固件文件名称:AIO-3588Q_Ubuntu20.04-Gnome-r30028_v1.1.1b_230914.
固件下载地址:百度网盘
Log日志:新建 文本文档.txt
使用的iCore-3588Q和AIO-3588Q的底板,没有wifi模块的时候系统无法启动,Debug接口停在了下面内容就不再输出(详细的打印见附件):
[ 6.594718] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 6.595000] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 28, base_baud = 1500000) is a 16550A
[ 6.595287] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 95, base_baud = 1500000) is a 16550A
[ 6.595476] feb80000.serial: ttyS5 at MMIO 0xfeb80000 (irq = 96, base_baud = 1500000) is a 16550A
[ 6.595713] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 97, base_baud = 1500000) is a 16550A
[ 6.596619] random: fast init done
[ 6.596672] random: crng init done
[ 6.597390] rockchip-vop2 fdd90000.vop: Adding to iommu group 15
[ 6.597404] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 6.604931] panel-simple-dsi fde20000.dsi.0: supply power not found, using dummy regulator
[ 6.783735] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.809282] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.835948] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.862616] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.889281] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.915948] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.942615] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.969281] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 6.995949] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 7.022615] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 9.449279] rk-pcie fe170000.pcie: PCIe Link Fail
[ 9.449300] rk-pcie fe170000.pcie: failed to initialize host
[ 66.589245] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 66.589256] rcu: 0-…0: (1 GPs behind) idle=dce/1/0x4000000000000000 softirq=36/42 fqs=6000
[ 66.589263] (detected by 7, t=18002 jiffies, g=-1095, q=39)
[ 66.589267] Task dump for CPU 0:
[ 66.589271] task:rk-pcie state:R running task stack: 0 pid: 156 ppid: 2 flags:0x0000000a
[ 66.589280] Call trace:
新建 文本文档.txt (58.8 KB)
