Core-3588J分区烧写异常
Core-3588J(V1.0)可以正常烧录统一固件
sudo pgrade_tool uf pack/update.img
Using  config.ini
Loading firmware...
Support Type:3588       FW Ver:1.0.00   FW Time:2024-01-15 17:32:57
Loader ver:1.0b Loader Time:2024-01-15 17:32:16
Start to upgrade firmware...
Download Boot Start
Download Boot Success
Wait For Maskrom Start
Wait For Maskrom Success
Test Device Start
Test Device Success
Check Chip Start
Check Chip Success
Get FlashInfo Start
Get FlashInfo Success
Prepare IDB Start
Prepare IDB Success
Download IDB Start
Download IDB Success
Download Firmware Start
Download Image... (100%)
Download Firmware Success
Upgrade firmware ok.
但是分区烧录失败(连parameter.txt都不能烧录)
sudo upgrade_tool di -p parameter.txt
Using config.ini
directlba=0,first4access=0,gpt=1
Write gpt...
Read flashinfo failed!
设备测试、读取chip id都不行
sudo upgrade_tool td
Using config.ini
Test Device Fail!
sudo upgrade_tool rci
Using  config.ini
Read Chip Info Fail!
附加信息:
底板为自制底板,只有电源、调试USB、UART口和数个GPIO引出。
Linux_Upgrade_Tool版本:
sudo upgrade_tool -V
Using config.ini
Upgrade Tool v2.17
统一固件烧写后系统能正常启动。
1 机器是进入了loader模式没?
2 每次准备分区烧写都进入loader模式
3 烧写分区位置对不对
4 用windows的烧写工具试下
zhangzhenzhao 发表于 2024-1-16 09:49
1 机器是进入了loader模式没?
3 烧写分区位置对不对
感谢回复。
每次进入的是MaskRom模式,进入Loder模式正常了。个人技术问题,打扰了。
