, status 0x00000200
[ 5.148147] I[0: ksoftirqd/0: 3] mmc2: req done (CMD21): -84: 00c01b00 00000000 00000000 00000000
[ 5.148155] I[0: ksoftirqd/0: 3] mmc2: 0 bytes transferred: -110
[ 5.148211] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.148224] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.148240] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.148337] I[0: swapper/0: 0] dwmmc_rockchip ff0f0000.dwmmc: data error, status 0x00000088
[ 5.148369] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.148376] I[0: swapper/0: 0] mmc2: 0 bytes transferred: -84
[ 5.148423] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.148435] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.148448] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.148494] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00400900 00000000 00000000 00000000
[ 5.148502] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.148546] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.148557] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.148570] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.148613] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.148620] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.148662] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.148674] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.148686] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.148727] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.148734] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.148776] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.148787] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.148800] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.148842] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.148849] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.148890] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.148902] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.148915] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.148956] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.148963] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149005] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149015] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149028] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149069] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149076] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149118] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149129] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149142] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149183] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149190] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149231] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149242] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149255] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149296] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149303] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149345] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149356] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149368] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149409] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149416] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149458] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149469] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149482] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149527] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149534] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149575] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149586] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149599] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149640] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149647] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149688] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149699] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149713] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149752] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149760] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149801] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149813] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149825] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149865] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149872] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.149913] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.149924] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.149937] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.149977] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.149984] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150025] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150036] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150049] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150089] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150097] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150158] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150179] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150196] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150240] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150247] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150291] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150302] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150315] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150355] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150363] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150404] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150415] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150428] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150470] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150477] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150520] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150531] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150544] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150585] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150593] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150634] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150645] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150657] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150697] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150704] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150745] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150756] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150769] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150810] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150816] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150857] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150868] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150881] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.150922] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.150929] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.150970] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.150981] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.150994] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151034] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151041] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151082] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151093] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151106] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151147] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151154] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151194] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151206] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151219] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151259] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151266] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151308] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151319] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151332] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151372] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151379] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151420] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151430] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151444] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151484] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151491] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151533] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151544] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151556] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151597] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151604] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151646] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151656] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151669] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151709] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151717] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151758] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151768] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151781] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151822] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151829] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151871] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151882] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.151895] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.151934] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.151942] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.151983] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.151994] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152006] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152046] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152053] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152095] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152106] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152119] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152159] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152167] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152208] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152219] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152231] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152271] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152279] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152320] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152331] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152343] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152384] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152391] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152431] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152442] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152454] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152496] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152503] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152544] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152555] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152567] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152608] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152615] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152657] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152668] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152681] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152721] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152728] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152769] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152780] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152792] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152833] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152840] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152882] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.152893] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.152906] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.152947] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.152954] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.152995] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153006] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153020] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153060] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153067] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153107] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153117] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153131] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153175] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153182] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153222] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153233] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153246] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153287] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153294] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153335] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153346] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153359] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153399] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153406] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153447] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153459] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153471] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153512] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153519] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153559] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153570] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153583] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153624] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153631] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153671] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153682] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153695] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153736] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153743] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153785] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153796] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153809] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153850] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153857] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.153898] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.153908] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.153921] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.153961] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.153969] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154010] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154021] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154034] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154074] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154082] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154124] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154134] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154147] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154188] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154195] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154236] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154247] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154259] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154300] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154308] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154348] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154359] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154372] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154412] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154419] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154461] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154472] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154485] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154526] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154533] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154574] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154585] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154598] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154638] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154645] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154687] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154698] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154710] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154751] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154758] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154800] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154811] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154824] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154865] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154872] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.154913] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.154923] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.154936] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.154977] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.154984] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.155026] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.155037] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.155050] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.155091] I[0: swapper/0: 0] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.155098] I[0: swapper/0: 0] mmc2: 128 bytes transferred: 0
[ 5.155139] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.155150] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.155163] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.339456] I[1: kworker/1:1: 75] dwmmc_rockchip ff0f0000.dwmmc: data error, status 0x00000200
[ 5.339483] I[1: kworker/1:1: 75] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.339492] I[1: kworker/1:1: 75] mmc2: 0 bytes transferred: -110
[ 5.339545] [2: kworker/2:0: 19] mmc2: starting CMD21 arg 00000000 flags 00000035
[ 5.339557] [2: kworker/2:0: 19] mmc2: blksz 128 blocks 1 flags 00000200 tsac 150 ms nsac 0
[ 5.339571] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.533559] I[1: kworker/1:1: 75] dwmmc_rockchip ff0f0000.dwmmc: data error, status 0x00000200
[ 5.533584] I[1: kworker/1:1: 75] mmc2: req done (CMD21): 0: 00000900 00000000 00000000 00000000
[ 5.533592] I[1: kworker/1:1: 75] mmc2: 0 bytes transferred: -110
[ 5.533654] [2: kworker/2:0: 19] dwmmc_rockchip ff0f0000.dwmmc: Good phase range 0-232 (233 len)
[ 5.533669] [2: kworker/2:0: 19] dwmmc_rockchip ff0f0000.dwmmc: Good phase range 293-351 (59 len)
[ 5.533684] [2: kworker/2:0: 19] dwmmc_rockchip ff0f0000.dwmmc: Best phase range 0-232 (233 len)
[ 5.533695] [2: kworker/2:0: 19] dwmmc_rockchip ff0f0000.dwmmc: Successfully tuned phase to 116
[ 5.533716] [2: kworker/2:0: 19] mmc2: starting CMD6 arg 03a10101 flags 0000049d
[ 5.533729] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.533765] I[0: swapper/0: 0] mmc2: req done (CMD6): 0: 00000900 00000000 00000000 00000000
[ 5.533813] [2: kworker/2:0: 19] mmc2: starting CMD13 arg 00010000 flags 00000195
[ 5.533826] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.533853] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.533890] [2: kworker/2:0: 19] mmc2: starting CMD6 arg 03210101 flags 0000049d
[ 5.533903] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.533928] I[0: swapper/0: 0] mmc2: req done (CMD6): 0: 00000900 00000000 00000000 00000000
[ 5.533962] [2: kworker/2:0: 19] mmc2: starting CMD13 arg 00010000 flags 00000195
[ 5.533974] I[2: kworker/2:0: 19] mmc_host mmc2: card is present
[ 5.533998] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.534043] [2: kworker/2:0: 19] mmc2: new HS200 MMC card at address 0001
[ 5.535032] [2: kworker/2:0: 19] mmcblk2: mmc2:0001 AGND3R 14.6 GiB
[ 5.535491] [2: kworker/2:0: 19] mmcblk2boot0: mmc2:0001 AGND3R partition 1 4.00 MiB
[ 5.535940] [2: kworker/2:0: 19] mmcblk2boot1: mmc2:0001 AGND3R partition 2 4.00 MiB
[ 5.536378] [2: kworker/2:0: 19] mmcblk2rpmb: mmc2:0001 AGND3R partition 3 4.00 MiB
[ 5.537396] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.537408] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 00000000 flags 000000b5
[ 5.537419] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.537428] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.537445] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.537676] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.537687] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.537695] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.537705] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.537897] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.537907] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 00000008 flags 000000b5
[ 5.537918] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.537926] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.537940] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.538129] I[0: ksoftirqd/0: 3] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.538140] I[0: ksoftirqd/0: 3] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.538148] I[0: ksoftirqd/0: 3] mmc2: 4096 bytes transferred: 0
[ 5.538158] I[0: ksoftirqd/0: 3] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.538314] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.538323] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 00000010 flags 000000b5
[ 5.538335] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.538343] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.538357] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.538522] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.538533] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.538540] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.538550] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.538691] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.538700] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 00000018 flags 000000b5
[ 5.538712] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.538719] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.538733] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.538881] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.538891] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.538898] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.538908] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.539043] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.539052] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 00000020 flags 000000b5
[ 5.539063] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.539071] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.539084] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.539241] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.539251] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.539258] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.539268] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.539501] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.539511] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 01d1eff8 flags 000000b5
[ 5.539522] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.539530] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.539543] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.539749] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.539759] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.539766] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.539776] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.539916] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.539925] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 01d1efd8 flags 000000b5
[ 5.539935] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.539943] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.539956] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.540101] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.540111] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.540118] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.540128] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.540254] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.540264] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 01d1efe0 flags 000000b5
[ 5.540274] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.540281] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.540295] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.540452] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.540462] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.540469] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.540479] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.540616] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.540626] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 01d1efe8 flags 000000b5
[ 5.540636] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.540644] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.540656] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.540803] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.540812] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.540819] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.540829] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.540971] [3: mmcqd/2: 122] <mmc2: starting CMD23 arg 00000008 flags 00000015>
[ 5.540994] [3: mmcqd/2: 122] mmc2: starting CMD18 arg 01d1eff0 flags 000000b5
[ 5.541015] [3: mmcqd/2: 122] mmc2: blksz 512 blocks 8 flags 00000200 tsac 150 ms nsac 1000
[ 5.541035] [3: mmcqd/2: 122] mmc2: CMD12 arg 00000000 flags 00000095
[ 5.541051] I[3: mmcqd/2: 122] mmc_host mmc2: card is present
[ 5.541209] I[0: swapper/0: 0] mmc2: req done <CMD23>: 0: 00000900 00000000 00000000 00000000
[ 5.541218] I[0: swapper/0: 0] mmc2: req done (CMD18): 0: 00000900 00000000 00000000 00000000
[ 5.541225] I[0: swapper/0: 0] mmc2: 4096 bytes transferred: 0
[ 5.541235] I[0: swapper/0: 0] mmc2: (CMD12): 0: 00000000 00000000 00000000 00000000
[ 5.541540] [2: kworker/2:0: 19] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[ 5.548392] [2: kworker/2:0: 19] Unable to handle kernel NULL pointer dereference at virtual address 00000044
[ 5.548399] [2: kworker/2:0: 19] pgd = c0004000
[ 5.548408] [2: kworker/2:0: 19] [00000044] *pgd=00000000
[ 5.548420] [2: kworker/2:0: 19] Internal error: Oops: 5 [#1] SMP ARM
[ 5.548429] [2: kworker/2:0: 19] Modules linked in:
[ 5.548443] [2: kworker/2:0: 19] CPU: 2 PID: 19 Comm: kworker/2:0 Not tainted 4.4.194 #1
[ 5.548448] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 5.548473] [2: kworker/2:0: 19] Workqueue: events_freezable mmc_rescan
[ 5.548481] [2: kworker/2:0: 19] task: ee991d00 task.stack: ee9a0000
[ 5.548496] [2: kworker/2:0: 19] PC is at mmc_blk_drm_part_get+0x28/0x48
[ 5.548504] [2: kworker/2:0: 19] LR is at mmc_blk_emmc_add+0x24/0x13c
[ 5.548517] [2: kworker/2:0: 19] pc : [<c04ccc50>] lr : [<c04ccf04>] psr: 20000013
[ 5.548517] [2: kworker/2:0: 19] sp : ee9a1c70 ip : ee9a1c80 fp : ee9a1c7c
[ 5.548523] [2: kworker/2:0: 19] r10: edb93f00 r9 : ee9a1cd6 r8 : edb21808
[ 5.548531] [2: kworker/2:0: 19] r7 : 00000000 r6 : edb92c00 r5 : 00000348 r4 : edb21800
[ 5.548538] [2: kworker/2:0: 19] r3 : edb92c00 r2 : 00000001 r1 : 00000348 r0 : fffffd18
[ 5.548549] [2: kworker/2:0: 19] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 5.548557] [2: kworker/2:0: 19] Control: 10c5387d Table: 0000406a DAC: 00000051
[ 5.548565] [2: kworker/2:0: 19] Process kworker/2:0 (pid: 19, stack limit = 0xee9a0258)
[ 5.548572] [2: kworker/2:0: 19] Stack: (0xee9a1c70 to 0xee9a2000)
[ 5.548586] [2: kworker/2:0: 19] 1c60: ee9a1ca4 ee9a1c80 c04ccf04 c04ccc34
[ 5.548603] [2: kworker/2:0: 19] 1c80: edb21800 edb92c00 edb92c00 00000000 edb21808 ee9a1cd6 ee9a1d0c ee9a1ca8
[ 5.548620] [2: kworker/2:0: 19] 1ca0: c0989f80 c04cceec 00000003 ee9a1cd6 0000000a c148597c ee9a1cec edb92f00
[ 5.548636] [2: kworker/2:0: 19] 1cc0: edb21a2c 00000003 edb21808 362e3431 42694720 2e340000 4d203030 00004269
[ 5.548653] [2: kworker/2:0: 19] 1ce0: ee9a1cfc edb21808 c13bc930 c14859a0 00000000 c14007c0 00000002 c148597c
[ 5.548670] [2: kworker/2:0: 19] 1d00: ee9a1d1c ee9a1d10 c097bccc c0989e08 ee9a1d5c ee9a1d20 c0594d28 c097bcb4
[ 5.548686] [2: kworker/2:0: 19] 1d20: 00000000 c0cf4634 60000013 ee9a1d80 ee9a1d54 c13bc930 ee9a1da8 edb21808
[ 5.548703] [2: kworker/2:0: 19] 1d40: edb2183c 00000000 c13bc538 c148597c ee9a1d7c ee9a1d60 c0594fd4 c0594a60
[ 5.548720] [2: kworker/2:0: 19] 1d60: 00000000 ee9a1da8 c0594f60 edb2183c ee9a1da4 ee9a1d80 c0592d5c c0594f6c
[ 5.548736] [2: kworker/2:0: 19] 1d80: ee031c94 edb06044 edb21808 edb21808 c13bc454 00000001 ee9a1dcc ee9a1da8
[ 5.548753] [2: kworker/2:0: 19] 1da0: c0594944 c0592cd0 edb21808 00000001 edb21808 c13bc454 edb21808 edb21008
[ 5.548769] [2: kworker/2:0: 19] 1dc0: ee9a1ddc ee9a1dd0 c0595164 c05948a0 ee9a1dfc ee9a1de0 c0593de8 c0595154
[ 5.548786] [2: kworker/2:0: 19] 1de0: edb21808 00000000 edb21810 edb21008 ee9a1e3c ee9a1e00 c0591e00 c0593dbc
[ 5.548803] [2: kworker/2:0: 19] 1e00: ee9a1e3c ee9a1e10 c097a600 c09c41b4 edb21000 edb21800 edb21808 c0fb932b
[ 5.548820] [2: kworker/2:0: 19] 1e20: 00000001 c0fb932b c0de4ca4 c13f65b8 ee9a1e7c ee9a1e40 c097c248 c05919b0
[ 5.548836] [2: kworker/2:0: 19] 1e40: c0fb932b c0fb932b c0fb932b c0fde98d 00000001 ee9a1e60 c0978658 edb21000
[ 5.548853] [2: kworker/2:0: 19] 1e60: 00000000 00061a80 00000000 c0de4c94 ee9a1e9c ee9a1e80 c097fab8 c097c0e8
[ 5.548869] [2: kworker/2:0: 19] 1e80: 00000000 c0ff8080 edb212d8 edb21000 ee9a1ec4 ee9a1ea0 c097b888 c097f9b8
[ 5.548886] [2: kworker/2:0: 19] 1ea0: ee88d680 edb212d8 eef97f40 00000000 eef9bb00 edb212dc ee9a1f04 ee9a1ec8
[ 5.548911] [2: kworker/2:0: 19] 1ec0: c0135570 c097b554 ee9a1f04 ee9a1ed8 c0168c24 00000000 00000000 ee88d680
[ 5.548927] [2: kworker/2:0: 19] 1ee0: eef97f40 eef97f40 c1302100 eef97f60 ee88d698 00000008 ee9a1f3c ee9a1f08
[ 5.548944] [2: kworker/2:0: 19] 1f00: c01365f8 c013535c ee88d680 c01362c0 00000000 ee9a0000 ee89bc80 00000000
[ 5.548960] [2: kworker/2:0: 19] 1f20: ee88d680 c01362c0 00000000 00000000 ee9a1fac ee9a1f40 c013b284 c01362cc
[ 5.548976] [2: kworker/2:0: 19] 1f40: ee9a1f8c 00000000 c0144e6c ee88d680 00000000 00000000 dead4ead ffffffff
[ 5.548992] [2: kworker/2:0: 19] 1f60: ffffffff ee9a1f64 ee9a1f64 00000000 00000000 dead4ead ffffffff ffffffff
[ 5.549008] [2: kworker/2:0: 19] 1f80: ee9a1f80 ee9a1f80 c01490b8 ee89bc80 c013b180 00000000 00000000 00000000
[ 5.549024] [2: kworker/2:0: 19] 1fa0: 00000000 ee9a1fb0 c0107e68 c013b18c 00000000 00000000 00000000 00000000
[ 5.549038] [2: kworker/2:0: 19] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.549053] [2: kworker/2:0: 19] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 5.549084] [2: kworker/2:0: 19] [<c04ccc50>] (mmc_blk_drm_part_get) from [<c04ccf04>] (mmc_blk_emmc_add+0x24/0x13c)
[ 5.549106] [2: kworker/2:0: 19] [<c04ccf04>] (mmc_blk_emmc_add) from [<c0989f80>] (mmc_blk_probe+0x184/0x314)
[ 5.549130] [2: kworker/2:0: 19] [<c0989f80>] (mmc_blk_probe) from [<c097bccc>] (mmc_bus_probe+0x24/0x28)
[ 5.549156] [2: kworker/2:0: 19] [<c097bccc>] (mmc_bus_probe) from [<c0594d28>] (driver_probe_device+0x2d4/0x424)
[ 5.549181] [2: kworker/2:0: 19] [<c0594d28>] (driver_probe_device) from [<c0594fd4>] (__device_attach_driver+0x74/0x9c)
[ 5.549203] [2: kworker/2:0: 19] [<c0594fd4>] (__device_attach_driver) from [<c0592d5c>] (bus_for_each_drv+0x98/0xa0)
[ 5.549223] [2: kworker/2:0: 19] [<c0592d5c>] (bus_for_each_drv) from [<c0594944>] (__device_attach+0xb0/0x140)
[ 5.549245] [2: kworker/2:0: 19] [<c0594944>] (__device_attach) from [<c0595164>] (device_initial_probe+0x1c/0x20)
[ 5.549265] [2: kworker/2:0: 19] [<c0595164>] (device_initial_probe) from [<c0593de8>] (bus_probe_device+0x38/0x90)
[ 5.549285] [2: kworker/2:0: 19] [<c0593de8>] (bus_probe_device) from [<c0591e00>] (device_add+0x45c/0x54c)
[ 5.549306] [2: kworker/2:0: 19] [<c0591e00>] (device_add) from [<c097c248>] (mmc_add_card+0x16c/0x268)
[ 5.549328] [2: kworker/2:0: 19] [<c097c248>] (mmc_add_card) from [<c097fab8>] (mmc_attach_mmc+0x10c/0x158)
[ 5.549348] [2: kworker/2:0: 19] [<c097fab8>] (mmc_attach_mmc) from [<c097b888>] (mmc_rescan+0x340/0x358)
[ 5.549369] [2: kworker/2:0: 19] [<c097b888>] (mmc_rescan) from [<c0135570>] (process_one_work+0x220/0x424)
[ 5.549387] [2: kworker/2:0: 19] [<c0135570>] (process_one_work) from [<c01365f8>] (worker_thread+0x338/0x430)
[ 5.549406] [2: kworker/2:0: 19] [<c01365f8>] (worker_thread) from [<c013b284>] (kthread+0x104/0x114)
[ 5.549428] [2: kworker/2:0: 19] [<c013b284>] (kthread) from [<c0107e68>] (ret_from_fork+0x14/0x2c)
[ 5.549445] [2: kworker/2:0: 19] Code: 159302e8 1a000005 e3a00000 e89da800 (e590232c)
[ 5.549455] [2: kworker/2:0: 19] ---[ end trace 7d359c806f6b5bdd ]---
[ 5.582836] [2: kworker/2:0: 19] Unable to handle kernel paging request at virtual address ffffffe0
[ 5.582842] [2: kworker/2:0: 19] pgd = c0004000
[ 5.582857] [2: kworker/2:0: 19] [ffffffe0] *pgd=2fffd861, *pte=00000000, *ppte=00000000
[ 5.582869] [2: kworker/2:0: 19] Internal error: Oops: 37 [#2] SMP ARM
[ 5.582877] [2: kworker/2:0: 19] Modules linked in:
[ 5.582890] [2: kworker/2:0: 19] CPU: 2 PID: 19 Comm: kworker/2:0 Tainted: G D 4.4.194 #1
[ 5.582895] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 5.582917] [2: kworker/2:0: 19] task: ee991d00 task.stack: ee9a0000
[ 5.582933] [2: kworker/2:0: 19] PC is at kthread_data+0x18/0x20
[ 5.582943] [2: kworker/2:0: 19] LR is at wq_worker_sleeping+0x1c/0xdc
[ 5.582956] [2: kworker/2:0: 19] pc : [<c013ba24>] lr : [<c0136978>] psr: 20000193
[ 5.582956] [2: kworker/2:0: 19] sp : ee9a19f8 ip : ee9a1a08 fp : ee9a1a04
[ 5.582962] [2: kworker/2:0: 19] r10: 00000002 r9 : eef98440 r8 : c1307edc
[ 5.582970] [2: kworker/2:0: 19] r7 : ee9921d4 r6 : c12bc440 r5 : ee991d00 r4 : 00000002
[ 5.582977] [2: kworker/2:0: 19] r3 : 00000000 r2 : eef98440 r1 : 00000002 r0 : ee991d00
[ 5.582987] [2: kworker/2:0: 19] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 5.582996] [2: kworker/2:0: 19] Control: 10c5387d Table: 0000406a DAC: 00000051
[ 5.583003] [2: kworker/2:0: 19] Process kworker/2:0 (pid: 19, stack limit = 0xee9a0258)
[ 5.583011] [2: kworker/2:0: 19] Stack: (0xee9a19f8 to 0xee9a2000)
[ 5.583021] [2: kworker/2:0: 19] 19e0: ee9a1a1c ee9a1a08
[ 5.583038] [2: kworker/2:0: 19] 1a00: c0136978 c013ba18 eef98440 ee991d00 ee9a1a64 ee9a1a20 c0cf0ad8 c0136968
[ 5.583055] [2: kworker/2:0: 19] 1a20: 00000000 edb4fbe0 edb4fbec 60000113 c0cf0e88 00000000 c040716c ee9a0000
[ 5.583072] [2: kworker/2:0: 19] 1a40: ee9a1634 ee9a1634 ee9a1a88 ee9a1a88 00000454 00000000 ee9a1a7c ee9a1a68
[ 5.583088] [2: kworker/2:0: 19] 1a60: c0cf0e88 c0cf06dc ee991d00 ee9a1634 ee9a1aa4 ee9a1a80 c01208d8 c0cf0dec
[ 5.583105] [2: kworker/2:0: 19] 1a80: c0f0c664 c130ea38 ee9a1a88 ee9a1a88 c011e3bc 00000000 ee9a1ae4 ee9a1aa8
[ 5.583122] [2: kworker/2:0: 19] 1aa0: c010c338 c011ff8c ee9a0258 0000000b c0115e38 60000113 c0fd33d1 00000044
[ 5.583139] [2: kworker/2:0: 19] 1ac0: ee9a1c20 00000005 00000000 ee991d00 00000000 00000005 ee9a1afc ee9a1ae8
[ 5.583155] [2: kworker/2:0: 19] 1ae0: c011aac0 c010c0b0 ee9a1c20 ee9a1c20 ee9a1b54 ee9a1b00 c01161bc c011aa68
[ 5.583171] [2: kworker/2:0: 19] 1b00: ee9a1b2c 00000012 ee887f88 000046ff 00000000 edb14704 edb14700 00000000
[ 5.583188] [2: kworker/2:0: 19] 1b20: ee9a1b84 ee9a1b30 c0423c00 00000005 00000005 c130ef9c ee9a1c20 edb21808
[ 5.583204] [2: kworker/2:0: 19] 1b40: ee9a1cd6 edb93f00 ee9a1b74 ee9a1b58 c0116358 c0115ecc 00000005 00000044
[ 5.583221] [2: kworker/2:0: 19] 1b60: c130ef9c ee9a1c20 ee9a1c1c ee9a1b78 c0101224 c0116338 00000000 c13f6278
[ 5.583238] [2: kworker/2:0: 19] 1b80: ee9a1ba4 ee9a1b90 c02a03d4 c02a147c ed61d500 c02a148c ee9a1bc4 ee9a1ba8
[ 5.583254] [2: kworker/2:0: 19] 1ba0: c02a148c c0cf28b8 ed61d500 00000000 00000000 00000000 ee9a1bfc ee9a1bc8
[ 5.583271] [2: kworker/2:0: 19] 1bc0: c02a1670 c02a1450 edb93724 c02a1438 ed619c30 ed61d500 ee9a1bfc ee9a1be8
[ 5.583288] [2: kworker/2:0: 19] 1be0: c02a1438 ed61d500 c0d147d8 edb93724 ee9a1c14 ee9a1c00 c02a2c44 c02a1548
[ 5.583304] [2: kworker/2:0: 19] 1c00: c04ccc50 20000013 ffffffff ee9a1c54 ee9a1c7c ee9a1c20 c010ca60 c01011e8
[ 5.583321] [2: kworker/2:0: 19] 1c20: fffffd18 00000348 00000001 edb92c00 edb21800 00000348 edb92c00 00000000
[ 5.583337] [2: kworker/2:0: 19] 1c40: edb21808 ee9a1cd6 edb93f00 ee9a1c7c ee9a1c80 ee9a1c70 c04ccf04 c04ccc50
[ 5.583354] [2: kworker/2:0: 19] 1c60: 20000013 ffffffff 00000051 c04ccf04 ee9a1ca4 ee9a1c80 c04ccf04 c04ccc34
[ 5.583371] [2: kworker/2:0: 19] 1c80: edb21800 edb92c00 edb92c00 00000000 edb21808 ee9a1cd6 ee9a1d0c ee9a1ca8
[ 5.583387] [2: kworker/2:0: 19] 1ca0: c0989f80 c04cceec 00000003 ee9a1cd6 0000000a c148597c ee9a1cec edb92f00
[ 5.583404] [2: kworker/2:0: 19] 1cc0: edb21a2c 00000003 edb21808 362e3431 42694720 2e340000 4d203030 00004269
[ 5.583420] [2: kworker/2:0: 19] 1ce0: ee9a1cfc edb21808 c13bc930 c14859a0 00000000 c14007c0 00000002 c148597c
[ 5.583437] [2: kworker/2:0: 19] 1d00: ee9a1d1c ee9a1d10 c097bccc c0989e08 ee9a1d5c ee9a1d20 c0594d28 c097bcb4
[ 5.583454] [2: kworker/2:0: 19] 1d20: 00000000 c0cf4634 60000013 ee9a1d80 ee9a1d54 c13bc930 ee9a1da8 edb21808
[ 5.583470] [2: kworker/2:0: 19] 1d40: edb2183c 00000000 c13bc538 c148597c ee9a1d7c ee9a1d60 c0594fd4 c0594a60
[ 5.583487] [2: kworker/2:0: 19] 1d60: 00000000 ee9a1da8 c0594f60 edb2183c ee9a1da4 ee9a1d80 c0592d5c c0594f6c
[ 5.583503] [2: kworker/2:0: 19] 1d80: ee031c94 edb06044 edb21808 edb21808 c13bc454 00000001 ee9a1dcc ee9a1da8
[ 5.583520] [2: kworker/2:0: 19] 1da0: c0594944 c0592cd0 edb21808 00000001 edb21808 c13bc454 edb21808 edb21008
[ 5.583537] [2: kworker/2:0: 19] 1dc0: ee9a1ddc ee9a1dd0 c0595164 c05948a0 ee9a1dfc ee9a1de0 c0593de8 c0595154
[ 5.583553] [2: kworker/2:0: 19] 1de0: edb21808 00000000 edb21810 edb21008 ee9a1e3c ee9a1e00 c0591e00 c0593dbc
[ 5.583570] [2: kworker/2:0: 19] 1e00: ee9a1e3c ee9a1e10 c097a600 c09c41b4 edb21000 edb21800 edb21808 c0fb932b
[ 5.583587] [2: kworker/2:0: 19] 1e20: 00000001 c0fb932b c0de4ca4 c13f65b8 ee9a1e7c ee9a1e40 c097c248 c05919b0
[ 5.583603] [2: kworker/2:0: 19] 1e40: c0fb932b c0fb932b c0fb932b c0fde98d 00000001 ee9a1e60 c0978658 edb21000
[ 5.583620] [2: kworker/2:0: 19] 1e60: 00000000 00061a80 00000000 c0de4c94 ee9a1e9c ee9a1e80 c097fab8 c097c0e8
[ 5.583636] [2: kworker/2:0: 19] 1e80: 00000000 c0ff8080 edb212d8 edb21000 ee9a1ec4 ee9a1ea0 c097b888 c097f9b8
[ 5.583653] [2: kworker/2:0: 19] 1ea0: ee88d680 edb212d8 eef97f40 00000000 eef9bb00 edb212dc ee9a1f04 ee9a1ec8
[ 5.583670] [2: kworker/2:0: 19] 1ec0: c0135570 c097b554 ee9a1f04 ee9a1ed8 c0168c24 00000000 00000000 ee88d680
[ 5.583686] [2: kworker/2:0: 19] 1ee0: eef97f40 eef97f40 c1302100 eef97f60 ee88d698 00000008 ee9a1f3c ee9a1f08
[ 5.583702] [2: kworker/2:0: 19] 1f00: c01365f8 c013535c ee88d680 c01362c0 00000000 ee9a0000 ee89bc80 00000000
[ 5.583719] [2: kworker/2:0: 19] 1f20: ee88d680 c01362c0 00000000 00000000 ee9a1fac ee9a1f40 c013b284 c01362cc
[ 5.583735] [2: kworker/2:0: 19] 1f40: ee9a1f8c 00000000 c0144e6c ee88d680 00000000 00000000 dead4ead ffffffff
[ 5.583751] [2: kworker/2:0: 19] 1f60: ffffffff ee9a1f64 ee9a1f64 00000001 00010001 dead4ead ffffffff ffffffff
[ 5.583767] [2: kworker/2:0: 19] 1f80: ee9a1f80 ee9a1f80 c01490b8 ee89bc80 c013b180 00000000 00000000 00000000
[ 5.583783] [2: kworker/2:0: 19] 1fa0: 00000000 ee9a1fb0 c0107e68 c013b18c 00000000 00000000 00000000 00000000
[ 5.583797] [2: kworker/2:0: 19] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.583812] [2: kworker/2:0: 19] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 5.583838] [2: kworker/2:0: 19] [<c013ba24>] (kthread_data) from [<c0136978>] (wq_worker_sleeping+0x1c/0xdc)
[ 5.583864] [2: kworker/2:0: 19] [<c0136978>] (wq_worker_sleeping) from [<c0cf0ad8>] (__schedule+0x408/0x710)
[ 5.583888] [2: kworker/2:0: 19] [<c0cf0ad8>] (__schedule) from [<c0cf0e88>] (schedule+0xa8/0xc0)
[ 5.583908] [2: kworker/2:0: 19] [<c0cf0e88>] (schedule) from [<c01208d8>] (do_exit+0x958/0xa00)
[ 5.583926] [2: kworker/2:0: 19] [<c01208d8>] (do_exit) from [<c010c338>] (die+0x294/0x318)
[ 5.583949] [2: kworker/2:0: 19] [<c010c338>] (die) from [<c011aac0>] (__do_kernel_fault.part.0+0x64/0x1f4)
[ 5.583970] [2: kworker/2:0: 19] [<c011aac0>] (__do_kernel_fault.part.0) from [<c01161bc>] (do_page_fault+0x2fc/0x354)
[ 5.583989] [2: kworker/2:0: 19] [<c01161bc>] (do_page_fault) from [<c0116358>] (do_translation_fault+0x2c/0xbc)
[ 5.584005] [2: kworker/2:0: 19] [<c0116358>] (do_translation_fault) from [<c0101224>] (do_DataAbort+0x48/0xc8)
[ 5.584021] [2: kworker/2:0: 19] [<c0101224>] (do_DataAbort) from [<c010ca60>] (__dabt_svc+0x40/0x60)
[ 5.584028] [2: kworker/2:0: 19] Exception stack(0xee9a1c20 to 0xee9a1c68)
[ 5.584044] [2: kworker/2:0: 19] 1c20: fffffd18 00000348 00000001 edb92c00 edb21800 00000348 edb92c00 00000000
[ 5.584061] [2: kworker/2:0: 19] 1c40: edb21808 ee9a1cd6 edb93f00 ee9a1c7c ee9a1c80 ee9a1c70 c04ccf04 c04ccc50
[ 5.584069] [2: kworker/2:0: 19] 1c60: 20000013 ffffffff
[ 5.584088] [2: kworker/2:0: 19] [<c010ca60>] (__dabt_svc) from [<c04ccc50>] (mmc_blk_drm_part_get+0x28/0x48)
[ 5.584106] [2: kworker/2:0: 19] [<c04ccc50>] (mmc_blk_drm_part_get) from [<c04ccf04>] (mmc_blk_emmc_add+0x24/0x13c)
[ 5.584126] [2: kworker/2:0: 19] [<c04ccf04>] (mmc_blk_emmc_add) from [<c0989f80>] (mmc_blk_probe+0x184/0x314)
[ 5.584150] [2: kworker/2:0: 19] [<c0989f80>] (mmc_blk_probe) from [<c097bccc>] (mmc_bus_probe+0x24/0x28)
[ 5.584175] [2: kworker/2:0: 19] [<c097bccc>] (mmc_bus_probe) from [<c0594d28>] (driver_probe_device+0x2d4/0x424)
[ 5.584198] [2: kworker/2:0: 19] [<c0594d28>] (driver_probe_device) from [<c0594fd4>] (__device_attach_driver+0x74/0x9c)
[ 5.584219] [2: kworker/2:0: 19] [<c0594fd4>] (__device_attach_driver) from [<c0592d5c>] (bus_for_each_drv+0x98/0xa0)
[ 5.584240] [2: kworker/2:0: 19] [<c0592d5c>] (bus_for_each_drv) from [<c0594944>] (__device_attach+0xb0/0x140)
[ 5.584261] [2: kworker/2:0: 19] [<c0594944>] (__device_attach) from [<c0595164>] (device_initial_probe+0x1c/0x20)
[ 5.584281] [2: kworker/2:0: 19] [<c0595164>] (device_initial_probe) from [<c0593de8>] (bus_probe_device+0x38/0x90)
[ 5.584301] [2: kworker/2:0: 19] [<c0593de8>] (bus_probe_device) from [<c0591e00>] (device_add+0x45c/0x54c)
[ 5.584321] [2: kworker/2:0: 19] [<c0591e00>] (device_add) from [<c097c248>] (mmc_add_card+0x16c/0x268)
[ 5.584342] [2: kworker/2:0: 19] [<c097c248>] (mmc_add_card) from [<c097fab8>] (mmc_attach_mmc+0x10c/0x158)
[ 5.584362] [2: kworker/2:0: 19] [<c097fab8>] (mmc_attach_mmc) from [<c097b888>] (mmc_rescan+0x340/0x358)
[ 5.584380] [2: kworker/2:0: 19] [<c097b888>] (mmc_rescan) from [<c0135570>] (process_one_work+0x220/0x424)
[ 5.584396] [2: kworker/2:0: 19] [<c0135570>] (process_one_work) from [<c01365f8>] (worker_thread+0x338/0x430)
[ 5.584413] [2: kworker/2:0: 19] [<c01365f8>] (worker_thread) from [<c013b284>] (kthread+0x104/0x114)
[ 5.584434] [2: kworker/2:0: 19] [<c013b284>] (kthread) from [<c0107e68>] (ret_from_fork+0x14/0x2c)
[ 5.584450] [2: kworker/2:0: 19] Code: e24cb004 e52de004 e8bd4000 e5903490 (e5130020)
[ 5.584459] [2: kworker/2:0: 19] ---[ end trace 7d359c806f6b5bde ]---
[ 5.618705] [2: kworker/2:0: 19] Fixing recursive fault but reboot is needed!
[ 5.958104] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c00 flags 00000035
[ 5.958117] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.958134] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.958344] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.958353] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.958395] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.958409] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.958437] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.958483] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7f flags 00000035
[ 5.958494] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.958507] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.958619] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.958627] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.958662] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.958675] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.958700] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.958742] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c80 flags 00000035
[ 5.958754] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.958766] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.958820] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.958827] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.958861] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.958874] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.958899] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.958942] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001cff flags 00000035
[ 5.958953] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.958965] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959018] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.959025] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.959060] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.959073] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959099] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.959141] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001d00 flags 00000035
[ 5.959152] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.959165] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959217] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.959225] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.959259] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.959271] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959296] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.959337] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001d7f flags 00000035
[ 5.959348] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.959360] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959413] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.959420] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.959454] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.959468] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959493] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.959535] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001d80 flags 00000035
[ 5.959546] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.959559] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959611] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.959619] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.959652] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.959665] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959690] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.959732] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001dff flags 00000035
[ 5.959743] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.959755] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959807] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.959815] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.959850] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.959863] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.959888] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.959930] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c00 flags 00000035
[ 5.959942] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.959954] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960053] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.960060] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.960095] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.960108] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960133] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.960176] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c01 flags 00000035
[ 5.960187] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.960199] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960298] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.960306] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.960341] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.960354] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960380] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.960422] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c02 flags 00000035
[ 5.960433] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.960446] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960555] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.960563] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.960598] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.960611] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960636] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.960678] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c03 flags 00000035
[ 5.960689] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.960702] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960812] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.960820] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.960854] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.960868] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.960893] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.960934] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c04 flags 00000035
[ 5.960945] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.960958] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961068] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.961076] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.961111] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.961125] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961150] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.961191] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c05 flags 00000035
[ 5.961202] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.961215] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961325] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.961333] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.961367] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.961381] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961406] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.961447] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c06 flags 00000035
[ 5.961458] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.961471] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961580] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.961588] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.961623] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.961636] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961661] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.961702] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c07 flags 00000035
[ 5.961714] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.961726] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961836] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.961843] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.961878] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.961891] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.961916] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.961958] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c08 flags 00000035
[ 5.961969] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.961981] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962091] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.962098] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.962133] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.962146] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962171] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.962213] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c09 flags 00000035
[ 5.962224] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.962237] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962347] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.962354] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.962388] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.962401] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962427] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.962468] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c0a flags 00000035
[ 5.962478] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.962491] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962600] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.962607] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.962643] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.962655] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962684] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.962725] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c0b flags 00000035
[ 5.962737] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.962750] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962860] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.962867] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.962901] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.962914] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.962940] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.962981] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c0c flags 00000035
[ 5.962992] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.963004] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963114] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.963121] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.963155] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.963168] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963193] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.963234] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c0d flags 00000035
[ 5.963246] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.963257] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963367] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.963375] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.963409] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.963422] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963447] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.963489] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c0e flags 00000035
[ 5.963500] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.963512] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963622] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.963629] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.963663] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.963676] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963701] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.963743] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c0f flags 00000035
[ 5.963754] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.963768] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963877] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.963884] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.963919] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.963932] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.963957] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.963999] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c10 flags 00000035
[ 5.964010] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.964023] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964121] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.964129] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.964163] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.964177] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964202] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.964245] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c11 flags 00000035
[ 5.964256] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.964269] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964368] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.964376] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.964410] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.964423] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964449] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.964491] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c12 flags 00000035
[ 5.964502] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.964515] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964625] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.964632] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.964667] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.964680] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964705] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.964747] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c13 flags 00000035
[ 5.964758] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.964771] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964883] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.964891] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.964942] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.964955] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.964981] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.965024] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c14 flags 00000035
[ 5.965035] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.965046] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965156] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.965163] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.965197] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.965210] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965235] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.965276] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c15 flags 00000035
[ 5.965286] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.965299] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965409] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.965417] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.965451] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.965463] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965489] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.965531] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c16 flags 00000035
[ 5.965542] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.965554] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965663] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.965670] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.965704] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.965718] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965743] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.965784] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c17 flags 00000035
[ 5.965796] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.965808] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965918] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.965925] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.965960] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.965973] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.965998] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.966040] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c18 flags 00000035
[ 5.966051] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.966063] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966172] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.966180] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.966214] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.966226] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966253] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.966294] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c19 flags 00000035
[ 5.966306] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.966318] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966429] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.966436] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.966471] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.966484] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966509] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.966551] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c1a flags 00000035
[ 5.966562] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.966574] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966683] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.966691] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.966725] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.966739] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966764] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.966806] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c1b flags 00000035
[ 5.966817] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.966829] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.966939] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.966946] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.966981] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.966994] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967019] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.967060] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c1c flags 00000035
[ 5.967071] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.967084] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967193] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.967201] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.967234] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.967247] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967272] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.967313] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c1d flags 00000035
[ 5.967324] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.967336] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967446] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.967453] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.967488] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.967500] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967526] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.967567] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c1e flags 00000035
[ 5.967577] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.967589] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967699] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.967707] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.967741] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.967753] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967779] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.967820] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c1f flags 00000035
[ 5.967831] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.967843] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.967953] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.967961] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.967995] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.968008] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968032] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.968108] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c20 flags 00000035
[ 5.968120] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.968134] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968240] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.968248] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.968286] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.968299] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968326] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.968368] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c21 flags 00000035
[ 5.968379] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.968391] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968492] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.968500] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.968535] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.968548] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968574] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.968615] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c22 flags 00000035
[ 5.968626] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.968639] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968749] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.968756] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.968790] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.968803] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.968828] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.968870] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c23 flags 00000035
[ 5.968882] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.968893] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969005] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.969013] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.969048] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.969060] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969085] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.969127] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c24 flags 00000035
[ 5.969137] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.969150] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969259] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.969267] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.969301] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.969314] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969340] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.969381] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c25 flags 00000035
[ 5.969392] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.969404] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969515] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.969522] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.969558] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.969571] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969597] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.969639] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c26 flags 00000035
[ 5.969650] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.969662] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969772] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.969779] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.969814] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.969827] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.969852] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.969895] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c27 flags 00000035
[ 5.969905] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.969918] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970028] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.970036] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.970071] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.970083] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970109] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.970151] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c28 flags 00000035
[ 5.970162] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.970174] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970283] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.970290] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.970325] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.970338] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970364] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.970405] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c29 flags 00000035
[ 5.970416] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.970428] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970639] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.970647] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.970683] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.970696] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970721] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.970763] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c2a flags 00000035
[ 5.970774] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.970787] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970895] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.970903] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.970937] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.970949] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.970975] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.971017] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c2b flags 00000035
[ 5.971027] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.971039] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971150] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.971157] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.971192] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.971205] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971230] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.971271] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c2c flags 00000035
[ 5.971282] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.971294] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971404] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.971411] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.971446] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.971459] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971484] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.971526] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c2d flags 00000035
[ 5.971536] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.971548] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971658] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.971665] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.971701] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.971714] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971739] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.971780] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c2e flags 00000035
[ 5.971791] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.971804] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971913] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.971920] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.971956] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.971968] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.971993] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.972035] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c2f flags 00000035
[ 5.972046] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.972059] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972169] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.972176] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.972211] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.972224] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972250] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.972291] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c30 flags 00000035
[ 5.972302] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.972314] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972412] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.972419] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.972454] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.972466] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972491] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.972533] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c31 flags 00000035
[ 5.972545] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.972557] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972656] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.972664] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.972699] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.972712] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972738] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.972780] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c32 flags 00000035
[ 5.972791] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.972803] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972913] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.972921] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.972955] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.972967] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.972992] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.973034] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c33 flags 00000035
[ 5.973045] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.973058] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973167] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.973175] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.973211] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.973224] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973250] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.973291] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c34 flags 00000035
[ 5.973303] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.973315] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973425] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.973432] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.973466] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.973479] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973505] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.973547] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c35 flags 00000035
[ 5.973558] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.973570] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973683] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.973691] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.973725] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.973737] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973762] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.973804] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c36 flags 00000035
[ 5.973815] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.973827] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.973936] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.973944] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.973978] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.973991] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974016] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.974058] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c37 flags 00000035
[ 5.974069] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.974081] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974192] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.974199] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.974233] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.974246] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974271] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.974313] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c38 flags 00000035
[ 5.974323] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.974336] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974445] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.974453] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.974487] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.974499] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974525] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.974566] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c39 flags 00000035
[ 5.974578] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.974590] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974700] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.974707] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.974742] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.974755] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974780] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.974822] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c3a flags 00000035
[ 5.974833] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.974846] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.974955] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.974962] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.974997] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.975010] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975035] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.975076] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c3b flags 00000035
[ 5.975088] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.975100] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975209] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.975217] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.975250] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.975263] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975288] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.975331] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c3c flags 00000035
[ 5.975342] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.975355] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975464] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.975471] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.975505] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.975517] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975542] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.975583] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c3d flags 00000035
[ 5.975594] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.975606] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975716] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.975724] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.975758] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.975771] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975796] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.975838] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c3e flags 00000035
[ 5.975850] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.975862] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.975971] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.975978] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.976013] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.976025] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976051] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.976092] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c3f flags 00000035
[ 5.976103] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.976116] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976226] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.976233] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.976267] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.976280] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976306] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.976347] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c40 flags 00000035
[ 5.976359] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.976371] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976473] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.976481] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.976515] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.976527] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976553] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.976595] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c41 flags 00000035
[ 5.976606] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.976618] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976722] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.976729] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.976763] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.976776] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976801] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.976842] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c42 flags 00000035
[ 5.976853] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.976866] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.976976] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.976983] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.977017] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.977030] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977055] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.977097] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c43 flags 00000035
[ 5.977108] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.977121] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977232] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.977239] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.977273] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.977286] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977311] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.977353] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c44 flags 00000035
[ 5.977364] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.977376] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977485] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.977493] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.977529] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.977541] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977567] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.977607] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c45 flags 00000035
[ 5.977619] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.977631] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977742] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.977749] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.977783] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.977796] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977822] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.977862] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c46 flags 00000035
[ 5.977874] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.977886] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.977996] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.978003] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.978073] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.978088] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978120] I[0: rcu_sched: 7] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.978169] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c47 flags 00000035
[ 5.978181] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.978194] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978309] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.978317] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.978354] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.978367] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978394] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.978436] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c48 flags 00000035
[ 5.978448] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.978460] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978569] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.978577] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.978611] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.978624] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978650] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.978690] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c49 flags 00000035
[ 5.978702] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.978714] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978825] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.978832] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.978866] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.978879] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.978905] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.978947] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c4a flags 00000035
[ 5.978958] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.978970] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979079] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.979087] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.979122] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.979135] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979164] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.979205] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c4b flags 00000035
[ 5.979216] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.979228] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979338] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.979346] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.979379] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.979392] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979418] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.979458] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c4c flags 00000035
[ 5.979469] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.979482] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979591] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.979598] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.979633] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.979645] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979670] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.979711] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c4d flags 00000035
[ 5.979722] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.979735] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979845] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.979853] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.979887] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.979900] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.979925] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.979966] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c4e flags 00000035
[ 5.979978] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.979990] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980099] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.980107] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.980142] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.980154] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980179] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.980221] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c4f flags 00000035
[ 5.980232] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.980244] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980354] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.980361] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.980396] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.980408] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980433] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.980475] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c50 flags 00000035
[ 5.980486] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.980498] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980599] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.980607] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.980642] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.980654] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980679] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.980720] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c51 flags 00000035
[ 5.980732] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.980744] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980847] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.980854] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.980888] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.980901] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.980926] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.980968] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c52 flags 00000035
[ 5.980979] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.980992] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981102] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.981109] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.981143] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.981156] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981181] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.981222] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c53 flags 00000035
[ 5.981233] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.981246] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981356] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.981363] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.981398] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.981411] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981436] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.981478] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c54 flags 00000035
[ 5.981489] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.981502] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981611] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.981618] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.981653] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.981666] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981692] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.981734] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c55 flags 00000035
[ 5.981746] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.981758] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981868] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.981876] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.981910] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.981923] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.981948] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.981989] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c56 flags 00000035
[ 5.982000] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.982013] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982124] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.982132] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.982185] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.982198] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982224] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.982267] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c57 flags 00000035
[ 5.982278] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.982290] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982401] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.982408] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.982443] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.982456] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982481] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.982522] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c58 flags 00000035
[ 5.982533] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.982545] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982654] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.982662] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.982696] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.982709] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982734] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.982776] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c59 flags 00000035
[ 5.982787] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.982800] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982910] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.982918] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.982951] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.982964] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.982989] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.983030] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c5a flags 00000035
[ 5.983041] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.983053] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983162] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.983170] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.983204] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.983217] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983242] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.983284] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c5b flags 00000035
[ 5.983296] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.983308] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983418] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.983425] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.983459] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.983472] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983497] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.983538] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c5c flags 00000035
[ 5.983549] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.983562] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983671] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.983679] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.983712] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.983725] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983750] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.983793] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c5d flags 00000035
[ 5.983803] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.983816] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.983926] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.983934] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.983968] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.983981] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984006] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.984048] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c5e flags 00000035
[ 5.984059] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.984071] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984180] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.984188] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.984222] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.984235] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984261] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.984302] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c5f flags 00000035
[ 5.984314] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.984326] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984436] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.984444] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.984478] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.984491] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984516] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.984557] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c60 flags 00000035
[ 5.984568] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.984581] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984683] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.984691] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.984725] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.984738] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984763] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.984804] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c61 flags 00000035
[ 5.984815] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.984828] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.984931] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.984939] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.984973] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.984985] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985011] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.985053] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c62 flags 00000035
[ 5.985063] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.985075] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985184] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.985192] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.985226] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.985238] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985263] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.985304] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c63 flags 00000035
[ 5.985315] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.985327] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985438] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.985446] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.985479] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.985492] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985517] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.985558] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c64 flags 00000035
[ 5.985569] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.985581] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985691] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.985699] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.985733] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.985746] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985772] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.985812] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c65 flags 00000035
[ 5.985823] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.985836] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.985947] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.985954] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.985989] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.986003] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986028] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.986069] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c66 flags 00000035
[ 5.986080] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.986092] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986203] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.986210] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.986244] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.986257] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986282] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.986324] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c67 flags 00000035
[ 5.986335] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.986347] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986457] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.986465] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.986499] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.986511] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986537] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.986578] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c68 flags 00000035
[ 5.986589] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.986602] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986710] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.986718] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.986752] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.986765] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986790] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.986831] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c69 flags 00000035
[ 5.986842] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.986854] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.986964] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.986971] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.987007] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.987020] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987044] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.987085] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c6a flags 00000035
[ 5.987096] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.987109] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987218] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.987226] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.987260] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.987273] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987298] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.987340] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c6b flags 00000035
[ 5.987350] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.987363] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987472] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.987479] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.987514] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.987527] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987552] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.987593] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c6c flags 00000035
[ 5.987604] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.987616] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987725] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.987732] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.987766] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.987778] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987804] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.987845] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c6d flags 00000035
[ 5.987856] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.987868] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.987978] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.987986] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.988021] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.988063] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988099] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.988148] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c6e flags 00000035
[ 5.988159] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.988173] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988286] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.988294] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.988331] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.988343] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988370] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.988412] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c6f flags 00000035
[ 5.988423] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.988436] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988547] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.988570] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.988607] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.988619] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988645] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.988686] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c70 flags 00000035
[ 5.988698] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.988710] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988812] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.988820] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.988854] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.988867] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.988893] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.988934] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c71 flags 00000035
[ 5.988944] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.988956] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989059] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.989067] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.989102] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.989115] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989140] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.989182] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c72 flags 00000035
[ 5.989193] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.989206] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989315] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.989323] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.989356] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.989369] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989394] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.989436] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c73 flags 00000035
[ 5.989447] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.989459] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989570] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.989578] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.989613] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.989626] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989652] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.989693] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c74 flags 00000035
[ 5.989703] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.989716] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989826] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.989834] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.989868] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.989880] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.989906] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.989946] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c75 flags 00000035
[ 5.989957] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.989970] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990084] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.990092] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.990127] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.990140] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990165] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.990207] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c76 flags 00000035
[ 5.990219] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.990231] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990340] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.990347] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.990382] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.990394] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990420] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.990460] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c77 flags 00000035
[ 5.990471] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.990484] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990594] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.990602] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.990635] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.990648] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990674] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.990716] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c78 flags 00000035
[ 5.990727] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.990739] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990847] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.990855] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.990890] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.990903] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.990929] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.990970] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c79 flags 00000035
[ 5.990981] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.990993] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991103] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.991110] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.991144] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.991156] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991182] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.991222] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7a flags 00000035
[ 5.991233] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.991246] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991356] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.991363] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.991397] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.991410] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991436] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.991478] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7b flags 00000035
[ 5.991488] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.991501] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991611] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.991619] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.991653] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.991666] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991691] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.991733] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7c flags 00000035
[ 5.991745] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.991757] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991866] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.991873] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.991908] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.991920] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.991946] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.991987] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7d flags 00000035
[ 5.991999] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.992011] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.992121] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.992128] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.992163] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.992175] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.992200] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.992240] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7e flags 00000035
[ 5.992251] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.992263] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.992373] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.992380] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.992414] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.992427] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.992453] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.992494] [3:vendor_storage_: 112] mmc2: starting CMD17 arg 00001c7f flags 00000035
[ 5.992506] [3:vendor_storage_: 112] mmc2: blksz 512 blocks 1 flags 00000200 tsac 150 ms nsac 1000
[ 5.992518] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.992628] I[0: swapper/0: 0] mmc2: req done (CMD17): 0: 00000900 00000000 00000000 00000000
[ 5.992636] I[0: swapper/0: 0] mmc2: 512 bytes transferred: 0
[ 5.992670] [3:vendor_storage_: 112] mmc2: starting CMD13 arg 00010000 flags 00000015
[ 5.992683] I[3:vendor_storage_: 112] mmc_host mmc2: card is present
[ 5.992709] I[0: swapper/0: 0] mmc2: req done (CMD13): 0: 00000900 00000000 00000000 00000000
[ 5.993056] [3:vendor_storage_: 112] vendor storage:20190527 ret = 0
[ 15.635389] [2: kworker/2:0: 19] BUG: spinlock lockup suspected on CPU#2, kworker/2:0/19
[ 15.635404] [2: kworker/2:0: 19] lock: 0xeef98440, .magic: dead4ead, .owner: kworker/2:0/19, .owner_cpu: 2
[ 15.635416] [2: kworker/2:0: 19] CPU: 2 PID: 19 Comm: kworker/2:0 Tainted: G D 4.4.194 #1
[ 15.635422] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 15.635466] [2: kworker/2:0: 19] [<c01106cc>] (unwind_backtrace) from [<c010c0a0>] (show_stack+0x20/0x24)
[ 15.635487] [2: kworker/2:0: 19] [<c010c0a0>] (show_stack) from [<c0422634>] (dump_stack+0x84/0xa0)
[ 15.635508] [2: kworker/2:0: 19] [<c0422634>] (dump_stack) from [<c0170530>] (spin_dump+0x8c/0xa0)
[ 15.635526] [2: kworker/2:0: 19] [<c0170530>] (spin_dump) from [<c017070c>] (do_raw_spin_lock+0x120/0x1a4)
[ 15.635544] [2: kworker/2:0: 19] [<c017070c>] (do_raw_spin_lock) from [<c0cf457c>] (_raw_spin_lock_irq+0x1c/0x20)
[ 15.635567] [2: kworker/2:0: 19] [<c0cf457c>] (_raw_spin_lock_irq) from [<c0cf07c0>] (__schedule+0xf0/0x710)
[ 15.635588] [2: kworker/2:0: 19] [<c0cf07c0>] (__schedule) from [<c0cf0e88>] (schedule+0xa8/0xc0)
[ 15.635609] [2: kworker/2:0: 19] [<c0cf0e88>] (schedule) from [<c012009c>] (do_exit+0x11c/0xa00)
[ 15.635626] [2: kworker/2:0: 19] [<c012009c>] (do_exit) from [<c010c338>] (die+0x294/0x318)
[ 15.635646] [2: kworker/2:0: 19] [<c010c338>] (die) from [<c011aac0>] (__do_kernel_fault.part.0+0x64/0x1f4)
[ 15.635667] [2: kworker/2:0: 19] [<c011aac0>] (__do_kernel_fault.part.0) from [<c01161bc>] (do_page_fault+0x2fc/0x354)
[ 15.635684] [2: kworker/2:0: 19] [<c01161bc>] (do_page_fault) from [<c0101224>] (do_DataAbort+0x48/0xc8)
[ 15.635700] [2: kworker/2:0: 19] [<c0101224>] (do_DataAbort) from [<c010ca60>] (__dabt_svc+0x40/0x60)
[ 15.635706] [2: kworker/2:0: 19] Exception stack(0xee9a19a8 to 0xee9a19f0)
[ 15.635722] [2: kworker/2:0: 19] 19a0: ee991d00 00000002 eef98440 00000000 00000002 ee991d00
[ 15.635738] [2: kworker/2:0: 19] 19c0: c12bc440 ee9921d4 c1307edc eef98440 00000002 ee9a1a04 ee9a1a08 ee9a19f8
[ 15.635749] [2: kworker/2:0: 19] 19e0: c0136978 c013ba24 20000193 ffffffff
[ 15.635769] [2: kworker/2:0: 19] [<c010ca60>] (__dabt_svc) from [<c013ba24>] (kthread_data+0x18/0x20)
[ 15.635789] [2: kworker/2:0: 19] [<c013ba24>] (kthread_data) from [<c0136978>] (wq_worker_sleeping+0x1c/0xdc)
[ 15.635810] [2: kworker/2:0: 19] [<c0136978>] (wq_worker_sleeping) from [<c0cf0ad8>] (__schedule+0x408/0x710)
[ 15.635832] [2: kworker/2:0: 19] [<c0cf0ad8>] (__schedule) from [<c0cf0e88>] (schedule+0xa8/0xc0)
[ 15.635850] [2: kworker/2:0: 19] [<c0cf0e88>] (schedule) from [<c01208d8>] (do_exit+0x958/0xa00)
[ 15.635866] [2: kworker/2:0: 19] [<c01208d8>] (do_exit) from [<c010c338>] (die+0x294/0x318)
[ 15.635885] [2: kworker/2:0: 19] [<c010c338>] (die) from [<c011aac0>] (__do_kernel_fault.part.0+0x64/0x1f4)
[ 15.635906] [2: kworker/2:0: 19] [<c011aac0>] (__do_kernel_fault.part.0) from [<c01161bc>] (do_page_fault+0x2fc/0x354)
[ 15.635923] [2: kworker/2:0: 19] [<c01161bc>] (do_page_fault) from [<c0116358>] (do_translation_fault+0x2c/0xbc)
[ 15.635939] [2: kworker/2:0: 19] [<c0116358>] (do_translation_fault) from [<c0101224>] (do_DataAbort+0x48/0xc8)
[ 15.635954] [2: kworker/2:0: 19] [<c0101224>] (do_DataAbort) from [<c010ca60>] (__dabt_svc+0x40/0x60)
[ 15.635961] [2: kworker/2:0: 19] Exception stack(0xee9a1c20 to 0xee9a1c68)
[ 15.635978] [2: kworker/2:0: 19] 1c20: fffffd18 00000348 00000001 edb92c00 edb21800 00000348 edb92c00 00000000
[ 15.635995] [2: kworker/2:0: 19] 1c40: edb21808 ee9a1cd6 edb93f00 ee9a1c7c ee9a1c80 ee9a1c70 c04ccf04 c04ccc50
[ 15.636002] [2: kworker/2:0: 19] 1c60: 20000013 ffffffff
[ 15.636021] [2: kworker/2:0: 19] [<c010ca60>] (__dabt_svc) from [<c04ccc50>] (mmc_blk_drm_part_get+0x28/0x48)
[ 15.636038] [2: kworker/2:0: 19] [<c04ccc50>] (mmc_blk_drm_part_get) from [<c04ccf04>] (mmc_blk_emmc_add+0x24/0x13c)
[ 15.636059] [2: kworker/2:0: 19] [<c04ccf04>] (mmc_blk_emmc_add) from [<c0989f80>] (mmc_blk_probe+0x184/0x314)
[ 15.636081] [2: kworker/2:0: 19] [<c0989f80>] (mmc_blk_probe) from [<c097bccc>] (mmc_bus_probe+0x24/0x28)
[ 15.636105] [2: kworker/2:0: 19] [<c097bccc>] (mmc_bus_probe) from [<c0594d28>] (driver_probe_device+0x2d4/0x424)
[ 15.636130] [2: kworker/2:0: 19] [<c0594d28>] (driver_probe_device) from [<c0594fd4>] (__device_attach_driver+0x74/0x9c)
[ 15.636151] [2: kworker/2:0: 19] [<c0594fd4>] (__device_attach_driver) from [<c0592d5c>] (bus_for_each_drv+0x98/0xa0)
[ 15.636171] [2: kworker/2:0: 19] [<c0592d5c>] (bus_for_each_drv) from [<c0594944>] (__device_attach+0xb0/0x140)
[ 15.636193] [2: kworker/2:0: 19] [<c0594944>] (__device_attach) from [<c0595164>] (device_initial_probe+0x1c/0x20)
[ 15.636213] [2: kworker/2:0: 19] [<c0595164>] (device_initial_probe) from [<c0593de8>] (bus_probe_device+0x38/0x90)
[ 15.636233] [2: kworker/2:0: 19] [<c0593de8>] (bus_probe_device) from [<c0591e00>] (device_add+0x45c/0x54c)
[ 15.636253] [2: kworker/2:0: 19] [<c0591e00>] (device_add) from [<c097c248>] (mmc_add_card+0x16c/0x268)
[ 15.636275] [2: kworker/2:0: 19] [<c097c248>] (mmc_add_card) from [<c097fab8>] (mmc_attach_mmc+0x10c/0x158)
[ 15.636294] [2: kworker/2:0: 19] [<c097fab8>] (mmc_attach_mmc) from [<c097b888>] (mmc_rescan+0x340/0x358)
[ 15.636312] [2: kworker/2:0: 19] [<c097b888>] (mmc_rescan) from [<c0135570>] (process_one_work+0x220/0x424)
[ 15.636329] [2: kworker/2:0: 19] [<c0135570>] (process_one_work) from [<c01365f8>] (worker_thread+0x338/0x430)
[ 15.636347] [2: kworker/2:0: 19] [<c01365f8>] (worker_thread) from [<c013b284>] (kthread+0x104/0x114)
[ 15.636367] [2: kworker/2:0: 19] [<c013b284>] (kthread) from [<c0107e68>] (ret_from_fork+0x14/0x2c)
[ 15.636376] [2: kworker/2:0: 19] Sending NMI to all CPUs:
[ 15.888081] [0: kworker/u8:0: 6] BUG: spinlock lockup suspected on CPU#0, kworker/u8:0/6
[ 15.888097] [0: kworker/u8:0: 6] lock: 0xeef98440, .magic: dead4ead, .owner: kworker/2:0/19, .owner_cpu: 2
[ 15.888110] [0: kworker/u8:0: 6] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: G D 4.4.194 #1
[ 15.888115] [0: kworker/u8:0: 6] Hardware name: Generic DT based system
[ 15.888137] [0: kworker/u8:0: 6] Workqueue: deferwq deferred_probe_work_func
[ 15.888163] [0: kworker/u8:0: 6] [<c01106cc>] (unwind_backtrace) from [<c010c0a0>] (show_stack+0x20/0x24)
[ 15.888181] [0: kworker/u8:0: 6] [<c010c0a0>] (show_stack) from [<c0422634>] (dump_stack+0x84/0xa0)
[ 15.888198] [0: kworker/u8:0: 6] [<c0422634>] (dump_stack) from [<c0170530>] (spin_dump+0x8c/0xa0)
[ 15.888214] [0: kworker/u8:0: 6] [<c0170530>] (spin_dump) from [<c017070c>] (do_raw_spin_lock+0x120/0x1a4)
[ 15.888232] [0: kworker/u8:0: 6] [<c017070c>] (do_raw_spin_lock) from [<c0cf4598>] (_raw_spin_lock+0x18/0x1c)
[ 15.888252] [0: kworker/u8:0: 6] [<c0cf4598>] (_raw_spin_lock) from [<c01486c8>] (try_to_wake_up+0x100/0x390)
[ 15.888269] [0: kworker/u8:0: 6] [<c01486c8>] (try_to_wake_up) from [<c0148a10>] (wake_up_process+0x24/0x28)
[ 15.888289] [0: kworker/u8:0: 6] [<c0148a10>] (wake_up_process) from [<c0133250>] (wake_up_worker+0x30/0x34)
[ 15.888311] [0: kworker/u8:0: 6] [<c0133250>] (wake_up_worker) from [<c01332fc>] (insert_work+0xa8/0xb4)
[ 15.888331] [0: kworker/u8:0: 6] [<c01332fc>] (insert_work) from [<c01335e8>] (__queue_work+0x2e0/0x354)
[ 15.888352] [0: kworker/u8:0: 6] [<c01335e8>] (__queue_work) from [<c01336ac>] (queue_work_on+0x50/0x5c)
[ 15.888374] [0: kworker/u8:0: 6] [<c01336ac>] (queue_work_on) from [<c01321ac>] (call_usermodehelper_exec+0xcc/0x184)
[ 15.888396] [0: kworker/u8:0: 6] [<c01321ac>] (call_usermodehelper_exec) from [<c0132478>] (__request_module+0x214/0x2a8)
[ 15.888418] [0: kworker/u8:0: 6] [<c0132478>] (__request_module) from [<c05ebff0>] (phy_device_create+0x268/0x2a8)
[ 15.888439] [0: kworker/u8:0: 6] [<c05ebff0>] (phy_device_create) from [<c05ed27c>] (get_phy_device+0x1a4/0x1b4)
[ 15.888458] [0: kworker/u8:0: 6] [<c05ed27c>] (get_phy_device) from [<c05ed56c>] (mdiobus_scan+0x24/0x118)
[ 15.888488] [0: kworker/u8:0: 6] [<c05ed56c>] (mdiobus_scan) from [<c05ed750>] (__mdiobus_register+0xf0/0x180)
[ 15.888508] [0: kworker/u8:0: 6] [<c05ed750>] (__mdiobus_register) from [<c05f9938>] (stmmac_mdio_register+0xe8/0x250)
[ 15.888526] [0: kworker/u8:0: 6] [<c05f9938>] (stmmac_mdio_register) from [<c05f59a0>] (stmmac_dvr_probe+0x6d4/0x954)
[ 15.888545] [0: kworker/u8:0: 6] [<c05f59a0>] (stmmac_dvr_probe) from [<c05ffc34>] (rk_gmac_probe+0x3b8/0x568)
[ 15.888566] [0: kworker/u8:0: 6] [<c05ffc34>] (rk_gmac_probe) from [<c0596c8c>] (platform_drv_probe+0x60/0xac)
[ 15.888587] [0: kworker/u8:0: 6] [<c0596c8c>] (platform_drv_probe) from [<c0594d28>] (driver_probe_device+0x2d4/0x424)
[ 15.888609] [0: kworker/u8:0: 6] [<c0594d28>] (driver_probe_device) from [<c0594fd4>] (__device_attach_driver+0x74/0x9c)
[ 15.888631] [0: kworker/u8:0: 6] [<c0594fd4>] (__device_attach_driver) from [<c0592d5c>] (bus_for_each_drv+0x98/0xa0)
[ 15.888651] [0: kworker/u8:0: 6] [<c0592d5c>] (bus_for_each_drv) from [<c0594944>] (__device_attach+0xb0/0x140)
[ 15.888673] [0: kworker/u8:0: 6] [<c0594944>] (__device_attach) from [<c0595164>] (device_initial_probe+0x1c/0x20)
[ 15.888694] [0: kworker/u8:0: 6] [<c0595164>] (device_initial_probe) from [<c0593de8>] (bus_probe_device+0x38/0x90)
[ 15.888716] [0: kworker/u8:0: 6] [<c0593de8>] (bus_probe_device) from [<c0594328>] (deferred_probe_work_func+0xa4/0xc4)
[ 15.888736] [0: kworker/u8:0: 6] [<c0594328>] (deferred_probe_work_func) from [<c0135570>] (process_one_work+0x220/0x424)
[ 15.888752] [0: kworker/u8:0: 6] [<c0135570>] (process_one_work) from [<c01365f8>] (worker_thread+0x338/0x430)
[ 15.888770] [0: kworker/u8:0: 6] [<c01365f8>] (worker_thread) from [<c013b284>] (kthread+0x104/0x114)
[ 15.888790] [0: kworker/u8:0: 6] [<c013b284>] (kthread) from [<c0107e68>] (ret_from_fork+0x14/0x2c)
[ 25.640972] [2: kworker/2:0: 19] NMI backtrace for cpu 1
[ 25.640978] [2: kworker/2:0: 19] CPU: 1 PID: 75 Comm: kworker/1:1 Tainted: G D 4.4.194 #1
[ 25.640983] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 25.640987] [2: kworker/2:0: 19] Workqueue: usb_hub_wq hub_event
[ 25.640991] [2: kworker/2:0: 19] task: ed8b4140 task.stack: ed90a000
[ 25.640995] [2: kworker/2:0: 19] PC is at console_unlock+0x368/0x418
[ 25.641000] [2: kworker/2:0: 19] LR is at _raw_spin_unlock_irqrestore+0x1c/0x24
[ 25.641005] [2: kworker/2:0: 19] pc : [<c0176d00>] lr : [<c0cf4634>] psr: 60000013
[ 25.641009] [2: kworker/2:0: 19] sp : ed90bbf8 ip : ed90bb70 fp : ed90bc4c
[ 25.641014] [2: kworker/2:0: 19] r10: c141c148 r9 : 00000069 r8 : c14540ac
[ 25.641019] [2: kworker/2:0: 19] r7 : 00000007 r6 : 00000000 r5 : c141b808 r4 : c141b808
[ 25.641024] [2: kworker/2:0: 19] r3 : 60000013 r2 : 00000000 r1 : ed8b4140 r0 : c135013c
[ 25.641029] [2: kworker/2:0: 19] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 25.641034] [2: kworker/2:0: 19] Control: 10c5387d Table: 0000406a DAC: 00000051
[ 25.641039] [2: kworker/2:0: 19] CPU: 1 PID: 75 Comm: kworker/1:1 Tainted: G D 4.4.194 #1
[ 25.641043] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 25.641048] [2: kworker/2:0: 19] Workqueue: usb_hub_wq hub_event
[ 25.641053] [2: kworker/2:0: 19] [<c01106cc>] (unwind_backtrace) from [<c010c0a0>] (show_stack+0x20/0x24)
[ 25.641058] [2: kworker/2:0: 19] [<c010c0a0>] (show_stack) from [<c0422634>] (dump_stack+0x84/0xa0)
[ 25.641063] [2: kworker/2:0: 19] [<c0422634>] (dump_stack) from [<c01089ec>] (show_regs+0x1c/0x20)
[ 25.641069] [2: kworker/2:0: 19] [<c01089ec>] (show_regs) from [<c0426c90>] (nmi_cpu_backtrace+0x8c/0xd0)
[ 25.641074] [2: kworker/2:0: 19] [<c0426c90>] (nmi_cpu_backtrace) from [<c010eac4>] (handle_IPI+0x220/0x29c)
[ 25.641079] [2: kworker/2:0: 19] [<c010eac4>] (handle_IPI) from [<c01014a0>] (gic_handle_irq+0x88/0xa4)
[ 25.641085] [2: kworker/2:0: 19] [<c01014a0>] (gic_handle_irq) from [<c010cad4>] (__irq_svc+0x54/0x70)
[ 25.641089] [2: kworker/2:0: 19] Exception stack(0xed90bba8 to 0xed90bbf0)
[ 25.641094] [2: kworker/2:0: 19] bba0: c135013c ed8b4140 00000000 60000013 c141b808 c141b808
[ 25.641100] [2: kworker/2:0: 19] bbc0: 00000000 00000007 c14540ac 00000069 c141c148 ed90bc4c ed90bb70 ed90bbf8
[ 25.641104] [2: kworker/2:0: 19] bbe0: c0cf4634 c0176d00 60000013 ffffffff
[ 25.641110] [2: kworker/2:0: 19] [<c010cad4>] (__irq_svc) from [<c0176d00>] (console_unlock+0x368/0x418)
[ 25.641115] [2: kworker/2:0: 19] [<c0176d00>] (console_unlock) from [<c0177194>] (vprintk_emit+0x3e4/0x534)
[ 25.641121] [2: kworker/2:0: 19] [<c0177194>] (vprintk_emit) from [<c0590ae0>] (dev_vprintk_emit+0x170/0x1a0)
[ 25.641126] [2: kworker/2:0: 19] [<c0590ae0>] (dev_vprintk_emit) from [<c0590b3c>] (dev_printk_emit+0x2c/0x34)
[ 25.641132] [2: kworker/2:0: 19] [<c0590b3c>] (dev_printk_emit) from [<c0590b9c>] (__dev_printk+0x58/0x78)
[ 25.641137] [2: kworker/2:0: 19] [<c0590b9c>] (__dev_printk) from [<c0590e88>] (_dev_info+0x44/0x50)
[ 25.641142] [2: kworker/2:0: 19] [<c0590e88>] (_dev_info) from [<c081eed0>] (usb_new_device+0x2f8/0x578)
[ 25.641148] [2: kworker/2:0: 19] [<c081eed0>] (usb_new_device) from [<c0820e00>] (hub_event+0x1060/0x1274)
[ 25.641153] [2: kworker/2:0: 19] [<c0820e00>] (hub_event) from [<c0135570>] (process_one_work+0x220/0x424)
[ 25.641159] [2: kworker/2:0: 19] [<c0135570>] (process_one_work) from [<c01365f8>] (worker_thread+0x338/0x430)
[ 25.641164] [2: kworker/2:0: 19] [<c01365f8>] (worker_thread) from [<c013b284>] (kthread+0x104/0x114)
[ 25.641169] [2: kworker/2:0: 19] [<c013b284>] (kthread) from [<c0107e68>] (ret_from_fork+0x14/0x2c)
[ 25.641174] [2: kworker/2:0: 19] NMI backtrace for cpu 2
[ 25.641179] [2: kworker/2:0: 19] CPU: 2 PID: 19 Comm: kworker/2:0 Tainted: G D 4.4.194 #1
[ 25.641183] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 25.641189] [2: kworker/2:0: 19] [<c01106cc>] (unwind_backtrace) from [<c010c0a0>] (show_stack+0x20/0x24)
[ 25.641194] [2: kworker/2:0: 19] [<c010c0a0>] (show_stack) from [<c0422634>] (dump_stack+0x84/0xa0)
[ 25.641199] [2: kworker/2:0: 19] [<c0422634>] (dump_stack) from [<c0426cc0>] (nmi_cpu_backtrace+0xbc/0xd0)
[ 25.641205] [2: kworker/2:0: 19] [<c0426cc0>] (nmi_cpu_backtrace) from [<c010e140>] (raise_nmi+0x60/0x70)
[ 25.641211] [2: kworker/2:0: 19] [<c010e140>] (raise_nmi) from [<c0426aa0>] (nmi_trigger_all_cpu_backtrace+0xc4/0x228)
[ 25.641217] [2: kworker/2:0: 19] [<c0426aa0>] (nmi_trigger_all_cpu_backtrace) from [<c010ece8>] (arch_trigger_all_cpu_backtrace+0x1c/0x24)
[ 25.641223] [2: kworker/2:0: 19] [<c010ece8>] (arch_trigger_all_cpu_backtrace) from [<c0170714>] (do_raw_spin_lock+0x128/0x1a4)
[ 25.641229] [2: kworker/2:0: 19] [<c0170714>] (do_raw_spin_lock) from [<c0cf457c>] (_raw_spin_lock_irq+0x1c/0x20)
[ 25.641235] [2: kworker/2:0: 19] [<c0cf457c>] (_raw_spin_lock_irq) from [<c0cf07c0>] (__schedule+0xf0/0x710)
[ 25.641240] [2: kworker/2:0: 19] [<c0cf07c0>] (__schedule) from [<c0cf0e88>] (schedule+0xa8/0xc0)
[ 25.641245] [2: kworker/2:0: 19] [<c0cf0e88>] (schedule) from [<c012009c>] (do_exit+0x11c/0xa00)
[ 25.641250] [2: kworker/2:0: 19] [<c012009c>] (do_exit) from [<c010c338>] (die+0x294/0x318)
[ 25.641255] [2: kworker/2:0: 19] [<c010c338>] (die) from [<c011aac0>] (__do_kernel_fault.part.0+0x64/0x1f4)
[ 25.641261] [2: kworker/2:0: 19] [<c011aac0>] (__do_kernel_fault.part.0) from [<c01161bc>] (do_page_fault+0x2fc/0x354)
[ 25.641267] [2: kworker/2:0: 19] [<c01161bc>] (do_page_fault) from [<c0101224>] (do_DataAbort+0x48/0xc8)
[ 25.641272] [2: kworker/2:0: 19] [<c0101224>] (do_DataAbort) from [<c010ca60>] (__dabt_svc+0x40/0x60)
[ 25.641276] [2: kworker/2:0: 19] Exception stack(0xee9a19a8 to 0xee9a19f0)
[ 25.641282] [2: kworker/2:0: 19] 19a0: ee991d00 00000002 eef98440 00000000 00000002 ee991d00
[ 25.641287] [2: kworker/2:0: 19] 19c0: c12bc440 ee9921d4 c1307edc eef98440 00000002 ee9a1a04 ee9a1a08 ee9a19f8
[ 25.641291] [2: kworker/2:0: 19] 19e0: c0136978 c013ba24 20000193 ffffffff
[ 25.641297] [2: kworker/2:0: 19] [<c010ca60>] (__dabt_svc) from [<c013ba24>] (kthread_data+0x18/0x20)
[ 25.641302] [2: kworker/2:0: 19] [<c013ba24>] (kthread_data) from [<c0136978>] (wq_worker_sleeping+0x1c/0xdc)
[ 25.641308] [2: kworker/2:0: 19] [<c0136978>] (wq_worker_sleeping) from [<c0cf0ad8>] (__schedule+0x408/0x710)
[ 25.641313] [2: kworker/2:0: 19] [<c0cf0ad8>] (__schedule) from [<c0cf0e88>] (schedule+0xa8/0xc0)
[ 25.641318] [2: kworker/2:0: 19] [<c0cf0e88>] (schedule) from [<c01208d8>] (do_exit+0x958/0xa00)
[ 25.641323] [2: kworker/2:0: 19] [<c01208d8>] (do_exit) from [<c010c338>] (die+0x294/0x318)
[ 25.641328] [2: kworker/2:0: 19] [<c010c338>] (die) from [<c011aac0>] (__do_kernel_fault.part.0+0x64/0x1f4)
[ 25.641334] [2: kworker/2:0: 19] [<c011aac0>] (__do_kernel_fault.part.0) from [<c01161bc>] (do_page_fault+0x2fc/0x354)
[ 25.641340] [2: kworker/2:0: 19] [<c01161bc>] (do_page_fault) from [<c0116358>] (do_translation_fault+0x2c/0xbc)
[ 25.641345] [2: kworker/2:0: 19] [<c0116358>] (do_translation_fault) from [<c0101224>] (do_DataAbort+0x48/0xc8)
[ 25.641351] [2: kworker/2:0: 19] [<c0101224>] (do_DataAbort) from [<c010ca60>] (__dabt_svc+0x40/0x60)
[ 25.641355] [2: kworker/2:0: 19] Exception stack(0xee9a1c20 to 0xee9a1c68)
[ 25.641361] [2: kworker/2:0: 19] 1c20: fffffd18 00000348 00000001 edb92c00 edb21800 00000348 edb92c00 00000000
[ 25.641366] [2: kworker/2:0: 19] 1c40: edb21808 ee9a1cd6 edb93f00 ee9a1c7c ee9a1c80 ee9a1c70 c04ccf04 c04ccc50
[ 25.641370] [2: kworker/2:0: 19] 1c60: 20000013 ffffffff
[ 25.641375] [2: kworker/2:0: 19] [<c010ca60>] (__dabt_svc) from [<c04ccc50>] (mmc_blk_drm_part_get+0x28/0x48)
[ 25.641381] [2: kworker/2:0: 19] [<c04ccc50>] (mmc_blk_drm_part_get) from [<c04ccf04>] (mmc_blk_emmc_add+0x24/0x13c)
[ 25.641387] [2: kworker/2:0: 19] [<c04ccf04>] (mmc_blk_emmc_add) from [<c0989f80>] (mmc_blk_probe+0x184/0x314)
[ 25.641392] [2: kworker/2:0: 19] [<c0989f80>] (mmc_blk_probe) from [<c097bccc>] (mmc_bus_probe+0x24/0x28)
[ 25.641398] [2: kworker/2:0: 19] [<c097bccc>] (mmc_bus_probe) from [<c0594d28>] (driver_probe_device+0x2d4/0x424)
[ 25.641403] [2: kworker/2:0: 19] [<c0594d28>] (driver_probe_device) from [<c0594fd4>] (__device_attach_driver+0x74/0x9c)
[ 25.641409] [2: kworker/2:0: 19] [<c0594fd4>] (__device_attach_driver) from [<c0592d5c>] (bus_for_each_drv+0x98/0xa0)
[ 25.641415] [2: kworker/2:0: 19] [<c0592d5c>] (bus_for_each_drv) from [<c0594944>] (__device_attach+0xb0/0x140)
[ 25.641420] [2: kworker/2:0: 19] [<c0594944>] (__device_attach) from [<c0595164>] (device_initial_probe+0x1c/0x20)
[ 25.641426] [2: kworker/2:0: 19] [<c0595164>] (device_initial_probe) from [<c0593de8>] (bus_probe_device+0x38/0x90)
[ 25.641431] [2: kworker/2:0: 19] [<c0593de8>] (bus_probe_device) from [<c0591e00>] (device_add+0x45c/0x54c)
[ 25.641437] [2: kworker/2:0: 19] [<c0591e00>] (device_add) from [<c097c248>] (mmc_add_card+0x16c/0x268)
[ 25.641442] [2: kworker/2:0: 19] [<c097c248>] (mmc_add_card) from [<c097fab8>] (mmc_attach_mmc+0x10c/0x158)
[ 25.641447] [2: kworker/2:0: 19] [<c097fab8>] (mmc_attach_mmc) from [<c097b888>] (mmc_rescan+0x340/0x358)
[ 25.641452] [2: kworker/2:0: 19] [<c097b888>] (mmc_rescan) from [<c0135570>] (process_one_work+0x220/0x424)
[ 25.641458] [2: kworker/2:0: 19] [<c0135570>] (process_one_work) from [<c01365f8>] (worker_thread+0x338/0x430)
[ 25.641463] [2: kworker/2:0: 19] [<c01365f8>] (worker_thread) from [<c013b284>] (kthread+0x104/0x114)
[ 25.641468] [2: kworker/2:0: 19] [<c013b284>] (kthread) from [<c0107e68>] (ret_from_fork+0x14/0x2c)
[ 25.641472] [2: kworker/2:0: 19] NMI backtrace for cpu 3
[ 25.641478] [2: kworker/2:0: 19] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.194 #1
[ 25.641482] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 25.641486] [2: kworker/2:0: 19] task: ee8cd700 task.stack: ee8fe000
[ 25.641491] [2: kworker/2:0: 19] PC is at arch_cpu_idle+0x2c/0x48
[ 25.641495] [2: kworker/2:0: 19] LR is at arch_cpu_idle+0x3c/0x48
[ 25.641500] [2: kworker/2:0: 19] pc : [<c010874c>] lr : [<c010875c>] psr: 60000013
[ 25.641504] [2: kworker/2:0: 19] sp : ee8fffa8 ip : ee8fffb8 fp : ee8fffb4
[ 25.641508] [2: kworker/2:0: 19] r10: 00000000 r9 : c1306d74 r8 : 0000406a
[ 25.641513] [2: kworker/2:0: 19] r7 : c1419300 r6 : c12b73e8 r5 : 00000000 r4 : 00000000
[ 25.641518] [2: kworker/2:0: 19] r3 : c01199c0 r2 : 00000000 r1 : 00000000 r0 : 00000001
[ 25.641523] [2: kworker/2:0: 19] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 25.641528] [2: kworker/2:0: 19] Control: 10c5387d Table: 0000406a DAC: 00000051
[ 25.641533] [2: kworker/2:0: 19] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.194 #1
[ 25.641538] [2: kworker/2:0: 19] Hardware name: Generic DT based system
[ 25.641543] [2: kworker/2:0: 19] [<c01106cc>] (unwind_backtrace) from [<c010c0a0>] (show_stack+0x20/0x24)
[ 25.641548] [2: kworker/2:0: 19] [<c010c0a0>] (show_stack) from [<c0422634>] (dump_stack+0x84/0xa0)
[ 25.641553] [2: kworker/2:0: 19] [<c0422634>] (dump_stack) from [<c01089ec>] (show_regs+0x1c/0x20)
[ 25.641559] [2: kworker/2:0: 19] [<c01089ec>] (show_regs) from [<c0426c90>] (nmi_cpu_backtrace+0x8c/0xd0)
[ 25.641564] [2: kworker/2:0: 19] [<c0426c90>] (nmi_cpu_backtrace) from [<c010eac4>] (handle_IPI+0x220/0x29c)
[ 25.641570] [2: kworker/2:0: 19] [<c010eac4>] (handle_IPI) from [<c01014a0>] (gic_handle_irq+0x88/0xa4)
[ 25.641575] [2: kworker/2:0: 19] [<c01014a0>] (gic_handle_irq) from [<c010cad4>] (__irq_svc+0x54/0x70)
[ 25.641579] [2: kworker/2:0: 19] Exception stack(0xee8fff58 to 0xee8fffa0)
[ 25.641585] [2: kworker/2:0: 19] ff40: 00000001 00000000
[ 25.641590] [2: kworker/2:0: 19] ff60: 00000000 c01199c0 00000000 00000000 c12b73e8 c1419300 0000406a c1306d74
[ 25.641596] [2: kworker/2:0: 19] ff80: 00000000 ee8fffb4 ee8fffb8 ee8fffa8 c010875c c010874c 60000013 ffffffff
[ 25.641601] [2: kworker/2:0: 19] [<c010cad4>] (__irq_svc) from [<c010874c>] (arch_cpu_idle+0x2c/0x48)
[ 25.641606] [2: kworker/2:0: 19] [<c010874c>] (arch_cpu_idle) from [<c01697e4>] (default_idle_call+0x38/0x3c)
[ 25.641612] [2: kworker/2:0: 19] [<c01697e4>] (default_idle_call) from [<c0169ac0>] (cpu_startup_entry+0x278/0x344)
[ 25.641618] [2: kworker/2:0: 19] [<c0169ac0>] (cpu_startup_entry) from [<c010e620>] (secondary_start_kernel+0x130/0x154)
[ 25.641623] [2: kworker/2:0: 19] [<c010e620>] (secondary_start_kernel) from [<0010186c>] (0x10186c)
[ 29.551345] [1: kworker/1:1: 75] usb 3-1.1: Product: USB2.0 Hub
[ 29.579468] [1: kworker/1:1: 75] hub 3-1.1:1.0: USB hub found
[ 29.680107] [1: kworker/1:1: 75] hub 3-1.1:1.0: 4 ports detected
[ 36.558037] I[3: swapper/3: 0] ------------[ cut here ]------------
[ 36.565037] I[3: swapper/3: 0] WARNING: CPU: 3 PID: 0 at kernel/watchdog.c:352 watchdog_timer_fn+0x164/0x340()
[ 36.575735] [3: swapper/3: 0] Watchdog detected hard LOCKUP on cpu 0
[ 36.582697] I[3: swapper/3: 0] Modules linked in:
[ 36.588343] I[3: swapper/3: 0] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.194 #1
[ 36.597914] I[3: swapper/3: 0] Hardware name: Generic DT based system
[ 36.605080] I[3: swapper/3: 0] [<c01106cc>] (unwind_backtrace) from [<c010c0a0>] (show_stack+0x20/0x24)
[ 36.615192] I[3: swapper/3: 0] [<c010c0a0>] (show_stack) from [<c0422634>] (dump_stack+0x84/0xa0)
[ 36.624781] I[3: swapper/3: 0] [<c0422634>] (dump_stack) from [<c011e298>] (warn_slowpath_common+0x98/0xc4)
[ 36.635227] I[3: swapper/3: 0] [<c011e298>] (warn_slowpath_common) from [<c011e304>] (warn_slowpath_fmt+0x40/0x48)
[ 36.646286] I[3: swapper/3: 0] [<c011e304>] (warn_slowpath_fmt) from [<c01b5500>] (watchdog_timer_fn+0x164/0x340)
[ 36.657263] I[3: swapper/3: 0] [<c01b5500>] (watchdog_timer_fn) from [<c018be9c>] (__hrtimer_run_queues+0x1bc/0x31c)
[ 36.668498] I[3: swapper/3: 0] [<c018be9c>] (__hrtimer_run_queues) from [<c018c670>] (hrtimer_interrupt+0xac/0x1f8)
[ 36.679645] I[3: swapper/3: 0] [<c018c670>] (hrtimer_interrupt) from [<c09a23a8>] (arch_timer_handler_phys+0x38/0x48)
[ 36.690966] I[3: swapper/3: 0] [<c09a23a8>] (arch_timer_handler_phys) from [<c017c6c8>] (handle_percpu_devid_irq+0xd4/0x1a8)
[ 36.702897] I[3: swapper/3: 0] [<c017c6c8>] (handle_percpu_devid_irq) from [<c0177f2c>] (generic_handle_irq+0x28/0x38)
[ 36.714308] I[3: swapper/3: 0] [<c0177f2c>] (generic_handle_irq) from [<c0178288>] (__handle_domain_irq+0xb0/0xc4)
[ 36.725368] I[3: swapper/3: 0] [<c0178288>] (__handle_domain_irq) from [<c0101478>] (gic_handle_irq+0x60/0xa4)
[ 36.736074] I[3: swapper/3: 0] [<c0101478>] (gic_handle_irq) from [<c010cad4>] (__irq_svc+0x54/0x70)
[ 36.745909] I[3: swapper/3: 0] Exception stack(0xee8fff58 to 0xee8fffa0)
[ 36.753319] I[3: swapper/3: 0] ff40: 00000001 00000000
[ 36.763856] I[3: swapper/3: 0] ff60: 00000000 c01199c0 00000000 00000000 c12b73e8 c1419300 0000406a c1306d74
[ 36.774389] I[3: swapper/3: 0] ff80: 00000000 ee8fffb4 ee8fffb8 ee8fffa8 c010875c c010874c 60000013 ffffffff
[ 36.784933] I[3: swapper/3: 0] [<c010cad4>] (__irq_svc) from [<c010874c>] (arch_cpu_idle+0x2c/0x48)
[ 36.794691] I[3: swapper/3: 0] [<c010874c>] (arch_cpu_idle) from [<c01697e4>] (default_idle_call+0x38/0x3c)
[ 36.805140] I[3: swapper/3: 0] [<c01697e4>] (default_idle_call) from [<c0169ac0>] (cpu_startup_entry+0x278/0x344)
[ 36.816111] I[3: swapper/3: 0] [<c0169ac0>] (cpu_startup_entry) from [<c010e620>] (secondary_start_kernel+0x130/0x154)
[ 36.827519] I[3: swapper/3: 0] [<c010e620>] (secondary_start_kernel) from [<0010186c>] (0x10186c)
[ 36.837094] I[3: swapper/3: 0] ---[ end trace 7d359c806f6b5bdf ]---
qq2317783075 发表于 2023-12-29 16:58
为什么无法启动呢?看看log
怎么样?大佬。能给提供个解决方案不?
已自行解决
